[frozen@frozen ~]$ sudo tune2fs -l /dev/sda2
[sudo] password for frozen:
tune2fs 1.46.2 (28-Feb-2021)
Filesystem volume name: <none>
Last mounted on: /
Filesystem UUID: e39a313c-b400-489e-924d-db45ae47bddc
Filesystem magic number: 0xEF53
Filesystem revision #: 1 (dynamic)
Filesystem features: has_journal ext_attr resize_inode dir_index filetype needs_recovery extent 64bit flex_bg sparse_super large_file huge_file dir_nlink extra_isize metadata_csum
Filesystem flags: signed_directory_hash
Default mount options: user_xattr acl
Filesystem state: clean
Errors behavior: Continue
Filesystem OS type: Linux
Inode count: 29974528
Block count: 119872752
Reserved block count: 5993637
Overhead clusters: 2162364
Free blocks: 115255617
Free inodes: 29680773
First block: 0
Block size: 4096
Fragment size: 4096
Group descriptor size: 64
Reserved GDT blocks: 1024
Blocks per group: 32768
Fragments per group: 32768
Inodes per group: 8192
Inode blocks per group: 512
Flex block group size: 16
Filesystem created: Fri Apr 9 14:39:57 2021
Last mount time: Sun Apr 11 09:30:29 2021
Last write time: Sun Apr 11 09:30:29 2021
Mount count: 9
Maximum mount count: -1
Last checked: Fri Apr 9 14:40:16 2021
Check interval: 0 (<none>)
Lifetime writes: 33 GB
Reserved blocks uid: 0 (user root)
Reserved blocks gid: 0 (group root)
First inode: 11
Inode size: 256
Required extra isize: 32
Desired extra isize: 32
Journal inode: 8
First orphan inode: 18483078
Default directory hash: half_md4
Directory Hash Seed: 7192c4c0-fa8f-42b5-a44a-0eb02ced0df1
Journal backup: inode blocks
Checksum type: crc32c
Checksum: 0xc3bff6a4
Your file-system has never been fsckād since you first created it, and it remains that way even now after you rebooted.
Maybe youāre seeing something else during bootup?
No Iām sure itās fsck.
How come? Iām genuinely confused. You can even see sda2 has only been fsckād once, and that was just after you initially created it. Ever since then, itās never been checked.
Your flags for -c (based on maximum mounts) and -i (based on time intervals) have also been disabled.
So Iām not sure what youāre seeing at bootup.
give me 5min iāll find a example
This is the message i gets everytime. X means numbers I didnāt include them
/dev/sda2: clean, XXXXXX/XXXXXXXX files, XXXXXXX/XXXXXXXXX blocks
I donāt see the problem, though? Itās telling you that sda2 is clean (and was cleanly unmounted).
Is the bootup process notably slower during this time, as if itās running through a full file-system check?
Itās slow down the boot time.
This is the only message i see during boot nothing else.
This shows like for 10 seconds then boot into manjaro kde login screen.
Iām not sure that it is slowing the boot time down.
When that message appears, the check is already done - as the message says.
But, as has been said, your filesystem has never actually been checked since it was created.
btw:
You where asked to provide the contents of:
/etc/default/grub
but you never did.
cat /etc/default/grub
Unless you explicitly configure your filesystem to be checked every x times you boot your machine or every x days ⦠it will only be checked on existent errors - and probably not even then, if
/etc/default/grub
is not configured correctly.
To force a filesystem check once every 20 times the system is started, issue this command:
sudo tune2fs -c 20 /dev/sda2
Iād recommend that or an even lower interval -
until you are sure that the filesystem check initiated by Grub actually can work in case it is needed.
The check (and possible repair) just takes a few seconds.
The consequences of a corrupted filesystem are nasty.
What this command does?
Youāre saying it scans file system every 20min.
It will use lots of resources.
Are you even reading what people write?
Yes I do, But I have to know the impacts about what a command does before executing.
Read then.
Also most programs have man pages, or help switches
man command
command --help
Iāve read it but Iāve got no idea about the impacts.
1st decide what do u want 2 do.
U want to hide the fsck msg or what?!
If u want to hide them then the solutions are already there in the forum & also in this conversation.
But I donāt wanna execute a command that runs every 20min
It activates a feature in the filesystem itself, forcing it to be checked every x times the filesystem is mounted - basically: every x times you boot your machine.
man tune2fs
the -c option is the first one to be explained in that manual page
no, I did not say that
man tune2fs
the -c option
it checks every x times ⦠blah, blah - see above
no, it wonāt
That says after 20 times u restart ur system
That is not what the effect of the command will be.
You got to take some time to read and comprehend - also the references given.
So what exactly do I have to do? I have no idea what @Nachlese talking about.
See Iām new to linux.
And also no programming knowledge
