Hi,
what is the best way to get widevine to work in manjaro to be able to stream netflix or amazon prime. I heard vivaldi has a setup that should work on arm but am getting continuous web page crashes with it. Im currently using pbpro manjaro xfce.
Install chromium-docker
package.
Thanks, I just tried it now and it doesn’t seem to do anything. A terminal window will appear for a second and close. How do you run it?
Sounds like docker permission issue.
sudo usermod -aG docker $(whoami)
And then reboot so it will take effect.
Nothing should work.
Ok I typed in that exact command and rebooted. It still didn’t work. Terminal window opens for one sec and closes. Then I tried
Sudo usermod -aG docker mangled
(mangled computer username)
Still nothing.
Not sure but during the docker install, it couldnt load daemon. Could that be the issue?
Then you need to uninstall it and install it again and share the output from ite installation process.
sudo pacman -R chromium-docker
sudo pacman -S chromium-docker
Please share the output while it’s installing.
The logs can tell us something.
Thank you for your help. Reinstalling it fixed the issue. I wonder if the permissions had to be in place first before installing the docker. It works now and this time I did not see any issues with the daemon.
Thanks again
Hi,
I had the same issue as Mangled. Double installation worked.
Next issue I am facing is that there is no sound in chromium-docker.
I am working on Raspberry pi 4. Youtube audio plays ok in Firefox, but not in Chromium Docker.
@spikerguy I have found your other post where you say:
This is covered in my git already.
User will have to enable it from. Paprefs
https://github.com/spikerguy/docker-chromium-armhf/blob/master/chromium-armhf#L15
but i do not understand how to manage it to work.
Could you please explain step by step?
Regards
I will try it on my rpi4 and try to reproduce this.
It should work fine though.
Same issue on pi4 with chromium-docker 4.10.1610.6-3. Double installation and no sound.
Set host IP for Pulseaudio
/usr/local/bin/chromium-armhf: ligne 4: hostname : commande introuvable
Enabling XHost Forwarding
non-network local connections being added to access control list
Searching for Docker image ...
Found and using 3c58bc5d3e4a
WARNING: The requested image's platform (linux/arm) does not match the detected host platform (linux/arm64/v8) and no specific platform was requested
[1:217:0103/223651.901139:ERROR:bus.cc(393)] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are "tcp" and on UNIX "unix")
[1:217:0103/223652.025724:ERROR:bus.cc(393)] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are "tcp" and on UNIX "unix")
[1:217:0103/223652.025834:ERROR:bus.cc(393)] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are "tcp" and on UNIX "unix")
ALSA lib pcm.c:8382:(snd_pcm_set_params) Sample format not available for PLAYBACK: Invalid argument
[632:1:0103/223715.216617:ERROR:child_process_sandbox_support_impl_linux.cc(81)] FontService unique font name matching request did not receive a response.
[632:1:0103/223715.218034:ERROR:child_process_sandbox_support_impl_linux.cc(81)] FontService unique font name matching request did not receive a response.
[632:1:0103/223719.122721:ERROR:child_process_sandbox_support_impl_linux.cc(81)] FontService unique font name matching request did not receive a response.
[632:1:0103/223719.131174:ERROR:child_process_sandbox_support_impl_linux.cc(81)] FontService unique font name matching request did not receive a response.
[632:1:0103/223719.458249:ERROR:child_process_sandbox_support_impl_linux.cc(81)] FontService unique font name matching request did not receive a response.
[632:1:0103/223719.459732:ERROR:child_process_sandbox_support_impl_linux.cc(81)] FontService unique font name matching request did not receive a response.
I would like to test it, if I was not such a novice in linux. Can you give me a hint how to do it? Is there any other option to watch eg. Netflix on Manjaro ARM 64-bit run on Raspbery pi 4?
@spikerguy, will you try your chrome-docker solution, on your rpi?
Hello
Yes I have tried it but my electricity went off while installing and it corrupted my os idk why.
I tried it on another arm device and I see some warnings and some errors, I will look into it tomorrow will have to update the docker script.
Other user have it working fine he tried it few hours ago.
Update: I tried on GT King Pro and everything worked fine.
Please try this following
- Enable these in
papre
- Reboot
- Start
chromium-docker
Hopefully it use work and @Ace just confirmed that it works on his RPI4 8Gb on the second attempt.
Always no sound, triple installation. paprefs ok and reboot.(pi4 8Go)
After another attempt (I did double pacman again and PAPre changes), I see now what is my current problem. Starting from reference: in Firefox I have possibility to switch between the audio devices (hdmi0 and jack output). In chromium-docker, I can hear only from hdmi output. What is wierd, I see two devices in Audio settings, but switching between them, changes nothing - hdmi plays for both cases. And of course it does not suits to my needs, I would like to use jack connection. @spikerguy, does docker somehow force to use only the hdmi output?
If the paprefs is used then it will follow the default selected in the host pc.
I have tested it with Bluetooth headset and also hdmi but this was long time ago.
I can confirm that watching DRM contents in ARM is possible with chromium-docker. And been using it to watch Netflix in three days straight having work left behind
Primary problem for me now is that frame drops while watching it in full screen, nevertheless I don’t mind watching in normal-size window, you will eventually get used to it.
Also, I had this Error regarding bus.cc and maybe it’s the reason why the video is somewhat pixelated but I can bare with it.
Here’s the error I got.
[1:221:0109/060104.439404:ERROR:bus.cc(393)] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are “tcp” and on UNIX “unix”)
Came across this issue once. I could not toggle the volume from chromium-docker and all I did was the same way @spikerguy did.
Hello All,
I did fresh Manjaro Plasma ARM 64-bit installation on my new Raspberry Pi 4B 4GB ram. Firmware is from December 2020. After I have settled usb-storage configuration for SSD msata drive from which I am booting the system and after i did all system updates… I have did “this double” chromium-docker installation.
My issue now is:
Even I disable all audio devices I still can hear the chromium-docker audio e.g. youtube. I can"t change the voice volume and the sound came out as from hdmi cable.
@Ace, I don"t understand your last post, by saying “toggle the voice” you mean you can not control voice neighter?
@spikerguy, how do you understand this issue? can you refer to something? how can I test it? what to configure?
I wanted to create fully media rpi: spotify, netflix, youtube, kodi runned on relatively fast and cheap device. If I not find the solution with this Manjaro, what should i look for next?
Thanks in advance, regards.
