I was thinking of trying out mplayer , the cli video player …
I choose to use $ pamac install mplayer instead of $ pacman -S mplayer just for the fun of trying out … But to my surprise, it is 1.6GB size and have taken forever to download …What is it ? it is still downloading
Looking at arch package size, mplayer should only size 2.2MB… why 1.6GB ?
Should i cancel the downloading command ?
Have i did something seriously wrong ?! I am nervous now. :-p
Hurry up guys… it is 740MB already
No. Pamac wants to update your system when you install something, because partial updates are not supported.
Pacman on the other hand does not care if you break your system.
it should be fine.
if you have an issue you can report it here:
or open a thread about it,
and it’s good practice to read the updates announcements to see if there are special instructions or things to look for etc.
On a side note I recommend you to install SMPlayer, this way you have a good interface to use Mplayer. Mplayer by itself works great but it is keyboard control only if I recall correctly.
Hmm … How come this link said: to use mplayer in gui mode , just run gmplayer instead of mplayer , But you said need to install SMPlayer ?
[Linux is NOT Windows]
I have read through pamac install --help and man pamac … it didn’t mention anything about what pamac install does. pamac install --help : Install packages from repositories , path or url.
It didn’t mention anything about update system…or what else it does apart from install package from repo…
I was running pamac install , and pamac upgraded my whole system.
But in man pamac never mention that it does upgrade system first than install package…
This is not a big deal, but since it never mention that pamac will do upgrade first than install package (pamac don’t do partial update/ install)… Or is it that i miss something … or i don’t know how to use man/ help .
It does, if you enable the setting for in the Advanced Settings (not sure about the CLI but for sure the GUI has the setting for it so maybe it works for the CLI too).
