wine打不开,SteamPlay一启动就会黑屏然后跳出/dev/sda2/:clean,373429/6553600 files,4332681 /26214400 blocks后直接被强制注销
When wine doesn’t open, SteamPlay will black out as soon as it starts and then jump out/dev/sda2/:clean, 373429/6553600 files, 4332681 /26214400 the blocks and be forced to log off directly
Note: This is machine translated and may not be accurate
Kernel: 5.13.11-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=4e7e0115-6e72-48de-90a1-156f9d1cadf7 rw quiet apparmor=1
Desktop: KDE Plasma 5.22.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Hewlett-Packard product: HP EliteBook 820 G1
v: A3009DD10303 serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: Hewlett-Packard model: 1991 v: KBC Version 15.59 serial: <filter>
UEFI: Hewlett-Packard v: L71 Ver. 01.48 date: 08/29/2019
ID-1: BAT0 charge: 35.4 Wh (94.4%) condition: 37.5/37.5 Wh (100.0%)
volts: 12.4 min: 11.2 model: Hewlett-Packard Primary type: Li-ion
serial: <filter> status: Unknown
RAM: total: 7.67 GiB used: 1.96 GiB (25.5%)
Info: Dual Core model: Intel Core i5-4310U bits: 64 type: MT MCP
arch: Haswell family: 6 model-id: 45 (69) stepping: 1 microcode: 26 cache:
L2: 3 MiB bogomips: 20756
Speed: 1991 MHz min/max: 800/3000 MHz Core speeds (MHz): 1: 1991 2: 2084
3: 2098 4: 1995
Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2 bts
clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm
dts epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase
fxsr ht ibpb ibrs ida invpcid invpcid_single lahf_lm lm mca mce md_clear mmx
monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdtscp rep_good
sdbg sep smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xsave
xsaveopt xtopology xtpr
Type: l1tf
Device-1: Intel Haswell-ULT Integrated Graphics vendor: Hewlett-Packard
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:0a16 class-ID: 0300
Device-2: Lite-On HP HD Webcam type: USB driver: uvcvideo bus-ID: 2-7:7
chip-ID: 04ca:7034 class-ID: 0e02 serial: <filter>
loaded: intel unloaded: modesetting alternate: fbdev,vesa display-ID: :0
screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: eDP1 res: 1366x768 hz: 60 dpi: 124 size: 280x160mm (11.0x6.3")
diag: 322mm (12.7")
OpenGL: renderer: Mesa DRI Intel HD Graphics 4400 (HSW GT2)
v: 4.5 Mesa 21.2.1 compat-v: 3.0 direct render: Yes
Device-1: Intel Haswell-ULT HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 00:03.0 chip-ID: 8086:0a0c
class-ID: 0403
Device-2: Intel 8 Series HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9c20
class-ID: 0403
Sound Server-1: ALSA v: k5.13.11-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.33 running: yes
Device-1: Intel Ethernet I218-LM vendor: Hewlett-Packard driver: e1000e
v: kernel port: 3080 bus-ID: 00:19.0 chip-ID: 8086:155a class-ID: 0200
IF: enp0s25 state: down mac: <filter>
Device-2: Intel Wireless 7260 driver: iwlwifi v: kernel port: ef80
bus-ID: 02:00.0 chip-ID: 8086:08b1 class-ID: 0280
bus-ID: 2-4:4 chip-ID: 8087:07dc class-ID: e001
Local Storage: total: 476.94 GiB used: 168.31 GiB (35.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: SanDisk model: SD6SB2M-512G-1006
size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 706 scheme: GPT
ID-1: / raw-size: 60 GiB size: 58.76 GiB (97.93%) used: 8.68 GiB (14.8%)
fs: ext4 dev: /dev/sda3 maj-min: 8:3 label: N/A
uuid: 4e7e0115-6e72-48de-90a1-156f9d1cadf7
ID-2: /boot/efi raw-size: 513 MiB size: 512 MiB (99.80%)
used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
uuid: D37D-15DC
ID-3: /home raw-size: 416.44 GiB size: 408.9 GiB (98.19%)
used: 159.63 GiB (39.0%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 514df18a-5a04-4f3d-808f-2555274c8509
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 3 rev: 2.0
Hub-2: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
speed: 480 Mb/s chip-ID: 8087:8000 class-ID: 0900
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 9 rev: 2.0
Hub-4: 2-3:3 info: Microchip (formerly SMSC) Hub ports: 3 rev: 2.1
speed: 480 Mb/s chip-ID: 0424:2134 class-ID: 0900
Device-1: 2-3.1:5 info: Pixart Imaging Optical Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s
power: 100mA chip-ID: 093a:2510 class-ID: 0301
Device-2: 2-4:4 info: Intel Bluetooth wireless interface type: Bluetooth
Device-3: 2-5:6 info: Validity Sensors VFS495 Fingerprint Reader
type: <vendor specific> driver: N/A interfaces: 1 rev: 1.1 speed: 12 Mb/s
power: 100mA chip-ID: 138a:003f class-ID: ff00 serial: <filter>
Device-4: 2-7:7 info: Lite-On HP HD Webcam type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 04ca:7034
Hub-5: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 speed: 5 Gb/s
Hub-6: 3-3:2 info: Microchip (formerly SMSC) Hub ports: 3 rev: 3.0
speed: 5 Gb/s chip-ID: 0424:5534 class-ID: 0900
System Temperatures: cpu: 53.0 C mobo: 0.0 C
Processes: 186 Uptime: 12h 10m wakeups: 4 Init: systemd v: 248
tool: systemctl Compilers: gcc: N/A Packages: pacman: 1194 lib: 330
flatpak: 0 Shell: Zsh v: 5.8 default: Bash v: 5.1.8 running-in: konsole
inxi: 3.3.06
