Hello there. Just installed Manjaro XFCE 2 days ago and saw WiFi option not being there . I have been scrambling the internet for help. Nothing worked till now. I am sorry , I am completely new to Linux so please don’t expect me to know anything.
There is no option of wireless connection in network . Saw in Hardware Configurations and found out the network controller for WiFi I have is Wireless 8265 / 8275 (Intel Corporation)
Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=882db191-d1a6-4a88-a851-8252e191a3a2 ro quiet apparmor=1
Desktop: Xfce 4.16.0 tk: Gtk 3.24.24 info: xfce4-panel wm: xfwm4 vt: 7
Type: Convertible System: FUJITSU product: LIFEBOOK P728 v: N/A
serial: <filter> Chassis: type: 31 serial: <filter>
Mobo: FUJITSU model: FJNB2B3 v: G2 serial: <filter> UEFI: FUJITSU // Insyde
v: Version 1.10 date: 09/12/2018
ID-1: CMB1 charge: 32.7 Wh (82.2%) condition: 39.8/45.0 Wh (88.4%)
volts: 11.6 min: 10.8 model: Fujitsu CP734929-01 type: Li-ion
serial: <filter> status: Discharging cycles: 205
RAM: total: 7.61 GiB used: 1.45 GiB (19.1%)
Info: Quad Core model: Intel Core i5-8250U bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 8E (142) stepping: A (10)
microcode: E0 cache: L2: 6 MiB bogomips: 28808
Speed: 400 MHz min/max: 400/3400 MHz Core speeds (MHz): 1: 400 2: 400 3: 400
4: 400 5: 400 6: 400 7: 400 8: 400
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1
xsaves xtopology xtpr
Type: l1tf
Device-1: Intel UHD Graphics 620 vendor: Fujitsu Limited. driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:5917 class-ID: 0300
Device-2: Chicony FJ Camera type: USB driver: uvcvideo bus-ID: 1-10:5
chip-ID: 04f2:b564 class-ID: 0e02
Display: x11 server: X.Org 1.20.10 driver: loaded: intel
unloaded: modesetting alternate: fbdev,vesa display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: eDP1 res: 1366x768 hz: 60 dpi: 124 size: 280x160mm (11.0x6.3")
diag: 322mm (12.7")
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 20.3.4
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Fujitsu Limited.
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3
chip-ID: 8086:9d71 class-ID: 0403
Sound Server-1: ALSA v: k5.9.16-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.23 running: no
Device-1: Intel Ethernet I219-LM vendor: Fujitsu Limited. driver: e1000e
v: kernel port: 3040 bus-ID: 00:1f.6 chip-ID: 8086:15d7 class-ID: 0200
IF: enp0s31f6 state: down mac: <filter>
Device-2: Intel Wireless 8265 / 8275 driver: N/A modules: iwlwifi, wl
port: 3040 bus-ID: 02:00.0 chip-ID: 8086:24fd class-ID: 0280
IF-ID-1: enp0s20f0u1 state: unknown speed: N/A duplex: N/A mac: <filter>
IF-ID-2: pan1 state: down mac: <filter>
IP v4: <filter> scope: global
Device-1: OPPO SM6115-QRD _SN:E442A825 type: USB driver: rndis_host
v: kernel bus-ID: 1-1:7 chip-ID: 22d9:276a class-ID: 0a00 serial: <filter>
Device-2: Intel Bluetooth wireless interface type: USB driver: btusb v: 0.8
bus-ID: 1-7:3 chip-ID: 8087:0a2b class-ID: e001
Message: No LVM data was found.
Local Storage: total: 238.47 GiB used: 33.48 GiB (14.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: SanDisk model: SD8SN8U-256G-1016
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
rotation: SSD serial: <filter> rev: 2016 scheme: GPT
ID-1: / raw-size: 238.17 GiB size: 233.43 GiB (98.01%)
used: 33.48 GiB (14.3%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 882db191-d1a6-4a88-a851-8252e191a3a2
used: 312 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: F4F8-68D5
ID-3: /run/timeshift/backup raw-size: 238.17 GiB size: <superuser required>
used: <superuser required> fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
Message: No Unmounted partitions found.
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
Device-1: 1-1:7 info: OPPO SM6115-QRD _SN:E442A825 type: Bluetooth,CDC-Data
driver: rndis_host interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA
Device-2: 1-5:2 info: Validity Sensors Swipe Fingerprint Sensor
type: <vendor specific> driver: N/A interfaces: 1 rev: 1.1 speed: 12 Mb/s
power: 100mA chip-ID: 138a:0050 class-ID: ff00 serial: <filter>
Device-3: 1-7:3 info: Intel Bluetooth wireless interface type: Bluetooth
Device-4: 1-8:4 info: Wacom Pen and multitouch sensor type: HID
driver: usbhid,wacom interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 400mA
chip-ID: 056a:50a9 class-ID: 0300
Device-5: 1-10:5 info: Chicony FJ Camera type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 04f2:b564
class-ID: 0e02
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 43.0 C mobo: N/A
Processes: 218 Uptime: 13m wakeups: 3 Init: systemd v: 247 tool: systemctl
Compilers: gcc: 10.2.0 clang: 11.1.0 Packages: pacman: 1230 lib: 422
flatpak: 0 Shell: Bash v: 5.1.0 running-in: xfce4-terminal inxi: 3.3.03
So I went to find the driver on the Intel website and downloaded it. Went into /lib/firmware and tried to paste there , but it was already present there. The driver is not loading , rebooted the laptop and still not working. Need help.
