WiFi adapter not recognized
heyho. as the title states:
installed manjaro today for the first time next to win10 and manjaro doesn’t recognize the WiFi adapter. WiFi works on win10.
    vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp2s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-2: Realtek vendor: Lenovo driver: N/A pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: 2000 bus-ID: 03:00.0 chip-ID: 10ec:b852 class-ID: 0280
found a similar thread with a broadcomm board, but not for realtek. Also, it doesn’t even state the 2nd device properly
mhwd -l output:
> 0000:02:00.0 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd.:
         network-r8168            2016.04.20                true            PCI
> 0000:04:00.0 (0300:1002:15e7) Display controller ATI Technologies Inc:
           video-linux            2018.05.04                true            PCI
system info:
  Kernel: 5.15.74-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
    root=UUID=dcd2fe4e-1104-434c-b1fc-6127efd4f2c8 rw quiet splash apparmor=1
  Desktop: GNOME v: 42.5 tk: GTK v: 3.24.34 wm: gnome-shell dm: GDM v: 42.0
thanks a lot for your help!
post output from:
lspci
and is fast startup disabled in windows?
is fast boot disabled in bios - you may not have this option
fast boot in win10 is off. bios does not have a fast boot option. secure boot is off
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne Root Complex
00:00.2 IOMMU: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne IOMMU
00:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge
00:02.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge
00:02.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne PCIe GPP Bridge
00:02.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne PCIe GPP Bridge
00:02.3 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne PCIe GPP Bridge
00:08.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge
00:08.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir Internal PCIe GPP Bridge to Bus
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller (rev 51)
00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge (rev 51)
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 0
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 1
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 2
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 3
00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 4
00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 5
00:18.6 Host bridge: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 6
00:18.7 Host bridge: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 7
01:00.0 Non-Volatile memory controller: Shenzhen Unionmemory Information System Ltd. AM630 PCIe 4.0 x4 NVMe SSD Controller (rev 03)
02:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
03:00.0 Network controller: Realtek Semiconductor Co., Ltd. Device b852
04:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Barcelo (rev c1)
04:00.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Renoir Radeon High Definition Audio Controller
04:00.2 Encryption controller: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 10h-1fh) Platform Security Processor
04:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne USB 3.1
04:00.4 USB controller: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne USB 3.1
04:00.5 Multimedia controller: Advanced Micro Devices, Inc. [AMD] ACP/ACP3X/ACP6x Audio Coprocessor (rev 01)
04:00.6 Audio device: Advanced Micro Devices, Inc. [AMD] Family 17h/19h HD Audio
ok, also post output from:
mhwd-kernel -li
5.15.74-3-MANJARO (linux515)
   * linux515
so install kernel headers:
pamac install linux515-headers
install the driver, this one should be it:
pamac build rtl8852be-dkms-git
reboot and see if it helped
worked like a charm. thank you so very much!
side-question: whenever i shut down manjaro, i get a mainboard “beep” like I’m entering the bios. i dont have that with win10. could you by chance shine light on that?
you can disable the module that causes the beep:
sudo tee /etc/modprobe.d/nobeep.conf <<< 'blacklist pcspkr'
then run this:
sudo mkinitcpio -P
reboot to apply the blacklist;
it should be disabled by the next reboot or shutdown
much appreciated! thanks for the fast help
Hi all,
I read this thread because I do have similar problems.
The output from my console for Network is:
mhwd -l output:
lspci output:
04:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Barcelo (rev c2)
04:00.6 Audio device: Advanced Micro Devices, Inc. [AMD] Family 17h/19h HD Audio Controller
mhwd-kernel -li output:
6.0.8-1-MANJARO (linux60)
   * linux60
I tried the same steps as suggested here but my wifi is not working :frowning:
I would be very happy if someone can help me
did you installed the kernel headers for the linux60?
if yes, maybe the rtl8852be-dkms-git doesnt work with the linux60; so uninstall it and install this:
pamac build rtw8852be-dkms-git
reboot and test
Yes, I installed the headers for linux60.
I tried to install pamac build rtw8852be-dkms-git after uninstalling rtl8852be-dkms-gitbut this crashed while installing multiple times.
so install the 5.15 kernel + headers;
remove the rtw8852be-dkms-git
and install this again:
reboot and in grub menu select the 5.15 kernel and see if that helped
Sadly this didn’t help :frowning:
The same as before:
    lanes: 1 port: 2000 bus-ID: 03:00.0 chip-ID: 10ec:b852 class-ID: 0280```
post output from:
inxi -N
    driver: r8169
  Device-2: Realtek driver: N/A
load the driver:
sudo modprobe 8852be
and see if it helped, and also check with:
inxi -N
if the driver is loaded
output from Modprobe:
modprobe: FATAL: Module 8852be not found in directory /lib/modules/5.15.78-1-MANJARO
post output from:
pacman -Qs 'headers|dkms|git'
    Access control list utilities, libraries and headers
local/cdparanoia 10.2-8
    Compact Disc Digital Audio extraction tool
local/dkms 3.0.8-1
    Dynamic Kernel Modules System
local/git 2.38.1-2
    the fast distributed version control system
local/libcups 1:2.4.2-3
    The CUPS Printing System - client libraries and headers
local/libgphoto2 2.5.30-1
    Digital camera access library
local/libltc 1.3.2-1
    Linear/Logitudinal Time Code (LTC) Library
local/libraw 0.20.2-2
    A library for reading RAW files obtained from digital photo cameras (CRW/CR2, NEF, RAF, DNG, and others)
local/linux-api-headers 5.18.15-1
    Kernel headers sanitized for use in userspace
local/linux515-headers 5.15.78-1
    Header files and scripts for building modules for Linux515 kernel
local/linux60-headers 6.0.8-1
    Header files and scripts for building modules for Linux60 kernel
local/rtl8852be-dkms-git r28.28daf8c-1
    Realtek Linux WLAN Driver for RTL8852BE
local/vulkan-headers 1:1.3.227-1 (vulkan-devel)
    Vulkan header files
local/xorgproto 2022.2-1
    combined X.Org X11 Protocol headers
