it looks ok…
are you dual booting with windows?
if yes disable fast startup in windows;
and disable fast boot in bios - you may not have this option there
I am only using Manjaro, fast boot is disabled in bios.
have no idead what the issue is…
post output from:
inxi -M
Any update on this problem, I am facing exactly the same issue but still have no idea how to make it works.
Outputs:
inxi -M
Type: Laptop System: HP product: HP EliteBook 655 15.6 inch G9 Notebook PC
v: N/A serial: <superuser required>
Mobo: HP model: 89D2 v: KBC Version 14.47.00 serial: <superuser required>
UEFI: HP v: U77 Ver. 01.09.00 date: 10/18/2022
** pacman -Qs ‘headers|dkms|git’**
local/acl 2.3.1-2
Access control list utilities, libraries and headers
local/cdparanoia 10.2-8
Compact Disc Digital Audio extraction tool
local/dkms 3.0.9-1
Dynamic Kernel Modules System
local/git 2.39.0-1
the fast distributed version control system
local/libcups 1:2.4.2-3
The CUPS Printing System - client libraries and headers
local/libgit2 1:1.5.0-2
A linkable library for Git
local/libgphoto2 2.5.30-1
Digital camera access library
local/libltc 1.3.2-1
Linear/Logitudinal Time Code (LTC) Library
local/linux-api-headers 5.18.15-1
Kernel headers sanitized for use in userspace
local/linux515-headers 5.15.84-1
Header files and scripts for building modules for Linux515 kernel
local/linux60-headers 6.0.14-1
Header files and scripts for building modules for Linux60 kernel
local/rtl8852be-dkms-git r28.28daf8c-1
Realtek Linux WLAN Driver for RTL8852BE
local/vulkan-headers 1:1.3.235-1 (vulkan-devel)
Vulkan header files
local/xorgproto 2022.2-1
combined X.Org X11 Protocol headers
lspci
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne Root Complex
00:00.2 IOMMU: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne IOMMU
00:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge
00:01.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne PCIe GPP Bridge
00:01.3 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne PCIe GPP Bridge
00:02.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge
00:02.4 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne PCIe GPP Bridge
00:08.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge
00:08.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir Internal PCIe GPP Bridge to Bus
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller (rev 51)
00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge (rev 51)
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 0
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 1
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 2
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 3
00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 4
00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 5
00:18.6 Host bridge: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 6
00:18.7 Host bridge: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 7
01:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
02:00.0 Network controller: Realtek Semiconductor Co., Ltd. Device b852
03:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd NVMe SSD Controller SM981/PM981/PM983
04:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Barcelo (rev c1)
04:00.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Renoir Radeon High Definition Audio Controller
04:00.2 Encryption controller: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 10h-1fh) Platform Security Processor
04:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne USB 3.1
04:00.4 USB controller: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne USB 3.1
04:00.5 Multimedia controller: Advanced Micro Devices, Inc. [AMD] ACP/ACP3X/ACP6x Audio Coprocessor (rev 01)
04:00.6 Audio device: Advanced Micro Devices, Inc. [AMD] Family 17h/19h HD Audio Controller
mhwd-kernel -li
Currently running: 5.15.84-1-MANJARO (linux515)
* linux515
inxi -Fza
Kernel: 5.15.84-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=3a061dfd-134d-42f5-8f62-a21a699d0d3d rw quiet splash apparmor=1
Desktop: GNOME v: 43.2 tk: GTK v: 3.24.35 wm: gnome-shell dm: GDM v: 43.0
v: N/A serial: <superuser required> Chassis: type: 10
ID-1: BAT0 charge: 13.5 Wh (31.4%) condition: 43.0/42.8 Wh (100.6%)
volts: 11.0 min: 11.4 model: Hewlett-Packard Primary type: Li-ion
serial: <filter> status: discharging cycles: 4
Info: model: AMD Ryzen 7 5825U with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3 gen: 4 level: v3 note: check built: 2021-22
microcode: 0xA50000D
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1425 high: 1596 min/max: 1600/4547 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1330 2: 1329
3: 1430 4: 1596 5: 1411 6: 1596 7: 1331 8: 1330 9: 1461 10: 1596 11: 1426
12: 1596 13: 1330 14: 1344 15: 1366 16: 1329 bogomips: 63895
prctl and seccomp
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Barcelo vendor: Hewlett-Packard driver: amdgpu v: kernel
arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm) built: 2020-22 pcie:
gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s ports:
active: eDP-1 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 04:00.0 chip-ID: 1002:15e7
class-ID: 0300 temp: 44.0 C
Device-2: Chicony HP HD Camera type: USB driver: uvcvideo bus-ID: 3-4:3
chip-ID: 04f2:b76b class-ID: 0e02 serial: <filter>
Display: wayland server: X.org v: 1.21.1.6 with: Xwayland v: 22.1.7
compositor: gnome-shell driver: gpu: amdgpu display-ID: 0
Monitor-1: eDP-1 model: LG Display 0x071e built: 2021 res: 1920x1080
dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: max: 1920x1080 min: 640x480
API: OpenGL v: 4.6 Mesa 22.3.1 renderer: AMD Radeon Graphics (renoir LLVM
14.0.6 DRM 3.42 5.15.84-1-MANJARO) direct render: Yes
Device-1: AMD Renoir Radeon High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 04:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Hewlett-Packard
driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x pcie:
bus-ID: 04:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Hewlett-Packard
link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.6 chip-ID: 1022:15e3
class-ID: 0403
Sound API: ALSA v: k5.15.84-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.63 running: yes
vendor: Hewlett-Packard driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 3000 bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp1s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Realtek vendor: Hewlett-Packard driver: N/A pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 02:00.0 chip-ID: 10ec:b852
class-ID: 0280
Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 1-3:2 chip-ID: 0bda:b85c class-ID: e001 serial: <filter>
Local Storage: total: 480.08 GiB used: 46.2 GiB (9.6%)
model: SSD 970 EVO Plus 500GB size: 465.76 GiB block-size: physical: 512 B
rev: 2B2QEXM7 temp: 34.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: SanDisk model: Ultra USB 3.0
size: 14.32 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: 1.00 scheme: MBR
ID-1: / raw-size: 50 GiB size: 48.91 GiB (97.83%) used: 11.64 GiB (23.8%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
ID-2: /boot/efi raw-size: 500 MiB size: 499 MiB (99.80%)
used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 395 GiB size: 387.73 GiB (98.16%)
used: 34.56 GiB (8.9%) fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3
ID-1: swap-1 type: partition size: 20.27 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p4 maj-min: 259:4
System Temperatures: cpu: 53.1 C mobo: N/A gpu: amdgpu temp: 45.0 C
Processes: 348 Uptime: 15m wakeups: 1802 Memory: 30.67 GiB
used: 2.7 GiB (8.8%) Init: systemd v: 252 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman pkgs: 1259
libs: 310 tools: gnome-software,pamac pm: flatpak pkgs: 0 Shell: Zsh v: 5.9
running-in: gnome-terminal inxi: 3.3.24
ps. Sorry if I made any mistake in this comment, this is literally the first time I couldn’t find a solution for the problem I have.
install the 6.1 kernel:
sudo mhwd-kernel -i linux61
boot with it and provide output from:
inxi -N
lsmod | grep rtw
I have installed kernel 6.1 as you suggest, but it doesn’t seem to have solved any problem.
inxi -N
driver: r8169
Device-2: Realtek driver: N/A
lsmod | grep rtw
does not return anything ( neither sudo lsmod | grep rtw )
I have tried installing rtw8852be-dkms-git but I got this error
Error: target not found: rtw8852be-dkms-git
And when installing (probably again, I have no idea how many times I have installed those drivers so far) pamac build rtl8852be-dkms-git I got this:
Preparing...
Cloning rtl8852be-dkms-git build files...
Generating rtl8852be-dkms-git information...
Checking rtl8852be-dkms-git dependencies...
Warning: rtl8852be-dkms-git-r28.28daf8c-1 is up to date -- reinstalling
Resolving dependencies...
Checking inter-conflicts...
To build (1):
rtl8852be-dkms-git r28.28daf8c-1 AUR
Edit build files : [e]
Apply transaction ? [e/y/N] y
Building rtl8852be-dkms-git...
==> Making package: rtl8852be-dkms-git r28.28daf8c-1 (Sat 24 Dec 2022 15:45:01 CET)
==> Retrieving sources...
-> Updating rtl8852be git repo...
-> Found dkms.conf
rtl8852be ... Skipped
dkms.conf ... Passed
==> Extracting sources...
-> Creating working copy of rtl8852be git repo...
Cloning into 'rtl8852be'...
done.
Switched to a new branch 'makepkg'
==> Starting pkgver()...
==> Entering fakeroot environment...
==> Starting package()...
==> Tidying install...
-> Removing libtool files...
-> Purging unwanted files...
-> Removing static library files...
-> Stripping unneeded symbols from binaries and libraries...
-> Compressing man and info pages...
==> Checking for packaging issues...
==> Creating package "rtl8852be-dkms-git"...
-> Generating .PKGINFO file...
-> Generating .BUILDINFO file...
-> Generating .MTREE file...
-> Compressing package...
==> Leaving fakeroot environment.
==> Finished making: rtl8852be-dkms-git r28.28daf8c-1 (Sat 24 Dec 2022 15:45:06 CET)
==> Cleaning up...
Checking keyring... [1/1]
Checking integrity... [1/1]
Loading package files... [1/1]
Checking file conflicts... [1/1]
Checking available disc space... [1/1]
Running pre-transaction hooks...
Creating Timeshift snapshot before upgrade... [1/2]
==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
Remove upgraded DKMS modules [2/2]
==> dkms remove rtl8852be/r28.28daf8c
Reinstalling rtl8852be-dkms-git (r28.28daf8c-1)... [1/1]
Arming ConditionNeedsUpdate... [1/2]
Install DKMS modules [2/2]
==> dkms install --no-depmod rtl8852be/r28.28daf8c -k 6.1.1-1-MANJARO
Error! Bad return status for module build on kernel: 6.1.1-1-MANJARO (x86_64)
Consult /var/lib/dkms/rtl8852be/r28.28daf8c/build/make.log for more information.
==> WARNING: `dkms install --no-depmod rtl8852be/r28.28daf8c -k 6.1.1-1-MANJARO' exited 10
==> dkms install --no-depmod rtl8852be/r28.28daf8c -k 5.15.85-1-MANJARO
Error! Bad return status for module build on kernel: 5.15.85-1-MANJARO (x86_64)
==> WARNING: `dkms install --no-depmod rtl8852be/r28.28daf8c -k 5.15.85-1-MANJARO' exited 10
==> ERROR: Missing 6.0.15-1-MANJARO kernel modules tree for module rtl8852be/r28.28daf8c.
install headers for the 61:
sudo pacman -S linux61-headers
remove the8852be:
pamac remove rtl8852be-dkms-git
install this:
pamac build rtw89-dkms-git
reboot
Tremendous respect for your dedication, but still, there is no progress.
I have installed all necessary headers pacman list linux-headers-$(uname -r):
linux515-headers 5.15.85-1
linux60-headers 6.0.15-1
linux61-headers 6.1.1-1
and using latest kernel version uname -r:
6.1.1-1-MANJARO
and have installed necessary driver for Wi-Fi pacman -Qs ‘headers|dkms|git’
local/acl 2.3.1-2
local/dkms 3.0.9-1
local/linux515-headers 5.15.85-1
local/linux60-headers 6.0.15-1
local/linux61-headers 6.1.1-1
Header files and scripts for building modules for Linux61 kernel
local/rtw89-dkms-git 1:r327.e834edf-1
Driver for Realtek 8852AE, an 802.11ax device
Vulkan header files
also, trying to load drivers doesn’t work sudo modprobe 8852be:
modprobe: FATAL: Module 8852be not found in directory /lib/modules/6.1.1-1-MANJARO
At this point, I really doesn’t have any idea what is wrong. But again, HUGE respect for your help.
Edit1: rephrasing sentence.
the driver would be: rtw_8852be not 8852be… but that doesnt matter, it still wouldnt work… it looks like the driver for this specific wifi will be included in the 6.2 kernel (around 2-3 months)… until then, you have to use the rtw one… so remove it:
pamac remove rtw89-dkms-git
then check this link from user unclesam, where you have instructions on how to properly build it so that it works…
so open the add/remove software app, and search for: rtw89-dkms-git, click on build files and edit the dkms.conf and the pkgbuild according to the instructions in the link, then click build, reboot and it should work
Actually, that was it, happily typed via wifi.
Thank you so much :).
