Wayland's not starting by default having "start session when boot automatically" enabled
As title says, I have enabled the “start session automatically when boot” option so when I boot my PC, I don’t need to see the Login screen.
The thing is, I have an AMD GPU and Wayland works flawlessly so I prefer use this protocol.
I read here: Enable wayland automatic at boot?
And I saw that if I close my session and I choose my user selecting “Wayland session” instead of “X11”, the Login screen should remember that option always. But when I reboot my PC, it starts again directly to X11. Anyone knows if this is a bug or if it’s an issue known? There’s another way to change this in a config file or similar? I should say, that I have my disk encrypted so I need to introduce a password to start the boot.
  Kernel: 6.16.4-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.16-x86_64
    root=UUID=7b7d6fab-4cbc-41ba-b506-df0cea6abde7 rw quiet
    cryptdevice=UUID=df6dd55e-b2d2-4260-89fe-3a184f8b1241:luks-df6dd55e-b2d2-4260-89fe-3a184f8b1241
    root=/dev/mapper/luks-df6dd55e-b2d2-4260-89fe-3a184f8b1241 splash
    udev.log_priority=3 DEEPIN_GFXMODE=
  Desktop: KDE Plasma v: 6.3.6 tk: Qt v: N/A info: frameworks v: 6.17.0
  Mobo: ASUSTeK model: TUF GAMING B850-PLUS WIFI v: Rev 1.xx
    UEFI: American Megatrends v: 1066 date: 06/13/2025
  System RAM: total: 32 GiB available: 30.5 GiB used: 3.85 GiB (12.6%)
  Array-1: capacity: 256 GiB slots: 4 modules: 2 EC: None
    max-module-size: 64 GiB note: est.
  Device-1: Channel-A DIMM 0 type: no module installed
  Device-2: Channel-A DIMM 1 type: DDR5 detail: synchronous unbuffered
    (unregistered) size: 16 GiB speed: 4800 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: N/A
    part-no: FO-DDR-PRO-32GBCL32 serial: <filter>
  Device-3: Channel-B DIMM 0 type: no module installed
  Device-4: Channel-B DIMM 1 type: DDR5 detail: synchronous unbuffered
  Info: model: AMD Ryzen 7 9800X3D bits: 64 type: MT MCP arch: Zen 5 gen: 5
    level: v4 note: check built: 2024+ process: TSMC n4 (4nm) family: 0x1A (26)
    model-id: 0x44 (68) stepping: 0 microcode: 0xB404032
    smt: enabled cache: L1: 640 KiB desc: d-8x48 KiB; i-8x32 KiB L2: 8 MiB
    desc: 8x1024 KiB L3: 96 MiB desc: 1x96 MiB
  Speed (MHz): avg: 4106 min/max: 603/5272 boost: enabled scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 4106 2: 4106 3: 4106
    4: 4106 5: 4106 6: 4106 7: 4106 8: 4106 9: 4106 10: 4106 11: 4106 12: 4106
    13: 4106 14: 4106 15: 4106 16: 4106 bogomips: 150108
    apic arat avic avx avx2 avx512_bf16 avx512_bitalg avx512_vbmi2
    avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
    avx512dq avx512f avx512ifma avx512vbmi avx512vl avx_vnni bmi1 bmi2 bpext
    bus_lock_detect cat_l3 cdp_l3 clflush clflushopt clwb clzero cmov
    cmp_legacy constant_tsc cpb cppc cpuid cqm cqm_llc cqm_mbm_local
    cqm_mbm_total cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms
    extapic extd_apicid f16c flush_l1d flushbyasid fma fpu fsgsbase fsrm fxsr
    fxsr_opt gfni ht hw_pstate ibpb ibrs ibrs_enhanced ibs invpcid irperf
    lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor movbe
    movdir64b movdiri msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx ospke
    osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core
    perfctr_llc perfctr_nb perfmon_v2 pfthreshold pge pku pni popcnt pse
    pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
    skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp
    succor svm svm_lock syscall tce topoext tsc tsc_adjust tsc_scale umip
    vnmi vpclmulqdq wbnoinvd wdt x2avic xgetbv1 xsave xsavec xsaveerptr
    xsaveopt xsaves xtopology
  Type: spec_rstack_overflow mitigation: IBPB on VMEXIT only
    conditional; STIBP: always-on; PBRSB-eIBRS: Not affected; BHI: Not
    affected
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 48 [Radeon RX 9070/9070
    XT/9070 GRE] vendor: ASUSTeK driver: amdgpu v: kernel arch: RDNA-4
    code: Navi-4x process: TSMC n4 (4nm) built: 2025+ pcie: gen: 5
    speed: 32 GT/s lanes: 16 ports: active: DP-1 empty: DP-2, DP-3, HDMI-A-1,
    Writeback-1 bus-ID: 03:00.0 chip-ID: 1002:7550 class-ID: 0300
  Device-2: Advanced Micro Devices [AMD/ATI] Granite Ridge [Radeon Graphics]
    vendor: ASUSTeK driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
    process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s
    lanes: 16 ports: active: none empty: DP-4,HDMI-A-2,Writeback-2
    bus-ID: 0e:00.0 chip-ID: 1002:13c0 class-ID: 0300 temp: 46.0 C
  Device-3: Razer USA Gaming Webcam [Kiyo] driver: snd-usb-audio,uvcvideo
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-1:2
    chip-ID: 1532:0e03 class-ID: 0102
    compositor: kwin_wayland driver: X: loaded: amdgpu
    gpu: amdgpu display-ID: 0
  Monitor-1: DP-1 model: Samsung Odyssey G5 serial: <filter> built: 2024
    res: mode: 2560x1440 hz: 165 scale: 100% (1) dpi: 93 gamma: 1.2 chroma: red:
    x: 0.647 y: 0.333 green: x: 0.318 y: 0.616 blue: x: 0.153 y: 0.063 white:
    x: 0.314 y: 0.329 size: 698x393mm (27.48x15.47") diag: 806mm (31.7")
    ratio: 16:9 modes: 2560x1440, 1920x1200, 1920x1080, 1600x1200, 1680x1050,
    1600x900, 1280x1024, 1440x900, 1280x800, 1152x864, 1280x720, 1024x768,
    832x624, 800x600, 640x480, 720x400
    device: 1 drv: radeonsi device: 2 drv: swrast gbm: drv: radeonsi
    surfaceless: drv: radeonsi wayland: drv: radeonsi x11: drv: radeonsi
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.2.1-arch1.4
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 9070 XT (radeonsi
    gfx1201 LLVM 20.1.8 DRM 3.64 6.16.4-2-MANJARO) device-ID: 1002:7550
    memory: 15.62 GiB unified: no display-ID: :1.0
  API: Vulkan v: 1.4.321 layers: 4 device: 0 type: discrete-gpu name: AMD
    Radeon RX 9070 XT (RADV GFX1201) driver: mesa radv v: 25.2.1-arch1.4
    device-ID: 1002:7550 surfaces: N/A device: 1 type: integrated-gpu name: AMD
    Radeon Graphics (RADV RAPHAEL_MENDOCINO) driver: mesa radv
    v: 25.2.1-arch1.4 device-ID: 1002:13c0 surfaces: N/A
    x11: xdpyinfo, xprop, xrandr
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 48 HDMI/DP Audio
    driver: snd_hda_intel v: kernel pcie: gen: 5 speed: 32 GT/s lanes: 16
    bus-ID: 03:00.1 chip-ID: 1002:ab40 class-ID: 0403
  Device-2: Advanced Micro Devices [AMD/ATI] Radeon High Definition Audio
    [Rembrandt/Strix] vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie:
    gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0e:00.1 chip-ID: 1002:1640
    class-ID: 0403
    vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 0e:00.6 chip-ID: 1022:15e3 class-ID: 0403
  Device-4: Razer USA Gaming Webcam [Kiyo] driver: snd-usb-audio,uvcvideo
  Device-5: Texas Instruments PCM2903C Audio CODEC
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 5-2:3 chip-ID: 08bb:29c3 class-ID: 0300
  API: ALSA v: k6.16.4-2-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.7 status: active with: 1: pipewire-pulse
  Device-1: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169 v: kernel
    pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 0a:00.0
  Device-2: MEDIATEK vendor: AzureWave driver: mt7925e v: kernel pcie:
    gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 0b:00.0 chip-ID: 14c3:7925
    class-ID: 0280
  IF: wlp11s0 state: up mac: <filter>
  Device-1: IMC Networks Wireless_Device driver: btusb v: 0.8 type: USB
    rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:5 chip-ID: 13d3:3602
  Device-1: luks-df6dd55e-b2d2-4260-89fe-3a184f8b1241 maj-min: 253:0
    type: LUKS dm: dm-0 size: 1.86 TiB
  Components:
  p-1: nvme0n1p2 maj-min: 259:2 size: 1.86 TiB
  Local Storage: total: 2.77 TiB used: 1.27 TiB (45.8%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 model: FO-SSD-PLUS2TB size: 1.86 TiB
    block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s lanes: 4
    tech: SSD serial: <filter> fw-rev: H231225a temp: 38.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ04UBF100
    size: 931.51 GiB block-size: physical: 512 B logical: 512 B type: USB
    rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: HDD rpm: 5400
    serial: <filter> scheme: GPT
  ID-1: / raw-size: 1.86 TiB size: 1.83 TiB (98.37%) used: 556.84 GiB (29.7%)
    fs: ext4 dev: /dev/dm-0 maj-min: 253:0
    mapped: luks-df6dd55e-b2d2-4260-89fe-3a184f8b1241 label: N/A
    uuid: 7b7d6fab-4cbc-41ba-b506-df0cea6abde7
    used: 536 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: 57BE-29D3
  ID-3: /run/media/noctis/Datos_LINUX raw-size: 931.51 GiB
    size: 916.82 GiB (98.42%) used: 743.24 GiB (81.1%) fs: ext4 dev: /dev/sda2
    maj-min: 8:2 label: Datos_LINUX uuid: 8e67b426-b9bd-4b72-8808-6bd0e9940001
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Hub-2: 1-2:2 info: ASMedia ASM1074 High-Speed hub ports: 4 rev: 2.1
    chip-ID: 174c:2074 class-ID: 0900
  Device-1: 1-2.1:4 info: Holtek USB Gaming Mouse type: mouse,keyboard
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 04d9:a09e class-ID: 0300
  Device-2: 1-2.4:6 info: Cooler Master Masterkeys Lite L Combo RGB Keyboard
    type: keyboard,mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
    chip-ID: 2516:0042 class-ID: 0301
  Hub-3: 1-4:3 info: ASMedia ASM1074 High-Speed hub ports: 4 rev: 2.1
  Device-1: 1-6:5 info: IMC Networks Wireless_Device type: bluetooth
    mode: 2.0 power: 100mA chip-ID: 13d3:3602 class-ID: e001 serial: <filter>
  Device-2: 1-11:7 info: ASUSTek AURA LED Controller type: HID
    lanes: 1 mode: 1.1 power: 16mA chip-ID: 0b05:19af class-ID: 0300
    serial: <filter>
  Hub-4: 2-0:1 info: super-speed hub ports: 5 rev: 3.1
  Hub-5: 2-2:2 info: ASMedia ASM1074 SuperSpeed hub ports: 4 rev: 3.0
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 8mA
    chip-ID: 174c:3074 class-ID: 0900
  Hub-6: 2-4:3 info: ASMedia ASM1074 SuperSpeed hub ports: 4 rev: 3.0
  Device-1: 2-4.4:4 info: Toshiba America External USB 3.0
    type: mass storage driver: usb-storage interfaces: 1 rev: 3.0
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 896mA
    chip-ID: 0480:0901 class-ID: 0806 serial: <filter>
  Hub-7: 3-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-8: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-9: 5-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Device-1: 5-1:2 info: Razer USA Gaming Webcam [Kiyo] type: video,audio
  Device-2: 5-2:3 info: Texas Instruments PCM2903C Audio CODEC
    type: audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 4
    rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 20mA
  Hub-10: 6-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-11: 7-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-12: 8-0:1 info: Linux Foundation 3.0 root hub ports: N/A rev: 3.0
  System Temperatures: cpu: 50.6 C mobo: 41.5 C
  Fan Speeds (rpm): N/A
  GPU: device: amdgpu temp: 46.0 C device: amdgpu temp: 48.0 C mem: 68.0 C
    fan: 0 watts: 27.00
  Packages: 1522 pm: pacman pkgs: 1500 libs: 470 tools: pamac pm: flatpak
    pkgs: 22
    1: https://mirror.fcix.net/manjaro/stable/$repo/$arch
    2: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
    3: https://manjaro.mirrors.uk2.net/stable/$repo/$arch
    4: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
    5: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    6: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
    7: https://mirror.easyname.at/manjaro/stable/$repo/$arch
    8: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
    9: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
    10: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
    11: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
    12: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
    13: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
    14: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
    15: https://mirrors.manjaro.org/repo/stable/$repo/$arch
    16: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
    17: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
    18: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
    19: https://mirror.ibakerserver.pt/manjaro/stable/$repo/$arch
    20: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
    21: https://manjaro.ynh.ovh/stable/$repo/$arch
    22: https://muug.ca/mirror/manjaro/stable/$repo/$arch
    23: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
    24: https://manjaro.syxpi.fr/manjaro/stable/$repo/$arch
    25: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
    26: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
    27: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
    28: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
    29: https://mirror.dimensiondata.com/mirrors/manjaro.org/stable/$repo/$arch
    30: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
    31: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
    32: https://mirrors2.manjaro.org/stable/$repo/$arch
    33: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
    34: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
    35: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
    36: https://mirrors.atlas.net.co/manjaro/stable/$repo/$arch
    37: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
    38: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
    39: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
    40: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
    41: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
    42: https://mirror.init7.net/manjaro/stable/$repo/$arch
    43: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
    44: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
    45: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
    46: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
    47: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
    48: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
    49: https://manjaro.kurdy.org/stable/$repo/$arch
    50: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
    51: https://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
Processes:
  CPU top: 5 of 417
  1: cpu: 7.9% command: firefox pid: 6819 mem: 637.6 MiB (2.0%)
  2: cpu: 7.4% command: konsole pid: 8924 mem: 236.4 MiB (0.7%)
  3: cpu: 6.8% command: steamwebhelper pid: 7966 mem: 299.9 MiB (0.9%)
  4: cpu: 6.7% command: steamwebhelper pid: 8029 mem: 499.7 MiB (1.5%)
  5: cpu: 4.2% command: firefox pid: 7203 mem: 324.2 MiB (1.0%)
  Memory top: 5 of 417
  1: mem: 637.6 MiB (2.0%) command: firefox pid: 6819 cpu: 7.9%
  2: mem: 534.4 MiB (1.7%) command: plasmashell pid: 6267 cpu: 1.2%
  3: mem: 499.7 MiB (1.5%) command: steamwebhelper pid: 8029 cpu: 6.7%
  4: mem: 450.1 MiB (1.4%) command: ./steamwebhelper pid: 7935 cpu: 0.8%
  5: mem: 342.1 MiB (1.0%) command: kwin_wayland pid: 5981 cpu: 2.7%
  Processes: 417 Power: uptime: 1h 15m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.18 GiB services: org_kde_powerdevil,
    tool: systemctl
  Compilers: gcc: 15.2.1 Shell: Zsh v: 5.9 running-in: konsole inxi: 3.3.39
Thanks, guys!
… and what happens if you go to the login screen, select the wayland session, log in, log out
and then reboot?
It should “remember” your last choice.
Did you do it? Going to System Settings -> Colors & Themes -> Login Screen (SDDM) and under the Behavior tab there is the Automatically log in to choose user and session? So you selected there with session Plasma (Wayland) but it comes up with Plasma’s X11 session?
I’d generally suggest not having that enabled, as complications can potentially arise when you least expect it.
However, if you really must…
The resolution to your issue has already been given in the soution of the other topic you referenced Enable Wayland automatic at Boot, except, the location has changed a little since 2021;
Although it’s not particularly intuitive, here’s how:
System Settings:
Colours and Themes
Global Theme
Login Screen (SDDM):
Choose Behaviour at the top of the screen and from the Behaviour dialog, check the following:
Automatically log in: as user: (You) with session: …
  • Choose Plasma (Wayland) from the dropdown.
Reboot, and enjoy supreme laziness. :wink:
Hi, @jofi and @soundofthunder !
I didn’t know I can adjust this from Colors & Themes, what a shame from my part. Now yeah, it goes to Wayland directly when I reboot. Thank you, guys!!
PS: @soundofthunder If I end up having problems with automatic boot, I may end up removing it in the future. Let’s see how it goes. Thanks for the heads up!
To be ironic it’s a good thing not knowing too much of Plasma :slightly_smiling_face:
It is one of the least intuitive sections in the System Settings app. I would much prefer an additional entry in the Session area for SDDM behavior.
As I don’t use automatic login, I haven’t missed it, though I agree that users would likely benefit from better positioning of sddm-kcm entry points.
However, this is a KDE thing, and I’m sure they would welcome any suggestions you may have. It seems SDDM has been a problem child for KDE for some time – so much so that there is talk of creating a custom replacement for it.
I suppose we’ll wait with baited breath (as is said).
