Linux-Firmware-20240409.1Addd7dc-1.0 (last update from testing branch)
Can anyone tell me what is the difference between the Linux-Firmware 1. and 2.?
This question because the last one broke my AX200 WiFi and Bluetooth and i have to downgrade to the previous version to have a working wifi and BT.
Thanks for any given information
There are no differences except for the ZST compression of the individual firmware files.
But I had to downgrade the Rev.1.0 and return to the previous one (Rev.1) because WiFi and BT of the Ax200 no longer worked.
Since I repeated the installation more than once on two different PCs I have to think that there is some bugs in the packaging of the Rev. 1.0
I am on a kde Plasma testing branch
The update was runnig without error and the ZSTD 1.5.5-1 is installed.
My Beelink mini-PC is based on an intel i5-8259u cpu and was running well on a 5.10 kernel (the most recent kernel was tested but not working well with BT).
Long story
From the first installation of Manjaro, about two years ago, I faced a problem with BT (at Cold Restart after one night, the BT was not discovered and I have to boot once again or more to activate the BT) the solution was the use of Kernel 5.10, this solves everything, all the other kernels works until I leave the PC off for one night.
The boot log was relevant to the working firmware the 20240409.1addd7dc-1.
I did a Timeshift restore.
To create a log of the new firmware i have to reinstall the update.
You could, however like I mentioned, you can retrieve logs from previous boots. Say you’ve rebooted twice since you did the Timeshift restore, use -b -2:
Sorry for mistake, i discovered now that the logs are recorded in a reverse order.
The most recent is with higher index and that was confusing me.
Here below two logs, one doesn’t detect correctly the wifi.
In any case to achieve a clear log a will update in the next day the system and i will record the logs.
I did not use negative index, so to find the most recent logs i need to increase the index number to 28 and 29.
The 29 did not detect the BT (sorry not wifi)
