matv1
5 February 2025 20:14
1
I have the exact same issue, it looks like. Immediately after applying the latest Manjaro update, my Wifi adapter is no longer detected: iw dev and iw list show nothing. However, hwinfo does include:
29: PCI 700.0: 0280 Network controller
[Created at pci.386]
Unique ID: aK5u.o_xLA3Zg0GC
Parent ID: Muvi.HAl1_1tkVaC
SysFS ID: /devices/pci0000:00/0000:00:1d.5/0000:07:00.0
SysFS BusID: 0000:07:00.0
Hardware Class: network
Model: "Intel Wi-Fi 6 AX200NGW"
Vendor: pci 0x8086 "Intel Corporation"
Device: pci 0x2723 "Wi-Fi 6 AX200"
SubVendor: pci 0x8086 "Intel Corporation"
SubDevice: pci 0x0084 "Wi-Fi 6 AX200NGW"
Revision: 0x1a
Memory Range: 0xc2300000-0xc2303fff (rw,non-prefetchable)
IRQ: 17 (195 events)
Module Alias: "pci:v00008086d00002723sv00008086sd00000084bc02sc80i00"
Driver Info #0:
Driver Status: iwlwifi is active
Driver Activation Cmd: "modprobe iwlwifi"
Config Status: cfg=new, avail=yes, need=no, active=unknown
Attached to: #43 (PCI bridge)
So it looks like we lost the Wifi adapter over the same update. The only difference is that I didnt upgrade to Kernel 6.13 yet, being on the last 6.12 release for stable.
inxi -NSazy ✔
Kernel: 6.12.11-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=634dcde8-9db5-4dd9-8f54-ef1da89697e6 ro quiet apparmor=1
security=apparmor resume=UUID=7d14346f-3d32-439c-9f28-19c3a3d4aa08
udev.log_priority=3
Desktop: KDE Plasma v: 6.2.5 tk: Qt v: N/A info: frameworks v: 6.10.0
Device-1: Intel Wi-Fi 6 AX200 driver: N/A modules: iwlwifi pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 07:00.0 chip-ID: 8086:2723 class-ID: 0280
vendor: CLEVO/KAPOK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 3000 bus-ID: 08:00.1 chip-ID: 10ec:8168 class-ID: 0200
interesting is that we both are apparently running nvidia-prime
mhwd -li
Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-modesetting 2020.01.13 true PCI
video-hybrid-intel-nvidia-prime 2023.03.23 false PCI
I am on 6.12.11-1-MANJARO, still it is not working for me.
matv1
8 February 2025 12:13
3
So what info could we provide to further investigate the missing intel wireless driver?
matv1
8 February 2025 13:02
4
lspci:
00:00.0 Host bridge: Intel Corporation 10th Gen Core Processor Host Bridge/DRAM Registers (rev 02)
00:01.0 PCI bridge: Intel Corporation 6th-10th Gen Core Processor PCIe Controller (x16) (rev 02)
00:02.0 VGA compatible controller: Intel Corporation CometLake-H GT2 [UHD Graphics] (rev 05)
00:12.0 Signal processing controller: Intel Corporation Comet Lake PCH Thermal Controller
00:14.0 USB controller: Intel Corporation Comet Lake USB 3.1 xHCI Host Controller
00:14.2 RAM memory: Intel Corporation Comet Lake PCH Shared SRAM
00:15.0 Serial bus controller: Intel Corporation Comet Lake PCH Serial IO I2C Controller #0
00:15.1 Serial bus controller: Intel Corporation Comet Lake PCH Serial IO I2C Controller #1
00:16.0 Communication controller: Intel Corporation Comet Lake HECI Controller
00:17.0 SATA controller: Intel Corporation Device 06d3
00:1d.0 PCI bridge: Intel Corporation Comet Lake PCI Express Root Port #9 (rev f0)
00:1d.5 PCI bridge: Intel Corporation Device 06b5 (rev f0)
00:1d.6 PCI bridge: Intel Corporation Device 06b6 (rev f0)
00:1f.0 ISA bridge: Intel Corporation Comet Lake LPC Controller
00:1f.3 Audio device: Intel Corporation Comet Lake PCH cAVS
00:1f.4 SMBus: Intel Corporation Comet Lake PCH SMBus Controller
00:1f.5 Serial bus controller: Intel Corporation Comet Lake PCH SPI Controller
01:00.0 VGA compatible controller: NVIDIA Corporation TU116M [GeForce GTX 1660 Ti Mobile] (rev a1)
01:00.1 Audio device: NVIDIA Corporation TU116 High Definition Audio Controller (rev a1)
06:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd NVMe SSD Controller SM981/PM981/PM983
07:00.0 Network controller: Intel Corporation Wi-Fi 6 AX200 (rev 1a)
08:00.0 Unassigned class [ff00]: Realtek Semiconductor Co., Ltd. RTL8411B PCI Express Card Reader (rev 01)
08:00.1 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet Controller (rev 12)
and inxi --admin --verbosity=7 --filter --no-host --width :
udev.log_priority=3
Type: Laptop System: Notebook product: NH5x_7xDCx_DDx v: N/A
serial: <superuser required> Chassis: No Enclosure type: 10
Mobo: Notebook model: NH5x_7xDCx_DDx serial: <superuser required>
uuid: <superuser required> UEFI: INSYDE v: 1.07.06LWL date: 06/17/2020
ID-1: BAT0 charge: 42.5 Wh (99.8%) condition: 42.6/47.2 Wh (90.3%)
volts: 15.6 min: 14.4 model: Notebook BAT type: Li-ion serial: <filter>
status: discharging
System RAM: total: 16 GiB available: 15.32 GiB used: 2.13 GiB (13.9%)
Array-1: capacity: 32 GiB slots: 2 modules: 1 EC: None
Device-1: ChannelA-DIMM0 type: DDR4 detail: synchronous size: 16 GiB
speed: 2667 MT/s volts: curr: 1 min: 1.25 max: 2 width (bits): data: 64
total: 64 manufacturer: Kingston part-no: KHX2666C15S4/16G serial: <filter>
Device-2: ChannelB-DIMM0 type: no module installed
Info: model: Intel Core i7-10750H bits: 64 type: MT MCP arch: Comet Lake
gen: core 10 level: v3 note: check built: 2020 process: Intel 14nm family: 6
model-id: 0xA5 (165) stepping: 2 microcode: 0xFC
Topology: cpus: 1x dies: 1 clusters: 6 cores: 6 threads: 12 tpc: 2
smt: enabled cache: L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB
desc: 6x256 KiB L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 1121 min/max: 800/5000 scaling: driver: intel_pstate
governor: powersave cores: 1: 1121 2: 1121 3: 1121 4: 1121 5: 1121 6: 1121
7: 1121 8: 1121 9: 1121 10: 1121 11: 1121 12: 1121 bogomips: 62431
fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs
ibrs_enhanced ida intel_pt invpcid lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq
pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdrand rdseed
rdtscp rep_good sdbg sep sgx sgx_lc smap smep ss ssbd sse sse2 sse4_1
xsaves xtopology xtpr
Type: retbleed mitigation: Enhanced IBRS
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
RSB filling; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW loop
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: CLEVO/KAPOK
ports: active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2, HDMI-A-3
bus-ID: 00:02.0 chip-ID: 8086:9bc4 class-ID: 0300
Device-2: NVIDIA TU116M [GeForce GTX 1660 Ti Mobile] vendor: CLEVO/KAPOK
driver: nvidia v: 550.144.03 alternate: nouveau,nvidia_drm
non-free: 550/565.xx+ status: current (as of 2025-01; EOL~2026-12-xx)
arch: Turing code: TUxxx process: TSMC 12nm FF built: 2018-2022 pcie:
gen: 2 speed: 5 GT/s lanes: 8 link-max: gen: 3 speed: 8 GT/s lanes: 16
ports: active: none empty: DP-3,HDMI-A-4 bus-ID: 01:00.0 chip-ID: 10de:2191
class-ID: 0300
Device-3: Chicony USB2.0 Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-8:2 chip-ID: 04f2:b685
class-ID: 0e02
Display: x11 server: X.Org v: 21.1.15 with: Xwayland v: 24.1.4
compositor: kwin_x11 driver: X: loaded: modesetting,nvidia dri: iris
gpu: i915 display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: Najing CEC Panda 0x004d built: 2019 res:
mode: 1920x1080 hz: 144 scale: 100% (1) dpi: 142 gamma: 1.2
size: 344x194mm (13.54x7.64") diag: 395mm (15.5") ratio: 16:9
modes: 1920x1080
drv: nvidia device: 1 drv: iris gbm: drv: iris surfaceless: drv: nvidia x11:
drv: iris inactive: wayland
API: OpenGL v: 4.6.0 compat-v: 4.6 vendor: intel mesa v: 24.3.4-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics (CML GT2)
device-ID: 8086:9bc4 memory: 7.48 GiB unified: yes
API: Vulkan v: 1.4.303 layers: 8 device: 0 type: discrete-gpu name: NVIDIA
GeForce GTX 1660 Ti driver: N/A device-ID: 10de:2191 surfaces: xcb,xlib
de: kscreen-console,kscreen-doctor gpu: nvidia-smi wl: wayland-info
x11: xdpyinfo, xprop, xrandr
Device-1: Intel Comet Lake PCH cAVS vendor: CLEVO/KAPOK driver: snd_hda_intel
v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_cnl bus-ID: 00:1f.3
chip-ID: 8086:06c8 class-ID: 0403
Device-2: NVIDIA TU116 High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 8 link-max: gen: 3 speed: 8 GT/s
lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:1aeb class-ID: 0403
API: ALSA v: k6.12.11-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.2.7 status: off with: pipewire-media-session
status: active tools: pw-cli
Server-4: PulseAudio v: 17.0-43-g3e2bb status: active with:
tools: pacat,pactl
speed: Unknown lanes: 63 link-max: gen: 6 speed: 64 GT/s bus-ID: 07:00.0
IF: enp8s0f1 state: down mac: <filter>
WAN IP: No WAN IP found. Connected to web? SSL issues? Try enabling dig
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:3 chip-ID: 8087:0029
class-ID: e001
Report: rfkill ID: hci0 rfk-id: 2 state: down bt-service: enabled,running
Local Storage: total: 480.21 GiB used: 323.14 GiB (67.3%)
model: SSD 970 EVO Plus 500GB size: 465.76 GiB block-size: physical: 512 B
fw-rev: 2B2QEXM7 temp: 37.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Verbatim model: STORE N GO
size: 14.45 GiB block-size: physical: 512 B logical: 512 B type: USB rev: 2.0
spd: 480 Mb/s lanes: 1 mode: 2.0 tech: N/A serial: <filter> fw-rev: 8.07
scheme: MBR
ID-1: / raw-size: 448.59 GiB size: 440.48 GiB (98.19%)
used: 314.46 GiB (71.4%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 634dcde8-9db5-4dd9-8f54-ef1da89697e6
used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 0569-ECB9
ID-3: /run/media/mathijs/VERBATIM raw-size: 14.45 GiB
size: 14.44 GiB (99.90%) used: 8.68 GiB (60.1%) fs: vfat dev: /dev/sda1
maj-min: 8:1 label: VERBATIM uuid: 0EE4-2EC7
ID-1: swap-1 type: partition size: 16.87 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
uuid: 7d14346f-3d32-439c-9f28-19c3a3d4aa08
Device-1: 1-1:4 info: Verbatim Flash Drive type: mass storage
driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 power: 200mA chip-ID: 18a5:0302 class-ID: 0806
serial: <filter>
Device-2: 1-8:2 info: Chicony USB2.0 Camera type: video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
power: 500mA chip-ID: 04f2:b685 class-ID: 0e02
Device-3: 1-14:3 info: Intel AX200 Bluetooth type: bluetooth driver: btusb
power: 100mA chip-ID: 8087:0029 class-ID: e001
Hub-2: 2-0:1 info: super-speed hub ports: 8 rev: 3.1
System Temperatures: cpu: 55.0 C pch: 65.0 C mobo: N/A
Fan Speeds (rpm): N/A
Processes: 357 Power: uptime: 5h 16m states: freeze,mem,disk suspend: deep
avail: s2idle wakeups: 2 hibernate: platform avail: shutdown, reboot,
suspend, test_resume image: 6.12 GiB services: org_kde_powerdevil,upowerd
Packages: 2116 pm: pacman pkgs: 2098 libs: 524 tools: pamac pm: flatpak
pkgs: 11 pm: snap pkgs: 7 Compilers: clang: 19.1.7 gcc: 14.2.1 alt: 11/13
Shell: Zsh v: 5.9 default: Bash v: 5.2.37 running-in: konsole inxi: 3.3.37
matv1
16 February 2025 18:07
5
So… I did a litlle more digging case I would realy like to get a handle on this without reverting to a complete backup/reinstall… But oth, this is my daily driver and cant do without it too much longer.
That being said, this is what my journalctl error says:
journalctl -p 3 -xb
feb 14 21:04:25 clevobuntu kernel: i915 0000:00:02.0: [drm] *ERROR* Failed to read source OUI feb 14 21:04:26 clevobuntu kernel: iwlwifi 0000:07:00.0: no suitable firmware found! feb 14 21:04:26 clevobuntu kernel: iwlwifi 0000:07:00.0: iwlwifi-cc-a0-77 is required feb 14 21:04:26 clevobuntu kernel: iwlwifi 0000:07:00.0: check git://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git feb 14 21:04:27 clevobuntu kernel: Bluetooth: hci0: Failed to load Intel firmware file intel/ibt-20-1-3.sfi (-2)
Also in the GUI, through Manjaro Settings Manager → Hardware Configuration panel, the hardware of the Intel AX200 is shown, but no drivers are toggled (indeed the toggle box doenst even show for that device. The auto Install Open-Source Drivers button does nothing to change this.
Furthermore, if I understand correctly, iwlwifi drivers should be in
/usr/lib/firmware
But I don’t see any iwlwifi files in that folder at all…
Any help is appreciated, as always
thnks, Mat
It should be in lib/firmware.
iwlwifi 0000:02:00.0: loaded firmware version 77.b405f9d4.0 cc-a0-77.ucode op_mode iwlmvm
If it isn’t for some odd reason, a quick and dirty fix is download linux-firmware from the manjaro repository (core) or grab from your cache, extract the .zst file and copy
iwlwifi-cc-a0-77.ucode to lib/firmware , then reboot.
It should work. To check if it loaded:
sudo journalctl -k | grep iwlwifi
matv1
16 February 2025 22:45
7
That totally worked! thank you very much
cscs
16 February 2025 22:57
8
/lib should be a symlink to /usr/lib and /usr/lib/firmware/iwlwifi-cc-a0-77.ucode is provided by linux-firmware.
It would be interesting to know how yours is not there.
system
Closed
19 February 2025 22:57
9
