theres really nothing there
output from:
systemctl status NetworkManager.service
blacklist rtw88_8821ce
● NetworkManager.service - Network Manager
Loaded: loaded (/usr/lib/systemd/system/NetworkManager.service; enabled; vendor preset: disabled)
Drop-In: /usr/lib/systemd/system/NetworkManager.service.d
└─NetworkManager-ovs.conf
Active: active (running) since Sat 2022-06-25 17:10:50 +0530; 14h ago
Docs: man:NetworkManager(8)
Main PID: 485 (NetworkManager)
Tasks: 3 (limit: 9294)
Memory: 9.1M
CPU: 753ms
CGroup: /system.slice/NetworkManager.service
└─485 /usr/bin/NetworkManager --no-daemon
Jun 26 07:08:53 xeb10 NetworkManager[485]: <info> [1656207533.4447] dhcp4 (enp0s21f0u3): activation: beginning transaction (timeout in 45 seconds)
Jun 26 07:08:53 xeb10 NetworkManager[485]: <info> [1656207533.5618] dhcp4 (enp0s21f0u3): state changed new lease, address=192.168.142.155
Jun 26 07:08:53 xeb10 NetworkManager[485]: <info> [1656207533.5636] device (enp0s21f0u3): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
Jun 26 07:08:53 xeb10 NetworkManager[485]: <info> [1656207533.6612] device (enp0s21f0u3): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
Jun 26 07:08:53 xeb10 NetworkManager[485]: <info> [1656207533.6615] device (enp0s21f0u3): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
Jun 26 07:08:53 xeb10 NetworkManager[485]: <info> [1656207533.6620] manager: NetworkManager state is now CONNECTED_LOCAL
Jun 26 07:08:53 xeb10 NetworkManager[485]: <info> [1656207533.6623] manager: NetworkManager state is now CONNECTED_SITE
Jun 26 07:08:53 xeb10 NetworkManager[485]: <info> [1656207533.6625] policy: set 'xebeoc' (enp0s21f0u3) as default for IPv4 routing and DNS
Jun 26 07:08:53 xeb10 NetworkManager[485]: <info> [1656207533.7409] device (enp0s21f0u3): Activation: successful, device activated.
Jun 26 07:08:53 xeb10 NetworkManager[485]: <info> [1656207533.7415] manager: NetworkManager state is now CONNECTED_GLOBAL
ok added that to /etc/modprobe.d/blacklist.conf
everything looks good in the status output…
output from:
dmesg | grep 8821
lspci -k | grep 8821
Looks like this fixed it after a reboot, thanks. I’m not sure if it will happen again but for now, I will mark it as the solution.
