Where is the package "tcllib 2.0-1"?
Sorry to ask such a stupid question but is/was this in the official repo?
I have it installed on my desktop and am rebuilding my laptop and can’t locate it. I suppose it’s possible that I added it myself but I didn’t think it would show up as listed in the Add/Remove Software GUI.
Thank you.
It is in the AUR:
You can install it with the following command:
pamac build tcllib
pamac info tcllib
❯ pamac info tcllib
Version               : 2.0-1
Description           : Set of pure-Tcl extensions
URL                   : http://core.tcl.tk/tcllib/
Licenses              : TCL
Repository            : AUR
Groups                : --
Depends On            : bash tcl
Optional Dependencies : --
Make Dependencies     : --
Check Dependencies    : --
Provides              : --
Replaces              : --
Conflicts With        : --
Maintainer            : PanisSupraOmnia
First Submitted       : Sat 06 Jan 2018 04:03:21
Last Modified         : Tue 31 Dec 2024 10:29:08
Votes                 : 31
Out of Date           : --
Thank you. I guess I was being stupid again because I turned on the AUR support in the GUI and it still could not locate tcllib or tdom; but if close it and re-open, then they are located.
It was imported from the AUR into in the official repos in 2018, but was dropped back to the AUR sometime in the last couple years.
