Wired Mouse Causes Manjaro to not Boot
Hello,
I’m not really new to Linux but I am new to Arch-based Distros.
I have a mouse (Roccat Burst Pro) that i use with my laptop (HP Spectre x360). For some reason, having the mouse plugged in stops the OS from booting, it just sits on a black screen and turns off the mouse. Turning off the laptop and unplugging the mouse, then turning the laptop back on fixes the problem. This also happens with restarts.
However, on boot I can get into the UEFI and manually boot into Manjaro with no problems (with the mouse plugged in).
I don’t have any other OS installed and I used the “erase disk” option at install. The system is formatted with BTRFS and secure boot is disabled if that helps.
edit: grammar
:+1: Welcome to Manjaro! :+1:
  1. Please read this:
    How to provide good information
    and give us more information so we can see what’s really going on.
    Now we know the symptom of the disease, but we need some more probing to know where the origin lies… :grin:
  2. An inxi --admin --verbosity=7 --filter --no-host --width would be the minimum required information for us to be able to help you. (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
    Also, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text.
  3. A journalctl output of a failed boot would be helpful as well:
    • Insert the mouse
    • Restart the machine
    • Wait for the mouse to turn off
    • Wait some more (5 minutes)
    • If still a black screen: REISUB
    • Post the output of:
      journalctl --system --boot=-1 --priority=warning
  4. If you would not get a black screen, just let us know, don’t provide any output
:+1:
P.S. If you enter a bit more details in your profile, we can also see which Desktop Environment you’re using, which exact CPU/GPU or Kernel, … you have without typing it every time
  Kernel: 5.14.2-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.14-x86_64
  root=UUID=c5991564-5edc-4461-b3b9-463cd03ed832 rw rootflags=subvol=@ quiet
  apparmor=1 security=apparmor udev.log_priority=3 sysrq_always_enabled=1
  Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Convertible System: HP product: HP Spectre x360 Convertible 13-ae0xx
  v: N/A serial: <filter> Chassis: type: 31 serial: <filter>
  Mobo: HP model: 83B9 v: 56.50 serial: <filter> UEFI: AMI v: F.31
  date: 08/07/2019
  ID-1: BAT0 charge: 51.6 Wh (100.0%) condition: 51.6/51.6 Wh (100.0%)
  volts: 12.7 min: 11.6 model: HP Primary type: Li-ion serial: N/A
  status: Full
  Device-1: hid-0018:04F3:2593.0001-battery model: ELAN2514:00 04F3:2593
  serial: N/A charge: N/A status: N/A
  RAM: total: 7.52 GiB used: 1.69 GiB (22.4%)
  Info: Quad Core model: Intel Core i5-8250U bits: 64 type: MT MCP
  arch: Kaby Lake note: check family: 6 model-id: 8E (142) stepping: A (10)
  microcode: EA cache: L2: 6 MiB bogomips: 28808
  Speed: 700 MHz min/max: 400/3400 MHz Core speeds (MHz): 1: 700 2: 1766
  3: 1170 4: 800 5: 800 6: 800 7: 800 8: 800
  Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
  avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
  hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
  mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
  rdrand rdseed rdtscp rep_good sdbg sep sgx smap smep ss ssbd sse sse2 sse4_1
  xsaves xtopology xtpr
  Type: l1tf
  Device-1: Intel UHD Graphics 620 vendor: Hewlett-Packard driver: i915
  v: kernel bus-ID: 00:02.0 chip-ID: 8086:5917 class-ID: 0300
  Device-2: Quanta HP Wide Vision FHD Camera type: USB driver: uvcvideo
  bus-ID: 1-5:2 chip-ID: 0408:5251 class-ID: 0e02 serial: <filter>
  loaded: modesetting alternate: fbdev,vesa display-ID: :0 screens: 1
  s-diag: 582mm (22.9")
  Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 166 size: 293x165mm (11.5x6.5")
  diag: 336mm (13.2")
  OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.2.1
  direct render: Yes
  Device-1: Intel Sunrise Point-LP HD Audio vendor: Hewlett-Packard
  driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3
  chip-ID: 8086:9d71 class-ID: 0403
  Sound Server-1: ALSA v: k5.14.2-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.35 running: yes
  Device-1: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel port: f040
  bus-ID: 02:00.0 chip-ID: 8086:24fd class-ID: 0280
  bus-ID: 1-7:3 chip-ID: 8087:0a2b class-ID: e001
  Local Storage: total: 335.35 GiB used: 10.59 GiB (3.2%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKKF360G7H
  size: 335.35 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
  lanes: 4 type: SSD serial: <filter> rev: HP03 temp: 29.9 C scheme: GPT
  ID-1: / raw-size: 335.05 GiB size: 335.05 GiB (100.00%)
  used: 10.59 GiB (3.2%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
  label: N/A uuid: c5991564-5edc-4461-b3b9-463cd03ed832
  used: 568 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  label: NO_LABEL uuid: 4295-1556
  ID-3: /home raw-size: 335.05 GiB size: 335.05 GiB (100.00%)
  ID-4: /var/cache raw-size: 335.05 GiB size: 335.05 GiB (100.00%)
  ID-5: /var/log raw-size: 335.05 GiB size: 335.05 GiB (100.00%)
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
  Device-1: 1-1:4 info: ROCCAT Burst Pro type: Mouse,HID
  driver: hid-generic,usbhid interfaces: 4 rev: 2.0 speed: 12 Mb/s
  power: 500mA chip-ID: 1e7d:2de1 class-ID: 0300
  Device-2: 1-5:2 info: Quanta HP Wide Vision FHD Camera type: Video
  driver: uvcvideo interfaces: 4 rev: 2.0 speed: 480 Mb/s power: 500mA
  Device-3: 1-7:3 info: Intel Bluetooth wireless interface type: Bluetooth
  Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s
  System Temperatures: cpu: 52.0 C mobo: N/A
  Processes: 262 Uptime: 2m wakeups: 3 Init: systemd v: 249 tool: systemctl
  Compilers: gcc: 11.1.0 Packages: pacman: 1252 lib: 333 flatpak: 0 Shell: Zsh
  v: 5.8 default: Bash v: 5.1.8 running-in: konsole inxi: 3.3.06
The REISUB didn’t do anything
Can you:
  • unplug the mouse
  • boot into Manjaro
  • close all applications (so that you don’t lose any work)
  • do a REISUB and confirm it works or not?
:stuck_out_tongue_winking_eye:
With the mouse unplugged, REISUB works fine.
That sounds like an UEFI firmware issue:
Try to look on your manufacturer’s or AMI’s website and see if there is an UEFI firmware update and try again with the mouse.
Then report back, please?
Ok, i’ll have a look
Someone is saying they are self-extracting archives that are Windows only
There is a “Windows Boot Manager” in the UEFI since this laptop came with windows (Idk why it’s still there though), maybe the mouse is trying to do something with that?
A self-extracting archive is a normal archive, with an additional exefile copied to the start of it. Therefore it is often possible to extract the archive without the included exe.
One way may be to rename the archive back to its original extension (.zip or .gz or …) :sunglasses:
I have found it, had to look on a windows machine for it to show up (I’m stupid)
They have given me a .sig and a .bin, what do i do with those?
Might just have to learn how to dual boot windows actually.
Thank you for your time :slight_smile:
