I’ve experienced this problem on every linux distro i tried: I seem to get a very week wifi signal reception from my pc. I’m not close to the router but when I use windows I have no problem at all with the wifi signal, on the other side when I’m on Manjaro Gnome I get such a bad connection. In fact every 2-3 minutes, I get a message from spotify and telegram saying I’m not connected.
I just can’t figure out what the problem could be.
Kernel: 5.10.30-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=afbbf05d-fef5-42a1-b677-22325f3535c2 rw quiet splash apparmor=1
security=apparmor resume=UUID=412a1d53-1d96-4981-ad98-32dd824eb99d
udev.log_priority=3
Desktop: GNOME 3.38.4 tk: GTK 3.24.28 wm: gnome-shell dm: GDM 40.0
Type: Laptop System: Timi product: TM1701 v: N/A serial: <filter> Chassis:
type: 10 serial: <filter>
Mobo: Timi model: TM1701 v: MP serial: <filter> UEFI: INSYDE
v: XMAKB5R0P0E07 date: 09/11/2020
ID-1: BAT0 charge: 36.4 Wh (80.9%) condition: 45.0/60.0 Wh (74.9%)
volts: 8.1 min: 7.6 model: SUNWODA R15B01W type: Li-ion serial: <filter>
status: Discharging
RAM: total: 15.52 GiB used: 2 GiB (12.9%)
Info: Quad Core model: Intel Core i7-8550U bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 8E (142) stepping: A (10)
microcode: E0 cache: L2: 8 MiB bogomips: 31999
Speed: 800 MHz min/max: 400/4000 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
4: 800 5: 800 6: 800 7: 800 8: 800
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1
xsaves xtopology xtpr
Type: l1tf
Device-1: Intel UHD Graphics 620 vendor: Xiaomi driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:5917 class-ID: 0300
Device-2: NVIDIA GP108M [GeForce MX150] vendor: Xiaomi Mi Notebook Pro
driver: nvidia v: 460.67 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:1d12 class-ID: 0302
Device-3: Cheng Uei Precision Industry (Foxlink) XiaoMi USB 2.0 Webcam
type: USB driver: uvcvideo bus-ID: 1-6:3 chip-ID: 05c8:03b7 class-ID: 0e02
Display: x11 server: X.org 1.20.11 compositor: gnome-shell driver:
loaded: modesetting,nvidia alternate: fbdev,intel,nouveau,nv,vesa
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.0.2
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Xiaomi
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3
chip-ID: 8086:9d71 class-ID: 0403
Sound Server-1: ALSA v: k5.10.30-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.25 running: yes
Device-1: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel port: 3000
bus-ID: 02:00.0 chip-ID: 8086:24fd class-ID: 0280
bus-ID: 1-5:2 chip-ID: 8087:0a2b class-ID: e001
Local Storage: total: 471.36 GiB used: 12.75 GiB (2.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLB256HAHQ-00000
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 rotation: SSD serial: <filter> rev: EXD7101Q temp: 28.9 C
scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WDS250G2B0B-00YS70 size: 232.89 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s rotation: SSD serial: <filter> rev: 00WD
scheme: GPT
ID-1: / raw-size: 215.52 GiB size: 211.08 GiB (97.94%)
used: 12.75 GiB (6.0%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: afbbf05d-fef5-42a1-b677-22325f3535c2
used: 296 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
uuid: 516A-AD6C
ID-1: swap-1 type: partition size: 17.07 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda3 maj-min: 8:3 label: N/A
uuid: 412a1d53-1d96-4981-ad98-32dd824eb99d
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 100 MiB fs: vfat label: N/A
uuid: 2AC4-47CB
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 237.86 GiB fs: ntfs label: N/A
uuid: EE00C52300C4F39D
ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 511 MiB fs: ntfs label: N/A
uuid: F4982B02982AC2CA
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
Device-1: 1-5:2 info: Intel Bluetooth wireless interface type: Bluetooth
Device-2: 1-6:3
info: Cheng Uei Precision Industry (Foxlink) XiaoMi USB 2.0 Webcam
type: Video driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s
power: 500mA chip-ID: 05c8:03b7 class-ID: 0e02
Device-3: 1-7:4 info: Realtek RTS5129 Card Reader Controller
interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:0129
class-ID: ff00 serial: <filter>
Device-4: 1-8:5 info: Elan Micro ELAN:Fingerprint type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA
chip-ID: 04f3:0c1a class-ID: 0000
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 41.0 C mobo: N/A
Processes: 269 Uptime: 14m wakeups: 135 Init: systemd v: 247 tool: systemctl
Compilers: gcc: 10.2.0 Packages: 1261 pacman: 1254 lib: 319 flatpak: 0
snap: 7 Shell: Zsh v: 5.8 running-in: gnome-terminal inxi: 3.3.04```
