Hello, all.
I’m posting again with a persistent problem on my wi-fi usage on Manjaro XFCE. My desktop computer is a HP Omnidesk M020 running a Realtek RTL8852BE-VT PCIe 802.11ax. I previously posted about this in this topic, but the problem surfaced again after a while and it has gotten increasingly worse in the past days.
Basically, when using the wi-fi with a 5g wi-fi network, the computer will suddenly completely disconnect from the wi-fi network and refuse any further connections to any wi-fi networks. Rebooting the network manager and/or WPA supplicant services yields no results and only a full reboot of the machine solves the problem. Ethernet, USB and Bluetooth can still supply wi-fi when the crash occurs, but it is a hassle to have to connect my cellphone to the computer and to lose any progress from my work.
This issue seems to occur randomly, but it is mostly triggered when using the wi-fi network for a prolonged duration of time with a lot of data incoming and outgoing (zoom meetings, remote connections, etc…) or when setting the machine to sleep for a couple hours. It also seems to occur both with the default network adapters provided and when the rtw89-dkms-git AUR package is installed, but with more crashes occurring on the former. Currently, rtw89-dkms-git is not installed.
Here’s some information that may help with the solution of the problem.
inxi -n :
Device-1: Realtek RTL8852BE-VT PCIe 802.11ax Wireless Network
driver: rtw89_8852bte
IF: wlp4s0 state: down mac: 26:02:3b:19:6c:37
driver: r8168
IF: enp7s0 state: down mac: 10:b6:76:51:d9:4d
IF-ID-1: enp5s0u7 state: unknown speed: N/A duplex: N/A
mac: f8:3d:c6:f2:46:85
inxi -zv8 :
Kernel: 6.18.38-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 16.1.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.18-x86_64
root=UUID=d7f3ed11-7104-4872-993b-88794641ab95 rw rootflags=subvol=@
quiet splash apparmor=1 security=apparmor udev.log_priority=3
Desktop: Xfce v: 4.20.2 tk: Gtk v: 3.24.52 wm: xfwm4 v: 4.20.0
with: xfce4-panel tools: xfce4-screensaver vt: 7 dm: LightDM v: 1.32.0
Type: Desktop System: HP product: HP OmniDesk Desktop M02-0xxx v: N/A
serial: <superuser required> Chassis: type: 3 serial: <superuser required>
Mobo: HP model: 8D32 v: SMVB serial: <superuser required>
part-nu: BP5E2AA#ABA uuid: <superuser required> Firmware: UEFI vendor: AMI
v: F.05 date: 03/13/2025
System RAM: total: 32 GiB available: 30.45 GiB used: 8.09 GiB (26.6%)
Array-1: capacity: 128 GiB slots: 2 modules: 2 EC: None
max-module-size: 64 GiB note: est.
Device-1: Channel-B DIMM 1 type: DDR5 detail: synchronous unbuffered
(unregistered) size: 16 GiB speed: spec: 5600 MT/s actual: 5200 MT/s
volts: note: check curr: 1 min: 1 max: 1 width (bits): data: 64 total: 64
manufacturer: SK Hynix part-no: HMCG78AGBUA081N serial: <filter>
Device-2: Channel-A DIMM 2 type: DDR5 detail: synchronous unbuffered
Info: model: AMD Ryzen 7 8700G w/ Radeon 780M Graphics bits: 64 type: MT MCP
arch: Zen 4 gen: 4 level: v4 note: check built: 2022+ process: TSMC n5 (5nm)
family: 0x19 (25) model-id: 0x75 (117) stepping: 2 microcode: 0xA705208
smt: enabled cache: L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 8 MiB
desc: 8x1024 KiB L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 2999 min/max: 423/5177 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 2999 2: 2999 3: 2999
4: 2999 5: 2999 6: 2999 7: 2999 8: 2999 9: 2999 10: 2999 11: 2999 12: 2999
13: 2999 14: 2999 15: 2999 16: 2999 bogomips: 134396
Flags: 3dnowprefetch abm adx aes amd_lbr_v2 aperfmperf apic arat avic avx
avx2 avx512_bf16 avx512_bitalg avx512_vbmi2 avx512_vnni avx512_vpopcntdq
avx512bw avx512cd avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1
constant_tsc cpb cppc cpuid cpuid_fault cqm cqm_llc cqm_mbm_local
cqm_mbm_total cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms
extapic extd_apicid f16c flush_l1d flushbyasid fma fpu fsgsbase fsrm fxsr
fxsr_opt gfni ht hw_pstate ibpb ibrs ibrs_enhanced ibs invpcid irperf
lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr
mwaitx nonstop_tsc nopl npt nrip_save nx ospke osvw overflow_recov pae
perfmon_v2 pfthreshold pge pku pni popcnt pse pse36 rapl rdpid rdpru
rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap smca smep ssbd
sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm_lock syscall tce
topoext tsc tsc_scale umip user_shstk v_spec_ctrl vaes vgif vmcb_clean
vme vmmcall vnmi vpclmulqdq wbnoinvd wdt x2avic xgetbv1 xsave xsavec
xsaveerptr xsaveopt xsaves xtopology
conditional; STIBP: always-on; PBRSB-eIBRS: Not affected; BHI: Not
affected
Device-1: Advanced Micro Devices [AMD/ATI] Phoenix1 vendor: Hewlett-Packard
driver: amdgpu v: kernel arch: RDNA-3 code: Phoenix process: TSMC n4 (4nm)
built: 2023+ pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: HDMI-A-1
empty: DP-1, DP-2, DP-3, DP-4, DP-5, DP-6, DP-7, Writeback-1
bus-ID: 08:00.0 chip-ID: 1002:15bf class-ID: 0300 temp: 34.0 C
Device-2: Logitech Brio 101 driver: snd-usb-audio,uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-11:5
chip-ID: 046d:094d class-ID: 0102 serial: <filter>
Display: x11 server: X.org v: 1.21.1.24 compositor: xfwm4 v: 4.20.0
driver: X: loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa
dri: radeonsi gpu: amdgpu display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-size: <missing: xdpyinfo>
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: LG (GoldStar) FULL HD
built: 2016 res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 102 gamma: 1.2
chroma: red: x: 0.647 y: 0.333 green: x: 0.306 y: 0.631 blue: x: 0.149
y: 0.047 white: x: 0.314 y: 0.329 size: 480x270mm (18.9x10.63")
diag: 551mm (21.7") ratio: 16:9 modes: 1920x1080, 1680x1050, 1400x1050,
1600x900, 1280x1024, 1440x900, 1280x800, 1152x864, 1280x720, 1024x768,
800x600, 720x576, 720x480, 640x480, 720x400
device: 1 drv: swrast gbm: drv: radeonsi surfaceless: drv: radeonsi x11:
API: OpenGL v: 4.6 vendor: amd mesa v: 26.1.4-arch1.1 glx-v: 1.4
direct-render: yes renderer: AMD Radeon 780M Graphics (radeonsi phoenix ACO
DRM 3.64 6.18.38-1-MANJARO) device-ID: 1002:15bf memory: 500 MiB
unified: yes
x11: xprop,xrandr
Device-1: Advanced Micro Devices [AMD/ATI] Radeon High Definition Audio
vendor: Hewlett-Packard driver: snd_hda_intel v: kernel pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 08:00.1 chip-ID: 1002:1640 class-ID: 0403
Device-2: Advanced Micro Devices [AMD] Ryzen HD Audio
speed: 16 GT/s lanes: 16 bus-ID: 08:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-3: Logitech Brio 101 driver: snd-usb-audio,uvcvideo type: USB
API: ALSA v: k6.18.38-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.6.7 status: active with: 1: pipewire-pulse
vendor: Hewlett-Packard driver: rtw89_8852bte v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 04:00.0 chip-ID: 10ec:b520
class-ID: 0280
IF: wlp4s0 state: down mac: <filter>
vendor: Hewlett-Packard driver: r8168 v: 8.056.02-NAPI modules: r8169 pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 07:00.0
IF: enp7s0 state: down mac: <filter>
IF-ID-1: enp5s0u7 state: unknown speed: N/A duplex: N/A mac: <filter>
Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:3 chip-ID: 0bda:b86a
Local Storage: total: 953.87 GiB used: 126.62 GiB (13.3%)
model: MZVL81T0HELB-00BH1 size: 953.87 GiB block-size: physical: 512 B
fw-rev: HPS3NKXM temp: 39.9 C scheme: GPT
ID-1: / raw-size: 796.45 GiB size: 796.45 GiB (100.00%)
used: 126.51 GiB (15.9%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
label: N/A uuid: d7f3ed11-7104-4872-993b-88794641ab95
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
used: 118.8 MiB (46.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: SYSTEM uuid: CCF0-6CAE
ID-3: /home raw-size: 796.45 GiB size: 796.45 GiB (100.00%)
ID-4: /var/cache raw-size: 796.45 GiB size: 796.45 GiB (100.00%)
ID-5: /var/log raw-size: 796.45 GiB size: 796.45 GiB (100.00%)
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 156.41 GiB fs: ntfs
label: Windows uuid: F216C3B016C3745F
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 746 MiB fs: ntfs
label: Windows RE tools uuid: 90689FD7689FBB04
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-6:2 info: MosArt Wireless Mouse type: mouse
lanes: 1 mode: 1.1 power: 100mA chip-ID: 062a:4102 class-ID: 0301
Device-2: 1-7:3 info: Realtek Bluetooth Radio type: bluetooth
driver: btusb interfaces: 2 rev: 1.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 500mA chip-ID: 0bda:b86a class-ID: e001 serial: <filter>
Device-3: 1-10:4 info: CASUE USB KB type: keyboard,HID
chip-ID: 2a7a:9a27 class-ID: 0300
Device-4: 1-11:5 info: Logitech Brio 101 type: video,audio
Hub-2: 2-0:1 info: super-speed hub ports: 6 rev: 3.1
Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
System Temperatures: cpu: 40.2 C mobo: 37.8 C gpu: amdgpu temp: 35.0 C
Fan Speeds (rpm): N/A
Packages: pm: pacman pkgs: 1560 libs: 461 tools: pamac,yay pm: flatpak
pkgs: 0
1: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
2: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
3: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
4: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
5: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
6: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
7: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
8: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
9: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
10: https://mirror.fcix.net/manjaro/stable/$repo/$arch
11: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
12: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
13: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
14: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
15: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
16: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 427
1: cpu: 18.7% command: zoom pid: 3990 mem: 984.8 MiB (3.1%)
2: cpu: 5.7% command: brave pid: 3104 mem: 215.3 MiB (0.6%)
3: cpu: 4.3% command: brave pid: 3067 mem: 571.4 MiB (1.8%)
4: cpu: 3.5% command: Xorg pid: 1020 mem: 125.1 MiB (0.4%)
5: cpu: 2.6% command: aomhost pid: 8494 mem: 75.6 MiB (0.2%)
Memory top: 5 of 427
1: mem: 984.8 MiB (3.1%) command: zoom pid: 3990 cpu: 18.7%
2: mem: 858.6 MiB (2.7%) command: pamac-manager pid: 17166 cpu: 1.3%
3: mem: 748.4 MiB (2.4%) command: java pid: 10484 cpu: 0.7%
4: mem: 571.4 MiB (1.8%) command: brave pid: 3067 cpu: 4.3%
5: mem: 435.0 MiB (1.3%) command: brave pid: 3611 cpu: 0.9%
Processes: 427 Power: uptime: 1h 27m states: freeze,mem,disk suspend: s2idle
image: 12.11 GiB services: upowerd,xfce4-power-manager Init: systemd
v: 261 default: graphical tool: systemctl
Compilers: gcc: 16.1.1 Shell: fish v: 4.8.0 default: Bash v: 5.3.15
running-in: xfce4-terminal inxi: 3.3.41
Also, here’s the output of some commands that I ran after the wi-fi cut-off:
systemctl status NetworkManager:
● NetworkManager.service - Network Manager
Loaded: loaded (/usr/lib/systemd/system/NetworkManager.service; enabled; preset: disabled)
Active: active (running) since Mon 2026-07-20 21:22:54 EDT; 4s ago
Invocation: 66379cadc10b4524aee35384dfd65729
Docs: man:NetworkManager(8)
Main PID: 20992 (NetworkManager)
Tasks: 5 (limit: 37331)
Memory: 4.3M (peak: 5.9M)
CPU: 54ms
CGroup: /system.slice/NetworkManager.service
└─20992 /usr/bin/NetworkManager --no-daemon
Jul 20 21:22:54 NetworkManager[20992]: <info> [1784596974.5602] device (lo): state change: ip-config -> ip-check (reason 'none', managed-type: 'external')
Jul 20 21:22:54 NetworkManager[20992]: <info> [1784596974.5606] manager: (64:1B:2F:D3:F5:C6): new Bluetooth device (/org/freedesktop/NetworkManager/Devices/4)
Jul 20 21:22:54 NetworkManager[20992]: <info> [1784596974.5607] device (64:1B:2F:D3:F5:C6): state change: unmanaged -> unavailable (reason 'managed', managed-type: 'exte>
Jul 20 21:22:54 NetworkManager[20992]: <warn> [1784596974.5607] device (64:1B:2F:D3:F5:C6): error setting IPv4 forwarding to '0': No such file or directory
Jul 20 21:22:54 NetworkManager[20992]: <info> [1784596974.5610] device (lo): state change: ip-check -> secondaries (reason 'none', managed-type: 'external')
Jul 20 21:22:54 NetworkManager[20992]: <info> [1784596974.5610] device (64:1B:2F:D3:F5:C6): state change: unavailable -> disconnected (reason 'none', managed-type: 'full>
Jul 20 21:22:54 NetworkManager[20992]: <info> [1784596974.5611] device (lo): state change: secondaries -> activated (reason 'none', managed-type: 'external')
Jul 20 21:22:54 NetworkManager[20992]: <info> [1784596974.5614] device (lo): Activation: successful, device activated.
Jul 20 21:22:54 NetworkManager[20992]: <info> [1784596974.6074] agent-manager: agent[39662fbb3ac1a435,:1.46/org.freedesktop.nm-applet/1000]: agent registered
Jul 20 21:22:54 NetworkManager[20992]: <error> [1784596974.7443] device (wlp4s0): Couldn't initialize supplicant interface: GDBus.Error:fi.w1.wpa_supplicant1.UnknownError>
systemctl status wpa_supplicant:
● wpa_supplicant.service - WPA supplicant
Loaded: loaded (/usr/lib/systemd/system/wpa_supplicant.service; disabled; preset: disabled)
Active: active (running) since Mon 2026-07-20 21:22:12 EDT; 58s ago
Invocation: 8983b6cdbab9421199b798b837c245ef
Main PID: 20794 (wpa_supplicant)
Tasks: 1 (limit: 37331)
Memory: 1.1M (peak: 2M)
CPU: 35ms
CGroup: /system.slice/wpa_supplicant.service
└─20794 /usr/bin/wpa_supplicant -u -s -O /run/wpa_supplicant
Jul 20 21:22:54 wpa_supplicant[20794]: WEXT: Could not set interface 'wlp4s0' UP
Jul 20 21:22:54 wpa_supplicant[20794]: wlp4s0: Failed to initialize driver interface
Jul 20 21:22:54 wpa_supplicant[20794]: wlp4s0: CTRL-EVENT-DSCP-POLICY clear_all
Jul 20 21:23:04 wpa_supplicant[20794]: Could not set interface wlp4s0 flags (UP): Connection timed out
Jul 20 21:23:04 wpa_supplicant[20794]: nl80211: Could not set interface 'wlp4s0' UP
Jul 20 21:23:04 wpa_supplicant[20794]: nl80211: deinit ifname=wlp4s0 disabled_11b_rates=0
Jul 20 21:23:04 wpa_supplicant[20794]: WEXT: Could not set interface 'wlp4s0' UP
Jul 20 21:23:04 wpa_supplicant[20794]: wlp4s0: Failed to initialize driver interface
Jul 20 21:23:04 wpa_supplicant[20794]: wlp4s0: CTRL-EVENT-DSCP-POLICY clear_all
Any help would be appreciated.
