so only touchpad, keyboard and the prime switcher?
Yes, only three configs
prime-switcher --detect advice to switch to nouveau-reverse-prime
ok i never heard about the prime switcher config, so delete it, if you dont know how, post the exact path here, i give you the command
it worked
so you booted normally?
Yes, I just switched to nouveau-reverse-prime
dont switch to anything, i wanted you to test on intel graphics if you have the artifacts also there…
so, just rm /etc/X11/xorg.conf.d/90-prime-switcher.conf
yes remove the prime swithcer conf, then reboot and test if you have artifacts
now reboot?
if you removed it, yes reboot and test
no artifacts
so go to system settings/hardware configuration and click on auto install proprietary driver, when its done reboot, and test again
no artifacts
ok, post output from mhwd -li
again
mhwd -li ✔
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-modesetting 2020.01.13 true PCI
network-r8168 2016.04.20 true PCI
video-hybrid-intel-nvidia-prime 2021.12.18 false PCI
ok looks good, now you can test artifacts with prime-run command… for example:
prime-run firefox
no artifactss
so no artifacts on intel also no artifacts when you run programs on nvidia with prime-run… it looks like its fixed… also post output from:
find /etc/X11/ -name "*.conf"
