hello, I recently installed gnome manjaro (dual booted with windows 10 Home). At first I didn’t find any issues but after some days I required to reboot to get my wifi working. In current scenario I powered off and started again many times but what happens is initially my wifi gets connected to the router but gets disconnected after 30-40 secs. Then after it completely stops working. It is not able to find any nearby devices.
I have read some posts but none of them helped. Some were in very abstract manner for a noob person to understand.
below is the output of my “inxi -Fazy” command
Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=b461a617-e282-4829-bafc-c6bcb48e1909 ro quiet splash apparmor=1
Desktop: GNOME 3.38.3 tk: GTK 3.24.24 wm: gnome-shell dm: GDM 3.38.2.1
Distro: Manjaro Linux
Type: Laptop System: ASUSTeK product: VivoBook_ASUSLaptop X412FJ_X412FJ
v: 1.0 serial: <filter>
Mobo: ASUSTeK model: X412FJ v: 1.0 serial: <filter>
UEFI: American Megatrends v: X412FJ.302 date: 03/27/2019
ID-1: BAT0 charge: 16.0 Wh condition: 28.0/37.1 Wh (75%) volts: 7.8/7.8
model: ASUSTeK ASUS Battery type: Li-ion serial: N/A status: Discharging
cycles: 329
Info: Quad Core model: Intel Core i5-8265U bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 8E (142) stepping: B (11)
microcode: DE L2 cache: 6 MiB
bogomips: 28808
Speed: 900 MHz min/max: 400/3900 MHz Core speeds (MHz): 1: 900 2: 900 3: 900
4: 900 5: 901 6: 900 7: 900 8: 900
Device-1: Intel UHD Graphics 620 vendor: ASUSTeK driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:3ea0 class ID: 0300
Device-2: NVIDIA GP108M [GeForce MX230] vendor: ASUSTeK driver: nouveau
v: kernel bus ID: 02:00.0 chip ID: 10de:1d11 class ID: 0302
Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus ID: 1-5:3 chip ID: 13d3:56dc class ID: 0e02 serial: <filter>
Display: wayland server: X.org 1.20.10 compositor: gnome-shell driver:
loaded: nouveau note: n/a (using device driver) - try sudo/root
display ID: 0 resolution: <missing: xdpyinfo>
OpenGL: renderer: Mesa Intel UHD Graphics 620 (WHL GT2) v: 4.6 Mesa 20.3.4
direct render: Yes
Device-1: Intel Cannon Point-LP High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci
bus ID: 00:1f.3 chip ID: 8086:9dc8 class ID: 0403
Sound Server: ALSA v: k5.9.16-1-MANJARO
Device-1: Realtek RTL8822BE 802.11a/b/g/n/ac WiFi adapter driver: rtw_8822be
v: N/A modules: rtw88_8822be port: 4000 bus ID: 04:00.0 chip ID: 10ec:b822
class ID: 0280
IF: wlo1 state: down mac: <filter>
IF-ID-1: enp0s20f0u1 state: unknown speed: N/A duplex: N/A mac: <filter>
Device-1: IMC Networks Bluetooth Radio type: USB driver: btusb v: 0.8
bus ID: 1-8:4 chip ID: 13d3:3526 class ID: e001 serial: <filter>
Message: Required tool hciconfig not installed. Check --recommends
Local Storage: total: 476.94 GiB used: 14.64 GiB (3.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW512G8
size: 476.94 GiB block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 rotation: SSD serial: <filter> rev: 002C temp: 29.9 C scheme: GPT
ID-1: / raw size: 199.74 GiB size: 195.6 GiB (97.93%) used: 14.62 GiB (7.5%)
fs: ext4 dev: /dev/nvme0n1p6 maj-min: 259:6
ID-2: /boot/efi raw size: 100 MiB size: 96 MiB (96.00%)
used: 25.2 MiB (26.3%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: 41.0 C mobo: N/A gpu: nouveau temp: 37.0 C
Fan Speeds (RPM): cpu: 1900
Processes: 242 Uptime: 15m wakeups: 24 Memory: 7.63 GiB
used: 2.15 GiB (28.2%) Init: systemd v: 247 Compilers: gcc: 10.2.0
Packages: 1298 pacman: 1291 lib: 381 flatpak: 0 snap: 7 Shell: Zsh v: 5.8
running in: gnome-terminal inxi: 3.3.01
