Just a question : Where may i download a ‘testing’ iso ? (in order to install KDE 6)
I know developer images are based on unstable branch, but is there any iso/image based on testing branch ?
Thanks
Thanks
Hi @ChrisCanyon,
Maybe this is what you’re looking for:
I doubt it. I suspect you’ll have to build your own.
Also see
ISO images use stable branch by default, but branch can be changed after installing
sudo pacman-mirrors --api --set-branch testing
If you use the python script mentioned here [root tip] [Utility Script] Using python to download and verify a Manjaro ISO
get-iso -p plasma
Thank you @linux-aarhus.
What i did meanwhile is to download the latest developer kde image (generated last night around 2:30 am, but there is a issue with it.
Once on the desktop, i cannot run the installer, it does not launch at all with several errors in journactl.
Sure, I could also download a stable release but as Plasma 6 is a big update, if i change the update branch to get it, i i will probably end up with lot of orphans file (which would be logical anyway).
That’s why, i am interested with a ‘testing’ iso based on the testing branch. Apparently your script is made for stable or unstable.
So, i do not know what would be the best way to do it…
Just a question, in case you know : is it always mandatory to choose /boot/efi
as mountpoint for EFI partition on a Manjaro installation ? On arch wiki, they now recommend /boot
(i do no want that) or /efi
(which replace /boot/efi
Not as far as I know. I think @cscs mentioned his is different, so he might be able to offer more, better insight.
The script is created for the automated builds and the releases from website.
If you use Calamares installer - yes - because Manjaro uses Grub and grub only works with /boot/efi.
But if you install manually using systemd-boot you can use /efi or /boot as mountpoint.
If we look at the iso-profiles you may try the build-iso with the kde-dev profile
You can always uninstall/remove all orphans afterwards…
pamac remove --orphans
Not sure about that, this is the default path.
I mean grub.cfg is located inside /boot/grub
But grubx64.efi
is located inside esp/EFI/GRUB/
. esp could be /boot/efi
but also /efi
no ?
Yes - you are correct - still the grub efi stub is only recognized by grub if it is mounted to /boot/efi.
On the grub website i see :
On EFI systems for fixed disk install you have to mount EFI System Partition. If you mount it at /boot/efi then you don’t need any special arguments:
grub-install
Otherwise you need to specify where your EFI System partition is mounted:
grub-install --efi-directory=/mnt/efi
I know - technically it is possible - but for the Calamares installer Manjaro uses defaults to /boot/efi and your question was about the Manjaro ISO so there is that.
Perhaps grub has had changes - but as I recall it - the default is /boot/efi
The reason Manjaro uses grub is because it can be installed to both bios and efi system.
So while grub can take a different argument for the esp - the insaller on the Manjaro iso expects /boot/efi.
If you want to do it differently - by all means - go ahead … but don’t complain
No no no, this is fine for me.
Now i understand better how things work.
Anyway, /efi or /boot/efi is kind of the same provided there is only grubx64.efi or bootx64.efi inside, which is the case.
Now, i understand /boot/efi is mandatory for Manjaro.
Look, yesterday, i installed Arch on en VM with archinstall. This is insane, you end up with your grub.cfg/grubenv, grub locales and theme inside your esp partition !!
I definitely do not want that, especially with luks or/and btrfs.
Thank you.
From download/.github/workflows/iso_build.yaml at master · manjaro-plasma/download · GitHub
strategy:
matrix:
EDITION: [kde-dev]
BRANCH: [unstable]
SCOPE: [minimal,full]
The preview you can get using the script mentioned is the unstable kde-dev profile
I wouldn’t either.
I recently experimented with a LUKS encrypted Manjaro using a verified boot with a single efi stub in $esp mount.
If you are interested you read about it [root tip] [Utility Script] Encrypted Manjaro Linux using Verified Boot - I have a Tuxedo laptop running this setup - flawless - removed all other signing certificates - not even Windows is allowed to boot - but is blocked by ‘Secure Boot’
It is an UKI or something ?
Yes - it is a unified image …
Interesting indeed, but i am so much attached to have my btrfs snapshots available in a bootloader.
I think only grub can do it with grub-btrfs
That is likely true - I did use btrfs - I speculate if this more safe as file system inside a LUKS container than ext4 is.
[nix@black ~]$ lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
nvme0n1 259:0 0 465,8G 0 disk
├─nvme0n1p1 259:1 0 512M 0 part /efi
├─nvme0n1p2 259:2 0 8G 0 part
│ └─swap 254:1 0 8G 0 crypt [SWAP]
├─nvme0n1p3 259:3 0 256G 0 part
│ └─system 254:0 0 256G 0 crypt /home
│ /.snapshots
└─nvme0n1p4 259:4 0 201,3G 0 part /a/vmstore
[nix@black ~]$ ls /efi
loader main.efi
[nix@black ~]$ tree /efi
/efi
├── loader
│ └── random-seed
└── main.efi
2 directories, 2 files
[nix@black ~]$ ls -l /efi
total 63292
drwxr-xr-x 2 root root 4096 Mar 21 17:00 loader
-rwxr-xr-x 1 root root 64803960 Mar 15 08:54 main.efi
