WiFi Shows Very Low Strength and Drops Package
I installed Manjaro Linux on a second system and noticed significantly weaker Wi-Fi signal strength compared to my primary machine.
  • The primary system (Broadcom Wi-Fi chipset) shows full signal strength and works without issues.
  • The other system uses a MediaTek MT7925 (Filogic 360) wireless adapter and only shows 1 bar, with extremely poor usability despite being connected.
$ inxi -SN
  Host: h3ll Kernel: 6.18.18-1-MANJARO arch: x86_64 bits: 64
  Desktop: KDE Plasma v: 6.5.6 Distro: Manjaro Linux
  Device-1: MEDIATEK MT7925 802.11be 160MHz 2x2 PCIe Wireless Network Adapter
    [Filogic 360] driver: mt7925e
    driver: r8169
What I have already checked
  • Installed firmware:
    pacman -Ss linux-firmware-mediatek
    core/linux-firmware-mediatek 20260309-1 [installed]
  • Power saving is disabled:
    sudo iw dev wlo1 get power_save
    Power save: off
Issue
The MediaTek MT7925 adapter connects to Wi-Fi but has extremely weak signal strength and is practically unusable, while the Broadcom-based system in the same environment works perfectly.
Hi @tbhaxor; we would prefer the full inxi -zv8 output. :wink:
My initial guess would be that the WiFi antenna(s) aren’t properly connected (assuming a laptop with the antenna wires usually in the screen section). I find those horribly fiddly to attach at the best of times.
  Kernel: 6.18.18-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    root=UUID=87d63a61-cd90-4f61-9306-31e752c58c88 rw quiet splash
    resume=UUID=7dfaba5c-b91c-46bd-99cb-9d3bfd0d361e udev.log_priority=3
  Desktop: KDE Plasma v: 6.5.6 tk: Qt v: N/A info: frameworks v: 6.24.0
  Type: Laptop System: LENOVO product: 83F2 v: Legion Pro 5 16AFR10
    serial: <superuser required> Chassis: type: 10 v: Legion Pro 5 16AFR10
  Mobo: LENOVO model: LNVNB161216 v: SDK0T76485 WIN
    serial: <superuser required> part-nu: LENOVO_MT_83F2_BU_idea_FM_Legion Pro
    5 16AFR10 uuid: <superuser required> Firmware: UEFI vendor: LENOVO
    v: RECN20WW date: 11/25/2025
  ID-1: BAT0 charge: 81.7 Wh (98%) condition: 83.4/80 Wh (104.2%) power: 8.7 W
    volts: 17.75 min: 15.52 model: SMP L24M4PC0 type: Li-poly serial: <filter>
    charging: status: charging type: standard avail: long_life,standard
    cycles: 20
  System RAM: total: 32 GiB available: 30.61 GiB used: 4.41 GiB (14.4%)
  Device-1: Channel-A DIMM 0 type: DDR5 detail: synchronous unbuffered
    (unregistered) size: 16 GiB speed: 5600 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: SK Hynix
    part-no: HMCG78AGBSA095N serial: <filter>
  Device-2: Channel-B DIMM 0 type: DDR5 detail: synchronous unbuffered
  Info: model: AMD Ryzen 9 9955HX bits: 64 type: MT MCP arch: Zen 5 gen: 5
    level: v4 note: check built: 2024+ process: TSMC n4 (4nm) family: 0x1A (26)
    model-id: 0x44 (68) stepping: 0 microcode: 0xB404035
  Topology: cpus: 1x dies: 2 clusters: 2x1 cores: 16 threads: 32 tpc: 2
    smt: enabled cache: L1: 1.2 MiB desc: d-16x48 KiB; i-16x32 KiB L2: 16 MiB
    desc: 16x1024 KiB L3: 64 MiB desc: 2x32 MiB
  Speed (MHz): avg: 1480 min/max: 1217/5461 boost: enabled scaling:
    driver: amd-pstate-epp governor: performance cores: 1: 1480 2: 1480 3: 1480
    4: 1480 5: 1480 6: 1480 7: 1480 8: 1480 9: 1480 10: 1480 11: 1480 12: 1480
    13: 1480 14: 1480 15: 1480 16: 1480 17: 1480 18: 1480 19: 1480 20: 1480
    21: 1480 22: 1480 23: 1480 24: 1480 25: 1480 26: 1480 27: 1480 28: 1480
    29: 1480 30: 1480 31: 1480 32: 1480 bogomips: 159689
    apic arat avx avx2 avx512_bf16 avx512_bitalg avx512_vbmi2 avx512_vnni
    avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f
    avx512ifma avx512vbmi avx512vl avx_vnni bmi1 bmi2 bpext bus_lock_detect
    cat_l3 cdp_l3 clflush clflushopt clwb clzero cmov cmp_legacy constant_tsc
    cpb cppc cpuid cpuid_fault cqm cqm_llc cqm_mbm_local cqm_mbm_total
    cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
    extd_apicid f16c flush_l1d flushbyasid fma fpu fsgsbase fsrm fxsr
    fxsr_opt gfni ht hw_pstate ibpb ibrs ibrs_enhanced ibs invpcid irperf
    lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor movbe
    movdir64b movdiri msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx ospke
    osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core
    perfctr_llc perfctr_nb perfmon_v2 pfthreshold pge pku pni popcnt pse
    pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
    skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp
    succor svm svm_lock syscall tce topoext tsc tsc_adjust tsc_scale umip
    vnmi vpclmulqdq wbnoinvd wdt x2avic xgetbv1 xsave xsavec xsaveerptr
    xsaveopt xsaves xtopology
  Type: spec_rstack_overflow mitigation: IBPB on VMEXIT only
    conditional; STIBP: always-on; PBRSB-eIBRS: Not affected; BHI: Not
    affected
  Type: vmscape mitigation: IBPB on VMEXIT
  Device-1: NVIDIA GB206M [GeForce RTX 5060 Max-Q / Mobile] vendor: Lenovo
    driver: nvidia v: 570.211.01 alternate: nouveau,nova_core,nvidia_drm
    non-free: 550-580.xx+ status: current (as of 2025-11) arch: Lovelace
    code: AD1xx process: TSMC n4 (5nm) built: 2022+ pcie: gen: 1
    speed: 2.5 GT/s lanes: 8 link-max: gen: 5 speed: 32 GT/s lanes: 16 ports:
    active: none empty: DP-1, DP-2, HDMI-A-1, eDP-2 bus-ID: 01:00.0
    chip-ID: 10de:2d59 class-ID: 0300
  Device-2: Advanced Micro Devices [AMD/ATI] Granite Ridge [Radeon Graphics]
    vendor: Lenovo driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
    process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s
    lanes: 16 ports: active: eDP-1 empty: Writeback-1 bus-ID: 07:00.0
    chip-ID: 1002:13c0 class-ID: 0300 temp: 52.0 C
  Device-3: Chicony Integrated Camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-1:2 chip-ID: 04f2:b83e
    compositor: kwin_wayland driver: X: loaded: amdgpu,nvidia
    unloaded: modesetting,nouveau alternate: fbdev,nv,vesa dri: radeonsi
    gpu: amdgpu display-ID: 0
  Monitor-1: eDP-1 model: Samsung ATNA60HS03-0 built: 2024 res:
    mode: 2560x1600 hz: 165 scale: 140% (1.4) to: 1829x1143 dpi: 191 gamma: 1.2
    chroma: red: x: 0.682 y: 0.318 green: x: 0.220 y: 0.725 blue: x: 0.141
    y: 0.039 white: x: 0.314 y: 0.329 size: 340x220mm (13.39x8.66")
    diag: 405mm (15.94") modes: 2560x1600, 1920x1200, 1920x1080, 1600x1200,
    1680x1050, 1280x1024, 1440x900, 1280x800, 1280x720, 1024x768, 800x600,
    640x480
  EDID-Warnings: 1: parse_edid: unknown tag 112 2: parse_edid: unknown tag
    112
  API: EGL v: 1.5 hw: drv: nvidia drv: amd radeonsi platforms: device: 0
    drv: nvidia device: 2 drv: radeonsi device: 3 drv: swrast gbm: drv: nvidia
    surfaceless: drv: nvidia wayland: drv: radeonsi x11: drv: radeonsi
    inactive: device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 26.0.2-arch1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Ryzen 9 9955HX 16-Core
    Processor (radeonsi raphael_mendocino ACO DRM 3.64 6.18.18-1-MANJARO)
    device-ID: 1002:13c0 memory: 500 MiB unified: no display-ID: :1.0
  API: Vulkan v: 1.4.341 layers: 7 device: 0 type: integrated-gpu name: AMD
    Ryzen 9 9955HX 16-Core Processor (RADV RAPHAEL_MENDOCINO)
    driver: mesa radv v: 26.0.2-arch1.1 device-ID: 1002:13c0 surfaces: N/A
    device: 1 type: discrete-gpu name: NVIDIA GeForce RTX 5060 Laptop GPU
    driver: nvidia v: 570.211.01 device-ID: 10de:2d59 surfaces: N/A
  Device-1: NVIDIA GB206 High Definition Audio driver: snd_hda_intel v: kernel
    pcie: gen: 5 speed: 32 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 01:00.1
    chip-ID: 10de:22eb class-ID: 0403
  Device-2: Advanced Micro Devices [AMD] Audio Coprocessor vendor: Lenovo
    driver: snd_rpl_pci_acp6x v: kernel alternate: snd_pci_acp3x,
    snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci, snd_pci_ps,
    snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh,
    snd_sof_amd_acp63, snd_sof_amd_acp70 pcie: gen: 4 speed: 16 GT/s lanes: 16
    bus-ID: 07:00.5 chip-ID: 1022:15e2 class-ID: 0480
  Device-3: Advanced Micro Devices [AMD] Ryzen HD Audio vendor: Lenovo
    bus-ID: 07:00.6 chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k6.18.18-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.6.2 status: active with: 1: pipewire-pulse
    [Filogic 360] vendor: Lenovo driver: mt7925e v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 14c3:7925 class-ID: 0280
    vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: 2000 bus-ID: 06:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp6s0 state: down mac: <filter>
  Device-1: Foxconn / Hon Hai Wireless_Device driver: btusb v: 0.8 type: USB
    rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2.3:4
    chip-ID: 0489:e111 class-ID: e001 serial: <filter>
  Report: rfkill ID: hci0 rfk-id: 2 state: down bt-service: enabled,running
  Local Storage: total: 2.75 TiB used: 253.05 GiB (9.0%)
    model: MZAL81T0HFLB-00BL2 size: 953.87 GiB block-size: physical: 512 B
    fw-rev: 4L1QKXF7 temp: 49.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: BUP Slim size: 1.82 TiB
    block-size: physical: 4096 B logical: 512 B type: USB rev: 3.2 spd: 5 Gb/s
    lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter> fw-rev: 0004
    scheme: GPT
  ID-1: / raw-size: 310 GiB size: 304.07 GiB (98.09%) used: 29.64 GiB (9.7%)
    fs: ext4 dev: /dev/nvme0n1p1 maj-min: 259:1 label: RootFS
    uuid: 87d63a61-cd90-4f61-9306-31e752c58c88
    used: 32.3 MiB (6.3%) fs: vfat dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
    uuid: 5B14-4D1B
  ID-3: /home raw-size: 627.62 GiB size: 616.7 GiB (98.26%)
    used: 223.38 GiB (36.2%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    label: Home uuid: a3425eb3-fd84-439e-ae60-8834b94c139b
  ID-1: swap-1 type: partition size: 15.75 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/nvme0n1p4 maj-min: 259:4 label: N/A
    uuid: 7dfaba5c-b91c-46bd-99cb-9d3bfd0d361e
  ID-1: /dev/sda1 maj-min: 8:1 size: 1.82 TiB fs: <superuser required>
    label: N/A uuid: N/A
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Device-1: 2-1:2 info: Seagate RSS LLC BUP Slim type: mass storage
    driver: uas interfaces: 1 rev: 3.2 speed: 5 Gb/s (596.0 MiB/s) lanes: 1
    mode: 3.2 gen-1x1 power: 144mA chip-ID: 0bc2:ac19 class-ID: 0806
    serial: <filter>
  Device-1: 3-1:2 info: Logitech M185 compact wireless mouse type: mouse
    lanes: 1 mode: 1.1 power: 50mA chip-ID: 046d:c542 class-ID: 0301
  Hub-4: 3-2:3 info: Genesys Logic Hub ports: 4 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 05e3:0610
  Device-1: 3-2.3:4 info: Foxconn / Hon Hai Wireless_Device type: bluetooth
    mode: 2.0 power: 100mA chip-ID: 0489:e111 class-ID: e001 serial: <filter>
  Device-2: 3-2.4:5 info: Integrated Express ITE Device(8258)
    type: keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
    chip-ID: 048d:c195 class-ID: 0300
  Hub-5: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-6: 4-2:2 info: Genesys Logic GL3523 Hub ports: 2 rev: 3.2
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 05e3:0620
  Hub-7: 5-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Device-1: 5-1:2 info: Chicony Integrated Camera type: video
    driver: uvcvideo interfaces: 3 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 04f2:b83e class-ID: fe01
    serial: <filter>
  System Temperatures: cpu: 60.5 C mobo: 49.5 C gpu: amdgpu temp: 55.0 C
  Fan Speeds (rpm): N/A
  Packages: pm: pacman pkgs: 1492 libs: 396 tools: pamac,yay pm: flatpak
    pkgs: 0
    1: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
    2: https://ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
    3: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
Processes:
  CPU top: 5 of 592
  1: cpu: 10.9% command: brave pid: 2866 mem: 635.8 MiB (2.0%)
  2: cpu: 3.0% command: brave pid: 4769 mem: 268.0 MiB (0.8%)
  3: cpu: 1.9% command: brave pid: 2480 mem: 377.1 MiB (1.2%)
  4: cpu: 1.6% command: brave pid: 2408 mem: 588.3 MiB (1.8%)
  5: cpu: 1.6% command: brave pid: 4965 mem: 299.8 MiB (0.9%)
  Memory top: 5 of 592
  1: mem: 635.8 MiB (2.0%) command: brave pid: 2866 cpu: 10.9%
  2: mem: 588.3 MiB (1.8%) command: brave pid: 2408 cpu: 1.6%
  3: mem: 385.9 MiB (1.2%) command: plasmashell pid: 1341 cpu: 0.2%
  4: mem: 377.1 MiB (1.2%) command: brave pid: 2480 cpu: 1.9%
  5: mem: 339.8 MiB (1.0%) command: konsole pid: 3097 cpu: 0.6%
  Processes: 592 Power: uptime: 57m states: freeze,mem,disk suspend: deep
    avail: s2idle wakeups: 1 hibernate: platform avail: shutdown, reboot,
    suspend, test_resume image: 12.12 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 259 default: graphical
    tool: systemctl
  Compilers: gcc: 15.2.1 Shell: Zsh v: 5.9 running-in: konsole inxi: 3.3.40
Thanks. I don’t suppose you have an external USB WIFi adapter to try?
Apart from checking the antenna connections or possibly swapping the cards between machines, if the same form-factor, but I do know (some) Lenovo machines are fussy about what cards they will accept.
Nope, it’s an builtin module.
That’s unfortunate. It does look like your only option is to get hold of a USB WiFi dongle. :man_shrugging:
Avoid the really cheap ones though; I got stung. Worked fantastically well for a few hours, great signal on both bands, but then started dropping out and packed up completely shortly afterwards, AFTER I’d left a good review … :roll_eyes:
Hi @tbhaxor ,
I wonder whether you could read the following posts in order to solve your problem.
‘[SOLVED] Mediatek MT7925 Bluetooth Controller Not Working / Laptop Issues / Arch Linux Forums’
‘[SOLVED] Mediatek mt7925e wifi has low reception compared to Win11 / Laptop Issues / Arch Linux Forums)’
The first link, although is related to the bluetooth, I found it in the forum,
‘Bluetooth broken after update - #5 by dudenas’
Hope it help, regards
I have installed the following kernel mod, the strength has bar has increased to 1 (still not 100%), but there are no drops and communication is working flawless as of now.
Until something breaks, this is the solution.
