Weird fonts in Chrome
I have installed minimal official KDE version of the manjaro and getting weird web fonts with misguiding cursor spacing
Site 1:
Site 2: Checkout loom video
Here are my browser details
:+1: Welcome to Manjaro! :+1:
  1. Please read this:
    How to provide good information
    and post some more information so we can see what’s really going on. Now we know the symptom of the disease, but we need some more probing to know where the origin lies… :grin:
  2. An inxi --admin --verbosity=7 --filter --no-host --width would be the minimum required information for us to be able to help you. (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
    Also, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text.
:+1:
P.S. If you enter a bit more details in your profile, we can also see which Desktop Environment you’re using, which CPU/GPU or Kernel, … you have without typing it every time
@Fabby here is the output
  Kernel: 5.4.124-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  root=UUID=38845911-dabf-40cf-a0fe-8abe080d3bfe rw udev.log_priority=3
  Desktop: KDE Plasma 5.21.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Laptop System: ASUSTeK product: TUF Gaming FX505GT_FX505GT v: 1.0
  serial: <filter>
  Mobo: ASUSTeK model: FX505GT v: 1.0 serial: <filter>
  UEFI: American Megatrends v: FX505GT.310 date: 11/26/2020
  ID-1: BAT0 charge: 39.7 Wh (99.2%) condition: 40.0/48.1 Wh (83.3%)
  volts: 12.7 min: 11.7 model: Simplo SDI ICR18650 type: Li-ion
  serial: <filter> status: Unknown cycles: 41
  RAM: total: 15.49 GiB used: 7.21 GiB (46.5%)
  Info: 6-Core model: Intel Core i7-9750H bits: 64 type: MT MCP
  arch: Kaby Lake note: check family: 6 model-id: 9E (158) stepping: A (10)
  microcode: DE cache: L2: 12 MiB bogomips: 62431
  Speed: 800 MHz min/max: 800/4500 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
  4: 800 5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800
  Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
  avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
  hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
  mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
  rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1
  xsaves xtopology xtpr
  Type: l1tf
  Device-1: Intel UHD Graphics 630 vendor: ASUSTeK driver: i915 v: kernel
  bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
  Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: ASUSTeK
  driver: nvidia v: 465.31 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
  chip-ID: 10de:1f91 class-ID: 0300
  Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
  bus-ID: 1-11:2 chip-ID: 13d3:56a2 class-ID: 0e02 serial: <filter>
  Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver:
  loaded: modesetting,nvidia alternate: fbdev,intel,nouveau,nv,vesa
  display-ID: :0 screens: 1
  s-diag: 582mm (22.9")
  OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 21.1.2
  direct render: Yes
  Device-1: Intel Cannon Lake PCH cAVS vendor: ASUSTeK driver: snd_hda_intel
  v: kernel alternate: snd_soc_skl,snd_sof_pci bus-ID: 00:1f.3
  Sound Server-1: ALSA v: k5.4.124-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.30 running: no
  Device-1: Intel Wireless-AC 9560 [Jefferson Peak] driver: iwlwifi v: kernel
  port: 5000 bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
  vendor: ASUSTeK driver: r8169 v: kernel port: 3000 bus-ID: 02:00.0
  Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
  driver: btusb v: 0.8 bus-ID: 1-14:3 chip-ID: 8087:0aaa class-ID: e001
  Permissions: Unable to run lvs. Root privileges required.
  Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
  v: 3.0 port: 5060 bus-ID: 00:17.0 chip-ID: 8086.282a rev: 10 class-ID: 0104
  Local Storage: total: 931.51 GiB used: 266.33 GiB (28.6%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10SPZX-11Z10T0
  rotation: 5400 rpm serial: <filter> rev: 1A01 scheme: GPT
  ID-1: / raw-size: 268.55 GiB size: 263.28 GiB (98.04%)
  used: 87.6 GiB (33.3%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
  uuid: 38845911-dabf-40cf-a0fe-8abe080d3bfe
  used: 79.9 MiB (15.6%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
  uuid: 6BB0-A5B3
  ID-3: /home raw-size: 662.46 GiB size: 650.99 GiB (98.27%)
  used: 178.65 GiB (27.4%) fs: ext4 dev: /dev/sda3 maj-min: 8:3 label: N/A
  uuid: 599d6bb8-a70e-4e8f-9e25-d0bd29595d48
  ID-1: swap-1 type: file size: 3 GiB used: 0 KiB (0.0%) priority: -2
  file: /swapfile
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0
  Device-1: 1-11:2 info: IMC Networks USB2.0 HD UVC WebCam type: Video
  Device-2: 1-14:3 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
  type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
  power: 100mA chip-ID: 8087:0aaa class-ID: e001
  Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 8 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 60.0 C mobo: 27.8 C
  Fan Speeds (RPM): cpu: 2600
  Processes: 359 Uptime: 3h 33m wakeups: 1 Init: systemd v: 248
  tool: systemctl Compilers: gcc: 11.1.0 alt: 10 clang: 12.0.0 Packages:
  pacman: 1411 lib: 329 Shell: Bash v: 5.1.8 running-in: yakuake inxi: 3.3.04
Thank you for the info.
Does this happen in Firefox as well or only Chrome?
:thinking:
Particularly with Chrome. Working on firebox, chromium and brave browser
you do have weird fonts selected, have you tried other fonts?
noto fonts seems to cover most languages.
Only style changes, but the spacing is still off. For example
that looks like terminal, it’s usually set to the system font unless you change it in the terminal settings.
It is ttyd, terminal in browser. Checkout this video. This is simple text editor on web Loom | Free Screen & Video Recording Software
@Fabby This is when i copied google chrome configs into chromium folder
So, google chrome configs are indeed broken
Drop Chrome from your system like the ballast it is…
:grin:
