Wifi gone after update
Hi. I did an update, and now the wifi is gone. I would be very grateful for some help.
  Kernel: 5.10.216-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    root=UUID=f9d2892d-3059-44c4-8c99-7984300d7167 rw quiet apparmor=1
  Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 wm: xfwm4 v: 4.18.0
    with: xfce4-panel tools: light-locker vt: 7 dm: LightDM v: 1.32.0
  Type: Laptop System: Dell product: Inspiron 15-3567 v: N/A
    serial: <superuser required> Chassis: type: 9 serial: <superuser required>
  Mobo: Dell model: 033HWX v: A00 serial: <superuser required> part-nu: 078B
    uuid: <superuser required> UEFI: Dell v: 2.5.1 date: 05/31/2018
  ID-1: BAT0 charge: 26.7 Wh (98.5%) condition: 27.1/41.4 Wh (65.4%)
    volts: 16.4 min: 14.8 model: LGC-LGC2.80 DELL 7PY0D83 type: Li-ion
    serial: <filter> status: discharging
  System RAM: total: 8 GiB available: 7.64 GiB used: 1.41 GiB (18.5%)
  Device-1: DIMM A type: DDR4 detail: synchronous unbuffered (unregistered)
    size: 4 GiB speed: spec: 2400 MT/s actual: 2133 MT/s volts: note: check
    curr: 1 min: 1 max: 1 width (bits): data: 64 total: 64
    manufacturer: 80AD000080AD part-no: HMA851S6CJR6N-UH serial: <filter>
  Device-2: DIMM B type: DDR4 detail: synchronous unbuffered (unregistered)
    size: 4 GiB speed: spec: 2667 MT/s actual: 2133 MT/s volts: note: check
    manufacturer: 859B0000802C part-no: CT4G4SFS6266.C4FJ��� serial: <filter>
  Info: model: Intel Core i3-7020U bits: 64 type: MT MCP arch: Amber/Kaby Lake
    note: check gen: core 7 level: v3 note: check built: 2017
    process: Intel 14nm family: 6 model-id: 0x8E (142) stepping: 9
    microcode: 0xF4
    L3: 3 MiB desc: 1x3 MiB
  Speed (MHz): avg: 1328 high: 1621 min/max: 400/2300 scaling:
    driver: intel_pstate governor: powersave cores: 1: 1149 2: 1127 3: 1621
    4: 1415 bogomips: 18406
    fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs intel_pt
    invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx
    msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs
    pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg
    sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
    vulnerable
    prctl and seccomp
  Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: conditional,
    RSB filling, PBRSB-eIBRS: Not affected
  Device-1: Intel HD Graphics 620 vendor: Dell driver: i915 v: kernel
    arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports: active: eDP-1
    empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:5921 class-ID: 0300
  Device-2: Realtek Integrated Webcam driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:3 chip-ID: 0bda:5689
  Display: x11 server: X.Org v: 21.1.13 compositor: xfwm4 v: 4.18.0 driver:
    X: loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915
    display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
    s-diag: 414mm (16.31")
  Monitor-1: eDP-1 model: BOE Display 0x0674 built: 2016 res: 1366x768
    hz: 60 dpi: 101 gamma: 1.2 chroma: red: x: 0.592 y: 0.349 green: x: 0.329
    y: 0.557 blue: x: 0.153 y: 0.118 white: x: 0.314 y: 0.329
    size: 344x194mm (13.54x7.64") diag: 395mm (15.5") ratio: 16:9
    modes: 1366x768
  API: OpenGL Message: Unable to show GL data. glxinfo is missing.
  Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell driver: snd_hda_intel
    v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3 chip-ID: 8086:9d71
    class-ID: 0403
  API: ALSA v: k5.10.216-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.0.5 status: off tools: pw-cli
  Server-3: PulseAudio v: 17.0 status: active with: 1: pulseaudio-alsa
    type: plugin 2: pulseaudio-jack type: module tools: pacat,pactl,pavucontrol
  Device-1: Intel Wireless 3165 driver: N/A modules: iwlwifi pcie:
    speed: Unknown lanes: 63 link-max: gen: 5 speed: 32 GT/s bus-ID: 01:00.0
    chip-ID: 8086:3165 class-ID: 0280
  Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell
    driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000
    bus-ID: 02:00.0 chip-ID: 10ec:8136 class-ID: 0200
  IF: enp2s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  Device-1: Intel Bluetooth wireless interface driver: btusb v: 0.8 type: USB
    rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-8:5 chip-ID: 8087:0a2a
    class-ID: e001
  Local Storage: total: 223.57 GiB used: 130.95 GiB (58.6%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT240BX500SSD1
    size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 041 scheme: GPT
  Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVD+-RW GU90N rev: A1C3
    dev-links: cdrom
  ID-1: / raw-size: 223.27 GiB size: 218.71 GiB (97.96%)
    used: 130.95 GiB (59.9%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
    uuid: f9d2892d-3059-44c4-8c99-7984300d7167
    used: 304 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
    uuid: C28F-11FE
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 1-2:2 info: SHARKOON GmbH 2.4GHz Wireless rechargeable vertical
    mouse [More&Better] type: mouse driver: hid-generic,usbhid interfaces: 1
    rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 100mA
    chip-ID: 1ea7:0064 class-ID: 0301
  Device-2: 1-5:3 info: Realtek Integrated Webcam type: video
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 0bda:5689 class-ID: 0e02
    serial: <filter>
  Device-3: 1-6:4 info: Realtek RTS5129 Card Reader Controller
    power: 500mA chip-ID: 0bda:0129 class-ID: ff00 serial: <filter>
  Device-4: 1-8:5 info: Intel Bluetooth wireless interface type: bluetooth
    mode: 1.1 power: 100mA chip-ID: 8087:0a2a class-ID: e001
  Hub-2: 2-0:1 info: super-speed hub ports: 6 rev: 3.0
  System Temperatures: cpu: 36.0 C pch: 35.5 C mobo: 35.0 C
  Fan Speeds (rpm): cpu: 0
  Packages: 1368 pm: pacman pkgs: 1362 libs: 440 tools: pamac pm: flatpak
    pkgs: 6
    1: https://mirrors.manjaro.org/repo/stable/$repo/$arch
    2: https://manjaro.kurdy.org/stable/$repo/$arch
    3: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
    4: https://mirror.koddos.net/manjaro/stable/$repo/$arch
    5: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
    6: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
    7: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
    8: https://mirror.funami.tech/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 217
  1: cpu: 200% command: ps pid: 2154 mem: 3.95 MiB (0.0%)
  2: cpu: 17.4% command: chromium pid: 1861 mem: 209.5 MiB (2.6%)
  3: cpu: 16.4% command: chromium pid: 1680 mem: 234.1 MiB (2.9%)
  4: cpu: 13.1% command: chromium pid: 1713 mem: 126.9 MiB (1.6%)
  5: cpu: 10.5% command: Xorg pid: 803 mem: 74.0 MiB (0.9%)
  Memory top: 5 of 217
  1: mem: 272.9 MiB (3.4%) command: /newerversion started-by: dropbox
    pid: 1509 cpu: 6.4%
  2: mem: 234.1 MiB (2.9%) command: chromium pid: 1680 cpu: 16.4%
  3: mem: 209.5 MiB (2.6%) command: chromium pid: 1861 cpu: 17.4%
  4: mem: 126.9 MiB (1.6%) command: chromium pid: 1713 cpu: 13.1%
  5: mem: 101.5 MiB (1.2%) command: chromium pid: 1820 cpu: 0.1%
  Processes: 217 Power: uptime: 3m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 3.05 GiB services: upowerd,xfce4-power-manager
    Init: systemd v: 255 default: graphical tool: systemctl
  Compilers: clang: 17.0.6 gcc: 13.2.1 Shell: Bash v: 5.2.26
    running-in: xfce4-terminal inxi: 3.3.34
quiet possibly related;
Hi @whazzatt,
There is no driver, but the card seems to be recognized:
So it seems the driver is/has been blacklisted. Please provide the output of:
ls -lah /etc/modprobe.d/
Unless you have very compelling reasons - use the latest LTS - currently Linux 6.6
Thanks linux-aarhus. I upgraded the kernel, and the wifi is back.
PS - all I did previously was upgrade the system; I didn’t mess with kernels or anything…
Doing updates is only part of maintaining your system. Not using outdated kernel is another :wink:
See
https://wiki.archlinux.org/title/System_maintenance#
Thanks for the link.
:+1:
This is also important:
Why should we keep track of the kernel updates separately? Especially when it breaks the network connectivity so we can’t easily update?
Because you are in control of your own system. You, and not Manjaro. That is why it’s recommended to have at least the latest LTS version installed. It makes maintenance that much easier.
