Hi i try to refresh my old macbook with manajro.
Unfortunately, i can not connect to a wifi. Tried several things i found in the forum but nothing helped.
Bcm4322
Would be great if someone can guide me through:
I am new to Linux at all .
In addition i have random freezes.
Thanks for your Support
Welcome to Manjaro! ![]()
- Please read this:
[HowTo] Provide System Information
and press the three dots … below your post and press the
to give us more information so we can see what’s really going on.
Now we know the symptom of the disease, but we need some more probing to know where the origin lies…
- An
inxi --admin --verbosity=7 --filter --no-host --widthwould be the minimum required information for us to be able to help you. (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
Also, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text.
:+1
Here is what is going on ![]()
Kernel: 5.15.19-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=3f502e1f-b4ab-4a4e-9a7c-8d8751a1ea90 rw quiet apparmor=1
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel, plank
wm: xfwm 4.16.1 vt: 7 dm: LightDM 1.30.0 Distro: Manjaro Linux
base: Arch Linux
Type: Laptop System: Apple product: MacBookPro7,1 v: 1.0
serial: <superuser required> Chassis: type: 10 v: Mac-F222BEC8
Mobo: Apple model: Mac-F222BEC8 serial: <superuser required> UEFI: Apple
v: MBP71.88Z.0039.B0E.1111071400 date: 11/07/11
ID-1: BAT0 charge: 49.2 Wh (97.8%) condition: 50.3/62.9 Wh (80.0%)
volts: 12.6 min: 10.9 model: SMP bq20z451 type: Li-ion serial: N/A
status: Charging cycles: 345
RAM: total: 3.58 GiB used: 1.3 GiB (36.2%)
RAM Report:
Info: model: Intel Core2 Duo P8600 bits: 64 type: MCP arch: Core Penryn
family: 6 model-id: 0x17 (23) stepping: 0xA (10) microcode: 0xA0B
Topology: cpus: 1x cores: 2 smt: <unsupported> cache: L1: 128 KiB
desc: d-2x32 KiB; i-2x32 KiB L2: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1277 high: 1593 min/max: 798/2394 scaling:
driver: acpi-cpufreq governor: schedutil cores: 1: 962 2: 1593
bogomips: 9560
Flags: acpi aperfmperf apic arch_perfmon bts clflush cmov constant_tsc
cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts est flexpriority fpu fxsr ht
lahf_lm lm mca mce mmx monitor msr mtrr nopl nx pae pat pbe pdcm pebs pge
pni pse pse36 pti rep_good sep smx sse sse2 sse4_1 ssse3 syscall tm tm2
tpr_shadow tsc vme vmx vnmi vpid xsave xtpr
Type: l1tf mitigation: PTE Inversion; VMX: EPT disabled
Type: mds
status: Vulnerable: Clear CPU buffers attempted, no microcode; SMT disabled
Type: spectre_v2
mitigation: Full generic retpoline, STIBP: disabled, RSB filling
Device-1: NVIDIA MCP89 [GeForce 320M] vendor: Apple driver: nouveau
v: kernel bus-ID: 04:00.0 chip-ID: 10de:08a0 class-ID: 0300
Device-2: Apple Built-in iSight type: USB driver: uvcvideo bus-ID: 1-6:2
chip-ID: 05ac:8507 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.21.1.3 compositor: xfwm4 v: 4.16.1 driver:
loaded: modesetting alternate: fbdev,vesa display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1280x800 s-dpi: 96 s-size: 338x211mm (13.3x8.3")
s-diag: 398mm (15.7")
Monitor-1: LVDS-1 res: 1280x800 hz: 60 dpi: 114
size: 286x179mm (11.3x7.0") diag: 337mm (13.3")
Device-1: NVIDIA MCP89 High Definition Audio driver: snd_hda_intel v: kernel
bus-ID: 00:08.0 chip-ID: 10de:0d94 class-ID: 0403
Sound Server-1: ALSA v: k5.15.19-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.45 running: no
Device-1: Broadcom BCM4322 802.11a/b/g/n Wireless LAN
vendor: Apple AirPort Extreme driver: N/A modules: ssb bus-ID: 02:00.0
chip-ID: 14e4:432b class-ID: 0280
Device-2: Broadcom NetXtreme BCM5764M Gigabit Ethernet PCIe driver: tg3
v: kernel port: N/A bus-ID: 03:00.0 chip-ID: 14e4:1684 class-ID: 0200
Device-1: Apple Bluetooth Host Controller type: USB driver: btusb v: 0.8
bus-ID: 4-6.1:5 chip-ID: 05ac:8213 class-ID: fe01 serial: <filter>
Local Storage: total: 298.09 GiB used: 11.28 GiB (3.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Hitachi model: HTS545032B9SA02
size: 298.09 GiB block-size: physical: 512 B logical: 512 B speed: 1.5 Gb/s
type: HDD rpm: 5400 serial: <filter> rev: C60W scheme: GPT
Optical-1: /dev/sr0 vendor: MATSHITA model: DVD-R UJ-898 rev: HC10
dev-links: cdrom
rw: cd-r,cd-rw,dvd-r state: running
ID-1: / raw-size: 297.79 GiB size: 292.06 GiB (98.07%)
used: 11.28 GiB (3.9%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 3f502e1f-b4ab-4a4e-9a7c-8d8751a1ea90
used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
uuid: 3D90-6067
Hub-1: 1-0:1 info: Full speed or root hub ports: 6 rev: 2.0 speed: 480 Mb/s
Device-1: 1-6:2 info: Apple Built-in iSight type: Video driver: uvcvideo
interfaces: 3 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 05ac:8507
Hub-2: 2-0:1 info: Full speed or root hub ports: 6 rev: 2.0
Device-1: 2-1:2 info: Apple Internal Memory Card Reader type: Mass Storage
driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA
chip-ID: 05ac:8403 class-ID: 0806 serial: <filter>
Hub-3: 3-0:1 info: Full speed or root hub ports: 6 rev: 1.1 speed: 12 Mb/s
chip-ID: 1d6b:0001 class-ID: 0900
Hub-4: 4-0:1 info: Full speed or root hub ports: 6 rev: 1.1 speed: 12 Mb/s
Device-1: 4-3:2 info: Apple Internal Keyboard/Trackpad (ISO)
type: Keyboard,HID,Mouse driver: apple,bcm5974,usbhid interfaces: 3 rev: 2.0
speed: 12 Mb/s power: 40mA chip-ID: 05ac:0237 class-ID: 0301
Device-2: 4-5:3 info: Apple Built-in IR Receiver type: HID
driver: appleir,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s power: 100mA
chip-ID: 05ac:8242 class-ID: 0300
Hub-5: 4-6:4
info: Broadcom BCM2046B1 USB 2.0 Hub (part of BCM2046 Bluetooth) ports: 3
rev: 2.0 speed: 12 Mb/s chip-ID: 0a5c:4500 class-ID: 0900
Device-1: 4-6.1:5 info: Apple Bluetooth Host Controller type: Bluetooth
driver: btusb interfaces: 4 rev: 2.0 speed: 12 Mb/s chip-ID: 05ac:8213
System Temperatures: cpu: 69.0 C mobo: N/A gpu: nouveau temp: 75.0 C
Processes: 164 Uptime: 3m wakeups: 2 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1123 lib: 317
flatpak: 0 Shell: Bash v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.12
can you give me a hint how to install the brcm80211 driver within the terminal
you can install it from pamac in the graphical packet manager. search for broadcom-wl and you’ll see all packets. please ask before you install the wrong packet
Ok i found about 14 entrys installed is:
Linux515-Broadcom WL
Linux54-Broadcom WL
Sorry but cannot match them to what is written in the Arch Linux forum
yes because time goes by. I’m not sure if it’s the one but you can give it a try. if not you can uninstall it.
Sorry did not get your point - the two i listed are already installed with no succses → So the way forward is to try others ?
you can search with ‘sudo pacman -Ss Bcm43’ for all related packages that includes broadcom bcm43 drivers
Ok this is what came out - unfortunally not BCM4322 listed
extra/linux414-broadcom-wl 6.30.223.271-238 (linux414-extramodules)
Broadcom 802.11 Linux STA wireless driver BCM43142.
extra/linux419-broadcom-wl 6.30.223.271-220 (linux419-extramodules)
extra/linux44-broadcom-wl 6.30.223.271-204 (linux44-extramodules)
extra/linux49-broadcom-wl 6.30.223.271-245 (linux49-extramodules)
extra/linux510-broadcom-wl 6.30.223.271-116 (linux510-extramodules)
extra/linux515-broadcom-wl 6.30.223.271-28 (linux515-extramodules) [Installiert]
extra/linux516-broadcom-wl 6.30.223.271-8 (linux516-extramodules)
extra/linux54-broadcom-wl 6.30.223.271-188 (linux54-extramodules) [Installiert]
community/linux515-rt-broadcom-wl 6.30.223.271-14 (linux515-rt-extramodules)
community/linux516-rt-broadcom-wl 6.30.223.271-3 (linux516-rt-extramodules)
for sure, because this apple-pie was never designed to be supported from third-party.
there is a ‘broadcom-wl-dkms’ package and from what i can read this was used by a lot of apple-users to bring wifi up. give this a try
fingers crossed
Ok sorry for the maby stupid question…
Where is the wifi menu and how do i connect to wifi
is the driver installed ? please post ’ inxi --admin --verbosity=7 --filter --no-host --width’ again and there should be a driver assigned at the wifi chip
Kernel: 5.15.21-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
base: Arch Linux
ID-1: BAT0 charge: 50.3 Wh (100.0%) condition: 50.3/62.9 Wh (80.0%)
volts: 12.5 min: 10.9 model: SMP bq20z451 type: Li-ion serial: N/A
status: Full cycles: 345
RAM: total: 3.58 GiB used: 1.47 GiB (41.2%)
RAM Report:
Speed (MHz): avg: 934 high: 1073 min/max: 798/2394 scaling:
driver: acpi-cpufreq governor: schedutil cores: 1: 796 2: 1073
bogomips: 9560
Type: mds
Type: spectre_v2
Sound Server-1: ALSA v: k5.15.21-1-MANJARO running: yes
vendor: Apple AirPort Extreme driver: wl v: kernel modules: ssb
bus-ID: 02:00.0 chip-ID: 14e4:432b class-ID: 0280
IF: wlp2s0 state: dormant mac: <filter>
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 298.09 GiB used: 12.16 GiB (4.1%)
dev-links: cdrom
used: 12.16 GiB (4.2%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 3D90-6067
Hub-5: 4-6:4
System Temperatures: cpu: 66.0 C mobo: N/A gpu: nouveau temp: 73.0 C
Processes: 173 Uptime: 16m wakeups: 2 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.1.0 clang: 13.0.1 Packages: pacman: 1124 lib: 317
the package is installed
in fact.
Before:
After:
The driver is installed, little success. that’s half of the prize. hopefully others can join that do have also some ideas. there was something in the network.conf file about mac-scan. i have to dig but maybe you can also check the forum-site help function.
please post the output of ‘rfkill’ that we can see.
ID TYPE DEVICE SOFT HARD
0 wlan phy0 entsperrt entsperrt
1 bluetooth hci0 gesperrt entsperrt
let’s check ‘ip link’ and ‘hwinfo --wlan’ if it’s ready to run.
ip link
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
2: enp3s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP mode DEFAULT group default qlen 1000
link/ether c8:bc:c8:8f:21:df brd ff:ff:ff:ff:ff:ff
3: wlp2s0: <NO-CARRIER,BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state DORMANT mode DORMANT group default qlen 1000
link/ether ca:29:df:d6:13:10 brd ff:ff:ff:ff:ff:ff permaddr 78:ca:39:ba:50:cf
hwinfo --wlan
07: PCI 200.0: 0282 WLAN controller
[Created at pci.386]
Unique ID: qru8.lC3SUoZ2SN7
Parent ID: Rgik.xeK6vjrqlrC
SysFS ID: /devices/pci0000:00/0000:00:15.0/0000:02:00.0
SysFS BusID: 0000:02:00.0
Hardware Class: network
Model: "Apple AirPort Extreme"
Vendor: pci 0x14e4 "Broadcom"
Device: pci 0x432b "BCM4322 802.11a/b/g/n Wireless LAN Controller"
SubVendor: pci 0x106b "Apple Inc."
SubDevice: pci 0x008d "AirPort Extreme"
Revision: 0x01
Driver: "wl"
Driver Modules: "wl"
Device File: wlp2s0
Features: WLAN
Memory Range: 0xd3200000-0xd3203fff (rw,non-prefetchable)
IRQ: 17 (no events)
HW Address: e6:7a:61:a4:b7:fc
Permanent HW Address: 78:ca:39:ba:50:cf
Link detected: yes
WLAN channels: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 32 34 36 38 40 42 44 46 48 50 52 54 56 58 60 62 64 66
WLAN frequencies: 2.412 2.417 2.422 2.427 2.432 2.437 2.442 2.447 2.452 2.457 2.462 2.467 2.472 2.484 5.16 5.17 5.18 5.19 5.2 5.21 5.22 5.23 5.24 5.25 5.26 5.27 5.28 5.29 5.3 5.31 5.32 5.33
WLAN encryption modes: WEP40 WEP104 TKIP CCMP
WLAN authentication modes: open sharedkey wpa-psk wpa-eap
Module Alias: "pci:v000014E4d0000432Bsv0000106Bsd0000008Dbc02sc80i00"
Driver Info #0:
Driver Status: ssb is not active
Driver Activation Cmd: "modprobe ssb"
Driver Info #1:
Driver Status: wl is active
Driver Activation Cmd: "modprobe wl"
Config Status: cfg=new, avail=yes, need=no, active=unknown
Attached to: #18 (PCI bridge)
