I’ve been facing this issue for months now: the WiFi in my machine works fine until I try to connect to it. Right after booting the machine does recognize multiple WiFi routers in the area, and I am able to connect to mine. The problem is that after a couple of minutes the connection is closed and I get a wlp5s0 device is not available error. After this, the routers in my area don’t show up anymore in the Networks menu.
I’m running Manjaro in a ThinkPad E490 under KDE, but I should point out that this issue started coming out quite a while ago when I has elementary OS installed in my machine. At that time I noticed that after the connections got close the WiFi would show up as “switched-off by hardware” or something along this lines. After switching to Manjaro KDE started to notify me that “the wlp5s0 device is not available” after the WiFi connection fails.
I digged around a bit and I found a section on the ArchWiki page on Network Manager that mentioned Network Manager has issues with some ThinkPad models due to “WiFi drivers incorrectly reporting a soft-block”. I imagine this is the issue I am facing, but I don’t know how to verify it or what to do about it.
Please read this: How to provide good information
and press the three dots … below your post and press the to give us more information so we can see what’s really going on.
Now we know the symptom of the disease, but we need some more probing to know where the origin lies…
An inxi --admin --verbosity=7 --filter --no-host --width would be the minimum required information for us to be able to help you. (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
Also, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text.
P.S. If you want to notify me that you did provide this information, please this message and I’ll come back and have another look.
Please let me know if you (or anyone else) need any additional information. Sorry for the late reply, I didn’t realize someone had answered the post (I thought I would get a email notification).
I see, thanks for the help! I don’t really fancy playing around with different versions of the kernel, would replacing the WiFi card to something with better Linux support work? Any advice on regards to models?
Unfortunately product recommendation requests are against the rules:
Threads seeking advice about specific computer product recommendations are discouraged.
Such topics, like the technology they discuss, quickly become obsolete and are unlikely to provide any lasting benefit to the wider community.
You are expected to be able to do your own research and draw your own conclusions about which product best suits your individual requirements.
However, Manjaro partners with several hardware vendors. If you’re interested in hardware powered by Manjaro, you are welcome to check out the available options at Manjaro hardware.
but some company that make processors also make WiFi cards and they’re actively supporting not only in Linux but also UEFI firmware as they invented that stuff…
