Why Manjaro Kde use fsck?
Replace my sdxx with your actual root device/partition. Might be sda1, sda2, or etc.
I don’t know how to do that see I’m newbie to manjaro so …:frowning:
ok wait.
You can see a list of partitions with:
lsblk
or
cat /proc/partitions
[frozen@frozen ~]$ sudo tune2fs -l /dev/sda2 grep -i ā€œlast checkedā€
tune2fs 1.46.2 (28-Feb-2021)
tune2fs: bad interval - ā€œlast
Usage: tune2fs [-c max_mounts_count] [-e errors_behavior] [-f] [-g group]
        [-i interval[d|m|w]] [-j] [-J journal_options] [-l]
        [-m reserved_blocks_percent] [-o [^]mount_options[,...]]
        [-r reserved_blocks_count] [-u user] [-C mount_count]
        [-L volume_label] [-M last_mounted_dir]
        [-O [^]feature[,...]] [-Q quota_options]
        [-E extended-option[,...]] [-T last_check_time] [-U UUID]
        [-I new_inode_size] [-z undo_file] device
sudo nano /etc/default/grub
At the end of ā€˜grub cmdline linux default’ add ā€˜console=tty3’
Save and exit nano or ur text editor
sudo update-grub
How to save?
You typed it wrong. It’s missing a ā€œpipeā€ before grep
Should be like this:
sudo tune2fs -l /dev/sda2 | grep -i ā€œLast checkedā€
Ctrl+o then press enter then press ctrl+x
Well I did typed it but nothing found
[frozen@frozen ~]$ sudo tune2fs -l /dev/sda2 | grep -i ā€œlast checkedā€
grep: checkedā€: No such file or directory
[sudo] password for frozen:
[frozen@frozen ~]$ cat /proc/partitions
major minor  #blocks  name
   8        0  488386584 sda
   8        1     307200 sda1
   8        2  479491009 sda2
   8        3    8583775 sda3
[frozen@frozen ~]$ lsblk
NAME   MAJ:MIN RM   SIZE RO TYPE MOUNTPOINT
sda      8:0    0 465.8G  0 disk
ā”œā”€sda1   8:1    0   300M  0 part /boot/efi
ā”œā”€sda2   8:2    0 457.3G  0 part /
└─sda3   8:3    0   8.2G  0 part [SWAP]
Okay, so let’s just see how everything is configured for sda2, and you can change the ā€œfsckā€ intervals to something less frequent. This might also help your boot-up times.
Forget the pipe or grep. Just make sure the text doesn’t get pasted in large font. :wink:
That’s a lowercase L in the command (as in ā€œlistā€), not an upper-case i, by the way. On the forums, I and l look alike.
tune2fs: Bad magic number in super-block while trying to open /dev/sda
/dev/sda contains `DOS/MBR boot sector MS-MBR Windows 7 english at offset 0x163 "Invalid partition table" at offset 0x17b "Error loading operating system" at offset 0x19a "Missing operating system"; partition 1 : ID=0xee, start-CHS (0x0,0,2), end-CHS (0x3ff,255,63), startsector 1, 976773167 sectors' data
sda2, not sda
Sorry, it’s late over here. Very sleepy. I made a typo.
Sorry, try again.
Filesystem volume name:   <none>
Last mounted on:          /
Filesystem UUID:          e39a313c-b400-489e-924d-db45ae47bddc
Filesystem magic number:  0xEF53
Filesystem revision #:    1 (dynamic)
Filesystem features:      has_journal ext_attr resize_inode dir_index filetype needs_recovery extent 64bit flex_bg sparse_super large_file huge_file dir_nlink extra_isize metadata_csum
Filesystem flags:         signed_directory_hash
Default mount options:    user_xattr acl
Filesystem state:         clean
Errors behavior:          Continue
Filesystem OS type:       Linux
Inode count:              29974528
Block count:              119872752
Reserved block count:     5993637
Overhead clusters:        2162364
Free blocks:              115260083
Free inodes:              29680981
First block:              0
Block size:               4096
Fragment size:            4096
Group descriptor size:    64
Reserved GDT blocks:      1024
Blocks per group:         32768
Fragments per group:      32768
Inodes per group:         8192
Inode blocks per group:   512
Flex block group size:    16
Filesystem created:       Fri Apr  9 14:39:57 2021
Last mount time:          Sun Apr 11 08:29:19 2021
Last write time:          Sun Apr 11 08:29:19 2021
Mount count:              8
Maximum mount count:      -1
Last checked:             Fri Apr  9 14:40:16 2021
Check interval:           0 (<none>)
Lifetime writes:          33 GB
Reserved blocks uid:      0 (user root)
Reserved blocks gid:      0 (group root)
First inode:              11
Inode size:               256
Required extra isize:     32
Desired extra isize:      32
Journal inode:            8
First orphan inode:       18489448
Default directory hash:   half_md4
Directory Hash Seed:      7192c4c0-fa8f-42b5-a44a-0eb02ced0df1
Journal backup:           inode blocks
Checksum type:            crc32c
Checksum:                 0x62334385
You’re saying you’ve seen a fsck on your root file system during bootup since that date/time?
I think so, well I see Everytime I boot.
Are you able to reboot now, and come back here and redo
If the value for ā€œLast checkedā€ remains the same, it means you’re probably seeing something else during bootup.
By all accounts, according to tune2fs, it looks like automatic fsck has been disabled.
wait give me 5min
