That looks good. Now please provide the output of:
lsmod | grep rlt
lsmod | grep rlt
There is no output for this command.
Cool! Now, letâs reboot and see what happens. Iâm sure you know the drill.
When done, please provide the output of:
âŚagain.
Here you go.
Kernel: 5.15.65-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=f78e2cfd-a105-4f69-a5eb-9781d465c7b3 rw quiet
udev.log_priority=3
Console: pty pts/1 wm: kwin_x11 DM: SDDM Distro: Manjaro Linux
base: Arch Linux
Type: Laptop System: LENOVO product: 81FV v: Lenovo Legion Y530-15ICH
serial: <filter> Chassis: type: 10 v: Lenovo Legion Y530-15ICH
serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: SDK0R32862 WIN serial: <filter>
UEFI: LENOVO v: 8JCN56WW date: 11/30/2020
ID-1: BAT0 charge: 47.7 Wh (97.1%) condition: 49.1/52.5 Wh (93.6%)
volts: 12.5 min: 11.3 model: LGC L17L3PG1 type: Li-poly serial: <filter>
status: N/A
RAM: total: 15.5 GiB used: 1.93 GiB (12.4%)
Array-1: capacity: 32 GiB slots: 2 EC: None max-module-size: 16 GiB
note: est.
Device-1: ChannelA-DIMM0 type: DDR4 detail: synchronous size: 8 GiB
speed: 2667 MT/s volts: curr: 1.2 min: 1.25 max: 1.35 width (bits): data: 64
total: 64 manufacturer: Ramaxel part-no: RMSA3260MD78HAF-2666
serial: <filter>
Device-2: ChannelB-DIMM0 type: DDR4 detail: synchronous size: 8 GiB
speed: 2667 MT/s volts: curr: 1.2 min: 1.25 max: 1.5 width (bits): data: 64
serial: <filter>
Info: model: Intel Core i7-8750H socket: BGA1440 (U3E1) note: check bits: 64
type: MT MCP arch: Coffee Lake gen: core 8 level: v3 built: 2018
process: Intel 14nm family: 6 model-id: 0x9E (158) stepping: 0xA (10)
microcode: 0xF0
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
L3: 9 MiB desc: 1x9 MiB
Speed (MHz): avg: 857 high: 900 min/max: 800/4100 scaling:
driver: intel_pstate governor: powersave volts: 0.8 V ext-clock: 100 MHz
cores: 1: 800 2: 800 3: 839 4: 900 5: 900 6: 900 7: 801 8: 877 9: 900
10: 900 11: 800 12: 873 bogomips: 52815
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp
rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
vulnerable
prctl and seccomp
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, RSB filling,
PBRSB-eIBRS: Not affected
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Lenovo
ports: active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:3e9b
class-ID: 0300
Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile] vendor: Lenovo
driver: nvidia v: 515.65.01 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-08) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-21 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:1c8d
class-ID: 0300
Device-3: Chicony Integrated Camera (1280x720@30) type: USB
driver: uvcvideo bus-ID: 1-6:5 chip-ID: 04f2:b604 class-ID: 0e02
serial: <filter>
Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
loaded: modesetting,nvidia alternate: fbdev,nouveau,nv,vesa gpu: i915
display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1013x285mm (39.88x11.22")
s-diag: 1052mm (41.43")
Monitor-1: HDMI-1-0 pos: primary,right res: 1920x1080 hz: 75 dpi: 102
size: 480x270mm (18.9x10.63") diag: 551mm (21.68") modes: N/A
Monitor-2: eDP-1 pos: primary,left res: 1920x1080 hz: 60 dpi: 142
size: 344x194mm (13.54x7.64") diag: 395mm (15.55") modes: N/A
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 22.1.7
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Lenovo driver: snd_hda_intel
Device-2: NVIDIA GP107GL High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 10de:0fb9 class-ID: 0403
Sound Server-1: ALSA v: k5.15.65-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.57 running: yes
Device-1: Realtek RTL8822BE 802.11a/b/g/n/ac WiFi adapter vendor: Lenovo
ThinkPad E595 driver: rtw_8822be v: kernel pcie: speed: Unknown lanes: 63
link-max: gen: 6 speed: 64 GT/s port: 4000 bus-ID: 07:00.0
chip-ID: 10ec:b822 class-ID: 0280
IF: wlp7s0 state: down mac: <filter>
vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: 3000 bus-ID: 08:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp8s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: Realtek RTL8822BE Bluetooth 4.2 Adapter type: USB driver: btusb
v: 0.8 bus-ID: 1-14:6 chip-ID: 0bda:b023 class-ID: e001 serial: <filter>
Report: rfkill ID: hci0 rfk-id: 3 state: down bt-service: enabled,running
Local Storage: total: 1.14 TiB used: 627.38 GiB (53.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN520
SDAPMUW-256G-1101 size: 238.47 GiB block-size: physical: 512 B
logical: 512 B speed: 15.8 Gb/s lanes: 2 type: SSD serial: <filter>
rev: 20110001 temp: 35.9 C scheme: GPT
SMART: yes health: PASSED on: 211d 15h cycles: 3,384 read-units: 62,551,096
[32.0 TB] written-units: 85,847,433 [43.9 TB]
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM049-2GH172
family: Barracuda Pro Compute size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B sata: 3.1 speed: 6.0 Gb/s type: HDD rpm: 7200
serial: <filter> rev: LXM3 temp: 28 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 1y 16d 20h cycles: 3382
Pre-Fail: attribute: Spin_Retry_Count value: 100 worst: 100 threshold: 97
ID-1: / raw-size: 100 GiB size: 97.87 GiB (97.87%) used: 22.67 GiB (23.2%)
fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: f78e2cfd-a105-4f69-a5eb-9781d465c7b3
ID-2: /boot/efi raw-size: 513 MiB size: 512 MiB (99.80%) used: 312 KiB
(0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p3 maj-min: 259:3
label: NO_LABEL uuid: 551A-FBD8
ID-3: /home raw-size: 137.97 GiB size: 134.75 GiB (97.66%) used: 35.95 GiB
(26.7%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: b8174b29-1d51-490a-8277-24f704305c22
ID-4: /media/sdb9 raw-size: 687.36 GiB size: 687.36 GiB (100.00%)
used: 568.76 GiB (82.7%) fs: ntfs block-size: 4096 B dev: /dev/sda2
maj-min: 8:2 label: Data uuid: 408CFC828CFC742E
ID-1: /dev/sda1 maj-min: 8:1 size: 16 MiB fs: N/A label: N/A uuid: N/A
ID-2: /dev/sda3 maj-min: 8:3 size: 244.14 GiB fs: ext4 label: N/A
uuid: 56e5a3c3-1353-435b-8bae-0cfdb1929855
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Hub-2: 1-1:2 info: Terminus Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 1a40:0101 class-ID: 0900
Device-1: 1-1.4:4 info: China Resource Semico USB Keyboard
type: Keyboard,Mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
speed: 1.5 Mb/s power: 500mA chip-ID: 1a2c:45e8 class-ID: 0301
Device-2: 1-2:3 info: Logitech G402 Gaming Mouse type: Mouse,HID
power: 300mA chip-ID: 046d:c07e class-ID: 0300 serial: <filter>
Device-3: 1-6:5 info: Chicony Integrated Camera (1280x720@30) type: Video
chip-ID: 04f2:b604 class-ID: 0e02 serial: <filter>
Device-4: 1-14:6 info: Realtek RTL8822BE Bluetooth 4.2 Adapter
type: Bluetooth driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s
power: 500mA chip-ID: 0bda:b023 class-ID: e001 serial: <filter>
Hub-3: 2-0:1 info: Super-speed hub ports: 8 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 44.0 C pch: 55.0 C mobo: N/A
Processes: 308 Uptime: 1m wakeups: 1 Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman
pkgs: 1439 libs: 439 tools: pamac pm: flatpak pkgs: 0 Shell: Zsh (sudo)
v: 5.9 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.21
And Iâm guessing it still doesnât work? Because I think everything regarding it has been set to default.
After some reading, it looks like you should install the rtlwifi_new-extended-d
drivers. But I was unable to find them in the AUR.
After some more reading, it seems it is included in rtw88-dkms-git
$ pamac info rtw88-dkms-git
Provides : rtlwifi_new-dkms rtlwifi_new-extended-dkms-git rtlwifi_new-rtw88-dkms
So, I think itâs safe to install rtw88-dkms-git
pamac build rtw88-dkms-git
And lets blacklist the current module:
sudo echo 'blacklist rtw_8822be' > /etc/modprobe.d/rtw_8822be.conf
Afterwards, it should be fine to reboot. So, you know the dance, go do it and reboot.
Want me to remove this first?
Didnât know it was installed, so yes, remove it first please.
Still didnât work outâŚ
udev.log_priority=3
base: Arch Linux
serial: <filter>
status: N/A
RAM: total: 15.5 GiB used: 1.79 GiB (11.5%)
note: est.
serial: <filter>
serial: <filter>
microcode: 0xF0
Speed (MHz): avg: 1391 high: 3991 min/max: 800/4100 scaling:
cores: 1: 3991 2: 3285 3: 800 4: 801 5: 800 6: 800 7: 800 8: 800 9: 800
10: 800 11: 1978 12: 1044 bogomips: 52815
vulnerable
prctl and seccomp
class-ID: 0300
class-ID: 0300
serial: <filter>
direct render: Yes
ThinkPad E595 driver: N/A modules: rtw_8822be pcie: speed: Unknown
lanes: 63 link-max: gen: 6 speed: 64 GT/s port: 4000 bus-ID: 07:00.0
Report: rfkill ID: hci0 rfk-id: 2 state: down bt-service: enabled,running
Local Storage: total: 1.14 TiB used: 627.4 GiB (53.6%)
rev: 20110001 temp: 36.9 C scheme: GPT
SMART: yes health: PASSED on: 211d 15h cycles: 3,385 read-units: 62,555,596
[32.0 TB] written-units: 85,848,560 [43.9 TB]
serial: <filter> rev: LXM3 temp: 29 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 1y 16d 20h cycles: 3383
ID-1: / raw-size: 100 GiB size: 97.87 GiB (97.87%) used: 22.7 GiB (23.2%)
ID-3: /home raw-size: 137.97 GiB size: 134.75 GiB (97.66%) used: 35.94 GiB
Processes: 306 Uptime: 1m wakeups: 1 Init: systemd v: 251 default: graphical
/usr/bin/cat /etc/modprobe.d/*
## Generated by mhwd - Manjaro Hardware Detection
blacklist nouveau
blacklist ttm
blacklist drm_kms_helper
blacklist drm
options nvidia "NVreg_DynamicPowerManagement=0x02"
/usr/bin/ls /etc/modprobe.d/
mhwd-gpu.conf rtw_8822be.conf
In the terminal, run:
sudo modprobe rtw_8723de
Then reboot.
If this doesnât work, then itâs got me stumped too.
just to check, when you were blacklisting and removing the blacklist, did you run everytime the mkinitcpio -P command?
So this is why I have to call in @anon89812132 and @Aragorn as reinforcements, because I really have no clue further.
For reference:
That device ID pointed me to this
https://bbs.archlinux.org/viewtopic.php?id=260589
and this
https://bbs.archlinux.org/viewtopic.php?id=245668
So, the proper driver should still be the
But if that doesnât work, then, as per this discussion [SOLVED] RTL8822BE driver installation / Newbie Corner / Arch Linux Forums it should be switched to rtw88-dkms-git
⌠installing the linux headers first and using apsm_pcie.policy=powersave
kernel boot parameter.
Some of that was already mentioned, with slight difference that to be honest i donât know much about, as the kernel boot parameter mentioned was:
pcie_aspm.policy=powersave
and
pcie_aspm.policy=performance
So what is it?
apsm_pcie.policy
or
pcie_aspm.policy
Are those interchangeable? Usually if the connection is failing, i simply delete the entry from Network manager and create a new one. I always disable mac address randomization (that was also mentioned) and i disable IPv6 âŚ
Guys thanks for all the help.
I have found this post:
⌠and for now everything is working correctly after I followed this plan.
As long as I donât post on this thread it is working correctly but I have to test it on an other network to be sure.
Again thanks for all the help because of you I knew in what direction I had to start looking.
