I had to set up my computer again with Manjaro Linux. But installing wine via pamac / Pacman does not succeed. The installation seems to be fine but wine does not run.
I have tried several ways.
I have uninstalled wine even with harder cleanings
Starting wine e.g with winecfg this error always appears.
0024:err:file:init_redirects /home/omlinux/.wine/dosdevices/c:/windows: Datei oder Verzeichnis nicht gefunden
wine: could not open working directory L"C:\\windows\\system32", starting in the Windows directory.
002c:err:wineboot:main Cannot set the dir to L"C:\\windows" (2)
002c:err:wineboot:process_run_key Error running cmd L"C:\\windows\\system32\\winemenubuilder.exe -a -r" (2).
0034:fixme:service:scmdatabase_autostart_services Auto-start service L"MountMgr" failed to start: 2
0034:fixme:service:scmdatabase_autostart_services Auto-start service L"wineusb" failed to start: 2
0034:fixme:service:scmdatabase_autostart_services Auto-start service L"npf" failed to start: 2
0034:fixme:service:scmdatabase_autostart_services Auto-start service L"winebus" failed to start: 2
0034:fixme:service:scmdatabase_autostart_services Auto-start service L"PlugPlay" failed to start: 2
0034:fixme:service:scmdatabase_autostart_services Auto-start service L"Eventlog" failed to start: 2
0034:fixme:service:scmdatabase_autostart_services Auto-start service L"nsiproxy" failed to start: 2
0034:fixme:service:scmdatabase_autostart_services Auto-start service L"NDIS" failed to start: 2
002c:err:winediag:nodrv_CreateWindow Application tried to create a window, but no driver could be loaded.
002c:err:winediag:nodrv_CreateWindow The explorer process failed to start.
0040:err:winediag:nodrv_CreateWindow Application tried to create a window, but no driver could be loaded.
0040:err:winediag:nodrv_CreateWindow The explorer process failed to start.
^C0024:err:module:process_init L"C:\\windows\\system32\\-version.exe" not found
Does anybody has a clue how to go on?
Thanks, Rulinux
cp -a ~/.wine/drive_c/windows/command/start.exe ~/.wine/drive_c/windows/
results in
cp: der Aufruf von stat für '/home/rulinux/.wine/drive_c/windows/command/start.exe' ist nicht möglich: Datei oder Verzeichnis nicht gefunden
This means basically translated from German into English … it is not possible: file or path not found.
Maybe the reason lies in my older installation where I took my “/home/” from. There I had separated /home and / (root). Now I have fully encrypted my hard disks which was sadly only possible with the standard installation with root and home on one partition together.
Maybe somewhere still may retain this information. This is just a guess.
Do you see the same problem with a new (empty) WINEPREFIX?
env WINEPREFIX=~/.customprefix wineboot -u
Seems to start wine. Finally it results in
wine: created the configuration directory '/home/rulinux/.customprefix'
002c:fixme:actctx:parse_depend_manifests Could not find dependent assembly L"Microsoft.Windows.Common-Controls" (6.0.0.0)
0048:fixme:actctx:parse_depend_manifests Could not find dependent assembly L"Microsoft.Windows.Common-Controls" (6.0.0.0)
0050:fixme:actctx:parse_depend_manifests Could not find dependent assembly L"Microsoft.Windows.Common-Controls" (6.0.0.0)
0048:err:ole:StdMarshalImpl_MarshalInterface Failed to create ifstub, hr 0x80004002
0048:err:ole:CoMarshalInterface Failed to marshal the interface {6d5140c1-7436-11ce-8034-00aa006009fa}, hr 0x80004002
0048:err:ole:apartment_get_local_server_stream Failed: 0x80004002
0050:err:ole:StdMarshalImpl_MarshalInterface Failed to create ifstub, hr 0x80004002
0050:err:ole:CoMarshalInterface Failed to marshal the interface {6d5140c1-7436-11ce-8034-00aa006009fa}, hr 0x80004002
0050:err:ole:apartment_get_local_server_stream Failed: 0x80004002
0050:err:ole:start_rpcss Failed to open RpcSs service
0040:fixme:winspool:AddPrinterW DocumentPropertiesW on printer L"Brother_MFC-L5750DW_series" fails
0040:fixme:winspool:AddPrinterW DocumentPropertiesW on printer L"iP7200-series" fails
0040:fixme:winspool:AddPrinterW DocumentPropertiesW on printer L"MX450-series" fails
0064:fixme:urlmon:InternetBindInfo_GetBindString not supported string type 20
0064:fixme:file:NtLockFile I/O completion on lock not implemented yet
0064:fixme:ntdll:NtQuerySystemInformation info_class SYSTEM_PERFORMANCE_INFORMATION
0064:err:mscoree:LoadLibraryShim error reading registry key for installroot
0078:fixme:file:NtLockFile I/O completion on lock not implemented yet
0078:fixme:ntdll:NtQuerySystemInformation info_class SYSTEM_PERFORMANCE_INFORMATION
0078:err:mscoree:LoadLibraryShim error reading registry key for installroot
0078:fixme:msi:internal_ui_handler internal UI not implemented for message 0x0b000000 (UI level = 5)
0064:fixme:msi:internal_ui_handler internal UI not implemented for message 0x0b000000 (UI level = 1)
00bc:err:module:open_builtin_so_file failed to load .so lib "/usr/lib32/wine/i386-unix/l3codeca.acm.so"
00bc:err:winediag:gnutls_initialize failed to load libgnutls, no support for encryption
00bc:err:winediag:gnutls_initialize failed to load libgnutls, no support for pfx import/export
00bc:err:module:open_builtin_so_file failed to load .so lib "/usr/lib32/wine/i386-unix/mp3dmod.dll.so"
wine: configuration in L"/home/rulinux/.customprefix" has been updated.
012c:err:module:open_builtin_so_file failed to load .so lib "/usr/lib32/wine/i386-unix/l3codeca.acm.so"
012c:err:winediag:gnutls_initialize failed to load libgnutls, no support for encryption
012c:err:winediag:gnutls_initialize failed to load libgnutls, no support for pfx import/export
012c:err:module:open_builtin_so_file failed to load .so lib "/usr/lib32/wine/i386-unix/mp3dmod.dll.so"
While I was curios I did the same command again. Second time it resulted differently.
Could not parse file "/home/omlinux/.local/share/applications/org.freefilesync.FreeFileSync.desktop": No such file or directory
0124:err:module:open_builtin_so_file failed to load .so lib "/usr/lib32/wine/i386-unix/l3codeca.acm.so"
0124:err:winediag:gnutls_initialize failed to load libgnutls, no support for encryption
0124:err:winediag:gnutls_initialize failed to load libgnutls, no support for pfx import/export
0124:err:module:open_builtin_so_file failed to load .so lib "/usr/lib32/wine/i386-unix/mp3dmod.dll.so"
I have looked for the file which failed to load /usr/lib32/wine/i386-unix/l3codeca.acm.so
but it is in designated folder.
Blockquote
Could not parse file “/home/omlinux/.local/share/applications/org.freefilesync.FreeFileSync.desktop”: No such file or directory
Looks like wine saw that you have 2 different home folder on the same run, omlinux and rulinux. One of them might be encrypted to the others. You might want to try to call wine from each home. e.g; WINEPREFIX=~/home/omlinux/.wine winecfg or WINEPREFIX=~/home/rulinux/.wine winecfg. Or you may have to login as omlinux instead of rulinux if wine is rooted to that user account.
Anyway, did you cleanly install Manjaro on an encrypted partition or reusing an old /home folder and encrypt it?
I have completely new installed Manjaro from the scratch with ONE USER ONLY. Let’s say the main user is rulinux. The omlinux is just a replace failure. So forget about it. With USB-Live stick I had deleted the content of /home/rulinux and replaced it with my old one.
The difference from my former installation to the new one is that it is fully encrypted and root and home are on one partition now not on 2 anymore.
Here the strange result of
wine: chdir to /home/rulinux/home/rulinux/.wine : Datei oder Verzeichnis nicht gefunden
… means file or path not found
I believe it comes from that /home before was on a separeted partition. Even a new installation of wine does correct the path. I can change it in configuration file that may be a solution.
Otherwise after all kind help from all of you I do not see any other solution. May be I have to uninstall wine first and than delete all folders and files with wine!?
Run ls -l and pwd. If both of them show the same username, then use that name. For example, if it shows omlinux then you need to run WINEPREFIX=/home/omlinux/.wine winecfg.
ls -l
insgesamt 0
drwxr-xr-x 1 rulinux rulinux 458 9. Okt 10:33 SoftMaker
and
pwd
/home/rulinux
And for a try.
Here it turns out that “/home/omlinux/.steam/sdk32/steam” is red marked an blinking. But I have uninstalled steam because of no need. Also something is wrong with Softmaker Office installation. “Softmaker” text is in blue color. “.wine” is yellow marked as a lot of others.
You folder ownership is kinda weird. You don’t have the common home folders ownership, you don’t even have default folders such as Documents or Desktop. And who is “wheel”? Are you using a sandbox or a docker? And did you install freefilesync from aur?
After my installation from scratch I have looked into the system settings “locations”. All was set to the path /home/rulinux. I have changed the folders but after restart it resets again to this wrong path. There is something wrong. I have claimed this problem under bugs.kde.org - no answer, yet.
Secondly I have two hard disks, one is for the OS (SSD drive) the other is for my data (normal hard disk). After a new system installation which I have done already many times always I do not have full access to my data drive. There is something wrong in the installation routine (standard or manual does not make a difference here). Therefore I got the recommendation to use
After this command I have full read and write access.
I am not using a sandbox or a docker, at least I am not aware of it. Just a virtualbox with with windows. But that should not be an issue, isn’t it.
I had installed freefilesync for trying it out but i have uninstalled it. It is a pitty that old programs are not completely cleaned out in Manjaro after uninstalling them.
LOL
Alright, now repeat that command and see if the wine configuration is still working.
If that works, then you can test wine explorer instead of winecfg. Use the working wineprefix.
About the wheel group. I think it’s has the same level as root or at least have the same administrative level as the root account. You may have problems using any file or folders registered to wheel group in the future. And it might be dangerous. I suggest you try to find another way to use your second hard drive without chown your user account to wheel group.
PS:
I’m sleepy. I need to off to bed now. So, good luck. I hope you can run wine without trouble anymore.
