Wifi adapter no connections found
Hi @Zneter, and welcome!
Please see
https://wiki.archlinux.org/title/Laptop/Lenovo
More specifically, the Troubleshooting section.
Also, remember to remove any blacklist changes done should you try something from there.
Hope it helps!
Sadly enough it didn’t work.
also you mentioned that it was working with ā€˜ideapad_laptop’ blacklisted on ubuntu, did you tried it also blacklisting in manjaro?
Also, please provide the output of:
/usr/bin/cat /etc/modprobe.d/*
And:
/usr/bin/ls /etc/modprobe.d/
Yes I did, I copied my blacklist list from Ubuntu but didn’t work out.
blacklist r8822be
blacklist rtw88
blacklist rtwpci
blacklist btrtl
blacklist btusb
## Generated by mhwd - Manjaro Hardware Detection
blacklist nouveau
blacklist ttm
blacklist drm_kms_helper
blacklist drm
options nvidia "NVreg_DynamicPowerManagement=0x02"
blacklist rtw88_8821be
options rtw_pci disable_aspm=1
blacklistManjaro.conf  mhwd-gpu.conf  rtl8821be.conf
It seems you’ve got nothing left to lose, so Let’s do a test:
  1. Un-blacklist the module(s) that was previously blacklisted:
sudo mv /etc/modprobe.d/blacklistManjaro.conf ~/
sudo mv /etc/modprobe.d/rtl8821be.conf ~/
Followed by a reboot, and if the wifi still doesn’t work, please post the output of:
…again.
Here we go again haha.
  Kernel: 5.15.65-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
    root=UUID=f78e2cfd-a105-4f69-a5eb-9781d465c7b3 rw quiet
    udev.log_priority=3
  Console: pty pts/1 wm: kwin_x11 DM: SDDM Distro: Manjaro Linux
    base: Arch Linux
  Type: Laptop System: LENOVO product: 81FV v: Lenovo Legion Y530-15ICH
    serial: <filter> Chassis: type: 10 v: Lenovo Legion Y530-15ICH
    serial: <filter>
  Mobo: LENOVO model: LNVNB161216 v: SDK0R32862 WIN serial: <filter>
    UEFI: LENOVO v: 8JCN56WW date: 11/30/2020
  ID-1: BAT0 charge: 48.7 Wh (99.2%) condition: 49.1/52.5 Wh (93.6%)
    volts: 12.6 min: 11.3 model: LGC L17L3PG1 type: Li-poly serial: <filter>
    status: N/A
  RAM: total: 15.5 GiB used: 1.83 GiB (11.8%)
  Array-1: capacity: 32 GiB slots: 2 EC: None max-module-size: 16 GiB
    note: est.
  Device-1: ChannelA-DIMM0 type: DDR4 detail: synchronous size: 8 GiB
    speed: 2667 MT/s volts: curr: 1.2 min: 1.25 max: 1.35 width (bits): data: 64
    total: 64 manufacturer: Ramaxel part-no: RMSA3260MD78HAF-2666
    serial: <filter>
  Device-2: ChannelB-DIMM0 type: DDR4 detail: synchronous size: 8 GiB
    speed: 2667 MT/s volts: curr: 1.2 min: 1.25 max: 1.5 width (bits): data: 64
    serial: <filter>
  Info: model: Intel Core i7-8750H socket: BGA1440 (U3E1) note: check bits: 64
    type: MT MCP arch: Coffee Lake gen: core 8 level: v3 built: 2018
    process: Intel 14nm family: 6 model-id: 0x9E (158) stepping: 0xA (10)
    microcode: 0xF0
    L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
    L3: 9 MiB desc: 1x9 MiB
  Speed (MHz): avg: 800 min/max: 800/4100 scaling: driver: intel_pstate
    governor: powersave volts: 0.8 V ext-clock: 100 MHz cores: 1: 800 2: 800
    3: 800 4: 800 5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800
    bogomips: 52815
    intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
    movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
    pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp
    rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
    vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
    vulnerable
    prctl and seccomp
  Type: spectre_v2 mitigation: IBRS, IBPB: conditional, RSB filling,
    PBRSB-eIBRS: Not affected
  Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Lenovo
    ports: active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:3e9b
    class-ID: 0300
  Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile] vendor: Lenovo
    driver: nvidia v: 515.65.01 alternate: nouveau,nvidia_drm non-free: 515.xx+
    status: current (as of 2022-08) arch: Pascal code: GP10x
    process: TSMC 16nm built: 2016-21 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
    link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:1c8d
    class-ID: 0300
  Device-3: Chicony Integrated Camera (1280x720@30) type: USB
    driver: uvcvideo bus-ID: 1-6:5 chip-ID: 04f2:b604 class-ID: 0e02
    serial: <filter>
  Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
    loaded: modesetting,nvidia alternate: fbdev,nouveau,nv,vesa gpu: i915
    display-ID: :0 screens: 1
  Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1013x285mm (39.88x11.22")
    s-diag: 1052mm (41.43")
  Monitor-1: HDMI-1-0 pos: primary,right res: 1920x1080 hz: 75 dpi: 102
    size: 480x270mm (18.9x10.63") diag: 551mm (21.68") modes: N/A
  Monitor-2: eDP-1 pos: primary,left res: 1920x1080 hz: 60 dpi: 142
    size: 344x194mm (13.54x7.64") diag: 395mm (15.55") modes: N/A
  OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 22.1.7
    direct render: Yes
  Device-1: Intel Cannon Lake PCH cAVS vendor: Lenovo driver: snd_hda_intel
  Device-2: NVIDIA GP107GL High Definition Audio driver: snd_hda_intel
    v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
    speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 10de:0fb9 class-ID: 0403
  Sound Server-1: ALSA v: k5.15.65-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.57 running: yes
  Device-1: Realtek RTL8822BE 802.11a/b/g/n/ac WiFi adapter vendor: Lenovo
    ThinkPad E595 driver: N/A modules: rtw_8822be pcie: speed: Unknown
    lanes: 63 link-max: gen: 6 speed: 64 GT/s port: 4000 bus-ID: 07:00.0
    chip-ID: 10ec:b822 class-ID: 0280
    vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: 3000 bus-ID: 08:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp8s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-1: Realtek RTL8822BE Bluetooth 4.2 Adapter type: USB driver: btusb
    v: 0.8 bus-ID: 1-14:6 chip-ID: 0bda:b023 class-ID: e001 serial: <filter>
  Local Storage: total: 1.14 TiB used: 627.3 GiB (53.6%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN520
    SDAPMUW-256G-1101 size: 238.47 GiB block-size: physical: 512 B
    logical: 512 B speed: 15.8 Gb/s lanes: 2 type: SSD serial: <filter>
    rev: 20110001 temp: 35.9 C scheme: GPT
  SMART: yes health: PASSED on: 211d 15h cycles: 3,381 read-units: 62,537,884
    [32.0 TB] written-units: 85,844,803 [43.9 TB]
  ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM049-2GH172
    family: Barracuda Pro Compute size: 931.51 GiB block-size: physical: 4096 B
    logical: 512 B sata: 3.1 speed: 6.0 Gb/s type: HDD rpm: 7200
    serial: <filter> rev: LXM3 temp: 28 C scheme: GPT
  SMART: yes state: enabled health: PASSED on: 1y 16d 19h cycles: 3379
    Pre-Fail: attribute: Spin_Retry_Count value: 100 worst: 100 threshold: 97
  ID-1: / raw-size: 100 GiB size: 97.87 GiB (97.87%) used: 22.6 GiB (23.1%)
    fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: f78e2cfd-a105-4f69-a5eb-9781d465c7b3
  ID-2: /boot/efi raw-size: 513 MiB size: 512 MiB (99.80%) used: 312 KiB
    (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p3 maj-min: 259:3
    label: NO_LABEL uuid: 551A-FBD8
  ID-3: /home raw-size: 137.97 GiB size: 134.75 GiB (97.66%) used: 35.93 GiB
    (26.7%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p2 maj-min: 259:2
    label: N/A uuid: b8174b29-1d51-490a-8277-24f704305c22
  ID-4: /media/sdb9 raw-size: 687.36 GiB size: 687.36 GiB (100.00%)
    used: 568.76 GiB (82.7%) fs: ntfs block-size: 4096 B dev: /dev/sda2
    maj-min: 8:2 label: Data uuid: 408CFC828CFC742E
  ID-1: /dev/sda1 maj-min: 8:1 size: 16 MiB fs: N/A label: N/A uuid: N/A
  ID-2: /dev/sda3 maj-min: 8:3 size: 244.14 GiB fs: ext4 label: N/A
    uuid: 56e5a3c3-1353-435b-8bae-0cfdb1929855
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
  Hub-2: 1-1:2 info: Terminus Hub ports: 4 rev: 2.0 speed: 480 Mb/s
    power: 100mA chip-ID: 1a40:0101 class-ID: 0900
  Device-1: 1-1.4:4 info: China Resource Semico USB Keyboard
    type: Keyboard,Mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
    speed: 1.5 Mb/s power: 500mA chip-ID: 1a2c:45e8 class-ID: 0301
  Device-2: 1-2:3 info: Logitech G402 Gaming Mouse type: Mouse,HID
    power: 300mA chip-ID: 046d:c07e class-ID: 0300 serial: <filter>
  Device-3: 1-6:5 info: Chicony Integrated Camera (1280x720@30) type: Video
    chip-ID: 04f2:b604 class-ID: 0e02 serial: <filter>
  Device-4: 1-14:6 info: Realtek RTL8822BE Bluetooth 4.2 Adapter
    type: Bluetooth driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s
    power: 500mA chip-ID: 0bda:b023 class-ID: e001 serial: <filter>
  Hub-3: 2-0:1 info: Super-speed hub ports: 8 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 40.0 C pch: 54.0 C mobo: N/A
  Processes: 307 Uptime: 0m wakeups: 1 Init: systemd v: 251 default: graphical
  tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman
  pkgs: 1438 libs: 439 tools: pamac pm: flatpak pkgs: 0 Shell: Zsh (sudo)
  v: 5.9 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.21
Yes, well, I actually suspected as much. There is no driver loaded for it:
But, there is something in the AUR:
$ pamac search rtw88
rtw88-dkms-git        r1.029812e-2  AUR
Newest Realtek rtlwifi codes
So, install that with:
pamac build rtw88-dkms-git
and please provide the output before rebooting.
This is the output of:
Preparing...
Cloning rtw88-dkms-git build files...
Generating rtw88-dkms-git information...
Checking rtw88-dkms-git dependencies...
bsdtar: Failed to set default locale
Resolving dependencies...
Checking inter-conflicts...
To build (1):
  rtw88-dkms-git  r148.d3f92c9-1    AUR
Edit build files : [e]
Apply transaction ? [e/y/N] y
Building rtw88-dkms-git...
==> Making package: rtw88-dkms-git r148.d3f92c9-1 (Sat Oct  1 15:53:31 2022)
==> Retrieving sources...
  -> Updating rtw88 git repo...
    rtw88 ... Skipped
==> Extracting sources...
  -> Creating working copy of rtw88 git repo...
Cloning into 'rtw88'...
done.
==> Starting pkgver()...
==> Entering fakeroot environment...
==> Starting package()...
==> Tidying install...
  -> Removing libtool files...
  -> Purging unwanted files...
  -> Removing static library files...
  -> Stripping unneeded symbols from binaries and libraries...
  -> Compressing man and info pages...
==> Checking for packaging issues...
==> Creating package "rtw88-dkms-git"...
  -> Generating .PKGINFO file...
  -> Generating .BUILDINFO file...
  -> Adding install file...
  -> Generating .MTREE file...
  -> Compressing package...
==> Leaving fakeroot environment.
==> Finished making: rtw88-dkms-git r148.d3f92c9-1 (Sat Oct  1 15:53:41 2022)
==> Cleaning up...
Checking keyring...        [1/1]
Checking integrity...        [1/1]
Loading package files...        [1/1]
Checking file conflicts...        [1/1]
Checking available disc space...        [1/1]
Installing rtw88-dkms-git (r148.d3f92c9-1)...        [1/1]
Sign command: /usr/lib/modules/5.15.65-1-MANJARO/build/scripts/sign-file
Signing key: /var/lib/dkms/mok.key
Public certificate (MOK): /var/lib/dkms/mok.pub
Creating symlink /var/lib/dkms/rtw88/r148.d3f92c9/source -> /usr/src/rtw88-r148.d3f92c9
Building module:
Cleaning build area...(bad exit status: 2)
make -j12 KERNELRELEASE=5.15.65-1-MANJARO -C /usr/lib/modules/5.15.65-1-MANJARO/build M=/var/lib/dkms/rtw88/r148.d3f92c9/build.....
Signing module /var/lib/dkms/rtw88/r148.d3f92c9/build/rtw_pci.ko
Signing module /var/lib/dkms/rtw88/r148.d3f92c9/build/rtw_8723de.ko
Signing module /var/lib/dkms/rtw88/r148.d3f92c9/build/rtw_8723d.ko
Signing module /var/lib/dkms/rtw88/r148.d3f92c9/build/rtw_8822be.ko
Signing module /var/lib/dkms/rtw88/r148.d3f92c9/build/rtw_8822b.ko
Signing module /var/lib/dkms/rtw88/r148.d3f92c9/build/rtw_8822ce.ko
Signing module /var/lib/dkms/rtw88/r148.d3f92c9/build/rtw_8822c.ko
Signing module /var/lib/dkms/rtw88/r148.d3f92c9/build/rtw_8821ce.ko
Signing module /var/lib/dkms/rtw88/r148.d3f92c9/build/rtw_8821c.ko
Signing module /var/lib/dkms/rtw88/r148.d3f92c9/build/rtw_core.ko
rtw_pci.ko.xz:
Running module version sanity check.
 - Original module
   - Found /usr/lib/modules/5.15.65-1-MANJARO/updates/rtw_pci.ko.xz
   - Storing in /var/lib/dkms/rtw88/original_module/5.15.65-1-MANJARO/x86_64/
   - Archiving for uninstallation purposes
 - Installation
   - Installing to /usr/lib/modules/5.15.65-1-MANJARO/updates/dkms/
rtw_8723de.ko.xz:
 - Original module
   - Found /usr/lib/modules/5.15.65-1-MANJARO/updates/rtw_8723de.ko.xz
 - Installation
rtw_8723d.ko.xz:
 - Original module
   - Found /usr/lib/modules/5.15.65-1-MANJARO/updates/rtw_8723d.ko.xz
 - Installation
rtw_8822be.ko.xz:
 - Original module
   - Found /usr/lib/modules/5.15.65-1-MANJARO/updates/rtw_8822be.ko.xz
 - Installation
rtw_8822b.ko.xz:
 - Original module
   - Found /usr/lib/modules/5.15.65-1-MANJARO/updates/rtw_8822b.ko.xz
 - Installation
rtw_8822ce.ko.xz:
 - Original module
   - Found /usr/lib/modules/5.15.65-1-MANJARO/updates/rtw_8822ce.ko.xz
 - Installation
rtw_8822c.ko.xz:
 - Original module
   - Found /usr/lib/modules/5.15.65-1-MANJARO/updates/rtw_8822c.ko.xz
 - Installation
rtw_8821ce.ko.xz:
 - Original module
   - Found /usr/lib/modules/5.15.65-1-MANJARO/updates/rtw_8821ce.ko.xz
 - Installation
rtw_8821c.ko.xz:
 - Original module
   - Found /usr/lib/modules/5.15.65-1-MANJARO/updates/rtw_8821c.ko.xz
 - Installation
rtw_core.ko.xz:
 - Original module
   - Found /usr/lib/modules/5.15.65-1-MANJARO/updates/rtw_core.ko.xz
 - Installation
depmod.....
Arming ConditionNeedsUpdate...        [1/3]
Install DKMS modules        [2/3]
==> dkms install --no-depmod rtw88/r148.d3f92c9 -k 4.19.257-1-MANJARO
Error! Bad return status for module build on kernel: 4.19.257-1-MANJARO (x86_64)
Consult /var/lib/dkms/rtw88/r148.d3f92c9/build/make.log for more information.
==> WARNING: `dkms install --no-depmod rtw88/r148.d3f92c9 -k 4.19.257-1-MANJARO' exited 10
==> dkms install --no-depmod rtw88/r148.d3f92c9 -k 5.4.212-1-MANJARO
==> dkms install --no-depmod rtw88/r148.d3f92c9 -k 5.19.7-1-MANJARO
==> dkms install --no-depmod rtw88/r148.d3f92c9 -k 5.15.65-1-MANJARO
==> dkms install --no-depmod rtw88/r148.d3f92c9 -k 5.10.141-1-MANJARO
==> depmod 5.15.65-1-MANJARO
==> depmod 5.4.212-1-MANJARO
==> depmod 5.10.141-1-MANJARO
==> depmod 5.19.7-1-MANJARO
Refreshing PackageKit...        [3/3]
and I didn’t know if you needed the full output again so better safe then sorry:
EDIT: I’ll wait with a reboot until you say so.
    udev.log_priority=3
    base: Arch Linux
    serial: <filter>
    status: N/A
  RAM: total: 15.5 GiB used: 2.46 GiB (15.9%)
    note: est.
    serial: <filter>
    serial: <filter>
    microcode: 0xF0
  Speed (MHz): avg: 901 high: 1200 min/max: 800/4100 scaling:
    driver: intel_pstate governor: powersave volts: 0.8 V ext-clock: 100 MHz
    cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 818 8: 1200 9: 1200
    10: 1200 11: 800 12: 799 bogomips: 52815
    vulnerable
    prctl and seccomp
    class-ID: 0300
    class-ID: 0300
    serial: <filter>
    direct render: Yes
  Local Storage: total: 1.14 TiB used: 627.34 GiB (53.6%)
    rev: 20110001 temp: 33.9 C scheme: GPT
  SMART: yes health: PASSED on: 211d 15h cycles: 3,381 read-units: 62,540,033
    [32.0 TB] written-units: 85,845,569 [43.9 TB]
  ID-1: / raw-size: 100 GiB size: 97.87 GiB (97.87%) used: 22.64 GiB (23.1%)
  System Temperatures: cpu: 42.0 C pch: 51.0 C mobo: N/A
  Processes: 291 Uptime: 13m wakeups: 1 Init: systemd v: 251
  default: graphical tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6
  Packages: pm: pacman pkgs: 1439 libs: 439 tools: pamac pm: flatpak pkgs: 0
  Shell: Zsh (sudo) v: 5.9 default: Bash v: 5.1.16 running-in: konsole
  inxi: 3.3.21```
I think it might b e safe to reboot and see what happens.
Let’s cross out hearts, say a prayer, hold thumbs. And REBOOT
The prayer didn’t work out.
The device has a driver now but still nothing.
    udev.log_priority=3
    base: Arch Linux
    serial: <filter>
    status: N/A
  RAM: total: 15.5 GiB used: 2 GiB (12.9%)
    note: est.
    serial: <filter>
    serial: <filter>
    microcode: 0xF0
  Speed (MHz): avg: 3155 high: 4064 min/max: 800/4100 scaling:
    cores: 1: 4028 2: 4021 3: 4064 4: 4022 5: 3856 6: 2772 7: 2191 8: 1677
    9: 1598 10: 1602 11: 4022 12: 4008 bogomips: 52815
    vulnerable
    prctl and seccomp
    class-ID: 0300
    class-ID: 0300
    serial: <filter>
    direct render: Yes
    ThinkPad E595 driver: rtw_8822be v: kernel pcie: speed: Unknown lanes: 63
  IF: wlp7s0 state: down mac: <filter>
  Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
  Local Storage: total: 1.14 TiB used: 627.33 GiB (53.6%)
  SMART: yes health: PASSED on: 211d 15h cycles: 3,381 read-units: 62,542,061
    [32.0 TB] written-units: 85,845,748 [43.9 TB]
  System Temperatures: cpu: 42.0 C pch: 53.0 C mobo: N/A
  Processes: 310 Uptime: 1m wakeups: 1 Init: systemd v: 251 default: graphical
  pkgs: 1439 libs: 439 tools: pamac pm: flatpak pkgs: 0 Shell: Zsh (sudo)
OK, let’s remove it and try something else:
First, remove the current, non-working driver:
pamac remove rtw88-dkms-git
Then, according to this page, the rtl8812au driver should be used. And it is in the AUR:
$ pamac search rtl8812au
rtl8812au422-dkms-git        r176.4fa0ce3-1          AUR
Realtek 802.11ac (rtl8812au) v4.2.2 (7502.20130507) driver altered to build on Linux kernel version >= 3.10.
rtl8812au-inject-dkms-git        r44.2577553-1           AUR
A kernel module for Realtek 8812au network cards with dkms support, with monitor mode and injection support
rtl8812au-dkms-git        5.13.6.r129.g0fe44f8-1  AUR
rtl8812AU chipset driver with firmware v5.13.6
So install it with:
pamac build rtl8812au422-dkms-git
Once again, post the output of the command before rebooting, as before.
Here we go
Preparing...
Checking rtl8812au422-dkms-git dependencies...
To build (1):
Cloning rtl8812au422-dkms-git build files...
Generating rtl8812au422-dkms-git information...
Building rtl8812au422-dkms-git...
==> Making package: rtl8812au422-dkms-git r176.4fa0ce3-1 (Sat Oct  1 16:19:06 2022)
  -> Cloning rtl8812au git repo...
Cloning into bare repository '/var/tmp/pamac-build-zlatko/rtl8812au422-dkms-git/rtl8812au'...
remote: Enumerating objects: 996, done.
remote: Counting objects: 100% (116/116), done.
remote: Compressing objects: 100% (74/74), done.
remote: Total 996 (delta 49), reused 93 (delta 41), pack-reused 880
Receiving objects: 100% (996/996), 2.06 MiB | 8.25 MiB/s, done.
Resolving deltas: 100% (449/449), done.
  -> Found dkms.conf
    rtl8812au ... Skipped
    dkms.conf ... Passed
  -> Creating working copy of rtl8812au git repo...
Cloning into 'rtl8812au'...
done.
==> Creating package "rtl8812au422-dkms-git"...
==> Finished making: rtl8812au422-dkms-git r176.4fa0ce3-1 (Sat Oct  1 16:19:10 2022)
==> Cleaning up...
Installing rtl8812au422-dkms-git (r176.4fa0ce3-1)...                                                           [1/1]
==> dkms install --no-depmod rtl8812au/r176.4fa0ce3 -k 4.19.257-1-MANJARO
==> dkms install --no-depmod rtl8812au/r176.4fa0ce3 -k 5.15.65-1-MANJARO
==> dkms install --no-depmod rtl8812au/r176.4fa0ce3 -k 5.19.7-1-MANJARO
==> dkms install --no-depmod rtl8812au/r176.4fa0ce3 -k 5.4.212-1-MANJARO
==> dkms install --no-depmod rtl8812au/r176.4fa0ce3 -k 5.10.141-1-MANJARO
==> depmod 4.19.257-1-MANJARO
and
    udev.log_priority=3
    base: Arch Linux
    serial: <filter>
    status: N/A
  RAM: total: 15.5 GiB used: 2.79 GiB (18.0%)
    note: est.
    serial: <filter>
    serial: <filter>
    microcode: 0xF0
  Speed (MHz): avg: 1356 high: 2400 min/max: 800/4100 scaling:
    cores: 1: 1400 2: 1165 3: 1100 4: 823 5: 800 6: 800 7: 1240 8: 2298
    9: 2400 10: 2056 11: 1100 12: 1100 bogomips: 52815
    vulnerable
    prctl and seccomp
    class-ID: 0300
    class-ID: 0300
    serial: <filter>
    direct render: Yes
  Report: rfkill ID: hci0 rfk-id: 3 state: down bt-service: enabled,running
  Local Storage: total: 1.14 TiB used: 627.31 GiB (53.6%)
  SMART: yes health: PASSED on: 211d 15h cycles: 3,381 read-units: 62,544,477
    [32.0 TB] written-units: 85,846,255 [43.9 TB]
  ID-1: / raw-size: 100 GiB size: 97.87 GiB (97.87%) used: 22.62 GiB (23.1%)
  Processes: 298 Uptime: 17m wakeups: 1 Init: systemd v: 251
  inxi: 3.3.21
The moment of truth is now().
So again, hold your thumbs, cross your heart, say a prayer, and REBOOT
Edit:
Still nothing no success. Even with the blacklist.
Please provide thhe output for:
…and
…as before, please.
blacklist ideapad_laptop
blacklist nouveau
blacklist ttm
blacklist drm
and
blacklist-ideapad.conf  mhwd-gpu.conf
OK.
So remove the blacklist-ideapad.conf file:
sudo rm /etc/modprobe.d/blacklist-ideapad.conf
And then provide:
…again, please.
blacklist nouveau
blacklist ttm
blacklist drm
