I recently installed Manjaro and it worked perfectly but then it started having network issues. I have a wifi connection and then it disappears. After this happens and I reboot or something it just stays at the no connections found.
I tried multiple things:
Change kernel from 5.15.65 to ‘5.10.141-1’ , ‘4.19.257-1’, ‘5.4.212-1’
Installed kernel headers and installed “rtw88-dkms-git”
Blacklist possible problem drivers
See if something is hard blocked with rfkill
I have no clue what to do now. I appreciate any help.
do you still have blacklisted drivers? if yes remove the blacklist, recreate initframs, reboot and test, if it doesnt work post again output from: inxi -N
and the wifi is working under ubuntu?
install headers for the 5.19: pamac install linux519-headers
also install headers for the 515 if you didnt already did that, then blacklist the following modules: kate /etc/modprobe.d/blacklist.conf
and add these there:
save the file, run this: sudo mkinitcpio -P
and reinstall the driver: pamac remove rtw88-dkms-git pamac build rtw88-dkms-git
reboot and see if that helped
It did in Kernel 4.19 but not in higher kernel version and I did something to let it work 99% of the times but don’t know what anymore. I know for sure I blacklisted ideapad_laptop for sure but tried that already.
so open this file: kate /etc/default/grub
and edit this line: GRUB_CMDLINE_LINUX_DEFAULT - inside the quotes add this parameter: pcie_aspm.policy=powersave
dont remove anything from there, just add it to existing parameters, save the file, update grub: sudo update-grub
reboot
so try the parameter with the built in driver, so remove headers: pamac remove linux515-headers linux519-headers
remove driver: pamac remove rtw88-dkms-git
delete the blacklist: sudo rm /etc/modprobe.d/blacklist.conf sudo mkinitcpio -P
reboot
if it didnt work replace the pcie_aspm.policy=powersave parameter with this one: pcie_aspm.policy=performance
save grub, update grub, reboot
damn, we tried all that i found…
do you use bluetooth? if not you can disable it in bios and see if that helped … if you dont have the option in bios, disable it in system settings
[ 0.169675] x86/cpu: SGX disabled by BIOS.
[ 0.218678] MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
[ 0.218678] MMIO Stale Data CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/processor_mmio_stale_data.html for more details.
[ 0.218834] #7 #8 #9 #10 #11
[ 0.232785] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[ 0.324449] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.TPLD], AE_ALREADY_EXISTS (20210730/dswload2-326)
[ 0.324459] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20210730/psobject-220)
[ 0.324535] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.XHC.RHUB.HS01], AE_NOT_FOUND (20210730/dswload2-162)
[ 0.324542] ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20210730/psobject-220)
[ 0.324582] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.XHC.RHUB.HS02], AE_NOT_FOUND (20210730/dswload2-162)
[ 0.324588] ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20210730/psobject-220)
[ 0.324628] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.XHC.RHUB.HS03], AE_NOT_FOUND (20210730/dswload2-162)
[ 0.324633] ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20210730/psobject-220)
[ 0.324672] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.XHC.RHUB.HS04], AE_NOT_FOUND (20210730/dswload2-162)
[ 0.324677] ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20210730/psobject-220)
[ 0.324717] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.XHC.RHUB.HS05], AE_NOT_FOUND (20210730/dswload2-162)
[ 0.324722] ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20210730/psobject-220)
[ 0.324762] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.XHC.RHUB.HS06], AE_NOT_FOUND (20210730/dswload2-162)
[ 0.324767] ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20210730/psobject-220)
[ 0.324806] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.XHC.RHUB.HS07], AE_NOT_FOUND (20210730/dswload2-162)
[ 0.324811] ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20210730/psobject-220)
[ 0.324850] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.XHC.RHUB.HS08], AE_NOT_FOUND (20210730/dswload2-162)
[ 0.324855] ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20210730/psobject-220)
[ 0.324894] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.XHC.RHUB.HS09], AE_NOT_FOUND (20210730/dswload2-162)
[ 0.324899] ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20210730/psobject-220)
[ 0.324939] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.XHC.RHUB.HS10], AE_NOT_FOUND (20210730/dswload2-162)
[ 0.324943] ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20210730/psobject-220)
[ 0.324983] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.XHC.RHUB.HS11], AE_NOT_FOUND (20210730/dswload2-162)
[ 0.324988] ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20210730/psobject-220)
[ 0.325027] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.XHC.RHUB.HS12], AE_NOT_FOUND (20210730/dswload2-162)
[ 0.325032] ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20210730/psobject-220)
[ 0.325071] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.XHC.RHUB.HS13], AE_NOT_FOUND (20210730/dswload2-162)
[ 0.325076] ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20210730/psobject-220)
[ 0.325117] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS14._UPC], AE_ALREADY_EXISTS (20210730/dswload2-326)
[ 0.325123] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20210730/psobject-220)
[ 0.325130] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS14._PLD], AE_ALREADY_EXISTS (20210730/dswload2-326)
[ 0.325134] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20210730/psobject-220)
[ 0.328192] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.XHC.RHUB.USR1], AE_NOT_FOUND (20210730/dswload2-162)
[ 0.328198] ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20210730/psobject-220)
[ 0.328207] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.XHC.RHUB.USR2], AE_NOT_FOUND (20210730/dswload2-162)
[ 0.328211] ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20210730/psobject-220)
[ 0.328255] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.XHC.RHUB.SS01], AE_NOT_FOUND (20210730/dswload2-162)
[ 0.328260] ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20210730/psobject-220)
[ 0.328300] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.XHC.RHUB.SS02], AE_NOT_FOUND (20210730/dswload2-162)
[ 0.328305] ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20210730/psobject-220)
[ 0.328345] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.XHC.RHUB.SS03], AE_NOT_FOUND (20210730/dswload2-162)
[ 0.328350] ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20210730/psobject-220)
[ 0.328389] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.XHC.RHUB.SS04], AE_NOT_FOUND (20210730/dswload2-162)
[ 0.328394] ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20210730/psobject-220)
[ 0.328433] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.XHC.RHUB.SS05], AE_NOT_FOUND (20210730/dswload2-162)
[ 0.328438] ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20210730/psobject-220)
[ 0.328477] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.XHC.RHUB.SS06], AE_NOT_FOUND (20210730/dswload2-162)
[ 0.328482] ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20210730/psobject-220)
[ 0.328523] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.XHC.RHUB.SS07], AE_NOT_FOUND (20210730/dswload2-162)
[ 0.328528] ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20210730/psobject-220)
[ 0.328569] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.XHC.RHUB.SS08], AE_NOT_FOUND (20210730/dswload2-162)
[ 0.328574] ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20210730/psobject-220)
[ 0.328613] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.XHC.RHUB.SS09], AE_NOT_FOUND (20210730/dswload2-162)
[ 0.328618] ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20210730/psobject-220)
[ 0.328657] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.XHC.RHUB.SS10], AE_NOT_FOUND (20210730/dswload2-162)
[ 0.328662] ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20210730/psobject-220)
[ 0.330107] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.I2C2.TPD0], AE_NOT_FOUND (20210730/dswload2-162)
[ 0.330114] ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20210730/psobject-220)
[ 0.330164] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.I2C3.TPL1], AE_NOT_FOUND (20210730/dswload2-162)
[ 0.330169] ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20210730/psobject-220)
[ 0.334616] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.PEG0.PEGP._ON], AE_ALREADY_EXISTS (20210730/dswload2-326)
[ 0.334624] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20210730/psobject-220)
[ 0.334631] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.PEG0.PEGP._OFF], AE_ALREADY_EXISTS (20210730/dswload2-326)
[ 0.334636] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20210730/psobject-220)
[ 0.687694] acpi device:4a: Cannot transition to power state D0 for parent in D3hot
[ 1.559515] i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
[ 2.725579] vboxdrv: loading out-of-tree module taints kernel.
[ 2.754631] VBoxNetAdp: Successfully started.
[ 2.759422] VBoxNetFlt: Successfully started.
[ 2.761863] usb 1-1.4: device descriptor read/64, error -71
[ 2.972667] wmi_bus wmi_bus-PNP0C14:00: WQ data block query control method not found
[ 2.972671] wmi_bus wmi_bus-PNP0C14:00: WQ data block query control method not found
[ 2.972673] wmi_bus wmi_bus-PNP0C14:00: WQ data block query control method not found
[ 2.972675] wmi_bus wmi_bus-PNP0C14:00: WQ data block query control method not found
[ 2.972849] acpi PNP0C14:02: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:01)
[ 3.816596] nvidia: module license 'NVIDIA' taints kernel.
[ 3.816600] Disabling lock debugging due to kernel taint
[ 3.967539] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 515.65.01 Wed Jul 20 14:00:58 UTC 2022
[ 4.803325] nvidia_uvm: module uses symbols from proprietary module nvidia, inheriting taint.
[ 7.186983] rtw_8822be 0000:07:00.0: failed to poll offset=0x5 mask=0x2 value=0x0
[ 7.186989] rtw_8822be 0000:07:00.0: mac power on failed
[ 7.186990] rtw_8822be 0000:07:00.0: failed to power on mac
[ 7.654540] ACPI Warning: \_SB.PCI0.PEG0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20210730/nsarguments-61)
[ 9.133940] kauditd_printk_skb: 31 callbacks suppressed
[ 9.187384] rtw_8822be 0000:07:00.0: failed to poll offset=0x5 mask=0x2 value=0x0
[ 9.187388] rtw_8822be 0000:07:00.0: mac power on failed
[ 9.187390] rtw_8822be 0000:07:00.0: failed to power on mac
[ 11.204577] rtw_8822be 0000:07:00.0: failed to poll offset=0x5 mask=0x2 value=0x0
[ 11.204583] rtw_8822be 0000:07:00.0: mac power on failed
[ 11.204585] rtw_8822be 0000:07:00.0: failed to power on mac
[ 13.204899] rtw_8822be 0000:07:00.0: failed to poll offset=0x5 mask=0x2 value=0x0
[ 13.204905] rtw_8822be 0000:07:00.0: mac power on failed
[ 13.204906] rtw_8822be 0000:07:00.0: failed to power on mac
[ 14.963029] kauditd_printk_skb: 15 callbacks suppressed
[ 25.005647] rtw_8822be 0000:07:00.0: failed to poll offset=0x5 mask=0x2 value=0x0
[ 25.005653] rtw_8822be 0000:07:00.0: mac power on failed
[ 25.005654] rtw_8822be 0000:07:00.0: failed to power on mac
[ 27.006152] rtw_8822be 0000:07:00.0: failed to poll offset=0x5 mask=0x2 value=0x0
[ 27.006158] rtw_8822be 0000:07:00.0: mac power on failed
[ 27.006159] rtw_8822be 0000:07:00.0: failed to power on mac
[ 27.016800] kauditd_printk_skb: 11 callbacks suppressed
[ 39.052210] rtw_8822be 0000:07:00.0: failed to poll offset=0x5 mask=0x2 value=0x0
[ 39.052215] rtw_8822be 0000:07:00.0: mac power on failed
[ 39.052216] rtw_8822be 0000:07:00.0: failed to power on mac
[ 41.067584] rtw_8822be 0000:07:00.0: failed to poll offset=0x5 mask=0x2 value=0x0
[ 41.067590] rtw_8822be 0000:07:00.0: mac power on failed
[ 41.067591] rtw_8822be 0000:07:00.0: failed to power on mac
[ 53.106274] rtw_8822be 0000:07:00.0: failed to poll offset=0x5 mask=0x2 value=0x0
[ 53.106279] rtw_8822be 0000:07:00.0: mac power on failed
[ 53.106281] rtw_8822be 0000:07:00.0: failed to power on mac
[ 55.108947] rtw_8822be 0000:07:00.0: failed to poll offset=0x5 mask=0x2 value=0x0
[ 55.108953] rtw_8822be 0000:07:00.0: mac power on failed
[ 55.108954] rtw_8822be 0000:07:00.0: failed to power on mac
[ 67.120717] rtw_8822be 0000:07:00.0: failed to poll offset=0x5 mask=0x2 value=0x0
[ 67.120723] rtw_8822be 0000:07:00.0: mac power on failed
[ 67.120725] rtw_8822be 0000:07:00.0: failed to power on mac
[ 69.120456] rtw_8822be 0000:07:00.0: failed to poll offset=0x5 mask=0x2 value=0x0
[ 69.120462] rtw_8822be 0000:07:00.0: mac power on failed
[ 69.120463] rtw_8822be 0000:07:00.0: failed to power on mac
[ 81.110730] rtw_8822be 0000:07:00.0: failed to poll offset=0x5 mask=0x2 value=0x0
[ 81.110735] rtw_8822be 0000:07:00.0: mac power on failed
[ 81.110737] rtw_8822be 0000:07:00.0: failed to power on mac
[ 83.110776] rtw_8822be 0000:07:00.0: failed to poll offset=0x5 mask=0x2 value=0x0
[ 83.110781] rtw_8822be 0000:07:00.0: mac power on failed
[ 83.110782] rtw_8822be 0000:07:00.0: failed to power on mac
Oct 01 10:16:06 Legion kernel: x86/cpu: SGX disabled by BIOS.
Oct 01 10:16:06 Legion kernel: MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
Oct 01 10:16:06 Legion kernel: MMIO Stale Data CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/processor_mmio_stale_data.html for more details.
Oct 01 10:16:06 Legion kernel: #7 #8 #9 #10 #11
Oct 01 10:16:06 Legion kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Oct 01 10:16:06 Legion kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.TPLD], AE_ALREADY_EXISTS (20210730/dswload2-326)
Oct 01 10:16:06 Legion kernel: ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20210730/psobject-220)
Oct 01 10:16:06 Legion kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.XHC.RHUB.HS01], AE_NOT_FOUND (20210730/dswload2-162)
Oct 01 10:16:06 Legion kernel: ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20210730/psobject-220)
Oct 01 10:16:06 Legion kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.XHC.RHUB.HS02], AE_NOT_FOUND (20210730/dswload2-162)
Oct 01 10:16:06 Legion kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.XHC.RHUB.HS03], AE_NOT_FOUND (20210730/dswload2-162)
Oct 01 10:16:06 Legion kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.XHC.RHUB.HS04], AE_NOT_FOUND (20210730/dswload2-162)
Oct 01 10:16:06 Legion kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.XHC.RHUB.HS05], AE_NOT_FOUND (20210730/dswload2-162)
Oct 01 10:16:06 Legion kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.XHC.RHUB.HS06], AE_NOT_FOUND (20210730/dswload2-162)
Oct 01 10:16:06 Legion kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.XHC.RHUB.HS07], AE_NOT_FOUND (20210730/dswload2-162)
Oct 01 10:16:06 Legion kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.XHC.RHUB.HS08], AE_NOT_FOUND (20210730/dswload2-162)
Oct 01 10:16:06 Legion kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.XHC.RHUB.HS09], AE_NOT_FOUND (20210730/dswload2-162)
Oct 01 10:16:06 Legion kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.XHC.RHUB.HS10], AE_NOT_FOUND (20210730/dswload2-162)
Oct 01 10:16:06 Legion kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.XHC.RHUB.HS11], AE_NOT_FOUND (20210730/dswload2-162)
Oct 01 10:16:06 Legion kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.XHC.RHUB.HS12], AE_NOT_FOUND (20210730/dswload2-162)
Oct 01 10:16:06 Legion kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.XHC.RHUB.HS13], AE_NOT_FOUND (20210730/dswload2-162)
Oct 01 10:16:06 Legion kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS14._UPC], AE_ALREADY_EXISTS (20210730/dswload2-326)
Oct 01 10:16:06 Legion kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS14._PLD], AE_ALREADY_EXISTS (20210730/dswload2-326)
Oct 01 10:16:06 Legion kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.XHC.RHUB.USR1], AE_NOT_FOUND (20210730/dswload2-162)
Oct 01 10:16:06 Legion kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.XHC.RHUB.USR2], AE_NOT_FOUND (20210730/dswload2-162)
Oct 01 10:16:06 Legion kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.XHC.RHUB.SS01], AE_NOT_FOUND (20210730/dswload2-162)
Oct 01 10:16:06 Legion kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.XHC.RHUB.SS02], AE_NOT_FOUND (20210730/dswload2-162)
Oct 01 10:16:06 Legion kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.XHC.RHUB.SS03], AE_NOT_FOUND (20210730/dswload2-162)
Oct 01 10:16:06 Legion kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.XHC.RHUB.SS04], AE_NOT_FOUND (20210730/dswload2-162)
Oct 01 10:16:06 Legion kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.XHC.RHUB.SS05], AE_NOT_FOUND (20210730/dswload2-162)
Oct 01 10:16:06 Legion kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.XHC.RHUB.SS06], AE_NOT_FOUND (20210730/dswload2-162)
Oct 01 10:16:06 Legion kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.XHC.RHUB.SS07], AE_NOT_FOUND (20210730/dswload2-162)
Oct 01 10:16:06 Legion kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.XHC.RHUB.SS08], AE_NOT_FOUND (20210730/dswload2-162)
Oct 01 10:16:06 Legion kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.XHC.RHUB.SS09], AE_NOT_FOUND (20210730/dswload2-162)
Oct 01 10:16:06 Legion kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.XHC.RHUB.SS10], AE_NOT_FOUND (20210730/dswload2-162)
Oct 01 10:16:06 Legion kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.I2C2.TPD0], AE_NOT_FOUND (20210730/dswload2-162)
Oct 01 10:16:06 Legion kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.I2C3.TPL1], AE_NOT_FOUND (20210730/dswload2-162)
Oct 01 10:16:06 Legion kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.PEG0.PEGP._ON], AE_ALREADY_EXISTS (20210730/dswload2-326)
Oct 01 10:16:06 Legion kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.PEG0.PEGP._OFF], AE_ALREADY_EXISTS (20210730/dswload2-326)
Oct 01 10:16:06 Legion kernel: acpi device:4a: Cannot transition to power state D0 for parent in D3hot
Oct 01 10:16:06 Legion kernel: i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
Oct 01 10:16:06 Legion kernel: vboxdrv: loading out-of-tree module taints kernel.
Oct 01 10:16:06 Legion kernel: VBoxNetAdp: Successfully started.
Oct 01 10:16:06 Legion kernel: VBoxNetFlt: Successfully started.
Oct 01 10:16:06 Legion kernel: usb 1-1.4: device descriptor read/64, error -71
Oct 01 10:16:06 Legion kernel: wmi_bus wmi_bus-PNP0C14:00: WQ data block query control method not found
Oct 01 10:16:06 Legion kernel: acpi PNP0C14:02: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:01)
Oct 01 10:16:07 Legion kernel: nvidia: module license 'NVIDIA' taints kernel.
Oct 01 10:16:07 Legion kernel: Disabling lock debugging due to kernel taint
Oct 01 10:16:07 Legion kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module 515.65.01 Wed Jul 20 14:00:58 UTC 2022
Oct 01 10:16:08 Legion kernel: nvidia_uvm: module uses symbols from proprietary module nvidia, inheriting taint.
Oct 01 10:16:08 Legion systemd[627]: ConfigurationDirectory 'bluetooth' already exists but the mode is different. (File system: 755 ConfigurationDirectoryMode: 555)
Oct 01 10:16:08 Legion bluetoothd[627]: Failed to set mode: Blocked through rfkill (0x12)
Oct 01 10:16:10 Legion NetworkManager[650]: <warn> [1664612170.9941] platform-linux: do-change-link[3]: failure changing link: failure 114 (Operation already in progress)
Oct 01 10:16:10 Legion kernel: rtw_8822be 0000:07:00.0: failed to poll offset=0x5 mask=0x2 value=0x0
Oct 01 10:16:10 Legion kernel: rtw_8822be 0000:07:00.0: mac power on failed
Oct 01 10:16:10 Legion kernel: rtw_8822be 0000:07:00.0: failed to power on mac
Oct 01 10:16:11 Legion kernel: ACPI Warning: \_SB.PCI0.PEG0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20210730/nsarguments-61)
Oct 01 10:16:12 Legion kernel: kauditd_printk_skb: 31 callbacks suppressed
Oct 01 10:16:12 Legion NetworkManager[650]: <warn> [1664612172.9945] platform-linux: do-change-link[3]: failure changing link: failure 114 (Operation already in progress)
Oct 01 10:16:12 Legion kernel: rtw_8822be 0000:07:00.0: failed to poll offset=0x5 mask=0x2 value=0x0
Oct 01 10:16:12 Legion kernel: rtw_8822be 0000:07:00.0: mac power on failed
Oct 01 10:16:12 Legion kernel: rtw_8822be 0000:07:00.0: failed to power on mac
Oct 01 10:16:13 Legion systemd[733]: xdg-user-dirs-update.service: Failed with result 'exit-code'.
Oct 01 10:16:13 Legion systemd[733]: Failed to start Update XDG user dir configuration.
Oct 01 10:16:13 Legion sddm-greeter[742]: QFont::fromString: Invalid description '(empty)'
Oct 01 10:16:13 Legion sddm-greeter[742]: QObject: Cannot create children for a parent that is in a different thread.
(Parent is QGuiApplication(0x7fffbb423be0), parent's thread is QThread(0x557c35566480), current thread is QThread(0x557c35686cf0)
Oct 01 10:16:13 Legion sddm-greeter[742]: QObject::installEventFilter(): Cannot filter events for objects in a different thread.
Oct 01 10:16:14 Legion sddm-greeter[742]: file:///usr/share/sddm/themes/breath/components/VirtualKeyboard.qml:11:1: Type InputPanel unavailable
Oct 01 10:16:14 Legion sddm-greeter[742]: qrc:/QtQuick/VirtualKeyboard/content/InputPanel.qml:127:5: Type Keyboard unavailable
Oct 01 10:16:14 Legion sddm-greeter[742]: qrc:/QtQuick/VirtualKeyboard/content/components/Keyboard.qml:38:1: module "QtQuick.VirtualKeyboard.Plugins" is not installed
Oct 01 10:16:14 Legion sddm-greeter[742]: file:///usr/share/sddm/themes/breath/Main.qml:465:13: Unable to assign [undefined] to QUrl
Oct 01 10:16:14 Legion sddm-greeter[742]: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.24'
Oct 01 10:16:15 Legion wpa_supplicant[727]: Could not set interface wlp7s0 flags (UP): Operation already in progress
Oct 01 10:16:15 Legion wpa_supplicant[727]: nl80211: Could not set interface 'wlp7s0' UP
Oct 01 10:16:15 Legion kernel: rtw_8822be 0000:07:00.0: failed to poll offset=0x5 mask=0x2 value=0x0
Oct 01 10:16:15 Legion kernel: rtw_8822be 0000:07:00.0: mac power on failed
Oct 01 10:16:15 Legion kernel: rtw_8822be 0000:07:00.0: failed to power on mac
Oct 01 10:16:17 Legion wpa_supplicant[727]: Could not set interface wlp7s0 flags (UP): Operation already in progress
Oct 01 10:16:17 Legion kernel: rtw_8822be 0000:07:00.0: failed to poll offset=0x5 mask=0x2 value=0x0
Oct 01 10:16:17 Legion kernel: rtw_8822be 0000:07:00.0: mac power on failed
Oct 01 10:16:17 Legion kernel: rtw_8822be 0000:07:00.0: failed to power on mac
Oct 01 10:16:17 Legion wpa_supplicant[727]: WEXT: Could not set interface 'wlp7s0' UP
Oct 01 10:16:17 Legion wpa_supplicant[727]: wlp7s0: Failed to initialize driver interface
Oct 01 10:16:17 Legion NetworkManager[650]: <error> [1664612177.0224] device (wlp7s0): Couldn't initialize supplicant interface: GDBus.Error:fi.w1.wpa_supplicant1.UnknownError: wpa_supplicant couldn't grab this interface.
Oct 01 10:16:18 Legion kernel: kauditd_printk_skb: 15 callbacks suppressed
Oct 01 10:16:25 Legion systemd-xdg-autostart-generator[801]: /home/zlatko/.config/autostart/org.kde.latte-dock.desktop:113: Unknown key name 'InitialPreference' in section 'Desktop Entry', ignoring.
Oct 01 10:16:26 Legion systemd-xdg-autostart-generator[839]: /home/zlatko/.config/autostart/org.kde.latte-dock.desktop:113: Unknown key name 'InitialPreference' in section 'Desktop Entry', ignoring.
Oct 01 10:16:26 Legion ksmserver[857]: Qt: Session management error: networkIdsList argument is NULL
Oct 01 10:16:26 Legion kwin_x11[860]: kwin_xkbcommon: XKB: inet:323:58: unrecognized keysym "XF86EmojiPicker"
Oct 01 10:16:26 Legion kwin_x11[860]: kwin_xkbcommon: XKB: inet:324:58: unrecognized keysym "XF86Dictate"
Oct 01 10:16:26 Legion ksmserver[857]: QDBusConnection: name 'org.kde.kglobalaccel' had owner '' but we thought it was ':1.11'
Oct 01 10:16:26 Legion kwin_x11[860]: kwin_decorations: Could not locate decoration plugin "org.kde.lightly"
Oct 01 10:16:26 Legion NetworkManager[650]: <warn> [1664612186.8118] device (wlp7s0): re-acquiring supplicant interface (#1).
Oct 01 10:16:26 Legion plasmashell[905]: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
Oct 01 10:16:26 Legion plasmashell[905]: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
Oct 01 10:16:26 Legion kwin_x11[860]: kwin_core: XCB error: 147 (BadOutput), sequence: 435, resource id: 33, major code: 140 (RANDR), minor code: 9 (GetOutputInfo)
Oct 01 10:16:26 Legion kwin_x11[860]: kwin_core: XCB error: 147 (BadOutput), sequence: 436, resource id: 0, major code: 140 (RANDR), minor code: 9 (GetOutputInfo)
Oct 01 10:16:26 Legion kwin_x11[860]: kwin_core: XCB error: 147 (BadOutput), sequence: 437, resource id: 357231616, major code: 140 (RANDR), minor code: 9 (GetOutputInfo)
Oct 01 10:16:26 Legion kwin_x11[860]: kwin_core: XCB error: 147 (BadOutput), sequence: 438, resource id: 32599, major code: 140 (RANDR), minor code: 9 (GetOutputInfo)
Oct 01 10:16:26 Legion kwin_x11[860]: QObject::connect(KWin::InputMethod, KWin::EffectsHandlerImpl): invalid nullptr parameter
Oct 01 10:16:27 Legion kded5[859]: kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/plasma/geolocationprovider/plasma-geolocation-gps.so: Cannot load library /usr/lib/qt/plugins/plasma/geolocationprovider/plasma-geolocation-gps.so: (libgps.so.29: cannot open shared object file: No such file or directory)"
Oct 01 10:16:27 Legion org_kde_powerdevil[924]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds not supported"
Oct 01 10:16:27 Legion kded5[859]: kscreen.kded: PowerDevil SuspendSession action not available!
Oct 01 10:16:27 Legion org_kde_powerdevil[924]: org.kde.powerdevil: Handle button events action could not check for screen configuration
Oct 01 10:16:27 Legion matray[1049]: Locale not supported by C library.
Using the fallback 'C' locale.
Oct 01 10:16:27 Legion kwin_x11[860]: kwin_core: XCB error: 147 (BadOutput), sequence: 1053, resource id: 53, major code: 140 (RANDR), minor code: 9 (GetOutputInfo)
Oct 01 10:16:27 Legion kwin_x11[860]: kwin_core: XCB error: 147 (BadOutput), sequence: 1054, resource id: 0, major code: 140 (RANDR), minor code: 9 (GetOutputInfo)
Oct 01 10:16:27 Legion kwin_x11[860]: kwin_core: XCB error: 147 (BadOutput), sequence: 1055, resource id: -42928505, major code: 140 (RANDR), minor code: 9 (GetOutputInfo)
Oct 01 10:16:27 Legion kwin_x11[860]: kwin_core: XCB error: 147 (BadOutput), sequence: 1056, resource id: 32592, major code: 140 (RANDR), minor code: 9 (GetOutputInfo)
Oct 01 10:16:27 Legion plasmashell[905]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:70:5: QML Connections: Detected function "onConfigurationChanged" in Connections element. This is probably intended to be a signal handler but no signal of the target matches the name.
Oct 01 10:16:27 Legion plasmashell[905]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:70:5: QML Connections: Detected function "onRepaintNeeded" in Connections element. This is probably intended to be a signal handler but no signal of the target matches the name.
Oct 01 10:16:27 Legion plasmashell[905]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:67: TypeError: Cannot read property 'wallpaper' of null
Oct 01 10:16:27 Legion plasmashell[905]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:71: TypeError: Cannot read property 'wallpaper' of null
Oct 01 10:16:27 Legion plasmashell[905]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
Oct 01 10:16:27 Legion kwin_x11[860]: kwin_core: XCB error: 152 (BadDamage), sequence: 2076, resource id: 16777253, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Oct 01 10:16:27 Legion kwin_x11[860]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 2092, resource id: 4194359, major code: 18 (ChangeProperty), minor code: 0
Oct 01 10:16:27 Legion plasmashell[905]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Panel.qml:179: TypeError: Cannot read property 'containmentDisplayHints' of null
Oct 01 10:16:27 Legion plasmashell[905]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Panel.qml:271: TypeError: Cannot read property 'location' of null
Oct 01 10:16:28 Legion plasmashell[905]: file:///usr/share/plasma/plasmoids/org.kde.plasma.panelspacer/contents/ui/main.qml:39:5: Unable to assign [undefined] to QQuickGridLayout*
Oct 01 10:16:28 Legion plasmashell[905]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:532:9: QML Label: Binding loop detected for property "height"
Oct 01 10:16:28 Legion plasmashell[905]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:497:13: QML Label: Binding loop detected for property "height"
Oct 01 10:16:28 Legion kded5[859]: kf.bluezqt: PendingCall Error: ""
Oct 01 10:16:28 Legion plasmashell[905]: org.kde.plasma.kicker: Entry is not valid "kontact.desktop" QSharedPointer(0x561d337a8e50)
Oct 01 10:16:28 Legion plasmashell[905]: org.kde.plasma.kicker: Entry is not valid "ktp-contactlist.desktop" QSharedPointer(0x561d337d1790)
Oct 01 10:16:28 Legion plasmashell[905]: org.kde.plasma.kicker: Entry is not valid "kontact.desktop" QSharedPointer(0x561d337d1790)
Oct 01 10:16:28 Legion plasmashell[905]: org.kde.plasma.kicker: Entry is not valid "ktp-contactlist.desktop" QSharedPointer(0x561d337d18c0)
Oct 01 10:16:28 Legion plasmashell[905]: org.kde.plasma.kicker: Entry is not valid "kontact.desktop" QSharedPointer(0x561d3390a350)
Oct 01 10:16:28 Legion plasmashell[905]: org.kde.plasma.kicker: Entry is not valid "ktp-contactlist.desktop" QSharedPointer(0x561d339381e0)
Oct 01 10:16:28 Legion plasmashell[905]: org.kde.plasma.kicker: Entry is not valid "kontact.desktop" QSharedPointer(0x561d33b56e50)
Oct 01 10:16:28 Legion plasmashell[905]: org.kde.plasma.kicker: Entry is not valid "ktp-contactlist.desktop" QSharedPointer(0x561d33b57d30)
Oct 01 10:16:28 Legion plasmashell[905]: file:///usr/share/plasma/plasmoids/org.kde.panel/contents/ui/ConfigOverlay.qml:312:17: QML SpinBox: Binding loop detected for property "implicitWidth"
Oct 01 10:16:28 Legion plasmashell[905]: file:///usr/share/plasma/plasmoids/org.kde.panel/contents/ui/ConfigOverlay.qml:304:17: QML Heading: Binding loop detected for property "verticalAlignment"
Oct 01 10:16:28 Legion plasmashell[905]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationHeader.qml"
Oct 01 10:16:28 Legion plasmashell[905]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/ThumbnailStrip.qml"
Oct 01 10:16:28 Legion wpa_supplicant[727]: Could not set interface wlp7s0 flags (UP): Operation already in progress
Oct 01 10:16:28 Legion wpa_supplicant[727]: nl80211: Could not set interface 'wlp7s0' UP
Oct 01 10:16:28 Legion kernel: rtw_8822be 0000:07:00.0: failed to poll offset=0x5 mask=0x2 value=0x0
Oct 01 10:16:28 Legion kernel: rtw_8822be 0000:07:00.0: mac power on failed
Oct 01 10:16:28 Legion kernel: rtw_8822be 0000:07:00.0: failed to power on mac
Oct 01 10:16:30 Legion wpa_supplicant[727]: Could not set interface wlp7s0 flags (UP): Operation already in progress
Oct 01 10:16:30 Legion wpa_supplicant[727]: WEXT: Could not set interface 'wlp7s0' UP
Oct 01 10:16:30 Legion wpa_supplicant[727]: wlp7s0: Failed to initialize driver interface
Oct 01 10:16:30 Legion NetworkManager[650]: <error> [1664612190.8137] device (wlp7s0): Couldn't initialize supplicant interface: GDBus.Error:fi.w1.wpa_supplicant1.UnknownError: wpa_supplicant couldn't grab this interface.
Oct 01 10:16:30 Legion kernel: rtw_8822be 0000:07:00.0: failed to poll offset=0x5 mask=0x2 value=0x0
Oct 01 10:16:30 Legion kernel: rtw_8822be 0000:07:00.0: mac power on failed
Oct 01 10:16:30 Legion kernel: rtw_8822be 0000:07:00.0: failed to power on mac
Oct 01 10:16:30 Legion kernel: kauditd_printk_skb: 11 callbacks suppressed
Oct 01 10:16:30 Legion plasmashell[905]: file:///usr/share/plasma/plasmoids/org.kde.plasma.volume/contents/ui/main.qml:603:39: Invalid property assignment: string expected - Assigning null to incompatible properties in QML is deprecated. This will become a compile error in future versions of Qt.
Oct 01 10:16:30 Legion pipewire[1210]: mod.rt: Can't find xdg-portal: (null)
Oct 01 10:16:30 Legion pipewire[1210]: mod.rt: found session bus but no portal
Oct 01 10:16:30 Legion pipewire-media-session[1211]: mod.rt: Can't find xdg-portal: (null)
Oct 01 10:16:30 Legion pipewire-media-session[1211]: mod.rt: found session bus but no portal
Oct 01 10:16:30 Legion pipewire-media-session[1211]: mod.rt: RTKit error: org.freedesktop.DBus.Error.AccessDenied
Oct 01 10:16:30 Legion pipewire-media-session[1211]: mod.rt: could not make thread 1212 realtime using RTKit: Permission denied
Oct 01 10:16:30 Legion pipewire[1210]: mod.rt: RTKit error: org.freedesktop.DBus.Error.AccessDenied
Oct 01 10:16:30 Legion pipewire[1210]: mod.rt: could not make thread 1215 realtime using RTKit: Permission denied
Oct 01 10:16:30 Legion plasmashell[905]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/ExpandedRepresentation.qml:167:9: QML HiddenItemsView: Binding loop detected for property "implicitHeight"
Oct 01 10:16:31 Legion plasmashell[905]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
Oct 01 10:16:31 Legion plasmashell[905]: qt.svg: Cannot open file '/usr/share/icons/Humanity/devices/48/printer.svg', because: No such file or directory
Oct 01 10:16:31 Legion plasmashell[905]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Oct 01 10:16:31 Legion plasmashell[905]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Oct 01 10:16:31 Legion pulseaudio[1186]: stat('/etc/pulse/default.pa.d'): No such file or directory
Oct 01 10:16:32 Legion plasmashell[905]: qt.svg: link #fcitx-kbd is undefined!
Oct 01 10:16:33 Legion plasmashell[905]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Oct 01 10:16:33 Legion plasmashell[905]: file:///usr/share/plasma/plasmoids/org.kde.plasma.networkmanagement/contents/ui/ConnectionItem.qml:45:32: QML Action: Accessible must be attached to an Item
Oct 01 10:16:33 Legion plasmashell[905]: kf.quickcharts.deprecated: ValueHistorySource is deprecated (since 5.78): Use HistoryProxySource instead
Oct 01 10:16:33 Legion plasmashell[905]: kf.quickcharts.deprecated: Note: Instantiated from "...plasma/plasmoids/org.kde.plasma.networkmanagement/contents/ui/TrafficMonitor.qml"
Oct 01 10:16:33 Legion plasmashell[905]: Qt Quick Layouts: Detected recursive rearrange. Aborting after two iterations.
Oct 01 10:16:39 Legion plasmashell[905]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Oct 01 10:16:40 Legion NetworkManager[650]: <warn> [1664612200.8135] device (wlp7s0): re-acquiring supplicant interface (#2).
Oct 01 10:16:42 Legion wpa_supplicant[727]: Could not set interface wlp7s0 flags (UP): Operation already in progress
Oct 01 10:16:42 Legion wpa_supplicant[727]: nl80211: Could not set interface 'wlp7s0' UP
Oct 01 10:16:42 Legion kernel: rtw_8822be 0000:07:00.0: failed to poll offset=0x5 mask=0x2 value=0x0
Oct 01 10:16:42 Legion kernel: rtw_8822be 0000:07:00.0: mac power on failed
Oct 01 10:16:42 Legion kernel: rtw_8822be 0000:07:00.0: failed to power on mac
Oct 01 10:16:43 Legion kstart5[1255]: Omitting both --window and --windowclass arguments is not recommended
Oct 01 10:16:43 Legion kwin_x11[860]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 6179, resource id: 60817418, major code: 18 (ChangeProperty), minor code: 0
Oct 01 10:16:43 Legion kwin_x11[860]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 6183, resource id: 60817419, major code: 18 (ChangeProperty), minor code: 0
Oct 01 10:16:44 Legion wpa_supplicant[727]: Could not set interface wlp7s0 flags (UP): Operation already in progress
Oct 01 10:16:44 Legion wpa_supplicant[727]: WEXT: Could not set interface 'wlp7s0' UP
Oct 01 10:16:44 Legion wpa_supplicant[727]: wlp7s0: Failed to initialize driver interface
Oct 01 10:16:44 Legion NetworkManager[650]: <error> [1664612204.8172] device (wlp7s0): Couldn't initialize supplicant interface: GDBus.Error:fi.w1.wpa_supplicant1.UnknownError: wpa_supplicant couldn't grab this interface.
Oct 01 10:16:44 Legion kernel: rtw_8822be 0000:07:00.0: failed to poll offset=0x5 mask=0x2 value=0x0
Oct 01 10:16:44 Legion kernel: rtw_8822be 0000:07:00.0: mac power on failed
Oct 01 10:16:44 Legion kernel: rtw_8822be 0000:07:00.0: failed to power on mac
Oct 01 10:16:54 Legion NetworkManager[650]: <warn> [1664612214.8153] device (wlp7s0): re-acquiring supplicant interface (#3).
Oct 01 10:16:56 Legion wpa_supplicant[727]: Could not set interface wlp7s0 flags (UP): Operation already in progress
Oct 01 10:16:56 Legion wpa_supplicant[727]: nl80211: Could not set interface 'wlp7s0' UP
Oct 01 10:16:56 Legion kernel: rtw_8822be 0000:07:00.0: failed to poll offset=0x5 mask=0x2 value=0x0
Oct 01 10:16:56 Legion kernel: rtw_8822be 0000:07:00.0: mac power on failed
Oct 01 10:16:56 Legion kernel: rtw_8822be 0000:07:00.0: failed to power on mac
Oct 01 10:16:58 Legion wpa_supplicant[727]: Could not set interface wlp7s0 flags (UP): Operation already in progress
Oct 01 10:16:58 Legion wpa_supplicant[727]: WEXT: Could not set interface 'wlp7s0' UP
Oct 01 10:16:58 Legion wpa_supplicant[727]: wlp7s0: Failed to initialize driver interface
Oct 01 10:16:58 Legion NetworkManager[650]: <error> [1664612218.8170] device (wlp7s0): Couldn't initialize supplicant interface: GDBus.Error:fi.w1.wpa_supplicant1.UnknownError: wpa_supplicant couldn't grab this interface.
Oct 01 10:16:58 Legion kernel: rtw_8822be 0000:07:00.0: failed to poll offset=0x5 mask=0x2 value=0x0
Oct 01 10:16:58 Legion kernel: rtw_8822be 0000:07:00.0: mac power on failed
Oct 01 10:16:58 Legion kernel: rtw_8822be 0000:07:00.0: failed to power on mac
Oct 01 10:17:04 Legion kwin_x11[860]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 7847, resource id: 56623187, major code: 18 (ChangeProperty), minor code: 0
Oct 01 10:17:04 Legion kwin_x11[860]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 7852, resource id: 56623188, major code: 18 (ChangeProperty), minor code: 0
Oct 01 10:17:08 Legion NetworkManager[650]: <warn> [1664612228.8191] device (wlp7s0): re-acquiring supplicant interface (#4).
Oct 01 10:17:10 Legion wpa_supplicant[727]: Could not set interface wlp7s0 flags (UP): Operation already in progress
Oct 01 10:17:10 Legion wpa_supplicant[727]: nl80211: Could not set interface 'wlp7s0' UP
Oct 01 10:17:10 Legion kernel: rtw_8822be 0000:07:00.0: failed to poll offset=0x5 mask=0x2 value=0x0
Oct 01 10:17:10 Legion kernel: rtw_8822be 0000:07:00.0: mac power on failed
Oct 01 10:17:10 Legion kernel: rtw_8822be 0000:07:00.0: failed to power on mac
Oct 01 10:17:12 Legion wpa_supplicant[727]: Could not set interface wlp7s0 flags (UP): Operation already in progress
Oct 01 10:17:12 Legion wpa_supplicant[727]: WEXT: Could not set interface 'wlp7s0' UP
Oct 01 10:17:12 Legion wpa_supplicant[727]: wlp7s0: Failed to initialize driver interface
Oct 01 10:17:12 Legion NetworkManager[650]: <error> [1664612232.8230] device (wlp7s0): Couldn't initialize supplicant interface: GDBus.Error:fi.w1.wpa_supplicant1.UnknownError: wpa_supplicant couldn't grab this interface.
Oct 01 10:17:12 Legion kernel: rtw_8822be 0000:07:00.0: failed to poll offset=0x5 mask=0x2 value=0x0
Oct 01 10:17:12 Legion kernel: rtw_8822be 0000:07:00.0: mac power on failed
Oct 01 10:17:12 Legion kernel: rtw_8822be 0000:07:00.0: failed to power on mac
Oct 01 10:17:22 Legion NetworkManager[650]: <warn> [1664612242.8124] device (wlp7s0): re-acquiring supplicant interface (#5).
Oct 01 10:17:24 Legion wpa_supplicant[727]: Could not set interface wlp7s0 flags (UP): Operation already in progress
Oct 01 10:17:24 Legion wpa_supplicant[727]: nl80211: Could not set interface 'wlp7s0' UP
Oct 01 10:17:24 Legion kernel: rtw_8822be 0000:07:00.0: failed to poll offset=0x5 mask=0x2 value=0x0
Oct 01 10:17:24 Legion kernel: rtw_8822be 0000:07:00.0: mac power on failed
Oct 01 10:17:24 Legion kernel: rtw_8822be 0000:07:00.0: failed to power on mac
Oct 01 10:17:26 Legion wpa_supplicant[727]: Could not set interface wlp7s0 flags (UP): Operation already in progress
Oct 01 10:17:26 Legion wpa_supplicant[727]: WEXT: Could not set interface 'wlp7s0' UP
Oct 01 10:17:26 Legion wpa_supplicant[727]: wlp7s0: Failed to initialize driver interface
Oct 01 10:17:26 Legion NetworkManager[650]: <error> [1664612246.8163] device (wlp7s0): Couldn't initialize supplicant interface: GDBus.Error:fi.w1.wpa_supplicant1.UnknownError: wpa_supplicant couldn't grab this interface.
Oct 01 10:17:26 Legion kernel: rtw_8822be 0000:07:00.0: failed to poll offset=0x5 mask=0x2 value=0x0
Oct 01 10:17:26 Legion kernel: rtw_8822be 0000:07:00.0: mac power on failed
Oct 01 10:17:26 Legion kernel: rtw_8822be 0000:07:00.0: failed to power on mac
Oct 01 10:17:29 Legion kioslave5[1003]: kf.kio.core: timeoutSpecialCommand() did not call finished() or error()! Please fix the kio_http KIO slave
Oct 01 10:17:29 Legion kioslave5[1007]: kf.kio.core: timeoutSpecialCommand() did not call finished() or error()! Please fix the kio_http KIO slave
Oct 01 10:19:33 Legion kstart5[1856]: Omitting both --window and --windowclass arguments is not recommended
Oct 01 10:19:33 Legion kwin_x11[860]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 33854, resource id: 79691786, major code: 18 (ChangeProperty), minor code: 0
Oct 01 10:19:33 Legion kwin_x11[860]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 33858, resource id: 79691787, major code: 18 (ChangeProperty), minor code: 0
Oct 01 10:20:52 Legion kwin_x11[860]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 42468, resource id: 16779974, major code: 3 (GetWindowAttributes), minor code: 0
Oct 01 10:20:52 Legion kwin_x11[860]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 42469, resource id: 16779974, major code: 14 (GetGeometry), minor code: 0
Oct 01 10:20:54 Legion kwin_x11[860]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Oct 01 10:20:54 Legion kwin_x11[860]: file:///usr/lib/qt/qml/org/kde/kwin/private/effects/WindowHeap.qml:56:9: Unable to assign null to QUuid
