I got this issue since I have done some software updates on my manjaro.
The docker is not working and by running it in console I got those couple of error lines.
chromium-armhf
Set host IP for Pulseaudio
/usr/local/bin/chromium-armhf: line 4: hostname: command not found
Enabling XHost Forwarding
non-network local connections being added to access control list
Searching for Docker image ...
Found and using 2cbe4a04edc2
WARNING: The requested image's platform (linux/arm) does not match the detected host platform (linux/arm64/v8) and no specific platform was requested
docker: Error response from daemon: failed to create shim: OCI runtime create failed: runc create failed: unable to start container process: unable to apply cgroup configuration: chown /sys/fs/cgroup/system.slice/docker-865912667ff981866e9c5be3bef890d4f70fc7b7901af3d438d032c6bc17053e.scope/memory.oom.group: no such file or directory: unknown.
Is there any solution for that?
I have been very happy since docker started to work for me almost 1 year ago.
Hope I will be able to get it back.
Regards!
You can fix that by adding the following entries at the end of your /boot/cmdline.txt file:
cgroup_enable=memory cgroup_memory=1
It is really a docker issue related to cgroup capabilities. Reboot and you will be good to go.
However, if you are planning to use the latest chromium-docker to have widevine, you are out of luck with the rest of us: chrome://components/ does not list widevine anymore
And there are a couple of other minor issues. For example, you may need to install inetutils to get hostname to work for that script and, if your paprefs is broken, you will need to install pulseaudio (uninstalling pipewire-pulse first, since it conflicts):
I did as you advised with this cgroup enable memory in cmdline.txt. I have also reinstalled docker and now it works as previous. It is possible for me to again watch Netflix. Thank you @LifeBlower .
Sry @Mangled, I can not list exact steps for you. I have just did as I mentioned. I can just suppose that I have some specific state of Manjaro. I could share with this but to be honest, I do not know how could I feed you.
Seems like the 64 bit Raspbian Bullseye has got the support for widevine through installing thee 32 bit version and switching to it.
Isnāt that possible on Manjaro?
this is what we do but we use dockers for 32bit app or systemd container option, as we do not maintain the 32bit user space anymore so we have to use the above options.
On a fresh Manjaro XFCE installation I didnāt need all those tips from this thread. What I did:
pamac install inetutils docker
reboot
systemctl enable docker
systemctl start docker
pamac install chromium-docker
reboot
And everything is fine, now I can watch Netflix on the second display (an old TV). Sound via HDMI works out of the box, I didnāt test bluetooth or other outputs (my Pi400 only has bluetooth and HDMI).
UPDATE: A minor drawback seems to be, that docker sends audio signals only to HDMI-1. Otherwise it works quite well.
Iām sorrry, I donāt have an account on amazon so I cannot test it. In general the solution for Manjaro with the armhf-docker-container is not perfect at all. It works, but only for some setups. Iām not able to route the audio output to bluetooth for example. Only HDMI-1 works. And after a few minutes of watching Netflix, chrome opens a popup and wantās to be updated.
I have just formatted and reinstalled from manjaro arm xfce to gnome.
I used fresh iso and proceed with chromium docker installation.
Netflix movie runs. Music is also available but I can not again manipulate with the volume (only one constant same level of volume is available from chromium docker).
First thing I did was to configure paprefs but i got this issue described here:
Sorry I do not get you @spikerguy.
I do not know how to use pipewire. Does pipewire is kind of substitute for paprefs?
You are saying that there is no way to use paprefs for chromium-docker?
Hi, i 've a problem with chromium-docker, i canāt start it
here is the error message :
[dams@dams-pc ~]$ sudo chromium-armhf
[sudo] Mot de passe de dams :
/usr/local/bin/chromium-armhf: ligne 4: hostname : commande introuvable
Searching for Docker image ā¦
Found and using ee9f33d99146
/usr/local/bin/chromium-armhf: ligne 13: pax11publish : commande introuvable
WARNING: The requested imageās platform (linux/arm/v7) does not match the detected host platform (linux/arm64/v8) and no specific platform was requested
Failed to dup renderonly object
free(): invalid pointer
[dams@dams-pc ~]$
