i cant connect to a wifi using EDUP wifi adapter can someone help
You might need rtl88x2bu
Thatβs actually for a Realtek WiFi; the OP is using an EDUP WiFi Adapter.
(the βrtlβ part of the driver name usually infers Realtek). Cheers.
i do that but i cant switch to the wifi adapter can you help me with that i try to kill the prossse using
airmon-ng check kill
sudo airmon-ng start wlan0
but i get wlan0 not exist in the output
you are likely following a kali linux tutorial and wifi is named differently on Manjaro
show us please the output - in text format - no screenshot - from
ip link
and
ip a
and
lsusb
lsusb:
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 004: ID 05ac:850a Apple, Inc. FaceTime Camera
Bus 001 Device 005: ID 0bda:a192 Realtek Semiconductor Corp. DISK
Bus 003 Device 006: ID 05ac:821b Apple, Inc. Bluetooth USB Host Controller
Bus 003 Device 003: ID 0a5c:4500 Broadcom Corp. BCM2046B1 USB 2.0 Hub (part of BCM2046 Bluetooth)
Bus 003 Device 002: ID 05ac:0242 Apple, Inc. Internal Keyboard/Trackpad (ANSI)
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Please, help others to help you. These tutorials should help:
Which Manjaro are you using?
You are using apple hardware judging from the output and your wiif is likely a broadcom device.
Please educate yourself Mac - ArchWiki
neofetch
β ββββββββ OS: Manjaro Linux x86_64
ββββββββββββββββββ ββββββββ Host: MacBookAir3,1 1.0
ββββββββ ββββββββ Kernel: 6.1.55-1-MANJARO
ββββββββ ββββββββ ββββββββ Uptime: 23 mins
ββββββββ ββββββββ ββββββββ Packages: 973 (pacman)
ββββββββ ββββββββ ββββββββ Shell: bash 5.1.16
ββββββββ ββββββββ ββββββββ Resolution: 1366x768
ββββββββ ββββββββ ββββββββ WM: i3
ββββββββ ββββββββ ββββββββ Theme: Adapta-Nokto-Eta-Maia [GTK2/3]
ββββββββ ββββββββ ββββββββ Icons: Papirus-Adapta-Nokto-Maia [GTK2/3]
ββββββββ ββββββββ ββββββββ Terminal: urxvt
ββββββββ ββββββββ ββββββββ Terminal Font: 9x15,xft
CPU: Intel Core 2 Duo U9600 (2) @ 1.600GHz
GPU: NVIDIA GeForce 320M
Memory: 1140MiB / 3662MiB
This is the only useful information from Neofetch.
Please provide information as mentioned in those links, and good luck. Frankly, I donβt think I have the patience today. Cheers.
Your devices is up and driver loaded - what is the problem?
You could expand by providing data requested from ip - more specifically
ip a
To me it appears the wifi adapter is working just fine.
What is the problem?
i cant switch to the the wifi dapter and i think it not detected
It obviously is detected.
How are you trying to switch to the adapter?
Is your firewall blocking it from connecting?
You are not making any sense. Your wifi works fine
What are you trying to do?
EXCEPT if thatβs not the device you plugged in, in which case itβs not even detected, so likely a hardware problem.
sorry about my english i just want to switch to the wifi adapter cause internet connection so slow and i think from the network card
Cable is generally faster than wireless. Not to mention more reliable. Which is why I use a cable myself.
So if you are getting problems with the cable, I doubt wireless will fix it.
This is entirely different from βWifi adapter not workingβ β You have wasted a lot of time, when you could have simply asked βWhy is my Internet so slow?β
The answer to that is, I donβt know. Perhaps itβs your ISP; or, perhaps you expected Wifi to be faster than it is; it isnβt.
So you are really asking about a second wifi adapter connected using usb?
The adapter is not recognized as an USB device?
Remove the device and run
lsusb
Insert the device and run
lsusb
What is the difference - if any?
If no difference then adapter is not functional.
