Wifi consuming half of my battery
I tried using my laptop without networking enabled and i have got twice as much battery life.
I mean i have only 2x25wh battery, that is about 2-3 hour but without wifi it was 4-6 hours. (according to powertop)
It not seems like that drastic, but sometimes it consumes 4-5watts.
I would like to upload the powertop html file.
[i3hunor@HunorT480 ~]$ inxi --admin --verbosity=7 --filter --no-host --width
  Kernel: 5.15.21-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
    root=UUID=cc7be21e-d9d4-4881-841a-b047d2a1253a rw quiet
    udev.log_priority=3
  Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: i3 4.20.1 vt: 7
  Type: Laptop System: LENOVO product: 20L6S1LV2F v: ThinkPad T480
  Mobo: LENOVO model: 20L6S1LV2F v: SDK0J40697 WIN
    serial: <superuser required> UEFI: LENOVO v: N24ET67W (1.42 )
    date: 11/17/2021
  ID-1: BAT0 charge: 14.4 Wh (77.4%) condition: 18.6/23.9 Wh (77.6%)
    volts: 11.7 min: 11.4 model: LGC 01AV489 type: Li-poly serial: <filter>
    status: Not charging cycles: 76
  ID-2: BAT1 charge: 18.2 Wh (84.7%) condition: 21.5/24.0 Wh (89.5%)
    volts: 12.4 min: 11.5 model: SMP 01AV452 type: Li-poly serial: <filter>
    status: Not charging cycles: 195
  RAM: total: 7.51 GiB used: 3.16 GiB (42.1%)
  RAM Report:
  Info: model: Intel Core i5-8350U bits: 64 type: MT MCP arch: Coffee Lake
    family: 6 model-id: 0x8E (142) stepping: 0xA (10) microcode: 0xEC
    L3: 6 MiB desc: 1x6 MiB
  Speed (MHz): avg: 1691 high: 1700 min/max: 400/3600 scaling:
    driver: intel_pstate governor: performance cores: 1: 1691 2: 1680 3: 1700
    4: 1683 5: 1681 6: 1700 7: 1700 8: 1700 bogomips: 30409
    arch_capabilities arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt
    cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts
    epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr
    ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid
    invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
    nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln
    pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg sep sgx
    smap smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
  Type: l1tf
  Device-1: Intel UHD Graphics 620 vendor: Lenovo driver: i915 v: kernel
    bus-ID: 00:02.0 chip-ID: 8086:5917 class-ID: 0300
  Device-2: Chicony Integrated Camera (1280x720@30) type: USB
    driver: uvcvideo bus-ID: 1-8:3 chip-ID: 04f2:b604 class-ID: 0e02
    serial: <filter>
  Display: x11 server: X.Org 1.21.1.3 driver: loaded: modesetting
    alternate: fbdev,vesa display-ID: :0.0 screens: 1
    s-diag: 582mm (22.9")
  Monitor-1: eDP-1 res: 1920x1080 dpi: 158 size: 309x174mm (12.2x6.9")
    diag: 355mm (14")
  Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo ThinkPad T480
    driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3
    chip-ID: 8086:9d71 class-ID: 0403
  Sound Server-1: ALSA v: k5.15.21-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.45 running: no
  Device-1: Intel Ethernet I219-LM vendor: Lenovo driver: e1000e v: kernel
    port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15d7 class-ID: 0200
  IF: enp0s31f6 state: down mac: <filter>
  Device-2: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel
    bus-ID: 03:00.0 chip-ID: 8086:24fd class-ID: 0280
  Local Storage: total: 238.47 GiB used: 48.29 GiB (20.3%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKKF256G8L
    size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 type: SSD serial: <filter> rev: L15P temp: 30.9 C scheme: GPT
  ID-1: / raw-size: 118.93 GiB size: 116.5 GiB (97.96%)
    used: 48.27 GiB (41.4%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
    label: N/A uuid: cc7be21e-d9d4-4881-841a-b047d2a1253a
    used: 25.3 MiB (26.3%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
    label: N/A uuid: 2EAD-1B08
  ID-1: swap-1 type: file size: 8 GiB used: 0 KiB (0.0%) priority: -2
    file: /swapfile
  ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 118.93 GiB fs: ntfs label: N/A
    uuid: 3648B0CC48B08C5D
  ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 509 MiB fs: ntfs label: N/A
    uuid: 1804C52004C5022C
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 1-8:3 info: Chicony Integrated Camera (1280x720@30) type: Video
    chip-ID: 04f2:b604 class-ID: 0e02 serial: <filter>
  Device-2: 1-9:4 info: Synaptics Metallica MIS Touch Fingerprint Reader
    type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s
    power: 100mA chip-ID: 06cb:009a class-ID: ff00 serial: <filter>
  Hub-2: 2-0:1 info: Super-speed hub ports: 6 rev: 3.0 speed: 5 Gb/s
  Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-4: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 56.0 C pch: 51.5 C mobo: N/A
  Processes: 238 Uptime: 38m wakeups: 9 Init: systemd v: 250 tool: systemctl
  Compilers: gcc: 11.1.0 clang: 13.0.1 Packages: pacman: 1207 lib: 327
  Shell: Bash v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.12
please, this is nothing we can deal with, the minimum should be the information linked below.
:+1: Welcome to Manjaro! :+1:
  1. Please read this:
    [HowTo] Provide System Information
    and press the three dots … below your post and press the :pencil2: to give us more information so we can see what’s really going on.
    Now we know the symptom of the disease, but we need some more probing to know where the origin lies… :grin:
  2. An inxi --admin --verbosity=7 --filter --no-host --width would be the minimum required information for us to be able to help you. (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
    Also, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text.
:+1:
please read this first
https://wiki.archlinux.org/title/Lenovo_ThinkPad_T480
Ive got different output for lsusb and lspci.
My outout:
[i3hunor@HunorT480 ~]$ lspci
00:00.0 Host bridge: Intel Corporation Xeon E3-1200 v6/7th Gen Core Processor Host Bridge/DRAM Registers (rev 08)
00:02.0 VGA compatible controller: Intel Corporation UHD Graphics 620 (rev 07)
00:04.0 Signal processing controller: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Thermal Subsystem (rev 08)
00:08.0 System peripheral: Intel Corporation Xeon E3-1200 v5/v6 / E3-1500 v5 / 6th/7th/8th Gen Core Processor Gaussian Mixture Model
00:14.0 USB controller: Intel Corporation Sunrise Point-LP USB 3.0 xHCI Controller (rev 21)
00:14.2 Signal processing controller: Intel Corporation Sunrise Point-LP Thermal subsystem (rev 21)
00:16.0 Communication controller: Intel Corporation Sunrise Point-LP CSME HECI #1 (rev 21)
00:16.3 Serial controller: Intel Corporation Sunrise Point-LP Active Management Technology - SOL (rev 21)
00:1c.0 PCI bridge: Intel Corporation Sunrise Point-LP PCI Express Root Port #1 (rev f1)
00:1c.6 PCI bridge: Intel Corporation Sunrise Point-LP PCI Express Root Port #7 (rev f1)
00:1d.0 PCI bridge: Intel Corporation Sunrise Point-LP PCI Express Root Port #9 (rev f1)
00:1d.2 PCI bridge: Intel Corporation Sunrise Point-LP PCI Express Root Port #11 (rev f1)
00:1f.0 ISA bridge: Intel Corporation Sunrise Point LPC Controller/eSPI Controller (rev 21)
00:1f.2 Memory controller: Intel Corporation Sunrise Point-LP PMC (rev 21)
00:1f.3 Audio device: Intel Corporation Sunrise Point-LP HD Audio (rev 21)
00:1f.4 SMBus: Intel Corporation Sunrise Point-LP SMBus (rev 21)
00:1f.6 Ethernet controller: Intel Corporation Ethernet Connection (4) I219-LM (rev 21)
03:00.0 Network controller: Intel Corporation Wireless 8265 / 8275 (rev 78)
04:00.0 PCI bridge: Intel Corporation JHL6240 Thunderbolt 3 Bridge (Low Power) [Alpine Ridge LP 2016] (rev 01)
05:00.0 PCI bridge: Intel Corporation JHL6240 Thunderbolt 3 Bridge (Low Power) [Alpine Ridge LP 2016] (rev 01)
05:01.0 PCI bridge: Intel Corporation JHL6240 Thunderbolt 3 Bridge (Low Power) [Alpine Ridge LP 2016] (rev 01)
05:02.0 PCI bridge: Intel Corporation JHL6240 Thunderbolt 3 Bridge (Low Power) [Alpine Ridge LP 2016] (rev 01)
06:00.0 System peripheral: Intel Corporation JHL6240 Thunderbolt 3 NHI (Low Power) [Alpine Ridge LP 2016] (rev 01)
3c:00.0 USB controller: Intel Corporation JHL6240 Thunderbolt 3 USB 3.1 Controller (Low Power) [Alpine Ridge LP 2016] (rev 01)
3d:00.0 Non-Volatile memory controller: Intel Corporation SSD Pro 7600p/760p/E 6100p Series (rev 03)
[i3hunor@HunorT480 ~]$ lsusb
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 004: ID 06cb:009a Synaptics, Inc. Metallica MIS Touch Fingerprint Reader
Bus 001 Device 003: ID 04f2:b604 Chicony Electronics Co., Ltd Integrated Camera (1280x720@30)
Is that bad?
no, why ? the lspci command will display all devices that are internal soldered at the mainboard, whereas the lsusb command displays all external devices that are connected to the usb-bus.
may you post the output of
lsmod | grep '^iwl.vm'
that should also display what power-scheme is used for your wifi
I tought that these commands do these, but the i dont understand why you send the arch forum page to me. I haven’t found anything that could be helpful.
Or am i looking somewhere else?
[i3hunor@HunorT480 ~]$ lsmod | grep '^iwl.vm'
iwlmvm                503808  0
manjaro is arch-related. everything that’s valid for arch in general is also valid for manjaro (at least it should)
Yeah, i know that.
But i haven’t found anything useful
your e1000e adapter is well supported. you can play with some settings of the power consumption of the wifi-adapter but be aware, the efficiency will drop down, latency will rise etc…
a peak of 4-5 Watts shouldn’t be that high. several settings will cause the wifi to get faster to standby,suspend but it will affect the response in negative.
https://wiki.archlinux.org/title/Power_management#Network_interfaces
