find /etc/X11/ -name "*.conf" ✔
/etc/X11/xorg.conf.d/90-mhwd.conf
/etc/X11/xorg.conf.d/30-touchpad.conf
/etc/X11/xorg.conf.d/00-keyboard.conf
/etc/X11/mhwd.d/nvidia.conf
ok, looks good, so test for some time, and if they dont appear you can consider it as resolved…
Should I stop using prime-switcher?
never heard of it, but i would say you should, its 3 years old… if you want to switch between intel/hybrid/nvidia, rather use optimus manager + optimus manager qt, or add prime-run to the programs/games you want to use with only nvidia
Thank you so much for all your help! Good luck to you and all the best! (deepl)
Artifacts again. I did optimus-manager --switch nvidia
so they appear only on nvidia? … you should unmark this post, so that more people could assist
Yep, I switched to hybrid and everything fixed, but is it good idea to doesn’t gpu?
so if you use some program/game with the prime-run command, are the glitches also present there on that program?
