When I connect to wifi it connects successfully and shows connected but the internet doesn’t work, I can’t ping anything or use anything with wifi, since I don’t have an ethernet cable and the router is far away I’ve been using the USB tethering feature to get acces to the internet.
But it is getting quite annoying to plug my phone and turn on tethering every time I start up my pc.
Any idea why this is happening?
post formatted output from:
inxi -Fazy
and try changing the dns in system settings to for example: 9.9.9.9
DNS didn’t change anything.
inxi -Fazy
Kernel: 5.17.6-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.17-x86_64
root=UUID=30b18d91-1cc5-4ff4-8bcb-fcd7ed041411 rw quiet apparmor=1
security=apparmor resume=UUID=c26b4703-d438-4462-92cb-3fb4a74d3dc1
udev.log_priority=3
Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.4 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: HP product: HP Laptop 15-da0xxx v: Type1ProductConfigId
Mobo: HP model: 84AA v: 82.52 serial: <superuser required> UEFI: Insyde
v: F.36 date: 02/03/2021
Info: model: Intel Celeron N4000 bits: 64 type: MCP arch: Goldmont Plus
built: 2017 process: Intel 14nm family: 6 model-id: 0x7A (122) stepping: 1
microcode: 0x38
Topology: cpus: 1x cores: 2 smt: <unsupported> cache: L1: 112 KiB
desc: d-2x24 KiB; i-2x32 KiB L2: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 2330 high: 2445 min/max: 800/2600 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 2216 2: 2445
bogomips: 4378
Flags: ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
Device-1: Intel GeminiLake [UHD Graphics 600] vendor: Hewlett-Packard
driver: i915 v: kernel arch: Gen9.5 process: Intel 14nm built: 2016-20
ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:3185
class-ID: 0300
Device-2: Quanta HP TrueVision HD Camera type: USB driver: uvcvideo
bus-ID: 1-5:5 chip-ID: 0408:5362 class-ID: 0e02
Display: x11 server: X.Org v: 21.1.3 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa gpu: i915 display-ID: :0
screens: 1
Screen-1: 0 s-res: 1280x720 s-dpi: 96 s-size: 338x190mm (13.31x7.48")
s-diag: 388mm (15.27")
Monitor-1: eDP-1 model: AU Optronics 0x70ec built: 2017 res: 1280x720
hz: 60 dpi: 95 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1366x768
OpenGL: renderer: Mesa Intel UHD Graphics 600 (GLK 2) v: 4.6 Mesa 22.1.1
direct render: Yes
Device-1: Intel Celeron/Pentium Silver Processor High Definition Audio
vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus-ID: 00:0e.0
chip-ID: 8086:3198 class-ID: 0403
Sound Server-1: ALSA v: k5.17.6-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 16.0 running: yes
Sound Server-4: PipeWire v: 0.3.52 running: yes
vendor: Hewlett-Packard driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 2000 bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtw_8821ce v: N/A pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 1000 bus-ID: 02:00.0 chip-ID: 10ec:c821
class-ID: 0280
IF: wlo1 state: down mac: <filter>
IF-ID-1: enp0s21f0u3 state: unknown speed: -1 duplex: half mac: <filter>
Device-1: Realtek Bluetooth 4.2 Adapter type: USB driver: btusb v: 0.8
bus-ID: 1-4:4 chip-ID: 0bda:b00a class-ID: e001 serial: <filter>
Report: rfkill ID: hci0 rfk-id: 5 state: up address: see --recommends
Local Storage: total: 465.76 GiB used: 195.64 GiB (42.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ01ABF050
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: HDD rpm: 5400 serial: <filter> rev: 4C scheme: GPT
ID-1: / raw-size: 179.49 GiB size: 175.62 GiB (97.84%)
used: 41.38 GiB (23.6%) fs: ext4 dev: /dev/sda8 maj-min: 8:8
ID-2: /boot/efi raw-size: 520 MiB size: 519 MiB (99.80%)
used: 292 KiB (0.1%) fs: vfat dev: /dev/sda6 maj-min: 8:6
Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default)
ID-1: swap-1 type: partition size: 12 GiB used: 147.8 MiB (1.2%)
priority: -2 dev: /dev/sda7 maj-min: 8:7
System Temperatures: cpu: 54.0 C mobo: N/A
Processes: 175 Uptime: 22h 57m wakeups: 5 Memory: 7.58 GiB
used: 3.04 GiB (40.2%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1 Packages: 1560
pacman: 1550 lib: 440 flatpak: 4 snap: 6 Shell: Zsh v: 5.9
running-in: konsole inxi: 3.3.19
do you have the same issue with 5.15/ 5.18 kernels?
Hi @xebeoc ,
I wonder whether you could try to fix your problem with the help of the following post, which aims to:
- disable mac randomization
- Unset IPV6 and choose another frequency channel on your wifi card.
- Look whether your wifi is locked by software or bios, perhaps you have a key binding that allows you to enable or disable wifi on your keyboard.
- At last, the option to use another kernel seems to be good.
‘No wifi visible or can connect to any wifi unless I restart my pc - #6 by man’
Hope it help, regards,
Could be related to power saving settings as well.
Also:
update your system.
The wifi started working again after posting this but it again seems to have stopped working.
I did but nothing changed.
I tried all the kernels I could but nothing seems to have fixed it.
so lets try to install the dkms drivers, but first post output from:
mhwd-kernel -li
mhwd-kernel -li
Currently running: 5.18.5-1-MANJARO (linux518)
* linux419
* linux510
* linux515
* linux517
* linux518
* linux54
Also, I should’ve mentioned that I am dual booting with windows, wifi works fine in windows.
uninstall following kernels:
sudo pacman -R linux419 linux517 linux54
create this file:
sudo nano /etc/modprobe.d/blacklist.conf
inside it put this:
blacklist rtw_8821ce
press ctrl+x
to save the file
install headers for kernels:
sudo pacman -S linux518-headers linux515-headers linux510-headers
install dkms driver:
pamac build rtl8821ce-dkms-git
reboot and test wifi
I did everything, still doesn’t work.
provide output from:
inxi -xn
journalctl -b0 -p5 --no-pager
inxi -xn
vendor: Hewlett-Packard driver: r8169 v: kernel port: 2000 bus-ID: 01:00.0
IF: eno1 state: down mac: f4:39:09:e9:bb:33
vendor: Hewlett-Packard driver: rtw_8821ce v: N/A port: 1000
bus-ID: 02:00.0
IF: wlo1 state: down mac: c2:01:77:36:40:cd
The output is too big to be posted here.
post output from:
cat /etc/modprobe.d/blacklist.conf
and you have there a lot of dumped cores from baloo, so disable it:
go to system settings/search/file search and uncheck everything, click apply
ㅤ
What do you mean?
in the logs you had a lot of dumped cores from baloo , so disable baloo from here:
then reboot, and post logs again from this command:
oh here
Jun 25 15:22:38 xeb10 kernel: Linux version 5.18.6-1-MANJARO (builduser@fv-az39-795) (gcc (GCC) 12.1.0, GNU ld (GNU Binutils) 2.38) #1 SMP PREEMPT_DYNAMIC Wed Jun 22 14:16:20 UTC 2022
Jun 25 15:22:38 xeb10 kernel: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.18-x86_64 root=UUID=30b18d91-1cc5-4ff4-8bcb-fcd7ed041411 rw quiet apparmor=1 security=apparmor resume=UUID=c26b4703-d438-4462-92cb-3fb4a74d3dc1 udev.log_priority=3
Jun 25 15:22:38 xeb10 kernel: Unknown kernel command line parameters "BOOT_IMAGE=/boot/vmlinuz-5.18-x86_64", will be passed to user space.
Jun 25 15:22:38 xeb10 kernel: random: crng init done
Jun 25 15:22:38 xeb10 kernel: x86/cpu: VMX (outside TXT) disabled by BIOS
Jun 25 15:22:38 xeb10 kernel: x86/cpu: SGX disabled by BIOS.
Jun 25 15:22:38 xeb10 kernel: audit: type=2000 audit(1656150742.063:1): state=initialized audit_enabled=0 res=1
Jun 25 15:22:38 xeb10 kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.RP03.PEGP.TDGC], AE_NOT_FOUND (20211217/psargs-330)
Jun 25 15:22:38 xeb10 kernel: ACPI Error: Aborting method \_SB.PCI0.RP03.PC01._ON due to previous error (AE_NOT_FOUND) (20211217/psparse-529)
Jun 25 15:22:38 xeb10 kernel: SCSI subsystem initialized
Jun 25 15:22:38 xeb10 kernel: Expanded resource Reserved due to conflict with PCI Bus 0000:00
Jun 25 15:22:38 xeb10 kernel: VFS: Disk quotas dquot_6.6.0
Jun 25 15:22:38 xeb10 kernel: pnp 00:00: disabling [io 0x164e-0x164f] because it overlaps 0000:00:14.1 BAR 13 [io 0x1000-0x1fff]
Jun 25 15:22:38 xeb10 kernel: Initialise system trusted keyrings
Jun 25 15:22:38 xeb10 kernel: Key type blacklist registered
Jun 25 15:22:38 xeb10 kernel: Key type asymmetric registered
Jun 25 15:22:38 xeb10 kernel: Asymmetric key parser 'x509' registered
Jun 25 15:22:38 xeb10 kernel: Loading compiled-in X.509 certificates
Jun 25 15:22:38 xeb10 kernel: Loaded X.509 cert 'Build time autogenerated kernel key: c8773c1d3b09f152ce0bb40682fe739753842995'
Jun 25 15:22:38 xeb10 kernel: Key type ._fscrypt registered
Jun 25 15:22:38 xeb10 kernel: Key type .fscrypt registered
Jun 25 15:22:38 xeb10 kernel: Key type fscrypt-provisioning registered
Jun 25 15:22:38 xeb10 kernel: scsi 0:0:0:0: Direct-Access ATA TOSHIBA MQ01ABF0 4C PQ: 0 ANSI: 5
Jun 25 15:22:38 xeb10 kernel: sd 0:0:0:0: [sda] 976773168 512-byte logical blocks: (500 GB/466 GiB)
Jun 25 15:22:38 xeb10 kernel: sd 0:0:0:0: [sda] 4096-byte physical blocks
Jun 25 15:22:38 xeb10 kernel: sd 0:0:0:0: [sda] Write Protect is off
Jun 25 15:22:38 xeb10 kernel: sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Jun 25 15:22:38 xeb10 kernel: sd 0:0:0:0: [sda] Attached SCSI disk
Jun 25 15:22:38 xeb10 kernel: sd 0:0:0:0: Attached scsi generic sg0 type 0
Jun 25 15:22:38 xeb10 kernel: audit: type=1400 audit(1656150756.836:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=219 comm="apparmor_parser"
Jun 25 15:22:38 xeb10 kernel: audit: type=1400 audit(1656150756.836:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=219 comm="apparmor_parser"
Jun 25 15:22:38 xeb10 kernel: audit: type=1400 audit(1656150756.863:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=218 comm="apparmor_parser"
Jun 25 15:22:38 xeb10 kernel: v4l2loopback_dc: loading out-of-tree module taints kernel.
Jun 25 15:22:38 xeb10 kernel: v4l2loopback_dc: module verification failed: signature and/or required key missing - tainting kernel
Jun 25 15:22:38 xeb10 kernel: audit: type=1400 audit(1656150757.203:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="samba-bgqd" pid=221 comm="apparmor_parser"
Jun 25 15:22:38 xeb10 kernel: audit: type=1400 audit(1656150757.233:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="php-fpm" pid=220 comm="apparmor_parser"
Jun 25 15:22:38 xeb10 kernel: audit: type=1400 audit(1656150757.450:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="dovecot-script-login" pid=222 comm="apparmor_parser"
Jun 25 15:22:38 xeb10 kernel: audit: type=1400 audit(1656150758.043:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/snapd/snap-confine" pid=223 comm="apparmor_parser"
Jun 25 15:22:38 xeb10 kernel: audit: type=1400 audit(1656150758.046:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/snapd/snap-confine//mount-namespace-capture-helper" pid=223 comm="apparmor_parser"
Jun 25 15:22:38 xeb10 kernel: audit: type=1130 audit(1656150758.300:10): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 25 15:22:55 xeb10 kernel: audit: type=1130 audit(1656150758.433:11): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-sysctl comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 25 15:22:55 xeb10 kernel: wmi_bus wmi_bus-PNP0C14:00: WQBJ data block query control method not found
Jun 25 15:22:55 xeb10 kernel: r8169 0000:01:00.0: can't disable ASPM; OS doesn't have ASPM control
Jun 25 15:22:55 xeb10 kernel: cfg80211: Loading compiled-in X.509 certificates for regulatory database
Jun 25 15:22:55 xeb10 kernel: cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
Jun 25 15:22:55 xeb10 kernel: kauditd_printk_skb: 25 callbacks suppressed
Jun 25 15:22:55 xeb10 kernel: audit: type=1130 audit(1656150765.756:21): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-backlight@backlight:intel_backlight comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 25 15:22:55 xeb10 kernel: ACPI BIOS Error (bug): AE_AML_PACKAGE_LIMIT, Index (0x00000004B) is beyond end of object (length 0x44) (20211217/exoparg2-393)
Jun 25 15:22:55 xeb10 kernel: ACPI Error: Aborting method \_SB.WMID.WHCM due to previous error (AE_AML_PACKAGE_LIMIT) (20211217/psparse-529)
Jun 25 15:22:55 xeb10 kernel: ACPI Error: Aborting method \_SB.WMID.WMAA due to previous error (AE_AML_PACKAGE_LIMIT) (20211217/psparse-529)
Jun 25 15:22:55 xeb10 kernel: audit: type=1130 audit(1656150766.023:22): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 25 15:22:55 xeb10 kernel: audit: type=1130 audit(1656150766.273:23): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-fsck@dev-disk-by\x2duuid-2D67\x2d8608 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 25 15:22:55 xeb10 kernel: audit: type=1130 audit(1656150766.986:24): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-binfmt comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 25 15:22:55 xeb10 kernel: audit: type=1131 audit(1656150771.096:25): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 25 15:22:55 xeb10 kernel: audit: type=1130 audit(1656150775.310:26): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-journal-flush comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 25 15:22:40 xeb10 systemd-udevd[274]: could not read from '/sys/module/pcc_cpufreq/initstate': No such device
Jun 25 15:22:56 xeb10 kernel: audit: type=1130 audit(1656150776.160:27): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-setup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 25 15:22:56 xeb10 kernel: audit: type=1334 audit(1656150776.163:28): prog-id=12 op=LOAD
Jun 25 15:22:56 xeb10 kernel: audit: type=1127 audit(1656150776.276:29): pid=434 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=' comm="systemd-update-utmp" exe="/usr/lib/systemd/systemd-update-utmp" hostname=? addr=? terminal=? res=success'
Jun 25 15:22:56 xeb10 kernel: audit: type=1130 audit(1656150776.353:30): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-update-utmp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 25 15:22:56 xeb10 kernel: audit: type=1130 audit(1656150776.363:31): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timesyncd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 25 15:22:56 xeb10 kernel: audit: type=1130 audit(1656150776.490:32): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=cronie comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 25 15:22:56 xeb10 kernel: audit: type=1334 audit(1656150776.866:33): prog-id=13 op=LOAD
Jun 25 15:22:56 xeb10 kernel: audit: type=1334 audit(1656150776.866:34): prog-id=14 op=LOAD
Jun 25 15:22:56 xeb10 kernel: audit: type=1334 audit(1656150776.866:35): prog-id=15 op=LOAD
Jun 25 15:22:56 xeb10 kernel: audit: type=1130 audit(1656150776.870:36): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=alsa-restore comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 25 15:23:00 xeb10 polkitd[442]: Loading rules from directory /etc/polkit-1/rules.d
Jun 25 15:23:01 xeb10 polkitd[442]: Loading rules from directory /usr/share/polkit-1/rules.d
Jun 25 15:23:01 xeb10 polkitd[442]: Finished loading, compiling and executing 8 rules
Jun 25 15:23:01 xeb10 polkitd[442]: Acquired the name org.freedesktop.PolicyKit1 on the system bus
Jun 25 15:23:01 xeb10 kernel: kauditd_printk_skb: 8 callbacks suppressed
Jun 25 15:23:01 xeb10 kernel: audit: type=1130 audit(1656150781.403:45): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=polkit comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 25 15:23:02 xeb10 kernel: audit: type=1130 audit(1656150781.870:46): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 25 15:23:02 xeb10 kernel: audit: type=1130 audit(1656150781.916:47): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-user-sessions comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 25 15:23:02 xeb10 kernel: audit: type=1130 audit(1656150781.920:48): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=sddm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 25 15:23:05 xeb10 kernel: audit: type=1130 audit(1656150785.020:49): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 25 15:23:05 xeb10 kernel: audit: type=1130 audit(1656150785.276:50): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=cups comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 25 15:23:05 xeb10 kernel: audit: type=1130 audit(1656150785.413:51): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=ModemManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 25 15:23:08 xeb10 kernel: audit: type=1130 audit(1656150787.963:52): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=snapd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 25 15:23:08 xeb10 kernel: audit: type=1334 audit(1656150788.033:53): prog-id=19 op=LOAD
Jun 25 15:23:08 xeb10 kernel: audit: type=1334 audit(1656150788.033:54): prog-id=20 op=LOAD
Jun 25 15:23:08 xeb10 kernel: audit: type=1334 audit(1656150788.033:55): prog-id=21 op=LOAD
Jun 25 15:23:08 xeb10 kernel: audit: type=1130 audit(1656150788.236:56): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 25 15:23:14 xeb10 kernel: audit: type=1100 audit(1656150794.563:57): pid=554 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
Jun 25 15:23:14 xeb10 kernel: audit: type=1101 audit(1656150794.563:58): pid=554 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
Jun 25 15:23:14 xeb10 kernel: audit: type=1103 audit(1656150794.606:59): pid=554 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
Jun 25 15:23:15 xeb10 kernel: audit: type=1130 audit(1656150795.070:60): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@963 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 25 15:23:15 xeb10 kernel: audit: type=1131 audit(1656150795.093:61): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 25 15:23:16 xeb10 kernel: audit: type=1101 audit(1656150795.826:62): pid=556 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="sddm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 25 15:23:16 xeb10 kernel: audit: type=1103 audit(1656150795.826:63): pid=556 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=? acct="sddm" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
Jun 25 15:23:16 xeb10 kernel: audit: type=1006 audit(1656150795.826:64): pid=556 uid=0 subj==unconfined old-auid=4294967295 auid=963 tty=(none) old-ses=4294967295 ses=1 res=1
Jun 25 15:23:16 xeb10 kernel: audit: type=1300 audit(1656150795.826:64): arch=c000003e syscall=1 success=yes exit=3 a0=9 a1=7fffa0d793e0 a2=3 a3=7fffa0d790f5 items=0 ppid=1 pid=556 auid=963 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="(systemd)" exe="/usr/lib/systemd/systemd" subj==unconfined key=(null)
Jun 25 15:23:16 xeb10 kernel: audit: type=1327 audit(1656150795.826:64): proctitle="(systemd)"
Jun 25 15:23:15 xeb10 systemd[556]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8002 service=[systemd-user] terminal=[] user=[sddm] ruser=[<unknown>] rhost=[<unknown>]
Jun 25 15:23:19 xeb10 kernel: kauditd_printk_skb: 1 callbacks suppressed
Jun 25 15:23:19 xeb10 kernel: audit: type=1130 audit(1656150799.663:66): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@963 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 25 15:23:19 xeb10 kernel: audit: type=1105 audit(1656150799.670:67): pid=554 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:session_open grantors=pam_unix,pam_systemd acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=:0 res=success'
Jun 25 15:23:19 xeb10 systemd[556]: xdg-user-dirs-update.service: Main process exited, code=exited, status=1/FAILURE
Jun 25 15:23:19 xeb10 systemd[556]: xdg-user-dirs-update.service: Failed with result 'exit-code'.
Jun 25 15:23:19 xeb10 systemd[556]: Failed to start Update XDG user dir configuration.
Jun 25 15:23:22 xeb10 sddm-greeter[565]: QFont::fromString: Invalid description '(empty)'
Jun 25 15:23:25 xeb10 sddm-greeter[565]: QObject: Cannot create children for a parent that is in a different thread.
(Parent is QGuiApplication(0x7ffd1df948e0), parent's thread is QThread(0x5643c6871010), current thread is QThread(0x5643c6990720)
Jun 25 15:23:25 xeb10 sddm-greeter[565]: QObject::installEventFilter(): Cannot filter events for objects in a different thread.
Jun 25 15:23:28 xeb10 udisksd[575]: udisks daemon version 2.9.4 starting
Jun 25 15:23:29 xeb10 kernel: audit: type=1130 audit(1656150809.770:68): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=udisks2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 25 15:23:29 xeb10 kernel: audit: type=1334 audit(1656150809.826:69): prog-id=22 op=LOAD
Jun 25 15:23:29 xeb10 kernel: audit: type=1334 audit(1656150809.826:70): prog-id=23 op=LOAD
Jun 25 15:23:30 xeb10 udisksd[575]: Acquired the name org.freedesktop.UDisks2 on the system message bus
Jun 25 15:23:30 xeb10 kernel: audit: type=1130 audit(1656150810.326:71): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 25 15:23:32 xeb10 sddm-greeter[565]: file:///usr/share/sddm/themes/breath/components/VirtualKeyboard.qml:11:1: Type InputPanel unavailable
Jun 25 15:23:32 xeb10 sddm-greeter[565]: qrc:/QtQuick/VirtualKeyboard/content/InputPanel.qml:127:5: Type Keyboard unavailable
Jun 25 15:23:32 xeb10 sddm-greeter[565]: qrc:/QtQuick/VirtualKeyboard/content/components/Keyboard.qml:38:1: module "QtQuick.VirtualKeyboard.Plugins" is not installed
Jun 25 15:23:32 xeb10 kernel: audit: type=1131 audit(1656150812.461:72): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 25 15:23:32 xeb10 kernel: audit: type=1334 audit(1656150812.514:73): prog-id=0 op=UNLOAD
Jun 25 15:23:32 xeb10 kernel: audit: type=1334 audit(1656150812.514:74): prog-id=0 op=UNLOAD
Jun 25 15:23:32 xeb10 kernel: audit: type=1334 audit(1656150812.514:75): prog-id=0 op=UNLOAD
Jun 25 15:23:33 xeb10 sddm-greeter[565]: file:///usr/share/sddm/themes/breath/Main.qml:465:13: Unable to assign [undefined] to QUrl
Jun 25 15:23:33 xeb10 sddm-greeter[565]: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.20'
Jun 25 15:23:37 xeb10 kernel: audit: type=1100 audit(1656150817.778:76): pid=595 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock acct="xebeoc" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
Jun 25 15:23:37 xeb10 kernel: audit: type=1101 audit(1656150817.778:77): pid=595 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="xebeoc" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
Jun 25 15:23:37 xeb10 kernel: audit: type=1103 audit(1656150817.778:78): pid=595 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock acct="xebeoc" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
Jun 25 15:23:37 xeb10 kernel: audit: type=1006 audit(1656150817.778:79): pid=595 uid=0 subj==unconfined old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=2 res=1
Jun 25 15:23:37 xeb10 kernel: audit: type=1300 audit(1656150817.778:79): arch=c000003e syscall=1 success=yes exit=4 a0=8 a1=7ffd6272ea00 a2=4 a3=7ffd6272e714 items=0 ppid=509 pid=595 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=2 comm="sddm-helper" exe="/usr/lib/sddm/sddm-helper" subj==unconfined key=(null)
Jun 25 15:23:37 xeb10 kernel: audit: type=1327 audit(1656150817.778:79): proctitle=2F7573722F6C69622F7364646D2F7364646D2D68656C706572002D2D736F636B6574002F746D702F7364646D2D6175746838326564323033622D323532302D343164632D613361312D383765316261386263643536002D2D69640031002D2D7374617274002F7573722F62696E2F7374617274706C61736D612D783131002D2D
Jun 25 15:23:37 xeb10 kernel: audit: type=1130 audit(1656150817.821:80): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 25 15:23:37 xeb10 kernel: audit: type=1101 audit(1656150817.838:81): pid=597 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="xebeoc" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 25 15:23:37 xeb10 kernel: audit: type=1103 audit(1656150817.838:82): pid=597 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=? acct="xebeoc" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
Jun 25 15:23:37 xeb10 kernel: audit: type=1006 audit(1656150817.838:83): pid=597 uid=0 subj==unconfined old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=3 res=1
Jun 25 15:23:37 xeb10 systemd[597]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8002 service=[systemd-user] terminal=[] user=[xebeoc] ruser=[<unknown>] rhost=[<unknown>]
Jun 25 15:23:45 xeb10 kernel: logitech-hidpp-device 0003:046D:4054.0005: Can not get the protocol version.
Jun 25 15:23:45 xeb10 klauncher[645]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
Jun 25 15:23:48 xeb10 kcminit_startup[649]: QDBusConnection: error: could not send signal to service "" path "//home/xebeoc/.kde4/share/config/kdeglobals" interface "org.kde.kconfig.notify" member "ConfigChanged": Invalid object path: //home/xebeoc/.kde4/share/config/kdeglobals
Jun 25 15:23:49 xeb10 kernel: kauditd_printk_skb: 11 callbacks suppressed
Jun 25 15:23:49 xeb10 kernel: audit: type=1131 audit(1656150828.962:93): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@963 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 25 15:23:49 xeb10 kernel: audit: type=1131 audit(1656150828.979:94): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@963 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 25 15:23:48 xeb10 systemd[557]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8004 service=[systemd-user] terminal=[] user=[sddm] ruser=[<unknown>] rhost=[<unknown>]
Jun 25 15:23:51 xeb10 kwin_x11[665]: Warning: Setting a new default format with a different version or profile after the global shared context is created may cause issues with context sharing.
Jun 25 15:23:52 xeb10 kwin_x11[665]: kwin_xkbcommon: XKB: inet:323:58: unrecognized keysym "XF86EmojiPicker"
Jun 25 15:23:52 xeb10 kwin_x11[665]: kwin_xkbcommon: XKB: inet:324:58: unrecognized keysym "XF86Dictate"
Jun 25 15:23:53 xeb10 ksmserver[689]: Qt: Session management error: networkIdsList argument is NULL
Jun 25 15:23:55 xeb10 kwin_x11[665]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 730, resource id: 10485765, major code: 18 (ChangeProperty), minor code: 0
Jun 25 15:23:55 xeb10 polkitd[442]: Registered Authentication Agent for unix-session:2 (system bus name :1.30 [/usr/lib/polkit-kde-authentication-agent-1], object path /org/kde/PolicyKit1/AuthenticationAgent, locale en_US.UTF-8)
Jun 25 15:23:57 xeb10 kernel: audit: type=1130 audit(1656150837.244:95): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=rtkit-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 25 15:23:56 xeb10 plasmashell[699]: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
Jun 25 15:23:56 xeb10 plasmashell[699]: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
Jun 25 15:23:59 xeb10 org_kde_powerdevil[706]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds not supported"
Jun 25 15:24:01 xeb10 org_kde_powerdevil[706]: org.kde.powerdevil: Handle button events action could not check for screen configuration
Jun 25 15:24:01 xeb10 unknown[824]: zeitgeist-datahub.vala:224: Unable to get name "org.gnome.zeitgeist.datahub" on the bus!
Jun 25 15:24:01 xeb10 org_kde_powerdevil[706]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds not supported"
Jun 25 15:24:03 xeb10 kwin_x11[665]: kf.config.core: "\"fsrestore1\" - conversion of \"0,0,0,0\" to QRect failed"
Jun 25 15:24:03 xeb10 kwin_x11[665]: kf.config.core: "\"fsrestore2\" - conversion of \"0,0,0,0\" to QRect failed"
Jun 25 15:24:03 xeb10 kwin_x11[665]: kf.config.core: "\"fsrestore3\" - conversion of \"0,0,0,0\" to QRect failed"
Jun 25 15:24:04 xeb10 kwin_x11[665]: kwin_core: XCB error: 10 (BadAccess), sequence: 797, resource id: 1921, major code: 142 (Composite), minor code: 2 (RedirectSubwindows)
Jun 25 15:24:05 xeb10 kwin_x11[665]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 918, resource id: 20971527, major code: 18 (ChangeProperty), minor code: 0
Jun 25 15:24:05 xeb10 kwin_x11[665]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 934, resource id: 20971528, major code: 18 (ChangeProperty), minor code: 0
Jun 25 15:24:06 xeb10 kernel: ntfs3: Unknown parameter 'windows_names'
Jun 25 15:24:09 xeb10 kernel: ntfs3: Unknown parameter 'windows_names'
Jun 25 15:24:12 xeb10 ntfs-3g[883]: Version 2022.5.17 external FUSE 29
Jun 25 15:24:12 xeb10 udisksd[575]: Mounted /dev/sda4 at /run/media/xebeoc/Games on behalf of uid 1000
Jun 25 15:24:12 xeb10 ntfs-3g[883]: Mounted /dev/sda4 (Read-Write, label "Games", NTFS 3.1)
Jun 25 15:24:12 xeb10 ntfs-3g[883]: Cmdline options: rw,nodev,nosuid,uid=1000,gid=1000,windows_names,uhelper=udisks2
Jun 25 15:24:12 xeb10 ntfs-3g[883]: Mount options: nodev,nosuid,uhelper=udisks2,allow_other,nonempty,relatime,rw,default_permissions,fsname=/dev/sda4,blkdev,blksize=4096
Jun 25 15:24:12 xeb10 ntfs-3g[883]: Global ownership and permissions enforced, configuration type 7
Jun 25 15:24:14 xeb10 kwin_x11[665]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 3107, resource id: 4194350, major code: 18 (ChangeProperty), minor code: 0
Jun 25 15:24:19 xeb10 pulseaudio[745]: stat('/etc/pulse/default.pa.d'): No such file or directory
Jun 25 15:24:19 xeb10 pulseaudio[745]: Could not find org.bluez.BatteryProviderManager1.RegisterBatteryProvider(), is bluetoothd started with experimental features enabled (-E flag)?
Jun 25 15:24:19 xeb10 gnome-keyring-daemon[929]: The Secret Service was already initialized
Jun 25 15:24:19 xeb10 gnome-keyring-d[929]: The Secret Service was already initialized
Jun 25 15:24:19 xeb10 gnome-keyring-daemon[928]: discover_other_daemon: 1
Jun 25 15:24:19 xeb10 ntfs-3g[948]: Version 2022.5.17 external FUSE 29
Jun 25 15:24:19 xeb10 ntfs-3g[948]: Mounted /dev/sda3 (Read-Write, label "", NTFS 3.1)
Jun 25 15:24:19 xeb10 udisksd[575]: Mounted /dev/sda3 at /run/media/xebeoc/548C788E8C786BFC on behalf of uid 1000
Jun 25 15:24:19 xeb10 ntfs-3g[948]: Cmdline options: rw,nodev,nosuid,uid=1000,gid=1000,windows_names,uhelper=udisks2
Jun 25 15:24:19 xeb10 ntfs-3g[948]: Mount options: nodev,nosuid,uhelper=udisks2,allow_other,nonempty,relatime,rw,default_permissions,fsname=/dev/sda3,blkdev,blksize=4096
Jun 25 15:24:19 xeb10 ntfs-3g[948]: Global ownership and permissions enforced, configuration type 7
Jun 25 15:24:21 xeb10 plasmashell[699]: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
Jun 25 15:24:21 xeb10 plasmashell[699]: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
Jun 25 15:24:24 xeb10 plasmashell[699]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
Jun 25 15:24:26 xeb10 xembedsniproxy[701]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 466, resource id: 58720259, major code: 12 (ConfigureWindow), minor code: 0
Jun 25 15:24:26 xeb10 plasmashell[699]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:530:9: QML Label: Binding loop detected for property "height"
Jun 25 15:24:26 xeb10 plasmashell[699]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:495:13: QML Label: Binding loop detected for property "height"
Jun 25 15:24:27 xeb10 plasmashell[699]: Trying to use rootObject before initialization is completed, whilst using setInitializationDelayed. Forcing completion
Jun 25 15:24:27 xeb10 plasmashell[699]: Entry is not valid "org.kde.kontact.desktop" QSharedPointer(0x561f912f9640)
Jun 25 15:24:27 xeb10 plasmashell[699]: Entry is not valid "ktp-contactlist.desktop" QSharedPointer(0x561f913c5bb0)
Jun 25 15:24:27 xeb10 plasmashell[699]: Entry is not valid "org.kde.discover.desktop" QSharedPointer(0x561f912f9690)
Jun 25 15:24:27 xeb10 plasmashell[699]: Entry is not valid "org.kde.kontact.desktop" QSharedPointer(0x561f9134a8f0)
Jun 25 15:24:27 xeb10 plasmashell[699]: Entry is not valid "ktp-contactlist.desktop" QSharedPointer(0x561f913c5980)
Jun 25 15:24:27 xeb10 plasmashell[699]: Entry is not valid "org.kde.discover.desktop" QSharedPointer(0x561f90498b70)
Jun 25 15:24:29 xeb10 kdeconnectd[710]: kdeconnect.core: Could not query capabilities from notifications server
Jun 25 15:24:30 xeb10 plasmashell[699]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:495:13: QML Label: Binding loop detected for property "height"
Jun 25 15:24:30 xeb10 plasmashell[699]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:530:9: QML Label: Binding loop detected for property "height"
Jun 25 15:24:30 xeb10 plasmashell[699]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:552:5: QML Label: Binding loop detected for property "height"
Jun 25 15:24:30 xeb10 plasmashell[699]: file:///usr/share/plasma/plasmoids/org.kde.panel/contents/ui/main.qml:18:1: QML DropArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth"
Jun 25 15:24:32 xeb10 plasmashell[699]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationHeader.qml"
Jun 25 15:24:33 xeb10 plasmashell[699]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/ExpandedRepresentation.qml:165:9: QML HiddenItemsView: Binding loop detected for property "implicitHeight"
Jun 25 15:24:34 xeb10 plasmashell[699]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Jun 25 15:24:34 xeb10 plasmashell[699]: file:///usr/share/plasma/plasmoids/org.kde.plasma.battery/contents/ui/CompactRepresentation.qml:71:17: Unable to assign [undefined] to int
Jun 25 15:24:35 xeb10 plasmashell[699]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Jun 25 15:24:35 xeb10 plasmashell[699]: Qt Quick Layouts: Detected recursive rearrange. Aborting after two iterations.
Jun 25 15:24:38 xeb10 plasmashell[699]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Jun 25 15:24:38 xeb10 plasmashell[699]: Qt Quick Layouts: Detected recursive rearrange. Aborting after two iterations.
Jun 25 15:24:47 xeb10 kstart5[1001]: Omitting both --window and --windowclass arguments is not recommended
Jun 25 15:24:47 xeb10 kwin_x11[665]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 4291, resource id: 71303177, major code: 18 (ChangeProperty), minor code: 0
Jun 25 15:24:49 xeb10 kwin_x11[665]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 4558, resource id: 14680540, major code: 3 (GetWindowAttributes), minor code: 0
Jun 25 15:24:49 xeb10 kwin_x11[665]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 4559, resource id: 14680540, major code: 14 (GetGeometry), minor code: 0
…should be: ctrl+o
- then enter
to confirm - ctrl+x
