I have a MS Surface Pro 3 with Debian Bookworm on it. Wifi works fine, and inxi -Fazy shows
Device-1: Marvell 88W8897 [AVASTAR] 802.11ac Wireless vendor: SafeNet
driver: mwifiex_pcie v: 1.0 pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 01:00.0 chip-ID: 11ab:2b38 class-ID: 0200
IF: wlp1s0 state: up mac:
There is space for another distro, so I am trying to check out Manjaro.
The live usb shows no connection available in the network manager.
When I boot to Manjaro, I can run lspci, lsmod, and inxi, but have no easy way to get the info where I can post it. Tried mounting the home partition from Debian, but any files I make are invisible when I go back to Debian.
It looks like most of the results from the above commands are very similar to what I get in Debian. The device is detected, and the same modules are installed
There must be a config file I have to modify to get connected. Any help would be marvellous.
nmcli device show => only shows loopback device
mhwd -l => MHWDCONFIG is invalid
rfkill => no output
rfkill unblock => no ouput
Well, you’re going to need to connect it to the Internet or otherwise get data onto it to fix it. There’s plenty of info on the Internet, but the summary is that the firmware is not installed by default. You need to install the linux-firmware-marvell package to make this Wifi chip work (info from Garuda Linux forums, which is also based on Arch).
As it turns out, I needed linux-firmware-marvell to enable wifi. It is not in the live iso. I downloaded it to an SD card and installed it, but to use it I had to reboot, which put me back in the same position.
Once I installed Manjaro fully, it was easy to add the firmware
sudo mount /dev/sdb /mnt/tmp
sudo pacman -U /mnt/tmp/linux-firmware-marvell...
