I have the official KDE release installed. I recently moved and so my computer was offline for a little over a month. I recently booted it up and was trying to do an upgrade via the GUI and I was getting the error:
“Invalid or corrupted database”
It was erroring out on the Extras repo with Megasync. I uninstalled Mega Sync. I was able to updgrade
Upon reboot machine does not progress past the vendor splash screen. I have to switch to console. I was able to run a timeshift restore to roll it back. Every time I do the upgrade the same issue happens.
I’ve been doing some research which is why I’ve progressed to where I’m at now and now I need help.
Here’s what I’m running into now on the command line:
sudo pacman -Syyu
core 170.6 KiB 1115 KiB/s 00:00 [############################] 100%
extra 1901.8 KiB 4.73 MiB/s 00:00 [############################] 100%
community 6.6 MiB 6.15 MiB/s 00:01 [############################] 100%
multilib 177.4 KiB 3.69 MiB/s 00:00 [############################] 100%
:: Replace brave with community/brave-browser? [Y/n]
:: Replace jack with extra/jack2? [Y/n]
:: Replace lib32-jack with multilib/lib32-jack2? [Y/n]
:: Replace lib32-libcanberra-pulse with multilib/lib32-libcanberra? [Y/n] n
:: Replace libcanberra-pulse with extra/libcanberra? [Y/n] n
:: Replace pamac-common with extra/libpamac? [Y/n] y
:: Replace pamac-flatpak-plugin with extra/libpamac-flatpak-plugin? [Y/n]
:: Replace pamac-snap-plugin with extra/libpamac-snap-plugin? [Y/n]
:: Replace qca with extra/qca-qt5? [Y/n]
resolving dependencies...
:: installing lib32-libcanberra (0.30+2+gc0620e4-5) breaks dependency 'lib32-libcanberra=0.30+2+gc0620e4-3' required by lib32-libcanberra-gstreamer
:: installing lib32-libcanberra (0.30+2+gc0620e4-5) breaks dependency 'lib32-libcanberra=0.30+2+gc0620e4-3' required by lib32-libcanberra-pulse
:: installing libcanberra (0.30+2+gc0620e4-5) breaks dependency 'libcanberra=0.30+2+gc0620e4-3' required by libcanberra-gstreamer
:: installing libcanberra (0.30+2+gc0620e4-5) breaks dependency 'libcanberra=0.30+2+gc0620e4-3' required by libcanberra-pulse
:: installing nvidia-utils (470.57.02-1) breaks dependency 'nvidia-utils=460.80' required by linux511-nvidia
Send help! ![]()
Thanks in advance!
