One Problem here, with the las upgrade of manjaro, when manjaro load kernel 5.15 wifi dongle stop working, work fine when i boot on kernel 5.14.x
Dongle usb TP-Link TL-wn727n v5.21 (based on realtek rtl8188eu )
when change the kernel dont load de driver of wlan:
Inxi 5.14
Kernel: 5.14.18-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.14-x86_64
root=UUID=90bff889-bf08-4cad-9f30-c33abe92f3a5 rw quiet
udev.log_priority=3
Desktop: GNOME v: 42.2 tk: GTK v: 3.24.34 wm: gnome-shell dm: GDM v: 42.0
Type: Desktop System: ECS product: H410H6-M2 v: 1.0
serial: <superuser required>
Mobo: ECS model: H410H6-M2 v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: 5.17 date: 06/18/2020
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M275/M280
status: discharging
Info: model: Intel Celeron G5900 bits: 64 type: MCP arch: Comet Lake
built: 2020 process: Intel 14nm family: 6 model-id: 0xA5 (165) stepping: 3
microcode: 0xF0
Topology: cpus: 1x cores: 2 smt: <unsupported> cache: L1: 128 KiB
desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB desc: 2x256 KiB L3: 2 MiB
desc: 1x2 MiB
Speed (MHz): avg: 3400 min/max: 800/3400 scaling: driver: intel_pstate
governor: powersave cores: 1: 3400 2: 3400 bogomips: 13604
Flags: ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Device-1: Intel CometLake-S GT1 [UHD Graphics 610] vendor: Elite Systems
driver: i915 v: kernel arch: Gen9.5 process: Intel 14nm built: 2016-20
ports: active: DP-1 empty: HDMI-A-1,HDMI-A-2,HDMI-A-3 bus-ID: 00:02.0
chip-ID: 8086:9ba8 class-ID: 0300
Display: wayland server: X.org v: 1.21.1.3 with: Xwayland v: 22.1.2
compositor: gnome-shell driver: gpu: i915 display-ID: 0
Monitor-1: DP-1 model: BenQ G922HDA serial: <filter> built: 2009
res: 1366x768 dpi: 85 gamma: 1.2 size: 410x230mm (16.14x9.06")
diag: 470mm (18.5") ratio: 16:9 modes: max: 1366x768 min: 720x400
Message: Wayland GBM/EGL data currently not available.
Device-1: Intel Comet Lake PCH-V cAVS vendor: Elite Systems
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_cnl
bus-ID: 00:1f.3 chip-ID: 8086:a3f0 class-ID: 0403
Sound Server-1: ALSA v: k5.14.18-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 16.0 running: yes
Sound Server-4: PipeWire v: 0.3.52 running: yes
vendor: Elite Systems driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 3000 bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp1s0 state: down mac: <filter>
Device-2: TP-Link 802.11n NIC type: USB driver: r8188eu bus-ID: 1-2:2
chip-ID: 2357:0111 class-ID: 0000 serial: <filter>
IF: wlp0s20f0u2 state: up mac: <filter>
Local Storage: total: 223.57 GiB used: 23.67 GiB (10.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37240G
size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 0100 scheme: GPT
ID-1: / raw-size: 34.78 GiB size: 33.94 GiB (97.58%) used: 18.03 GiB (53.1%)
fs: ext4 dev: /dev/sda3 maj-min: 8:3
ID-2: /boot/efi raw-size: 320 MiB size: 319.3 MiB (99.79%)
used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 188.48 GiB size: 184.46 GiB (97.87%)
used: 5.65 GiB (3.1%) fs: ext4 dev: /dev/sda2 maj-min: 8:2
System Temperatures: cpu: 18.0 C mobo: N/A
Processes: 194 Uptime: 6m wakeups: 2 Memory: 7.57 GiB used: 1.75 GiB (23.1%)
Init: systemd v: 251 default: graphical tool: systemctl Compilers:
gcc: 12.1.0 clang: 13.0.1 Packages: pacman: 1116 lib: 313 flatpak: 0
Shell: Zsh v: 5.9 running-in: gnome-terminal inxi: 3.3.19
inxi 5.15
Kernel: 5.15.48-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
udev.log_priority=3
status: discharging
microcode: 0xF0
desc: 1x2 MiB
Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
Sound Server-1: ALSA v: k5.15.48-1-MANJARO running: yes
Device-2: TP-Link 802.11n NIC type: USB driver: N/A bus-ID: 1-9:4
Local Storage: total: 223.57 GiB used: 23.68 GiB (10.6%)
System Temperatures: cpu: 20.0 C mobo: N/A
Processes: 185 Uptime: 0m wakeups: 2 Memory: 7.57 GiB
used: 926.5 MiB (12.0%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1 Packages: pacman: 1116
lib: 313 flatpak: 0 Shell: Zsh v: 5.9 running-in: gnome-terminal
inxi: 3.3.19
any solution? the problem is i’dont have Lan connection to make some test when boot with kernel 5.15 and download anything from aur.
