$ lsmod | grep -i rtw
rtw88_8821ce 16384 0
rtw88_8821c 77824 1 rtw88_8821ce
rtw88_pci 28672 1 rtw88_8821ce
rtw88_core 200704 2 rtw88_pci,rtw88_8821c
mac80211 1097728 2 rtw88_pci,rtw88_core
cfg80211 978944 2 rtw88_core,mac80211
And WiFi works?
unfortunately NO
Ruling out that there’s a hard switch that disabled the radio (doesn’t seem like it since you’ve used it recently), try to reinstall the following packages and reboot:
pamac reinstall linux510 linux-firmware manjaro-firmware
Your system is still configured to automatically invoke DKMS for that driver upon installation, upgrade, or re-installation of any kernel package.
For some reason, the removal script (from the GitHub instructions) didn’t work.
Try it manually,
sudo dkms remove (modulename) --all
If you want to check current configured ones:
dkms status
removed. dkms status showing none
What do you mean? What did you run?
dkms status
And its removal? (You need to use sudo to remove it)
done.
sudo dkms uninstall --no-depmod -m rtl8821ce -v 1.0.0.r128.gf93db73 --all
-------- Uninstall Beginning --------
Module: rtl8821ce
Version: 1.0.0.r128.gf93db73
Kernel: 5.10.56-1-MANJARO (x86_64)
Status: Before uninstall, this module version was ACTIVE on this kernel.
8821ce.ko.xz:
- Uninstallation
- Deleting from: /usr/lib/modules/5.10.56-1-MANJARO/updates/dkms/
- Original module
- No original module was found for this module on this kernel.
- Use the dkms install command to reinstall any previous module version.
depmod...
DKMS: uninstall completed.
➜ ~ sudo dkms remove --no-depmod -m rtl8821ce -v 1.0.0.r128.gf93db73 --all
Module: rtl8821ce
Status: This module version was INACTIVE for this kernel.
depmod...
Deleting module version: 1.0.0.r128.gf93db73
completely from the DKMS tree.
Done.
This is quite the adventure!
Can you force re-install linux510, linux-firmware, and manjaro-firmware, and then reboot? Hopefully it doesn’t try to rebuild the dkms module for the Realtek driver.
okay i’ll check it
