For some reason my usb wifi adapter only works on kernels that have the Real-Time tag on it, and I can’t figure out as of why.
Kernel: 5.18.0-1-rt11-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.18-rt-x86_64
root=UUID=110cd987-b31a-4a31-ae97-aaecf9d32a23 rw quiet
cryptdevice=UUID=a60aab6e-e721-4172-a18c-60acb874d6ed:luks-a60aab6e-e721-4172-a18c-60acb874d6ed
root=/dev/mapper/luks-a60aab6e-e721-4172-a18c-60acb874d6ed apparmor=1
Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.4 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: ASRock model: B250M Performance
serial: <superuser required> UEFI: American Megatrends v: P2.30
date: 02/23/2018
Device-1: ps-controller-battery-48:18:8d:69:d2:68 model: N/A serial: N/A
charge: N/A status: discharging
RAM: total: 15.59 GiB used: 4.83 GiB (31.0%)
RAM Report:
Info: model: Intel Core i7-6700K bits: 64 type: MT MCP arch: Skylake-S
gen: core 6 built: 2015 process: Intel 14nm family: 6 model-id: 0x5E (94)
stepping: 3 microcode: 0xF0
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 800 min/max: 800/4200 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
8: 800 bogomips: 63999
arch_capabilities arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt
cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts
epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr
ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln
pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg sep smap
smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave
xsavec xsaveopt xsaves xtopology xtpr
Type: l1tf
Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: XFX Pine driver: amdgpu v: kernel arch: GCN 4 process: GF 14nm
built: 2016-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 ports:
active: DVI-D-1,HDMI-A-1 empty: DP-1,DP-2,DP-3 bus-ID: 01:00.0
chip-ID: 1002:67df class-ID: 0300
Display: x11 server: X.Org v: 21.1.3 compositor: kwin_x11 driver: X:
loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa gpu: amdgpu
display-ID: :0 screens: 1
Screen-1: 0 s-res: 3520x1080 s-dpi: 96 s-size: 930x285mm (36.61x11.22")
s-diag: 973mm (38.29")
Monitor-1: DVI-D-1 mapped: DVI-D-0 pos: bottom-r model: Dell S2009W
serial: <filter> built: 2009 res: 1600x900 hz: 60 dpi: 92 gamma: 1.2
size: 443x249mm (17.44x9.8") diag: 508mm (20") ratio: 16:9 modes:
max: 1600x900 min: 720x400
Monitor-2: HDMI-A-1 mapped: HDMI-A-0 pos: primary,top-left model: E231-B1
serial: <filter> built: 2014 res: 1920x1080 hz: 60 dpi: 91 gamma: 1.2
size: 534x311mm (21.02x12.24") diag: 618mm (24.3") ratio: 15:9 modes:
max: 1360x768 min: 720x400
OpenGL: renderer: AMD Radeon RX 580 Series (polaris10 LLVM 13.0.1 DRM 3.46
5.18.0-1-rt11-MANJARO)
v: 4.6 Mesa 22.1.1 direct render: Yes
Device-1: Intel 200 Series PCH HD Audio vendor: ASRock driver: snd_hda_intel
bus-ID: 1-12:12 v: kernel bus-ID: 00:1f.3 chip-ID: 0c76:161e class-ID: 0300
chip-ID: 8086:a2f0 class-ID: 0403
Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: XFX Pine driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 16 bus-ID: 01:00.1 chip-ID: 1002:aaf0 class-ID: 0403
Device-3: JMTek LLC. USB PnP Audio Device type: USB
driver: hid-generic,snd-usb-audio,usbhid
Device-4: Razer USA Barracuda X type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-5:4 chip-ID: 1532:0536
class-ID: 0300
Sound Server-1: ALSA v: k5.18.0-1-rt11-MANJARO running: yes
Sound Server-3: JACK v: 1.9.21 running: no
Sound Server-4: PulseAudio v: 16.0 running: yes
Sound Server-5: PipeWire v: 0.3.52 running: yes
Device-1: Intel Ethernet I219-V vendor: ASRock driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15b8 class-ID: 0200
IF: enp0s31f6 state: down mac: <filter>
Device-2: Realtek RTL8188EUS 802.11n Wireless Network Adapter type: USB
driver: r8188eu bus-ID: 1-4.4:15 chip-ID: 0bda:8179 class-ID: 0000
serial: <filter>
IF: wlp0s20f0u4u4 state: up mac: <filter>
IF-ID-1: anbox0 state: down mac: <filter>
IP v4: <filter> scope: global
driver: btusb v: 0.8 bus-ID: 1-4.3:7 chip-ID: 0a12:0001 class-ID: e001
Device-1: luks-a60aab6e-e721-4172-a18c-60acb874d6ed maj-min: 254:0
type: LUKS dm: dm-0 size: 465.4 GiB
Components:
p-1: nvme0n1p5 maj-min: 259:5 size: 465.4 GiB
Local Storage: total: 2.73 TiB used: 1.28 TiB (46.9%)
model: WDS100T2B0C size: 931.51 GiB block-size: physical: 512 B
rev: 211210WD temp: 50.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM008-2FR102
type: HDD rpm: 7200 serial: <filter> rev: 0001 scheme: GPT
ID-1: / raw-size: 465.4 GiB size: 457.03 GiB (98.20%)
used: 295.05 GiB (64.6%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-a60aab6e-e721-4172-a18c-60acb874d6ed label: N/A
uuid: 110cd987-b31a-4a31-ae97-aaecf9d32a23
used: 27.4 MiB (28.6%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: N/A uuid: 54C3-B38F
ID-3: /mnt/205CC9345CC9060E raw-size: 465.4 GiB size: 465.4 GiB (100.00%)
used: 195.52 GiB (42.0%) fs: ntfs dev: /dev/nvme0n1p3 maj-min: 259:3
label: N/A uuid: 205CC9345CC9060E
ID-4: /mnt/sda1 raw-size: 1.36 TiB size: 1.34 TiB (98.35%)
used: 820.23 GiB (59.7%) fs: ext4 dev: /dev/sda1 maj-min: 8:1
label: Manjextra uuid: dec99700-dee2-4175-9504-dac6ca16c47b
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p4 maj-min: 259:4 size: 604 MiB fs: ntfs label: N/A
uuid: 0C6EF57C6EF55F40
ID-3: /dev/sda2 maj-min: 8:2 size: 466.03 GiB fs: ntfs label: Windextra
uuid: 74CC35FBCC35B866
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Hub-2: 1-4:3 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s
power: 100mA chip-ID: 05e3:0610 class-ID: 0900
Device-1: 1-4.3:7
info: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) type: Bluetooth
Device-2: 1-4.4:15
info: Realtek RTL8188EUS 802.11n Wireless Network Adapter type: Network
driver: r8188eu interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA
chip-ID: 0bda:8179 class-ID: 0000 serial: <filter>
Device-3: 1-5:4 info: Razer USA Barracuda X type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 1532:0536 class-ID: 0300
Hub-3: 1-7:6 info: NEC HighSpeed Hub ports: 3 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 0409:005a class-ID: 0900
Device-1: 1-7.3:10 info: SteelSeries ApS Merc Stealth type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 1.5 Mb/s
power: 100mA chip-ID: 1038:0510 class-ID: 0300
Device-2: 1-8:8 info: Logitech G502 Proteus Spectrum Optical Mouse
type: Mouse,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 300mA chip-ID: 046d:c332 class-ID: 0300
serial: <filter>
Hub-4: 1-11:11 info: Realtek RTS5411 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
chip-ID: 0bda:5411 class-ID: 0900
Device-1: 1-11.3:13 info: Oculus VR Quest Headset type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.1 speed: 480 Mb/s power: 500mA
chip-ID: 2833:0137 class-ID: 0000 serial: <filter>
Device-2: 1-11.4:32 info: Samsung Galaxy A5 (MTP)
type: Still Imaging,Abstract (modem),CDC-Data driver: cdc_acm interfaces: 4
rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 04e8:6860 class-ID: 0a00
serial: <filter>
Device-3: 1-12:12 info: JMTek LLC. USB PnP Audio Device type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 0c76:161e class-ID: 0300
Hub-5: 2-0:1 info: Super-speed hub ports: 6 rev: 3.0 speed: 5 Gb/s
Hub-6: 2-2:2 info: Genesys Logic hub ports: 4 rev: 3.0 speed: 5 Gb/s
chip-ID: 05e3:0616 class-ID: 0900
Hub-7: 2-4:3 info: Realtek Hub ports: 4 rev: 3.0 speed: 5 Gb/s
chip-ID: 0bda:0411 class-ID: 0900
System Temperatures: cpu: 53.0 C mobo: N/A gpu: amdgpu temp: 55.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 776
Processes: 366 Uptime: 6h 32m wakeups: 2 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.1.0 alt: 11
clang: 13.0.1 Packages: 1606 pacman: 1586 lib: 418 flatpak: 9 snap: 11
Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.19```
Had a similar problem with the same device. After the last upgrade, the usb wifi adapter stopped working. Downgrading to the 5.10 LTS kernel did the trick. Haven’t tried the RT kernels, though. Also no idea as to why this happened.
Hi @GoldenAJF
My 2 cents
Try install an LTS kernel and:
linux-lts-headers
Then reboot to the new kernel.
Maybe after that if it didn’t work:
broadcom-wl-dkms (that worked with me. I hope someone more experienced correct it if I am wrong, maybe different for your hardware)
Let me know if this helps.
Have a look at Internet connection is way too slow - #6 by limotux
Good luck.
I have similar problem with other model of realtek usb wifi, here is the solution that work in my case:
[Update to kernel 5.15 broke TP-LINK TL-wn727n wifi dongle driver ]
Saludos
Mirko.-
j8a
June 24, 2022, 11:41pm
#5
Hi @GoldenAJF ,
I wonder whether you could read this post, someone installed Manjaro on April 2021 and sent a probe to this page and you could find the information in order to solve your problem.
‘ASRock B250M Performance Desktop Computer ’
Regards,
5.18 kernels have not been playing well with usb wifi adapters. For me and my realtek 5.17 and down work fine.
AUR (en) - Packages Current list and none of them look to be updated in AUR.
Sorry for the late response, but for some reason I am not able to install some kernels. The ones that I can install are 5.18.0_rt, 5.18.5-1, 5.17.15, and 4.19.248. I already had 5.15.48, and 5.15.44_rt installed so I do not know if those will reinstall.
The error message I get for installing the others (besides for kernel numbers) are the same.
linux519
linux519-virtualbox-host-modules
linux519-headers
Starting
resolving dependencies...
Packages (3) linux519-5.19rc1.220606.gf2906aa-1 linux519-headers-5.19rc1.220606.gf2906aa-1 linux519-virtualbox-host-modules-6.1.34-0.1
Total Download Size: 155.01 MiB
Total Installed Size: 274.09 MiB
:: Retrieving packages...
linux519-5.19rc1.220606.gf2906aa-1-x86_64 downloading...
error: failed retrieving file 'linux519-5.19rc1.220606.gf2906aa-1-x86_64.pkg.tar.zst' from repo.ialab.dsu.edu : The requested URL returned error: 404
error: failed retrieving file 'linux519-5.19rc1.220606.gf2906aa-1-x86_64.pkg.tar.zst' from mirror.fcix.net : The requested URL returned error: 404
error: failed retrieving file 'linux519-5.19rc1.220606.gf2906aa-1-x86_64.pkg.tar.zst' from manjaro.mirrors.lavatech.top : The requested URL returned error: 404
error: failed retrieving file 'linux519-5.19rc1.220606.gf2906aa-1-x86_64.pkg.tar.zst' from osmirror.org : The requested URL returned error: 404
error: failed retrieving file 'linux519-5.19rc1.220606.gf2906aa-1-x86_64.pkg.tar.zst' from mirror.math.princeton.edu : The requested URL returned error: 404
error: failed retrieving file 'linux519-5.19rc1.220606.gf2906aa-1-x86_64.pkg.tar.zst' from mirror.zetup.net : The requested URL returned error: 404
error: failed retrieving file 'linux519-5.19rc1.220606.gf2906aa-1-x86_64.pkg.tar.zst' from mirror1.cl.netactuate.com : The requested URL returned error: 404
error: failed retrieving file 'linux519-5.19rc1.220606.gf2906aa-1-x86_64.pkg.tar.zst' from mirrors.colocall.net : The requested URL returned error: 404
warning: failed to retrieve some files
error: failed to commit transaction (failed to retrieve some files)
Done ...```
omano
June 26, 2022, 7:10pm
#9
Use an up to date mirror and sync your database.
sudo pacman-mirrors -c Global && sudo pacman -Syyu
Then install kernels.
Although I don’t remember it being this way, the adapter does work with the latest LTS Kernel.
Is their any way to fix it for other kernels or do I just have to wait for support for the device?
If it does not work with newer kernels nothing you can do unless you can rewrite the driver. I dropped links of the drivers and they have not been updated in sometime in the AUR.
Alright, well thanks for the help though.
I was having issues with virtualbox amd it mentioned something about a kernel so I figured I’ll try reinstalling my kernel and now the adapter just doesn’t work with any of them except 4.19.248-1 because that’s the only one I haven’t reinstalled.
I need to update to a newer kernel because my gear doesn’t have proper support on 4.19…
Am I just screwed until I get an ethernet cord?
j8a
July 2, 2022, 9:26pm
#14
Hi @GoldenAJF ,
Please, read the following recent post.
‘TP-Link TL-WN722N slow connection - #2 by brahma ’
I wonder whether you could solve the problem.
Regards,
secdoc
July 5, 2022, 1:56pm
#15
I am having an issue with wifi. My system has the Intel Wi-Fi 6 AX200 and Bluetooth module. The bluetooth works without issue but at some point, which I do not remember when) after an update, the wifi component stopped working.
inxi -Fxxxz ✔
Kernel: 5.18.6-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.5 wm: kwin_x11 vt: 1 dm: SDDM
Mobo: ASUSTeK model: ROG CROSSHAIR VIII HERO (WI-FI) v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 4201
date: 04/26/2022
Info: 16-core model: AMD Ryzen 9 5950X bits: 64 type: MT MCP smt: enabled
arch: Zen 3 rev: 0 cache: L1: 1024 KiB L2: 8 MiB L3: 64 MiB
Speed (MHz): avg: 3086 high: 4028 min/max: 2200/5083 boost: enabled
cores: 1: 3735 2: 3591 3: 2873 4: 2872 5: 3260 6: 2875 7: 2874 8: 2869
9: 2875 10: 3592 11: 2889 12: 2895 13: 3592 14: 2874 15: 2874 16: 2874
17: 4028 18: 3672 19: 2875 20: 3384 21: 2873 22: 2872 23: 2875 24: 2875
25: 2874 26: 3591 27: 2872 28: 2873 29: 2876 30: 2899 31: 2978 32: 2939
bogomips: 217297
Device-1: AMD Navi 23 [Radeon RX 6600/6600 XT/6600M]
vendor: Tul / PowerColor Red Devil driver: amdgpu v: kernel arch: RDNA 2
pcie: speed: 16 GT/s lanes: 16 ports: active: DP-1, DP-2, DP-3, HDMI-A-1
empty: none bus-ID: 0d:00.0 chip-ID: 1002:73ff class-ID: 0300
Device-2: NVIDIA GA104 [GeForce RTX 3070 Ti] vendor: eVga.com.
driver: N/A arch: Ampere pcie: speed: 16 GT/s lanes: 8 bus-ID: 0e:00.0
chip-ID: 10de:2482 class-ID: 0300
Device-3: Elgato Systems GmbH Cam Link 4K type: USB
driver: hid-generic,snd-usb-audio,usbhid,uvcvideo bus-ID: 2-3:2
chip-ID: 0fd9:0066 class-ID: 0102 serial: <filter>
loaded: amdgpu unloaded: modesetting,radeon alternate: fbdev,vesa
gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 3862x4680 s-dpi: 96 s-size: 1020x1237mm (40.16x48.70")
s-diag: 1603mm (63.12")
Monitor-1: DP-1 mapped: DisplayPort-0 pos: 3-1 model: VG278
serial: <filter> res: 1920x1080 dpi: 82 size: 598x336mm (23.54x13.23")
diag: 686mm (27") modes: max: 1920x1080 min: 720x400
Monitor-2: DP-2 mapped: DisplayPort-1 pos: primary,1-4
model: LG (GoldStar) Ultra HD serial: <filter> res: 3840x2160 hz: 60
dpi: 163 size: 600x340mm (23.62x13.39") diag: 690mm (27.2") modes:
max: 3840x2160 min: 640x480
Monitor-3: DP-3 mapped: DisplayPort-2 pos: 2-3 model: Acer EI342CKR
serial: <filter> res: 3440x1440 dpi: 110 size: 797x334mm (31.38x13.15")
diag: 864mm (34") modes: max: 3440x1440 min: 720x400
Monitor-4: HDMI-A-1 mapped: HDMI-A-0 pos: 3-2 model: VG278
OpenGL: renderer: AMD Radeon RX 6600 XT (dimgrey_cavefish LLVM 13.0.1 DRM
3.46 5.18.6-1-MANJARO)
v: 4.6 Mesa 22.1.2 direct render: Yes
Device-1: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel v: kernel
bus-ID: 2-3:2 pcie: chip-ID: 0fd9:0066 speed: 16 GT/s class-ID: 0102
lanes: 16 serial: <filter> bus-ID: 0d:00.1 chip-ID: 1002:ab28
class-ID: 0403
Device-2: NVIDIA GA104 High Definition Audio vendor: eVga.com.
driver: snd_hda_intel v: kernel pcie: speed: 16 GT/s lanes: 8
bus-ID: 0e:00.1 chip-ID: 10de:228b class-ID: 0403
Device-3: AMD Starship/Matisse HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel pcie: speed: 16 GT/s lanes: 16
bus-ID: 10:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-4: Elgato Systems GmbH Cam Link 4K type: USB
Sound Server-1: ALSA v: k5.18.6-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.52 running: yes
Device-1: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169 v: kernel
pcie: speed: 5 GT/s lanes: 1 port: d000 bus-ID: 05:00.0 chip-ID: 10ec:8125
class-ID: 0200
IF: enp5s0 state: down mac: <filter>
Device-2: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb
v: kernel pcie: speed: 2.5 GT/s lanes: 1 port: c000 bus-ID: 06:00.0
IF: enp6s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-3: Intel Wi-Fi 6 AX200 driver: N/A pcie: speed: 5 GT/s lanes: 1
bus-ID: 07:00.0 chip-ID: 8086:2723 class-ID: 0280
IF-ID-1: virbr0 state: down mac: <filter>
IF-ID-2: virbr1 state: down mac: <filter>
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-6:3 chip-ID: 8087:0029 class-ID: e001
Local Storage: total: 48.23 TiB used: 1016.25 GiB (2.1%)
ID-1: /dev/nvme0n1 vendor: Sabrent model: Rocket 4.0 2TB size: 1.82 TiB
speed: 63.2 Gb/s lanes: 4 type: SSD serial: <filter> rev: RKT401.3
ID-2: /dev/nvme1n1 vendor: Sabrent model: Rocket 4.0 2TB size: 1.82 TiB
temp: 54.9 C scheme: GPT
ID-3: /dev/sda vendor: Western Digital model: WDS500G2B0A-00SM50
size: 465.76 GiB speed: 6.0 Gb/s type: SSD serial: <filter> rev: 20WD
scheme: GPT
ID-4: /dev/sdb vendor: Western Digital model: WDS500G2B0A-00SM50
scheme: GPT
ID-5: /dev/sdc vendor: HGST (Hitachi) model: HUH721212ALE600
size: 10.91 TiB speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter>
rev: T925 scheme: GPT
ID-6: /dev/sdd vendor: HGST (Hitachi) model: HUH721212ALE600
ID-7: /dev/sde type: USB vendor: Seagate model: Backup+ Desk
size: 7.28 TiB type: N/A serial: <filter> rev: 040B scheme: GPT
ID-8: /dev/sdf type: USB model: Specific STORAGE DEVICE size: 29.3 GiB
type: N/A serial: <filter> rev: 0009 scheme: MBR
ID-9: /dev/sdg model: FILEIO size: 4.55 TiB type: N/A serial: N/A
rev: 4.0 scheme: GPT
ID-10: /dev/sdh model: FILEIO size: 2.73 TiB type: N/A serial: N/A
ID-11: /dev/sdi model: FILEIO size: 7.28 TiB type: N/A serial: N/A
ID-1: / size: 1.82 TiB used: 1016.25 GiB (54.6%) fs: btrfs
dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 299.4 MiB used: 568 KiB (0.2%) fs: vfat
dev: /dev/nvme0n1p1
ID-3: /home size: 1.82 TiB used: 1016.25 GiB (54.6%) fs: btrfs
dev: /dev/nvme0n1p2
ID-4: /var/log size: 1.82 TiB used: 1016.25 GiB (54.6%) fs: btrfs
dev: /dev/nvme0n1p2
System Temperatures: cpu: 48.0 C mobo: 43.0 C gpu: amdgpu temp: 59.0 C
mem: 58.0 C
Fan Speeds (RPM): cpu: 0 gpu: amdgpu fan: 0
Processes: 631 Uptime: 1h 17m wakeups: 0 Memory: 125.71 GiB
used: 10.73 GiB (8.5%) Init: systemd v: 251 default: graphical Compilers:
gcc: 12.1.0 clang: 13.0.1 Packages: 1565 pacman: 1518 flatpak: 21 snap: 26
Shell: Zsh v: 5.9 running-in: tilix inxi: 3.3.19
As you can see in the info above, it is recognized, but what is strange is that the interfaces:
virbr0/1 are associated with my KVM network. While I do not use wireless frequently, I would like to be able to have alternate network connections for differing purposes. Any thoughts or insights would be helpful.
I have also tried the following based on other threads:
lspci -k | grep Intel
06:00.0 Ethernet controller: Intel Corporation I211 Gigabit Network Connection (rev 03)
07:00.0 Network controller: Intel Corporation Wi-Fi 6 AX200 (rev 1a)
Subsystem: Intel Corporation Wi-Fi 6 AX200NGW
sudo sh -c "echo 1 > /sys/bus/pci/devices/0000\:07\:00.0/remove"
sudo sh -c "echo 1 > /sys/bus/pci/rescan"
