I am having Boat rockarz 510 which has a inbuilt mic(Connected via bluetooth) which was working fine when it was set with headset head unit(HSP/HFP,codec mSBC) But after I updated packages of manjaro all off a sudden my sound Output stopped but mic is still working when using headset head unit(HSP/HFP,codec mSBC) I am using Manjaro-Pipewire
Please help me Out!!!
How do I fix this???
Kernel: 5.13.4-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=f2d1a08b-fb1d-4a3b-a916-66d526d1a8d4 rw quiet apparmor=1
security=apparmor resume=UUID=5ec9b8a2-acb0-4503-a959-8f7b3c6f1a88
udev.log_priority=3
Desktop: KDE Plasma 5.22.3 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop System: Micro-Star product: MS-7C02 v: 3.0 serial: <filter>
Mobo: Micro-Star model: B450 TOMAHAWK MAX II (MS-7C02) v: 3.0
serial: <filter> UEFI-[Legacy]: American Megatrends v: H.00 date: 09/17/2020
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse serial: <filter>
charge: 55% (should be ignored) rechargeable: yes status: Discharging
RAM: total: 13.61 GiB used: 3.65 GiB (26.8%)
Info: Quad Core model: AMD Ryzen 5 3400G with Radeon Vega Graphics bits: 64
type: MT MCP arch: Zen family: 17 (23) model-id: 18 (24) stepping: 1
microcode: 8108109 cache: L2: 2 MiB bogomips: 59217
Speed: 3700 MHz min/max: N/A Core speeds (MHz): 1: 3700 2: 3700 3: 3700
4: 3700 5: 3700 6: 2553 7: 3700 8: 3700
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm mca
mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc nopl
npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb
perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36
rdrand rdseed rdtscp rep_good sep sev sev_es sha_ni skinit smap smca sme
smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock syscall tce
topoext tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt
disabled, RSB filling
Device-1: AMD Picasso vendor: Micro-Star MSI driver: amdgpu v: kernel
bus-ID: 26:00.0 chip-ID: 1002:15d8 class-ID: 0300
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver:
loaded: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: HDMI-A-0 res: 1366x768 hz: 60 dpi: 85 size: 410x230mm (16.1x9.1")
diag: 470mm (18.5")
OpenGL: renderer: AMD Radeon Vega 11 Graphics (RAVEN DRM 3.41.0
5.13.4-1-MANJARO LLVM 12.0.1)
v: 4.6 Mesa 21.1.5 direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio driver: snd_hda_intel
v: kernel bus-ID: 26:00.1 chip-ID: 1002:15de class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 26:00.6 chip-ID: 1022:15e3
class-ID: 0403
Sound Server-1: ALSA v: k5.13.4-1-MANJARO running: yes
Sound Server-3: JACK v: N/A running: no
Sound Server-4: PulseAudio v: 14.2 running: no
Sound Server-5: PipeWire v: 0.3.32 running: yes
vendor: Micro-Star MSI driver: r8168 v: 8.049.02-NAPI modules: r8169
port: f000 bus-ID: 22:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp34s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: vmnet1 state: unknown speed: N/A duplex: N/A mac: <filter>
IP v6: <filter> scope: link
IF-ID-2: vmnet8 state: unknown speed: N/A duplex: N/A mac: <filter>
driver: btusb v: 0.8 bus-ID: 1-7:2 chip-ID: 0a12:0001 class-ID: e001
Local Storage: total: 4.55 TiB used: 1.24 TiB (27.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT500MX500SSD1
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 023 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WD5000AAKX-603CA0 size: 465.76 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter>
rev: 1H18 scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 type: USB vendor: Western Digital
model: WD My Passport 2626 size: 1.82 TiB block-size: physical: 512 B
logical: 512 B type: N/A serial: <filter> rev: 1028 scheme: GPT
ID-4: /dev/sdd maj-min: 8:48 type: USB vendor: Western Digital
model: WD Elements 25A1 size: 1.82 TiB block-size: physical: 512 B
logical: 512 B type: N/A serial: <filter> rev: 1005 scheme: GPT
ID-1: / raw-size: 450.72 GiB size: 442.57 GiB (98.19%)
used: 114.1 GiB (25.8%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: f2d1a08b-fb1d-4a3b-a916-66d526d1a8d4
ID-2: /media/WDBlue raw-size: 155.51 GiB size: 155.51 GiB (100.00%)
used: 51.31 GiB (33.0%) fs: ntfs dev: /dev/sdb2 maj-min: 8:18
label: New Volume uuid: 6258808758805BA3
ID-3: /media/WDBlue2 raw-size: 155 GiB size: 155 GiB (100.00%)
used: 23.94 GiB (15.4%) fs: ntfs dev: /dev/sdb3 maj-min: 8:19
label: New Volume uuid: BCC6C32AC6C2E3AC
ID-4: /media/WDBlue3 raw-size: 155.25 GiB size: 155.25 GiB (100.00%)
used: 45.92 GiB (29.6%) fs: ntfs dev: /dev/sdb1 maj-min: 8:17
label: New Volume uuid: 0AA4DB49A4DB35C3
ID-5: /run/media/brijesh/Elements raw-size: 1.82 TiB
size: 1.82 TiB (100.00%) used: 1.01 TiB (55.7%) fs: ntfs dev: /dev/sdd1
maj-min: 8:49 label: Elements uuid: 44D84694D8468460
Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default)
ID-1: swap-1 type: partition size: 15.04 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 5ec9b8a2-acb0-4503-a959-8f7b3c6f1a88
ID-1: /dev/sdc1 maj-min: 8:33 size: 1.82 TiB fs: ntfs label: My Passport
uuid: F8426CE1426CA5DA
Device-1: 1-2:13 info: Xiaomi Mi/Redmi series (MTP + ADB)
type: <vendor specific> driver: usbfs interfaces: 2 rev: 2.0 speed: 480 Mb/s
power: 500mA chip-ID: 2717:ff48 class-ID: 0000 serial: <filter>
Device-2: 1-7:2 info: Cambridge Silicon Radio Bluetooth Dongle (HCI mode)
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
Device-3: 1-8:3 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c52b class-ID: 0300
Device-4: 1-9:4 info: China Resource Semico Keyboard type: Keyboard,HID
power: 98mA chip-ID: 1a2c:2124 class-ID: 0300
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
Device-1: 4-4:2 info: Western Digital Elements / My Passport
type: Mass Storage driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s
power: 896mA chip-ID: 1058:25a1 class-ID: 0806 serial: <filter>
Hub-5: 5-0:1 info: Full speed (or root) Hub ports: 1 rev: 2.0
Hub-6: 6-0:1 info: Full speed (or root) Hub ports: 1 rev: 3.1 speed: 10 Gb/s
Device-1: 6-1:2 info: Western Digital My Passport (WDBPKJ)
type: Mass Storage driver: usb-storage interfaces: 1 rev: 3.1 speed: 5 Gb/s
power: 896mA chip-ID: 1058:2626 class-ID: 0806 serial: <filter>
System Temperatures: cpu: 47.4 C mobo: N/A gpu: amdgpu temp: 47.0 C
Processes: 320 Uptime: 10h 37m wakeups: 45 Init: systemd v: 248
tool: systemctl Compilers: gcc: 11.1.0 alt: 10 clang: 12.0.1 Packages: 1705
pacman: 1694 lib: 410 flatpak: 4 snap: 7 Shell: Bash v: 5.1.8
running-in: gnome-terminal inxi: 3.3.06```
bash: pacmd: command not found
for pacmd dump
This is likely a Pipewire issue and not a Manjaro-specific issue. Pipewire is relatively new and their hardware compatibility is ramping up (with great progress in the last year!). I would open an issue here:
that would be great
Thanks for the help
Post link if you posted the issue
Fabby
28 July 2021 07:29
7
Please read this:
Difficulty: ☆☆☆☆☆
Remember when you installed your very first Windows, added bells and whistles and then couldn’t see the wood for the trees any more and had to re-install?
Well, you’re in the same situation now: You’re a N00b again! Embrace it!
I know right now you’re thinking:
Why is this so much more difficult than Windows? [image]
Whereas in 6 months time, you’ll be like:
Why can't I make Windows jump through fiery hoops like I do with Linux??? <a class="lightbox&qu…
And then file a bug yourself upstream, because that’s what @mynewlaptop is telling you…
I have the exact same problem with a Jabra Evolve 75 headset and pipewire update to 0.3.32.
The 0.3.31 version was fine.
The HSP profile has distorted sound while the High Fidelity profile is still fine.
Problem is even more annoying because online meetings via browser are defacto impossible now because they rely on the headset profile.
I have searched upstream bug reports but could not find any. Have you already posted there?
Seems it was a kernel patch that broke it, not the pipewire update.
Thank you
I think it should get fixed soon or we have to downgrade
In this post those guys told you can apply a patch. Is anyone here who can tell me how can i patch
Fabby
30 July 2021 10:43
13
If you don’t know how to apply a patch, better wait for the upstream patch to trickle downstream because that’ll only work if you are a developer yourself.
