Wayland is not starting
i want to know why my pc is not booting with wayland
echo $XDG_SESSION_TYPE  :heavy_check_mark:
x11
GNU nano 8.0 /etc/gdm/custom.conf
GDM configuration storage
[daemon]
AutomaticLogin=jps
AutomaticLoginEnable=True
Uncomment the line below to force the login screen to use Xorg
WaylandEnable=true
OS: Manjaro Linux x86_64
██████████████████ ████████ Kernel: 6.9.5-1-MANJARO
████████ ████████ Uptime: 15 mins
████████ ████████ ████████ Packages: 1212 (pacman), 8 (snap)
████████ ████████ ████████ Shell: zsh 5.9
████████ ████████ ████████ Resolution: 1920x1080
████████ ████████ ████████ DE: GNOME 46.2
████████ ████████ ████████ WM: Mutter
████████ ████████ ████████ WM Theme: Adwaita
████████ ████████ ████████ Theme: Adw-dark [GTK2/3]
████████ ████████ ████████ Icons: Papirus-Dark-Maia [GTK2/3]
████████ ████████ ████████ Terminal: gnome-terminal
CPU: AMD Ryzen 5 5600G with Radeon Graphics (12)
GPU: NVIDIA GeForce RTX 3050 8GB
Memory: 3868MiB / 15784MiB
wayland is the default
the default in the config file is, as far as I know:
# Uncomment the line below to force the login screen to use Xorg
# WaylandEnable=false
Not sure whether it is needed to uncomment it and set it to true.
Did you change that to:
WaylandEnable=true
I have modified it that way because it was not working for default
… and now you are in the same situation - it doesn’t work (with your change)
so I’d try to revert it
I cannot help because my Gnome installation is in a VM - and Wayland doesn’t work there anyway.
I’d always use what works …
This information (presumedly from neofetch, or similar) isn’t really as helpful as you might think, and doesn’t provide much useful information. When someone asks for system information, please provide the output of the following command, instead:
inxi --admin --verbosity=8 --filter --no-host --width
That is all. Cheers.
:bangbang: Tip :bangbang:
When posting terminal output, copy the output and paste it here, wrapped in three (3) backticks, before AND after the pasted text. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Sed
sollicitudin dolor
eget nisl elit id
condimentum
arcu erat varius
cursus sem quis eros.
Instead of like this:
Sed sollicitudin dolor eget nisl elit id condimentum arcu erat varius cursus sem quis eros.
Thereby increasing legibility thus making it easier for those trying to provide assistance.
For more information, please see:
:bangbang::bangbang: Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
