Ok, thanks for helping!
I removed the parameters from grub.
Reboot as you told me so, everything goes fine.
After suspend ok, but wifi disapears. So wifi issue persists.
I suspend it again, then it freeze
journalctl -b-1 -p5 --no-pager
dez 24 13:52:31 bruno-ser kernel: Linux version 6.1.1-1-MANJARO (builduser@fv-az191-932) (gcc (GCC) 12.2.0, GNU ld (GNU Binutils) 2.39.0) #1 SMP PREEMPT_DYNAMIC Wed Dec 21 23:21:50 UTC 2022
dez 24 13:52:31 bruno-ser kernel: Kernel command line: BOOT_IMAGE=/@/boot/vmlinuz-6.1-x86_64 root=UUID=8883d823-baf2-4d24-a39b-a9f4ad4d843c rw rootflags=subvol=@ bootsplash.bootfile=/bootsplash-themes/biglinux/bootsplash video=efifb:nobgrt nouveau.modeset=0 i915.modeset=1 radeon.modeset=1 nowatchdog systemd.show_status=1 nosoftlockup audit=0 nomce skew_tick=1 intremap=off intel_pstate=passive cpuidle.governor=teo clearcpuid=514 resume=UUID=dd880092-77f2-49fb-b0ee-c46c147d540b
dez 24 13:52:31 bruno-ser kernel: Unknown kernel command line parameters "BOOT_IMAGE=/@/boot/vmlinuz-6.1-x86_64", will be passed to user space.
dez 24 13:52:31 bruno-ser kernel: random: crng init done
dez 24 13:52:31 bruno-ser kernel: #2 #3 #4 #5 #6 #7 #8 #9 #10 #11
dez 24 13:52:31 bruno-ser kernel: ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
dez 24 13:52:31 bruno-ser kernel: SCSI subsystem initialized
dez 24 13:52:31 bruno-ser kernel: Expanded resource Reserved due to conflict with PCI Bus 0000:00
dez 24 13:52:31 bruno-ser kernel: VFS: Disk quotas dquot_6.6.0
dez 24 13:52:31 bruno-ser kernel: pci 0000:00:00.2: can't derive routing for PCI INT A
dez 24 13:52:31 bruno-ser kernel: pci 0000:00:00.2: PCI INT A: not connected
dez 24 13:52:31 bruno-ser kernel: Initialise system trusted keyrings
dez 24 13:52:31 bruno-ser kernel: Key type blacklist registered
dez 24 13:52:31 bruno-ser kernel: integrity: Platform Keyring initialized
dez 24 13:52:31 bruno-ser kernel: integrity: Machine keyring initialized
dez 24 13:52:31 bruno-ser kernel: Key type asymmetric registered
dez 24 13:52:31 bruno-ser kernel: Asymmetric key parser 'x509' registered
dez 24 13:52:31 bruno-ser kernel: mce: Unable to init MCE device (rc: -5)
dez 24 13:52:31 bruno-ser kernel: Loading compiled-in X.509 certificates
dez 24 13:52:31 bruno-ser kernel: Loaded X.509 cert 'Build time autogenerated kernel key: 5c5acb36a23c86b35d7c1f3b43fac8d124b46bd9'
dez 24 13:52:31 bruno-ser kernel: Key type .fscrypt registered
dez 24 13:52:31 bruno-ser kernel: Key type fscrypt-provisioning registered
dez 24 13:52:31 bruno-ser kernel: ata1.00: supports DRM functions and may not be fully accessible
dez 24 13:52:31 bruno-ser kernel: scsi 0:0:0:0: Direct-Access ATA Samsung SSD 870 1B6Q PQ: 0 ANSI: 5
dez 24 13:52:31 bruno-ser kernel: sd 0:0:0:0: [sda] 3907029168 512-byte logical blocks: (2.00 TB/1.82 TiB)
dez 24 13:52:31 bruno-ser kernel: sd 0:0:0:0: [sda] Write Protect is off
dez 24 13:52:31 bruno-ser kernel: sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
dez 24 13:52:31 bruno-ser kernel: sd 0:0:0:0: [sda] supports TCG Opal
dez 24 13:52:31 bruno-ser kernel: sd 0:0:0:0: [sda] Attached SCSI disk
dez 24 13:52:31 bruno-ser kernel: ACPI Error: No handler for Region [ECRM] (0000000064c8d1b7) [EmbeddedControl] (20220331/evregion-130)
dez 24 13:52:31 bruno-ser kernel: ACPI Error: Region EmbeddedControl (ID=3) has no handler (20220331/exfldio-261)
dez 24 13:52:31 bruno-ser kernel: ACPI Error: Aborting method \_SB.GPIO._EVT due to previous error (AE_NOT_EXIST) (20220331/psparse-529)
dez 24 13:52:31 bruno-ser kernel: sd 0:0:0:0: Attached scsi generic sg0 type 0
dez 24 13:52:31 bruno-ser kernel: v4l2loopback_dc: loading out-of-tree module taints kernel.
dez 24 13:52:31 bruno-ser kernel: v4l2loopback_dc: module verification failed: signature and/or required key missing - tainting kernel
dez 24 13:52:32 bruno-ser kernel: clocksource: timekeeping watchdog on CPU3: Marking clocksource 'tsc' as unstable because the skew is too large:
dez 24 13:52:32 bruno-ser kernel: clocksource: 'hpet' wd_nsec: 510549106 wd_now: 1ba2a15 wd_last: 14a9edf mask: ffffffff
dez 24 13:52:32 bruno-ser kernel: clocksource: 'tsc' cs_nsec: 506645786 cs_now: bc9ee5f16 cs_last: b65b2603a mask: ffffffffffffffff
dez 24 13:52:32 bruno-ser kernel: clocksource: 'tsc' is current clocksource.
dez 24 13:52:32 bruno-ser kernel: TSC found unstable after boot, most likely due to broken BIOS. Use 'tsc=unstable'.
dez 24 13:52:32 bruno-ser kernel: clocksource: Checking clocksource tsc synchronization from CPU 0 to CPUs 1-3,8.
dez 24 13:52:32 bruno-ser systemd-udevd[410]: nvme0: /etc/udev/rules.d/60-ioschedulers.rules:2 Failed to write ATTR{/sys/devices/pci0000:00/0000:00:02.3/0000:03:00.0/nvme/nvme0/queue/scheduler}, ignoring: No such file or directory
dez 24 13:52:32 bruno-ser systemd-udevd[400]: nvme0n1p2: /etc/udev/rules.d/60-ioschedulers.rules:2 Failed to write ATTR{/sys/devices/pci0000:00/0000:00:02.3/0000:03:00.0/nvme/nvme0/nvme0n1/nvme0n1p2/queue/scheduler}, ignoring: No such file or directory
dez 24 13:52:32 bruno-ser systemd-udevd[410]: nvme0n1p1: /etc/udev/rules.d/60-ioschedulers.rules:2 Failed to write ATTR{/sys/devices/pci0000:00/0000:00:02.3/0000:03:00.0/nvme/nvme0/nvme0n1/nvme0n1p1/queue/scheduler}, ignoring: No such file or directory
dez 24 13:52:32 bruno-ser systemd-udevd[401]: nvme0n1p3: /etc/udev/rules.d/60-ioschedulers.rules:2 Failed to write ATTR{/sys/devices/pci0000:00/0000:00:02.3/0000:03:00.0/nvme/nvme0/nvme0n1/nvme0n1p3/queue/scheduler}, ignoring: No such file or directory
dez 24 13:52:32 bruno-ser kernel: ccp 0000:04:00.2: ccp: unable to access the device: you might be running a broken BIOS.
dez 24 13:52:32 bruno-ser kernel: ccp 0000:04:00.2: tee enabled
dez 24 13:52:32 bruno-ser kernel: ccp 0000:04:00.2: psp enabled
dez 24 13:52:32 bruno-ser kernel: cfg80211: Loading compiled-in X.509 certificates for regulatory database
dez 24 13:52:32 bruno-ser kernel: cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
dez 24 13:52:32 bruno-ser kernel: r8168 Copyright (C) 2022 Realtek NIC software team <nicfae@realtek.com>
This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>.
This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>.
dez 24 13:52:33 bruno-ser kernel: amdgpu 0000:04:00.0: amdgpu: PSP runtime database doesn't exist
dez 24 13:52:33 bruno-ser kernel: wl: module license 'MIXED/Proprietary' taints kernel.
dez 24 13:52:33 bruno-ser kernel: Disabling lock debugging due to kernel taint
dez 24 13:52:33 bruno-ser systemd-udevd[416]: cfg80211: Process '/usr/bin/set-wireless-regdom' failed with exit code 1.
dez 24 13:52:33 bruno-ser systemd-udevd[401]: nvme0n1p1: /etc/udev/rules.d/60-ioschedulers.rules:2 Failed to write ATTR{/sys/devices/pci0000:00/0000:00:02.3/0000:03:00.0/nvme/nvme0/nvme0n1/nvme0n1p1/queue/scheduler}, ignoring: No such file or directory
dez 24 13:52:33 bruno-ser polkitd[593]: Loading rules from directory /etc/polkit-1/rules.d
dez 24 13:52:33 bruno-ser polkitd[593]: Loading rules from directory /usr/share/polkit-1/rules.d
dez 24 13:52:33 bruno-ser polkitd[593]: Finished loading, compiling and executing 9 rules
dez 24 13:52:33 bruno-ser polkitd[593]: Acquired the name org.freedesktop.PolicyKit1 on the system bus
dez 24 13:52:34 bruno-ser kernel: amdgpu: SRAT table not found
dez 24 13:52:35 bruno-ser kernel: usb 1-2-port4: connect-debounce failed
dez 24 13:52:35 bruno-ser uresourced[1045]: Setting resources on user.slice (MemoryMin: 262144000, MemoryLow: 0, CPUWeight: -, IOWeight: -)
dez 24 13:52:35 bruno-ser uresourced[1045]: Setting resources on user-960.slice (MemoryMin: 262144000, MemoryLow: 0, CPUWeight: 500, IOWeight: 500)
dez 24 13:52:35 bruno-ser uresourced[1045]: Setting resources on user@960.service (MemoryMin: 0, MemoryLow: 0, CPUWeight: 100, IOWeight: 100)
dez 24 13:52:35 bruno-ser python3[955]: QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-root'
dez 24 13:52:35 bruno-ser dbus-broker-launch[583]: Activation request for 'org.freedesktop.home1' failed: The systemd unit 'dbus-org.freedesktop.home1.service' could not be found.
dez 24 13:52:35 bruno-ser systemd[1050]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8002 service=[systemd-user] terminal=[] user=[sddm] ruser=[<unknown>] rhost=[<unknown>]
dez 24 13:52:35 bruno-ser python3[955]: No suitable graphics backend found
dez 24 13:52:35 bruno-ser dbus-broker-launch[1098]: Service file '/usr/share//dbus-1/services/org.kde.dolphin.FileManager1.service' is not named after the D-Bus name 'org.freedesktop.FileManager1'.
dez 24 13:52:35 bruno-ser dbus-broker-launch[1098]: Service file '/usr/share//dbus-1/services/org.kde.kscreen.service' is not named after the D-Bus name 'org.kde.KScreen'.
dez 24 13:52:35 bruno-ser dbus-broker-launch[1098]: Service file '/usr/share//dbus-1/services/org.kde.plasma.Notifications.service' is not named after the D-Bus name 'org.freedesktop.Notifications'.
dez 24 13:52:35 bruno-ser udisksd[1109]: udisks daemon version 2.9.4 starting
dez 24 13:52:35 bruno-ser udisksd[1109]: Acquired the name org.freedesktop.UDisks2 on the system message bus
dez 24 13:52:37 bruno-ser bluetoothd[1515]: profiles/audio/vcp.c:vcp_init() D-Bus experimental not enabled
dez 24 13:52:37 bruno-ser bluetoothd[1515]: src/plugin.c:plugin_init() Failed to init vcp plugin
dez 24 13:52:37 bruno-ser bluetoothd[1515]: profiles/audio/mcp.c:mcp_init() D-Bus experimental not enabled
dez 24 13:52:37 bruno-ser bluetoothd[1515]: src/plugin.c:plugin_init() Failed to init mcp plugin
dez 24 13:52:37 bruno-ser bluetoothd[1515]: profiles/audio/bap.c:bap_init() D-Bus experimental not enabled
dez 24 13:52:37 bruno-ser bluetoothd[1515]: src/plugin.c:plugin_init() Failed to init bap plugin
dez 24 13:52:37 bruno-ser kernel: Bluetooth: hci0: HCI Enhanced Setup Synchronous Connection command is advertised, but not supported.
dez 24 13:52:38 bruno-ser dbus-broker-launch[583]: Activation request for 'org.freedesktop.resolve1' failed: The systemd unit 'dbus-org.freedesktop.resolve1.service' could not be found.
dez 24 13:52:38 bruno-ser nmbd[1531]: [2022/12/24 13:52:38.343103, 0] ../../source3/nmbd/nmbd.c:901(main)
dez 24 13:52:38 bruno-ser nmbd[1531]: nmbd version 4.17.4 started.
dez 24 13:52:38 bruno-ser nmbd[1531]: Copyright Andrew Tridgell and the Samba Team 1992-2022
dez 24 13:52:38 bruno-ser smbd[1534]: [2022/12/24 13:52:38.405060, 0] ../../source3/smbd/server.c:1741(main)
dez 24 13:52:38 bruno-ser smbd[1534]: smbd version 4.17.4 started.
dez 24 13:52:38 bruno-ser smbd[1534]: Copyright Andrew Tridgell and the Samba Team 1992-2022
dez 24 13:52:38 bruno-ser NetworkManager[586]: <error> [1671900758.6270] audit: failed to open auditd socket: Protocolo sem suporte
dez 24 13:52:51 bruno-ser systemd[1822]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8002 service=[systemd-user] terminal=[] user=[bruno] ruser=[<unknown>] rhost=[<unknown>]
dez 24 13:52:51 bruno-ser uresourced[1045]: Setting resources on user-960.slice (MemoryMin: 0, MemoryLow: 0, CPUWeight: 100, IOWeight: 100)
dez 24 13:52:51 bruno-ser uresourced[1045]: Setting resources on user@960.service (MemoryMin: 0, MemoryLow: 0, CPUWeight: 100, IOWeight: 100)
dez 24 13:52:51 bruno-ser uresourced[1045]: Setting resources on user-1000.slice (MemoryMin: 262144000, MemoryLow: 0, CPUWeight: 500, IOWeight: 500)
dez 24 13:52:51 bruno-ser uresourced[1045]: Setting resources on user@1000.service (MemoryMin: 0, MemoryLow: 0, CPUWeight: 100, IOWeight: 100)
dez 24 13:52:52 bruno-ser uresourced[1045]: Setting resources on user-1000.slice (MemoryMin: 262144000, MemoryLow: 0, CPUWeight: 500, IOWeight: 500)
dez 24 13:52:52 bruno-ser uresourced[1045]: Setting resources on user@1000.service (MemoryMin: 262144000, MemoryLow: 0, CPUWeight: 500, IOWeight: 500)
dez 24 13:52:52 bruno-ser polkitd[593]: Registered Authentication Agent for unix-session:2 (system bus name :1.57 [/usr/lib/polkit-kde-authentication-agent-1], object path /org/kde/PolicyKit1/AuthenticationAgent, locale pt_BR.UTF-8)
dez 24 13:53:01 bruno-ser systemd[1054]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8004 service=[systemd-user] terminal=[] user=[sddm] ruser=[<unknown>] rhost=[<unknown>]
dez 24 13:53:02 bruno-ser bluetoothd[1515]: src/profile.c:record_cb() Unable to get Hands-Free Voice gateway SDP record: Host is down
dez 24 13:53:09 bruno-ser bluetoothd[1515]: profiles/audio/avdtp.c:avdtp_connect_cb() connect to EC:81:93:7A:6B:98: Host is down (112)
dez 24 13:53:11 bruno-ser nmbd[1531]: [2022/12/24 13:53:11.036680, 0] ../../source3/nmbd/nmbd_become_lmb.c:398(become_local_master_stage2)
dez 24 13:53:11 bruno-ser nmbd[1531]: *****
dez 24 13:53:11 bruno-ser nmbd[1531]: Samba name server BRUNO-SER is now a local master browser for workgroup WORKGROUP on subnet 192.168.0.229
dez 24 13:54:30 bruno-ser kernel: [UFW BLOCK] IN=enp1s0 OUT= MAC=01:00:5e:00:00:01:90:9a:4a:be:e4:b2:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=26788 DF PROTO=2
dez 24 13:54:39 bruno-ser kernel: [UFW BLOCK] IN=enp1s0 OUT= MAC=01:00:5e:00:00:fb:30:58:90:28:d1:0a:08:00 SRC=192.168.0.214 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
dez 24 13:56:35 bruno-ser kernel: [UFW BLOCK] IN=enp1s0 OUT= MAC=01:00:5e:00:00:01:90:9a:4a:be:e4:b2:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=47109 DF PROTO=2
dez 24 13:56:41 bruno-ser kernel: [UFW BLOCK] IN=enp1s0 OUT= MAC=01:00:5e:00:00:fb:30:58:90:28:d1:0a:08:00 SRC=192.168.0.214 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
dez 24 13:58:40 bruno-ser kernel: [UFW BLOCK] IN=enp1s0 OUT= MAC=01:00:5e:00:00:01:90:9a:4a:be:e4:b2:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=10595 DF PROTO=2
dez 24 13:58:44 bruno-ser kernel: [UFW BLOCK] IN=enp1s0 OUT= MAC=01:00:5e:00:00:fb:30:58:90:28:d1:0a:08:00 SRC=192.168.0.214 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
dez 24 14:00:45 bruno-ser kernel: [UFW BLOCK] IN=enp1s0 OUT= MAC=01:00:5e:00:00:01:90:9a:4a:be:e4:b2:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=29934 DF PROTO=2
dez 24 14:00:55 bruno-ser kernel: [UFW BLOCK] IN=enp1s0 OUT= MAC=01:00:5e:00:00:fb:30:58:90:28:d1:0a:08:00 SRC=192.168.0.214 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
dez 24 14:01:01 bruno-ser anacron[3614]: Anacron started on 2022-12-24
dez 24 14:01:01 bruno-ser anacron[3614]: Will run job `cron.daily' in 24 min.
dez 24 14:01:01 bruno-ser anacron[3614]: Jobs will be executed sequentially
dez 24 14:02:50 bruno-ser kernel: [UFW BLOCK] IN=enp1s0 OUT= MAC=01:00:5e:00:00:01:90:9a:4a:be:e4:b2:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=58357 DF PROTO=2
dez 24 14:02:53 bruno-ser kernel: [UFW BLOCK] IN=enp1s0 OUT= MAC=01:00:5e:00:00:fb:30:58:90:28:d1:0a:08:00 SRC=192.168.0.214 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
dez 24 14:04:30 bruno-ser polkitd[593]: Operator of unix-session:2 successfully authenticated as unix-user:bruno to gain TEMPORARY authorization for action org.manjaro.msm.mhwd.install for system-bus-name::1.137 [/usr/bin/manjaro-settings-manager] (owned by unix-user:bruno)
dez 24 14:04:55 bruno-ser kernel: [UFW BLOCK] IN=enp1s0 OUT= MAC=01:00:5e:00:00:01:90:9a:4a:be:e4:b2:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=3996 DF PROTO=2
dez 24 14:04:56 bruno-ser kernel: [UFW BLOCK] IN=enp1s0 OUT= MAC=01:00:5e:00:00:fb:bc:7f:a4:ff:da:35:08:00 SRC=192.168.0.147 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
dez 24 14:07:00 bruno-ser kernel: [UFW BLOCK] IN=enp1s0 OUT= MAC=01:00:5e:00:00:01:90:9a:4a:be:e4:b2:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=9372 DF PROTO=2
dez 24 14:07:01 bruno-ser kernel: [UFW BLOCK] IN=enp1s0 OUT= MAC=01:00:5e:00:00:fb:bc:7f:a4:ff:da:35:08:00 SRC=192.168.0.147 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
dez 24 14:09:06 bruno-ser kernel: [UFW BLOCK] IN=enp1s0 OUT= MAC=01:00:5e:00:00:01:90:9a:4a:be:e4:b2:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=32298 DF PROTO=2
dez 24 14:09:06 bruno-ser kernel: [UFW BLOCK] IN=enp1s0 OUT= MAC=01:00:5e:00:00:fb:30:58:90:28:d1:0a:08:00 SRC=192.168.0.214 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
dez 24 14:11:11 bruno-ser kernel: [UFW BLOCK] IN=enp1s0 OUT= MAC=01:00:5e:00:00:01:90:9a:4a:be:e4:b2:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=53125 DF PROTO=2
dez 24 14:11:14 bruno-ser kernel: [UFW BLOCK] IN=enp1s0 OUT= MAC=01:00:5e:00:00:fb:bc:7f:a4:ff:da:35:08:00 SRC=192.168.0.147 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
dez 24 14:13:16 bruno-ser kernel: [UFW BLOCK] IN=enp1s0 OUT= MAC=01:00:5e:00:00:01:90:9a:4a:be:e4:b2:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=5358 DF PROTO=2
dez 24 14:13:18 bruno-ser kernel: [UFW BLOCK] IN=enp1s0 OUT= MAC=01:00:5e:00:00:fb:30:58:90:28:d1:0a:08:00 SRC=192.168.0.214 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
dez 24 14:15:21 bruno-ser kernel: [UFW BLOCK] IN=enp1s0 OUT= MAC=01:00:5e:00:00:01:90:9a:4a:be:e4:b2:08:00 SRC=192.168.0.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=16440 DF PROTO=2
dez 24 14:15:25 bruno-ser kernel: [UFW BLOCK] IN=enp1s0 OUT= MAC=01:00:5e:00:00:fb:30:58:90:28:d1:0a:08:00 SRC=192.168.0.214 DST=224.0.0.251 LEN=32 TOS=0x00 PREC=0xC0 TTL=1 ID=0 DF PROTO=2
dez 24 14:16:17 bruno-ser polkitd[593]: Operator of unix-session:2 successfully authenticated as unix-user:bruno to gain ONE-SHOT authorization for action org.kde.ktexteditor.katetextbuffer.savefile for system-bus-name::1.288 [kate /etc/default/grub] (owned by unix-user:bruno)
dez 24 14:17:08 bruno-ser polkitd[593]: Unregistered Authentication Agent for unix-session:2 (system bus name :1.57, object path /org/kde/PolicyKit1/AuthenticationAgent, locale pt_BR.UTF-8) (disconnected from bus)
dez 24 14:17:08 bruno-ser systemd-logind[599]: The system will reboot now!
dez 24 14:17:08 bruno-ser systemd-logind[599]: System is rebooting.
dez 24 14:17:08 bruno-ser sddm[721]: Authentication error: "Process crashed"
dez 24 14:17:08 bruno-ser sddm[721]: Auth: sddm-helper crashed (exit code 15)
dez 24 14:17:08 bruno-ser sddm[721]: Auth: sddm-helper exited with 15
dez 24 14:17:09 bruno-ser sddm[721]: Failed to read display number from pipe
dez 24 14:17:09 bruno-ser sddm[721]: Attempt 1 starting the Display server on vt 1 failed
dez 24 14:17:09 bruno-ser sddm[721]: Signal received: SIGTERM
dez 24 14:17:09 bruno-ser udisksd[1109]: udisks daemon version 2.9.4 exiting
dez 24 14:17:09 bruno-ser systemd-coredump[6862]: Failed to connect to coredump service: Connection refused
dez 24 14:17:09 bruno-ser systemd[1]: udisks2.service: Main process exited, code=dumped, status=6/ABRT
dez 24 14:17:09 bruno-ser systemd[1]: udisks2.service: Failed with result 'core-dump'.
dez 24 14:17:09 bruno-ser systemd[1]: Requested transaction contradicts existing jobs: Transaction for bluetooth.service/start is destructive (systemd-journal-catalog-update.service has 'stop' job queued, but 'start' is included in transaction).
dez 24 14:17:09 bruno-ser systemd[1]: Requested transaction contradicts existing jobs: Transaction for bluetooth.service/start is destructive (shutdown.target has 'start' job queued, but 'stop' is included in transaction).
dez 24 14:17:09 bruno-ser systemd[1822]: dbus-:1.2-org.freedesktop.Notifications@1.service: Main process exited, code=exited, status=255/EXCEPTION
dez 24 14:17:09 bruno-ser systemd[1822]: dbus-:1.2-org.freedesktop.Notifications@1.service: Failed with result 'exit-code'.
dez 24 14:17:09 bruno-ser systemd[1822]: Requested transaction contradicts existing jobs: Transaction for dbus-:1.2-org.freedesktop.Notifications@2.service/start is destructive (shutdown.target has 'start' job queued, but 'stop' is included in transaction).
dez 24 14:17:09 bruno-ser wireplumber[1961]: stopped by signal: Terminado
dez 24 14:17:09 bruno-ser systemd[1822]: Requested transaction contradicts existing jobs: Transaction for dbus-:1.2-org.freedesktop.Notifications@3.service/start is destructive (gpg-agent-ssh.socket has 'stop' job queued, but 'start' is included in transaction).
dez 24 14:17:09 bruno-ser systemd[1822]: Requested transaction contradicts existing jobs: Transaction for dbus-:1.2-org.freedesktop.Notifications@4.service/start is destructive (gpg-agent-browser.socket has 'stop' job queued, but 'start' is included in transaction).
dez 24 14:17:09 bruno-ser systemd[1822]: Requested transaction contradicts existing jobs: Transaction for dbus-:1.2-org.freedesktop.Notifications@5.service/start is destructive (pipewire.socket has 'stop' job queued, but 'start' is included in transaction).
dez 24 14:17:09 bruno-ser wireplumber[1961]: disconnected from pipewire
dez 24 14:17:09 bruno-ser systemd[1822]: Requested transaction contradicts existing jobs: Transaction for dbus-:1.2-org.freedesktop.Notifications@6.service/start is destructive (basic.target has 'stop' job queued, but 'start' is included in transaction).
dez 24 14:17:09 bruno-ser systemd[1822]: Requested transaction contradicts existing jobs: Transaction for dbus-:1.2-org.freedesktop.Notifications@7.service/start is destructive (gpg-agent-ssh.socket has 'stop' job queued, but 'start' is included in transaction).
dez 24 14:17:09 bruno-ser systemd[1822]: noise-reduction-pipewire.service: Control process exited, code=exited, status=1/FAILURE
dez 24 14:17:09 bruno-ser systemd[1822]: noise-reduction-pipewire.service: Failed with result 'exit-code'.
dez 24 14:17:09 bruno-ser systemd[1829]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8004 service=[systemd-user] terminal=[] user=[bruno] ruser=[<unknown>] rhost=[<unknown>]
dez 24 14:17:09 bruno-ser systemd[1]: user@1000.service: Consumed 12min 33.301s CPU time.
dez 24 14:17:09 bruno-ser nmbd[1531]: [2022/12/24 14:17:09.758492, 0] ../../source3/nmbd/nmbd.c:59(terminate)
dez 24 14:17:09 bruno-ser nmbd[1531]: Got SIGTERM: going down...
dez 24 14:17:09 bruno-ser uresourced[1045]: Setting resources on user-1000.slice (MemoryMin: 0, MemoryLow: 0, CPUWeight: 100, IOWeight: 100)
dez 24 14:17:09 bruno-ser uresourced[1045]: Setting resources on user@1000.service (MemoryMin: 0, MemoryLow: 0, CPUWeight: 100, IOWeight: 100)
dez 24 14:17:09 bruno-ser uresourced[1045]: Setting resources on user.slice (MemoryMin: 0, MemoryLow: 0, CPUWeight: -, IOWeight: -)
dez 24 14:17:10 bruno-ser systemd[1]: user-1000.slice: Consumed 12min 34.226s CPU time.
dez 24 14:17:10 bruno-ser systemd[1]: Requested transaction contradicts existing jobs: Transaction for NetworkManager-dispatcher.service/start is destructive (ldconfig.service has 'stop' job queued, but 'start' is included in transaction).
dez 24 14:17:10 bruno-ser systemd[1]: user.slice: Consumed 12min 35.261s CPU time.
For the other comand:
s2idle [deep]
The trick question is: wifi works fine, nice speed. So there is no problem in the drive. But after suspension, stop working, it seems that system can not recognize the driver anymore.
