Hello! Decided to switch to KDE from Gnome (was also Manjaro), can’t resolve the issue:
configured sstp VPN for work, but can’t make it connect automatically on each boot. ‘Connect automatically’ checkbox is disabled, and if I enable ‘Auto connect to VPN’ in Wired connection’s properties (also tried nmcli edit, , the system boots with all connections off (green “cable” on tray icon), so I have to connect even Wired manually, then it also connects VPN automatically.
nmcli connection show BIO
shows ‘connection.autoconnect: yes’, tried adding it as secondary (as I understand, ‘Auto connect to VPN’ does the same) - no luck.
Hi @Egorro, and welcome!
What is the output of:
systemctl status NetworkManager.service
Tip: ![:bangbang: :bangbang:](https://forum.manjaro.org/images/emoji/twitter/bangbang.png?v=12)
When posting terminal output, copy the output and paste it here, wrapped in three (3) backticks, before AND after the pasted text. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Sed
sollicitudin dolor
eget nisl elit id
condimentum
arcu erat varius
cursus sem quis eros.
Instead of like this:
Sed sollicitudin dolor eget nisl elit id condimentum arcu erat varius cursus sem quis eros.
Thereby increasing legibility thus making it easier for those trying to provide assistance.
For more information, please see:
Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C
. For example:
LC_ALL=C bluetoothctl
Hi @Mirdarthos , thanks for detailed answer!
This is the output:
● NetworkManager.service - Network Manager
Loaded: loaded (/lib/systemd/system/NetworkManager.service; enabled; vendor preset: enabled)
Active: active (running) since Tue 2024-02-27 06:23:59 MSK; 2 days ago
Docs: man:NetworkManager(8)
Main PID: 547782 (NetworkManager)
Tasks: 3 (limit: 309221)
Memory: 17.4M
CGroup: /system.slice/NetworkManager.service
└─547782 /usr/sbin/NetworkManager --no-daemon
Right now I have automatic Wired connection and manual VPN.
I see the Wired is connected automatically. What is the output of:
nmcli connection
Edit:
I’ve got to run, I was shooting in the dark anyway, since I only use a Wired connection. But maybe someone else can help.
Edit #2:
See:
nmcli con:
NAME UUID TYPE DEVICE
BIO 57809492-f3ff-4e0f-8109-f72bc15a89c9 vpn enp42s0
Wired 3de33103-2668-3959-83e4-35e8c5459f75 ethernet enp42s0
lo 5f7c080b-bafd-4e66-a89d-85f51cbd9de6 loopback lo
Tried that solution, but the nmcli command hasn’t status parameter))
LC_ALL=C nmcli con status
Error: argument 'status' not understood. Try passing --help instead.
Tried leaving just line nmcli connection up BIO
in that script (without any conditions) - doesn’t work also.
Try show
instead of status
Looks like it’s default command for nmcli con
$ nmcli con show
lo 5c08c627-5024-4521-88c9-939fb233232a loopback lo
BIO 57809492-f3ff-4e0f-8109-f72bc15a89c9 vpn --
$ nmcli con
Resolved the issue by selecting “store password for all users” in VPN settings - as I understand, wired connection couldn’t activate VPN from Root without stored password, so it also didn’t connect on boot.
Thanks for the answers!
