Wireless adapter is not detected
I have full upgraded my system pacman -Syu and unable to connect to wifi, iw dev, iw phy or rfkill doesn’t list wifi adapters.
$ inxi -NSazy
  Kernel: 6.13.0-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.13-x86_64
    root=UUID=44e25003-1f04-4d4c-ae58-396e08b83bc4 rw udev.log_priority=3
  Desktop: KDE Plasma v: 6.2.5 tk: Qt v: N/A info: frameworks v: 6.10.0
  Device-1: Intel Cannon Lake PCH CNVi WiFi driver: N/A modules: iwlwifi, wl
    bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
    vendor: ASUSTeK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
I have already installed network-broadcom-wl package.
# mhwd -li
> Installed PCI configs:
video-hybrid-intel-nvidia-prime            2023.03.23               false            PCI
   network-broadcom-wl            2018.10.07               false            PCI
In both cases above the cards are detected.
Probably should not be installed.
There is no reason for this intel device to use anything related to broadcom.
But as to why both have no driver (N/A) I could not say.
Removed, network-broadcom-wl still not working
Sure,
$ lspci
00:00.0 Host bridge: Intel Corporation 8th Gen Core Processor Host Bridge/DRAM Registers (rev 07)
00:01.0 PCI bridge: Intel Corporation 6th-10th Gen Core Processor PCIe Controller (x16) (rev 07)
00:02.0 VGA compatible controller: Intel Corporation CoffeeLake-H GT2 [UHD Graphics 630]
00:04.0 Signal processing controller: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Thermal Sub
system (rev 07)
00:08.0 System peripheral: Intel Corporation Xeon E3-1200 v5/v6 / E3-1500 v5 / 6th/7th/8th Gen Core Processor Gaussia
n Mixture Model
00:12.0 Signal processing controller: Intel Corporation Cannon Lake PCH Thermal Controller (rev 10)
00:14.0 USB controller: Intel Corporation Cannon Lake PCH USB 3.1 xHCI Host Controller (rev 10)
00:14.2 RAM memory: Intel Corporation Cannon Lake PCH Shared SRAM (rev 10)
00:14.3 Network controller: Intel Corporation Cannon Lake PCH CNVi WiFi (rev 10)
00:15.0 Serial bus controller: Intel Corporation Cannon Lake PCH Serial IO I2C Controller #0 (rev 10)
00:16.0 Communication controller: Intel Corporation Cannon Lake PCH HECI Controller (rev 10)
00:17.0 SATA controller: Intel Corporation Cannon Lake Mobile PCH SATA AHCI Controller (rev 10)
00:1d.0 PCI bridge: Intel Corporation Cannon Lake PCH PCI Express Root Port #9 (rev f0)
00:1d.4 PCI bridge: Intel Corporation Cannon Lake PCH PCI Express Root Port #13 (rev f0)
00:1e.0 Communication controller: Intel Corporation Cannon Lake PCH Serial IO UART Host Controller (rev 10)
00:1f.0 ISA bridge: Intel Corporation HM470 Chipset LPC/eSPI Controller (rev 10)
00:1f.3 Audio device: Intel Corporation Cannon Lake PCH cAVS (rev 10)
00:1f.4 SMBus: Intel Corporation Cannon Lake PCH SMBus Controller (rev 10)
00:1f.5 Serial bus controller: Intel Corporation Cannon Lake PCH SPI Controller (rev 10)
01:00.0 VGA compatible controller: NVIDIA Corporation TU117M [GeForce GTX 1650 Mobile / Max-Q] (rev a1)
01:00.1 Audio device: NVIDIA Corporation Device 10fa (rev a1)
02:00.0 Non-Volatile memory controller: Micron Technology Inc 2200S NVMe SSD [Cassandra] (rev 01)
03:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet Cont
roller (rev 15)
$ inxi --admin --verbosity=7 --filter --no-host --width
  Kernel: 6.12.11-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
  Type: Laptop System: ASUSTeK product: TUF Gaming FX505GT_FX505GT v: 1.0
    serial: <superuser required>
  Mobo: ASUSTeK model: FX505GT v: 1.0 serial: <superuser required>
    uuid: <superuser required> UEFI: American Megatrends v: FX505GT.311
    date: 02/08/2021
  ID-1: BAT0 charge: 37.8 Wh (100.0%) condition: 37.8/48.1 Wh (78.7%)
    volts: 12.5 min: 11.7 model: Simplo SDI ICR18650 type: Li-ion
    serial: <filter> status: full cycles: 41
  System RAM: total: 32 GiB available: 31.2 GiB used: 11.79 GiB (37.8%)
  Array-1: capacity: 64 GiB slots: 4 modules: 2 EC: None
  Device-1: ChannelA-DIMM0 type: DDR4 detail: synchronous size: 16 GiB speed:
    spec: 3200 MT/s actual: 2667 MT/s volts: note: check curr: 1 min: 1 max: 1
    width (bits): data: 64 total: 64 manufacturer: Crucial
    part-no: CT16G4SFRA32A.C8FF serial: <filter>
  Device-2: ChannelA-DIMM1 type: no module installed
  Device-3: ChannelB-DIMM0 type: DDR4 detail: synchronous size: 16 GiB
    speed: 2667 MT/s volts: note: check curr: 1 min: 1 max: 1 width (bits):
    data: 64 total: 64 manufacturer: Samsung part-no: M471A2K43DB1-CTD
    serial: <filter>
  Device-4: ChannelB-DIMM1 type: no module installed
  Info: model: Intel Core i7-9750H bits: 64 type: MT MCP arch: Coffee Lake
    gen: core 9 level: v3 note: check built: 2018 process: Intel 14nm family: 6
    model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF8
  Topology: cpus: 1x dies: 1 clusters: 6 cores: 6 threads: 12 tpc: 2
    smt: enabled cache: L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB
    desc: 6x256 KiB L3: 12 MiB desc: 1x12 MiB
  Speed (MHz): avg: 4300 min/max: 800/4500 scaling: driver: intel_pstate
    governor: powersave cores: 1: 4300 2: 4300 3: 4300 4: 4300 5: 4300 6: 4300
    7: 4300 8: 4300 9: 4300 10: 4300 11: 4300 12: 4300 bogomips: 62431
    smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
    vulnerable
  Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: ASUSTeK
    ports: active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:3e9b
    class-ID: 0300
  Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: ASUSTeK
    driver: nvidia v: 550.144.03 alternate: nouveau,nvidia_drm
    non-free: 550/565.xx+ status: current (as of 2025-01; EOL~2026-12-xx)
    arch: Turing code: TUxxx process: TSMC 12nm FF built: 2018-2022 pcie:
    gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s
    bus-ID: 01:00.0 chip-ID: 10de:1f91 class-ID: 0300
  Device-3: IMC Networks USB2.0 HD UVC WebCam driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-11:3 chip-ID: 13d3:56a2
  Display: x11 server: X.Org v: 21.1.15 with: Xwayland v: 24.1.4
    compositor: kwin_x11 driver: X: loaded: modesetting,nvidia
    alternate: fbdev,nouveau,nv,vesa dri: iris gpu: i915 display-ID: :0
    screens: 1
  Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1013x285mm (39.88x11.22")
    s-diag: 1052mm (41.43")
  Monitor-1: HDMI-1-0 pos: primary,right res: mode: 1920x1080 hz: 60
    scale: 100% (1) dpi: 82 size: 598x336mm (23.54x13.23") diag: 686mm (27.01")
    modes: N/A
  Monitor-2: eDP-1 pos: left res: mode: 1920x1080 hz: 144 scale: 100% (1)
    dpi: 142 size: 344x193mm (13.54x7.6") diag: 394mm (15.53") modes: N/A
    drv: nvidia gbm: drv: kms_swrast surfaceless: drv: nvidia x11: drv: iris
    inactive: wayland
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 24.3.4-arch1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics 630 (CFL GT2)
    device-ID: 8086:3e9b memory: 15.23 GiB unified: yes
  API: Vulkan v: 1.4.303 layers: 5 device: 0 type: discrete-gpu
    name: NVIDIA GeForce GTX 1650 driver: N/A device-ID: 10de:1f91
    surfaces: xcb,xlib
  Device-1: Intel Cannon Lake PCH cAVS vendor: ASUSTeK
    driver: sof-audio-pci-intel-cnl alternate: snd_hda_intel, snd_soc_avs,
    snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
  Device-2: NVIDIA vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie:
    gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10fa
    class-ID: 0403
  API: ALSA v: k6.12.11-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.7 status: off with: wireplumber status: active
    tools: pw-cli,wpctl
  Server-3: PulseAudio v: 17.0-43-g3e2bb status: active with: pulseaudio-alsa
  IF-ID-1: vboxnet0 state: down mac: <filter>
  Info: services: NetworkManager, sshd, systemd-timesyncd
  Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) driver: btusb v: 0.8
    type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:4
  Local Storage: total: 1.4 TiB used: 513.74 GiB (35.7%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: 2200V MTFDHBA512TCK
    lanes: 4 tech: SSD serial: <filter> fw-rev: P1MA0V4 temp: 28.9 C
    scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 1TB
    tech: SSD serial: <filter> fw-rev: 3B6Q scheme: GPT
  ID-3: /dev/sdb maj-min: 8:16 vendor: HP model: x740w size: 28.88 GiB
    block-size: physical: 512 B logical: 512 B type: USB rev: 3.2 spd: 5 Gb/s
    lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter> fw-rev: PMAP
    scheme: MBR
  ID-1: / raw-size: 185.24 GiB size: 181.28 GiB (97.86%)
    used: 122.16 GiB (67.4%) fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3
    label: N/A uuid: 44e25003-1f04-4d4c-ae58-396e08b83bc4
    used: 288 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: 5EAB-DF4A
  ID-3: /home raw-size: 283.38 GiB size: 277.87 GiB (98.06%)
    used: 127.2 GiB (45.8%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:4
    label: Home FS uuid: bfedcb7c-0b0f-4b4b-a600-bccac5dfa4b6
  ID-4: /mnt/Dump raw-size: 781.51 GiB size: 768.17 GiB (98.29%)
    used: 218.99 GiB (28.5%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: Misc
    uuid: 1d4f105c-ff09-4ba4-960d-7e968d38304d
  ID-5: /mnt/Projects raw-size: 150 GiB size: 146.59 GiB (97.72%)
    used: 45.38 GiB (31.0%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: Projects
    uuid: d1447d2a-4f0a-479e-b882-298a77094592
  ID-1: swap-1 type: partition size: 7.81 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
    uuid: 0acb163f-1be1-4311-9a63-2a70453ecf15
  ID-1: /dev/sdb1 maj-min: 8:17 size: 3.87 GiB fs: iso9660
  ID-2: /dev/sdb2 maj-min: 8:18 size: 4 MiB fs: vfat label: MISO_EFI
    uuid: 8BF0-EDB3
  Device-1: 1-6:2 info: SHARKOON GmbH 2.4G Wireless type: keyboard,mouse
    driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 1ea7:0067 class-ID: 0301
  Device-2: 1-11:3 info: IMC Networks USB2.0 HD UVC WebCam type: video
    driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
    mode: 2.0 power: 500mA chip-ID: 13d3:56a2 class-ID: 0e02 serial: <filter>
  Device-3: 1-14:4 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
    type: bluetooth driver: btusb interfaces: 2 rev: 2.0
  Hub-2: 2-0:1 info: super-speed hub ports: 8 rev: 3.1
  Device-1: 2-1:2 info: HP x740w type: mass storage driver: usb-storage
    interfaces: 1 rev: 3.2 speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1
    power: 504mA chip-ID: 03f0:9140 class-ID: 0806 serial: <filter>
  System Temperatures: cpu: 51.0 C pch: 51.0 C mobo: N/A
  Fan Speeds (rpm): cpu: 3400
  Processes: 328 Power: uptime: 19h 59m states: freeze,mem,disk suspend: deep
    avail: s2idle wakeups: 1 hibernate: platform avail: shutdown, reboot,
    suspend, test_resume image: 12.43 GiB services: org_kde_powerdevil,
    tool: systemctl
  Packages: pm: pacman pkgs: 2076 libs: 442 tools: pamac,yay pm: rpm pkgs: 0
    Compilers: clang: 19.1.7 gcc: 14.2.1 alt: 13 Shell: Zsh v: 5.9
    running-in: konsole inxi: 3.3.37
Is this a dual-boot?
And if it is … has windoze been fully shutdown (fast start disabled)?
And have we tried other kernels? 6.6 maybe? Or even 6.1 or 5.15?
No, just manjaro
Ohk I have install linux66 kernel and it works for that. Not only that, now it works for 612 and 613.
One new thing, when I installed 6.6 using mhwd-kernel -i linux66 it didn’t install linux66-broadcom-wl, which I installed manually for other two kernels as well (in 6.13 it required downloading missing files ~1.3 mb).
On reboot tested all 3 versions, wifi is working now.
Now I am curious why?? Why I didnt check this before.
Well we covered this already and you said it was removed.
You do not have a broadcom card, and you should not have ‘broadcom’ drivers installed.
Never should have.
You mean linux*-broadcom-wl?
Yes, thats the package(s) mhwd profile network-broadcom-wl would provide.
