What happened to the telegram forum notification bot? It stopped working recently, and appears to have disappeared from the forum preferences.
Gone with the wind, it seems…
Jokes apart, I was wondering the same. I like Manjaro, but the communication skills of the devs can be improved
What is the telegram notification bot?
Yes… this used to be the case, and I had it set up and working. Then one day, it just stopped working, and the option to add the chat ID in your user preferences vanished.
Probably went missing with a forum software update. Maybe the plugin was not compatible with the new Discourse?
@codesardine do you know?
Most likely it was disabled by the system during last update.
Will it ever return?
don’t know I will have to check what happened to it.
Is telegram-desktop-manjaro related in anyway?
I get the Security/Overlay git feed, and that’s where I saw it.
notifications are back online.
