Thank you for the welcome message. I’ll make to sure to use the correct formatting on my next posts.
Here’s the output for running the command inxi -zv8:
Kernel: 6.12.68-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=d7f3ed11-7104-4872-993b-88794641ab95 rw rootflags=subvol=@
quiet splash apparmor=1 security=apparmor udev.log_priority=3
Desktop: Xfce v: 4.20.1 tk: Gtk v: 3.24.51 wm: xfwm4 v: 4.20.0
with: xfce4-panel tools: xfce4-screensaver vt: 7 dm: LightDM v: 1.32.0
Type: Desktop System: HP product: HP OmniDesk Desktop M02-0xxx v: N/A
serial: <superuser required> Chassis: type: 3 serial: <superuser required>
Mobo: HP model: 8D32 v: SMVB serial: <superuser required>
part-nu: BP5E2AA#ABA uuid: <superuser required> Firmware: UEFI vendor: AMI
v: F.05 date: 03/13/2025
System RAM: total: 32 GiB available: 30.45 GiB used: 3.68 GiB (12.1%)
Array-1: capacity: 128 GiB slots: 2 modules: 2 EC: None
max-module-size: 64 GiB note: est.
Device-1: Channel-B DIMM 1 type: DDR5 detail: synchronous unbuffered
(unregistered) size: 16 GiB speed: spec: 5600 MT/s actual: 5200 MT/s
volts: note: check curr: 1 min: 1 max: 1 width (bits): data: 64 total: 64
manufacturer: SK Hynix part-no: HMCG78AGBUA081N serial: <filter>
Device-2: Channel-A DIMM 2 type: DDR5 detail: synchronous unbuffered
Info: model: AMD Ryzen 7 8700G w/ Radeon 780M Graphics bits: 64 type: MT MCP
arch: Zen 4 gen: 4 level: v4 note: check built: 2022+ process: TSMC n5 (5nm)
family: 0x19 (25) model-id: 0x75 (117) stepping: 2 microcode: 0xA705208
smt: enabled cache: L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 8 MiB
desc: 8x1024 KiB L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 400 min/max: 400/5176 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 400 2: 400 3: 400
4: 400 5: 400 6: 400 7: 400 8: 400 9: 400 10: 400 11: 400 12: 400 13: 400
14: 400 15: 400 16: 400 bogomips: 134456
Flags: 3dnowprefetch abm adx aes amd_lbr_v2 aperfmperf apic arat avic avx
avx2 avx512_bf16 avx512_bitalg avx512_vbmi2 avx512_vnni avx512_vpopcntdq
avx512bw avx512cd avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1
cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
extd_apicid f16c flush_l1d flushbyasid fma fpu fsgsbase fsrm fxsr
fxsr_opt gfni ht hw_pstate ibpb ibrs ibrs_enhanced ibs invpcid irperf
lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr
mwaitx nonstop_tsc nopl npt nrip_save nx ospke osvw overflow_recov pae
perfmon_v2 pfthreshold pge pku pni popcnt pse pse36 rapl rdpid rdpru
rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap smca smep ssbd
sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm_lock syscall tce
topoext tsc tsc_scale umip user_shstk v_spec_ctrl vaes vgif vmcb_clean
vme vmmcall vnmi vpclmulqdq wbnoinvd wdt x2avic xgetbv1 xsave xsavec
xsaveerptr xsaveopt xsaves xtopology
conditional; STIBP: always-on; PBRSB-eIBRS: Not affected; BHI: Not
affected
Device-1: Advanced Micro Devices [AMD/ATI] Phoenix1 vendor: Hewlett-Packard
driver: amdgpu v: kernel arch: RDNA-3 code: Phoenix process: TSMC n4 (4nm)
built: 2023+ pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: HDMI-A-1
empty: DP-1, DP-2, DP-3, DP-4, DP-5, DP-6, DP-7, Writeback-1
bus-ID: 08:00.0 chip-ID: 1002:15bf class-ID: 0300 temp: 27.0 C
Device-2: Logitech Brio 101 driver: snd-usb-audio,uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-11:5
chip-ID: 046d:094d class-ID: 0102 serial: <filter>
Display: x11 server: X.org v: 1.21.1.21 compositor: xfwm4 v: 4.20.0
driver: X: loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa
dri: radeonsi gpu: amdgpu display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-size: <missing: xdpyinfo>
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: LG (GoldStar) FULL HD
built: 2016 res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 102 gamma: 1.2
chroma: red: x: 0.647 y: 0.333 green: x: 0.306 y: 0.631 blue: x: 0.149
y: 0.047 white: x: 0.314 y: 0.329 size: 480x270mm (18.9x10.63")
diag: 551mm (21.7") ratio: 16:9 modes: 1920x1080, 1680x1050, 1400x1050,
1600x900, 1280x1024, 1440x900, 1280x800, 1152x864, 1280x720, 1024x768,
800x600, 720x576, 720x480, 640x480, 720x400
device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.3.4-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon 780M Graphics (radeonsi
phoenix LLVM 21.1.6 DRM 3.61 6.12.68-1-MANJARO) device-ID: 1002:15bf
memory: 500 MiB unified: no
x11: xprop,xrandr
Device-1: Advanced Micro Devices [AMD/ATI] Radeon High Definition Audio
vendor: Hewlett-Packard driver: snd_hda_intel v: kernel pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 08:00.1 chip-ID: 1002:1640 class-ID: 0403
Device-2: Advanced Micro Devices [AMD] Ryzen HD Audio
speed: 16 GT/s lanes: 16 bus-ID: 08:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-3: Logitech Brio 101 driver: snd-usb-audio,uvcvideo type: USB
API: ALSA v: k6.12.68-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.10 status: active with: 1: pipewire-pulse
Device-1: Realtek RTL8852BE-VT PCIe 802.11ax Wireless Network
vendor: Hewlett-Packard driver: rtw89_8852bte_git v: kernel
modules: rtw89_8852bte pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000
bus-ID: 04:00.0 chip-ID: 10ec:b520 class-ID: 0280
IF: wlp4s0 state: up mac: <filter>
vendor: Hewlett-Packard driver: N/A modules: r8169 pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 07:00.0 chip-ID: 10ec:8168
class-ID: 0200
Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:3 chip-ID: 0bda:b86a
Local Storage: total: 953.87 GiB used: 74.46 GiB (7.8%)
model: MZVL81T0HELB-00BH1 size: 953.87 GiB block-size: physical: 512 B
fw-rev: HPS3NKXM temp: 32.9 C scheme: GPT
ID-1: / raw-size: 796.45 GiB size: 796.45 GiB (100.00%)
used: 74.38 GiB (9.3%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
label: N/A uuid: d7f3ed11-7104-4872-993b-88794641ab95
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
used: 79.8 MiB (31.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: SYSTEM uuid: CCF0-6CAE
ID-3: /home raw-size: 796.45 GiB size: 796.45 GiB (100.00%)
ID-4: /var/cache raw-size: 796.45 GiB size: 796.45 GiB (100.00%)
ID-5: /var/log raw-size: 796.45 GiB size: 796.45 GiB (100.00%)
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 156.41 GiB fs: ntfs
label: Windows uuid: F216C3B016C3745F
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 746 MiB fs: ntfs
label: Windows RE tools uuid: 90689FD7689FBB04
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-6:2 info: MosArt Wireless Mouse type: mouse
lanes: 1 mode: 1.1 power: 100mA chip-ID: 062a:4102 class-ID: 0301
Device-2: 1-7:3 info: Realtek Bluetooth Radio type: bluetooth
driver: btusb interfaces: 2 rev: 1.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 500mA chip-ID: 0bda:b86a class-ID: e001 serial: <filter>
Device-3: 1-10:4 info: CASUE USB KB type: keyboard,HID
chip-ID: 2a7a:9a27 class-ID: 0300
Device-4: 1-11:5 info: Logitech Brio 101 type: video,audio
Hub-2: 2-0:1 info: super-speed hub ports: 6 rev: 3.1
Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
System Temperatures: cpu: 33.1 C mobo: 28.5 C gpu: amdgpu temp: 27.0 C
Fan Speeds (rpm): N/A
Packages: pm: pacman pkgs: 1482 libs: 485 tools: pamac,yay pm: flatpak
pkgs: 0
1: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
2: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
3: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
4: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
5: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
6: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
7: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
8: https://mirror.fcix.net/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 406
1: cpu: 7.9% command: brave pid: 4203 mem: 492.7 MiB (1.5%)
2: cpu: 3.6% command: brave pid: 3773 mem: 430.3 MiB (1.3%)
3: cpu: 3.5% command: brave pid: 5148 mem: 242.2 MiB (0.7%)
4: cpu: 2.4% command: /newerversion started-by: dropbox pid: 2951
mem: 369.6 MiB (1.1%)
5: cpu: 2.4% command: brave pid: 3810 mem: 304.0 MiB (0.9%)
Memory top: 5 of 406
1: mem: 492.7 MiB (1.5%) command: brave pid: 4203 cpu: 7.9%
2: mem: 430.3 MiB (1.3%) command: brave pid: 3773 cpu: 3.6%
3: mem: 369.6 MiB (1.1%) command: /newerversion started-by: dropbox
pid: 2951 cpu: 2.4%
4: mem: 304.0 MiB (0.9%) command: brave pid: 3810 cpu: 2.4%
5: mem: 301.2 MiB (0.9%) command: brave pid: 3958 cpu: 1.4%
Processes: 406 Power: uptime: 5m states: freeze,mem,disk suspend: s2idle
image: 12.16 GiB services: upowerd,xfce4-power-manager Init: systemd
v: 258 default: graphical tool: systemctl
Compilers: gcc: 15.2.1 Shell: fish v: 4.3.3 default: Bash v: 5.3.9
running-in: xfce4-terminal inxi: 3.3.40
Apparently, the network driver switched from rtw89_8852bte to rtw89_8852bte_git overnight, which I’m not sure was caused by reinstalling some packages or not.
