Hello,
My wifi disconnects and I need to relaunch the wifi connection to make it work again it could happen every 5 minutes, every 1hour. I just sometimes lost my connections.
How to improve it?
I am using NetworkManager, maybe you suggest to use some other alternatives, which ones?
Maybe change network driver to another one, or update this one how to achieve this? I have reinstalled using:
Kernel: 6.4.6-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.4-x86_64
root=UUID=758df14c-2163-4fe3-a0db-2a38fe4278d3 rw amd_pstate.enable=1
amd_pstate=guided iommu=pt amd_pstate=active amd_pstate.shared_mem=1 quiet
splash initcall_blacklist=acpi_cpufreq_init amd_pstate.enable=1
amd_pstate=guided iommu=pt amd_pstate.shared_mem=1 apparmor=1
Desktop: GNOME v: 44.3 tk: GTK v: 3.24.38 wm: gnome-shell dm: GDM v: 44.1
Type: Laptop System: HP product: HP Pavilion 15 Laptop PC v: N/A
Mobo: HP model: 88D0 v: 78.31 serial: <superuser required> UEFI: AMI
v: F.23 date: 10/05/2022
Device-1: Realtek RTL8852AE 802.11ax PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtw89_8852ae v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 02:00.0 chip-ID: 10ec:8852
class-ID: 0280
2: wlo1 >
Link File: /usr/lib/systemd/network/99-default.link
Network File: n/a
State: routable (unmanaged)
Online state: unknown
Type: wlan
Path: pci-0000:02:00.0
Driver: rtw89_8852ae
Vendor: Realtek Semiconductor Co., Ltd.
Model: RTL8852AE 802.11ax PCIe Wireless Network Adapter
Alternative Names: wlp2s0
sudo /sbin/iwconfig wlo1 127 ✘
wlo1 IEEE 802.11 ESSID:"W-HUAWEI-B535-6518_5G"
Mode:Managed Frequency:5.32 GHz Access Point: A2:08:3A:18:65:80
Bit Rate=400 Mb/s Tx-Power=20 dBm
Retry short limit:7 RTS thr:off Fragment thr:off
Encryption key:off
Power Management:off
Link Quality=59/70 Signal level=-51 dBm
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:84 Missed beacon:0
My Invalid misc constatly increases.
I am using 5GHz internet.
