This is the message:
warning: grub: local (2.06.r297.g0c6c1aff2-1) is newer than core (2.06.r261.g2f4430cc0-1)
It appears you have an Arch package installed that was added on Aug 11th https://mirrors.cloud.tencent.com/archlinuxcn/x86_64/grub-git-1%3A2.06.r297.g0c6c1aff2-1-x86_64.pkg.tar.zst that hasnt been added to Manjaro. It isnt even in Unstable.
It was. I removed it for now as it would not display the GRUB menu while the previous version did.
@Tribble You can keep it installed if youâre having no issues. Otherwise, you may install the old version if you prefer.
@Tribble no offense, but seeing that youâre using unstable branch, you should have known what that message meant.
Personally have to downgrade via live environment. Otherwise I cannot boot into my system ![]()
Iâm not having any issue, working fine.
some say that there is no menu created anymore. my guess: grub.git - GNU GRUB
I had a drive where I had Manjaro unstable, then upgraded grub but didnât downgrade because it was working fine:
Original thread:
Today I just couldnât boot anymore, not even get the grub menu. Just getting the Slot 0 opened and a black screen.
Then downloaded and booted from live manjaro-kde-21.3.7-220816-linux515.iso and booted from it, followed the steps according to:
$ sudo cryptsetup luksOpen /dev/sdc2 manjaro
$ sudo mount /dev/mapper/manjaro /mnt
$ sudo mount /dev/sdc1 /mnt/boot/efi
$ sudo -i
# manjaro-chroot /mnt /bin/bash
Try to reinstall grub:
[manjaro /]# pacman -Sy grub
core is up to date
extra is up to date
community is up to date
multilib is up to date
warning: downgrading package grub (2.06.r322.gd9b4638c5-1 => 2.06.r261.g2f4430cc0-1)
resolving dependencies...
Packages (1) grub-2.06.r261.g2f4430cc0-1
Total Download Size: 14.81 MiB
Total Installed Size: 46.79 MiB
Net Upgrade Size: -0.18 MiB
:: Proceed with installation? [Y/n] Y
:: Retrieving packages...
grub-2.06.r261.g2f4430cc0-1-x86_64 14.8 MiB 5.11 MiB/s 00:03 [#######################################################################################] 100%
(1/1) checking keys in keyring [#######################################################################################] 100%
(1/1) checking package integrity [#######################################################################################] 100%
(1/1) loading package files [#######################################################################################] 100%
(1/1) checking for file conflicts [#######################################################################################] 100%
(1/1) checking available disk space [#######################################################################################] 100%
(1/1) downgrading grub [#######################################################################################] 100%
:: Grub does no longer support side-loading modules when secure boot is
enabled. Thus booting will fail, unless you have an efi executable
'grubx64.efi' with bundled modules.
(1/2) Arming ConditionNeedsUpdate...
(2/2) Updating the info directory file...
Continue:
# grub-install --target=x86_64-efi --efi-directory=/boot/efi --bootloader-id=manjaro --recheck
Installing for x86_64-efi platform.
Installation finished. No error reported.
Continue:
[manjaro /]# grub-mkconfig -o /boot/grub/grub.cfg
Found linux image: /boot/vmlinuz-5.19-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.19-x86_64.img
Found initrd fallback image: /boot/initramfs-5.19-x86_64-fallback.img
Found linux image: /boot/vmlinuz-5.18-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.18-x86_64.img
Found initrd fallback image: /boot/initramfs-5.18-x86_64-fallback.img
Found linux image: /boot/vmlinuz-5.15-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.15-x86_64.img
Found initrd fallback image: /boot/initramfs-5.15-x86_64-fallback.img
Found linux image: /boot/vmlinuz-5.10-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.10-x86_64.img
Found initrd fallback image: /boot/initramfs-5.10-x86_64-fallback.img
ERROR: mkdir /var/lock/dmraid
done
Continue:
[manjaro /]# ls /sys/firmware/efi
config_table efivars esrt fw_platform_size fw_vendor runtime runtime-map systab
[manjaro /]# exit
exit
[manjaro ~]# modprobe efivarfs
[manjaro ~]# manjaro-chroot /mnt /bin/bash
[manjaro /]# mount -t efivarfs efivarfs /sys/firmware/efi/efivars
mount: /sys/firmware/efi/efivars: efivarfs already mounted on /sys/firmware/efi/efivars.
dmesg(1) may have more information after failed mount system call.
Now after rebooting to installation, entering the LUKS password tries to boot to grub but fails:
ttempting to decrypt master key...
Enter passphrase for hd0,gpt2 (xxx):
Slot 0 opened
error: symbol `grub_debug_malloc` not found.
Entering rescue mode...
grub rescue>
Any help?
Most like that happens when you have installed grub in BIOS mode and overwrite with grub-install in EFI mode. When switching between modes, you need to purge the whole grub folder and then reinstall.
rm -Rf /boot/grub/*
It did not work, still stuck on same issue. Are you saying that my system was in BIOS mode instead of EFI? How do I reinstall in BIOS then?
No idea. It is just a guess. You are in front of your computer.
Ok on wiki.manjaro.org it is perfectly explained. Just search.
Just after running your command and rebooting again to live manjaro, these are the results:
$ sudo mkdir /sdc1/ /sdc2/
$ sudo mount /dev/mapper/manjaro /sdc2/
$ sudo mount /dev/sdc1 /sdc1/
Then these are the files:
$ sudo find /sdc1
/sdc1
/sdc1/EFI
/sdc1/EFI/Manjaro
/sdc1/EFI/Manjaro/grubx64.efi
/sdc1/EFI/boot
/sdc1/EFI/boot/bootx64.efi
/sdc1/System Volume Information
/sdc1/System Volume Information/IndexerVolumeGuid
/sdc1/System Volume Information/WPSettings.dat
$ sudo find /sdc2 -maxdepth 1
/sdc2
/sdc2/etc
/sdc2/dev
/sdc2/root
/sdc2/bin
/sdc2/rootfs-pkgs.txt
/sdc2/home
/sdc2/lib
/sdc2/.manjaro-tools
/sdc2/mnt
/sdc2/tmp
/sdc2/sys
/sdc2/proc
/sdc2/boot
/sdc2/crypto_keyfile.bin
/sdc2/usr
/sdc2/opt
/sdc2/desktopfs-pkgs.txt
/sdc2/run
/sdc2/srv
/sdc2/sbin
/sdc2/lib64
/sdc2/var
/sdc2/lost+found
$ sudo find /sdc2/boot
/sdc2/boot
/sdc2/boot/intel-ucode.img
/sdc2/boot/linux519-x86_64.kver
/sdc2/boot/initramfs-5.18-x86_64-fallback.img
/sdc2/boot/initramfs-5.19-x86_64.img
/sdc2/boot/syslinux
/sdc2/boot/syslinux/syslinux.cfg
/sdc2/boot/memtest86+
/sdc2/boot/memtest86+/memtest.bin
/sdc2/boot/initramfs-5.10-x86_64-fallback.img
/sdc2/boot/initramfs-5.15-x86_64.img
/sdc2/boot/linux510-x86_64.kver
/sdc2/boot/linux518-x86_64.kver
/sdc2/boot/grub
/sdc2/boot/grub/fonts
/sdc2/boot/grub/fonts/unicode.pf2
/sdc2/boot/grub/themes
/sdc2/boot/grub/themes/starfield
/sdc2/boot/grub/themes/starfield/dejavu_bold_14.pf2
/sdc2/boot/grub/themes/starfield/dejavu_10.pf2
/sdc2/boot/grub/themes/starfield/terminal_box_s.png
/sdc2/boot/grub/themes/starfield/theme.txt
/sdc2/boot/grub/themes/starfield/terminal_box_e.png
/sdc2/boot/grub/themes/starfield/terminal_box_n.png
/sdc2/boot/grub/themes/starfield/terminal_box_sw.png
/sdc2/boot/grub/themes/starfield/boot_menu_w.png
/sdc2/boot/grub/themes/starfield/terminal_box_se.png
/sdc2/boot/grub/themes/starfield/dejavu_12.pf2
/sdc2/boot/grub/themes/starfield/terminal_box_nw.png
/sdc2/boot/grub/themes/starfield/boot_menu_n.png
/sdc2/boot/grub/themes/starfield/boot_menu_c.png
/sdc2/boot/grub/themes/starfield/boot_menu_nw.png
/sdc2/boot/grub/themes/starfield/boot_menu_e.png
/sdc2/boot/grub/themes/starfield/slider_n.png
/sdc2/boot/grub/themes/starfield/dejavu_16.pf2
/sdc2/boot/grub/themes/starfield/terminal_box_c.png
/sdc2/boot/grub/themes/starfield/blob_w.png
/sdc2/boot/grub/themes/starfield/boot_menu_sw.png
/sdc2/boot/grub/themes/starfield/boot_menu_se.png
/sdc2/boot/grub/themes/starfield/starfield.png
/sdc2/boot/grub/themes/starfield/dejavu_14.pf2
/sdc2/boot/grub/themes/starfield/terminal_box_ne.png
/sdc2/boot/grub/themes/starfield/boot_menu_s.png
/sdc2/boot/grub/themes/starfield/boot_menu_ne.png
/sdc2/boot/grub/themes/starfield/COPYING.CC-BY-SA-3.0
/sdc2/boot/grub/themes/starfield/slider_s.png
/sdc2/boot/grub/themes/starfield/terminal_box_w.png
/sdc2/boot/grub/themes/starfield/README
/sdc2/boot/grub/themes/starfield/slider_c.png
/sdc2/boot/grub/grub.cfg
/sdc2/boot/grub/grubenv
/sdc2/boot/grub/x86_64-efi
/sdc2/boot/grub/x86_64-efi/partmap.lst
/sdc2/boot/grub/x86_64-efi/xfs.mod
/sdc2/boot/grub/x86_64-efi/cmp_test.mod
/sdc2/boot/grub/x86_64-efi/videoinfo.mod
/sdc2/boot/grub/x86_64-efi/font.mod
/sdc2/boot/grub/x86_64-efi/cmdline_cat_test.mod
/sdc2/boot/grub/x86_64-efi/macho.mod
/sdc2/boot/grub/x86_64-efi/iso9660.mod
/sdc2/boot/grub/x86_64-efi/cbtime.mod
/sdc2/boot/grub/x86_64-efi/search_fs_uuid.mod
/sdc2/boot/grub/x86_64-efi/gcry_sha512.mod
/sdc2/boot/grub/x86_64-efi/ldm.mod
/sdc2/boot/grub/x86_64-efi/odc.mod
/sdc2/boot/grub/x86_64-efi/bfs.mod
/sdc2/boot/grub/x86_64-efi/part_sun.mod
/sdc2/boot/grub/x86_64-efi/ehci.mod
/sdc2/boot/grub/x86_64-efi/password_pbkdf2.mod
/sdc2/boot/grub/x86_64-efi/cbfs.mod
/sdc2/boot/grub/x86_64-efi/gettext.mod
/sdc2/boot/grub/x86_64-efi/msdospart.mod
/sdc2/boot/grub/x86_64-efi/ohci.mod
/sdc2/boot/grub/x86_64-efi/wrmsr.mod
/sdc2/boot/grub/x86_64-efi/serial.mod
/sdc2/boot/grub/x86_64-efi/mdraid09_be.mod
/sdc2/boot/grub/x86_64-efi/geli.mod
/sdc2/boot/grub/x86_64-efi/romfs.mod
/sdc2/boot/grub/x86_64-efi/cat.mod
/sdc2/boot/grub/x86_64-efi/true.mod
/sdc2/boot/grub/x86_64-efi/gcry_rijndael.mod
/sdc2/boot/grub/x86_64-efi/gcry_serpent.mod
/sdc2/boot/grub/x86_64-efi/nativedisk.mod
/sdc2/boot/grub/x86_64-efi/gcry_rmd160.mod
/sdc2/boot/grub/x86_64-efi/btrfs.mod
/sdc2/boot/grub/x86_64-efi/usbserial_common.mod
/sdc2/boot/grub/x86_64-efi/raid6rec.mod
/sdc2/boot/grub/x86_64-efi/multiboot2.mod
/sdc2/boot/grub/x86_64-efi/minix3_be.mod
/sdc2/boot/grub/x86_64-efi/video_fb.mod
/sdc2/boot/grub/x86_64-efi/trig.mod
/sdc2/boot/grub/x86_64-efi/tar.mod
/sdc2/boot/grub/x86_64-efi/video.lst
/sdc2/boot/grub/x86_64-efi/part_gpt.mod
/sdc2/boot/grub/x86_64-efi/lspci.mod
/sdc2/boot/grub/x86_64-efi/archelp.mod
/sdc2/boot/grub/x86_64-efi/minix2_be.mod
/sdc2/boot/grub/x86_64-efi/uhci.mod
/sdc2/boot/grub/x86_64-efi/sleep_test.mod
/sdc2/boot/grub/x86_64-efi/cbmemc.mod
/sdc2/boot/grub/x86_64-efi/json.mod
/sdc2/boot/grub/x86_64-efi/video_bochs.mod
/sdc2/boot/grub/x86_64-efi/minix2.mod
/sdc2/boot/grub/x86_64-efi/xnu.mod
/sdc2/boot/grub/x86_64-efi/cpio_be.mod
/sdc2/boot/grub/x86_64-efi/multiboot.mod
/sdc2/boot/grub/x86_64-efi/grub.efi
/sdc2/boot/grub/x86_64-efi/gcry_blowfish.mod
/sdc2/boot/grub/x86_64-efi/backtrace.mod
/sdc2/boot/grub/x86_64-efi/usbserial_usbdebug.mod
/sdc2/boot/grub/x86_64-efi/memdisk.mod
/sdc2/boot/grub/x86_64-efi/rdmsr.mod
/sdc2/boot/grub/x86_64-efi/gfxterm.mod
/sdc2/boot/grub/x86_64-efi/probe.mod
/sdc2/boot/grub/x86_64-efi/minicmd.mod
/sdc2/boot/grub/x86_64-efi/http.mod
/sdc2/boot/grub/x86_64-efi/hexdump.mod
/sdc2/boot/grub/x86_64-efi/gcry_camellia.mod
/sdc2/boot/grub/x86_64-efi/squash4.mod
/sdc2/boot/grub/x86_64-efi/cryptodisk.mod
/sdc2/boot/grub/x86_64-efi/raid5rec.mod
/sdc2/boot/grub/x86_64-efi/terminal.mod
/sdc2/boot/grub/x86_64-efi/usbtest.mod
/sdc2/boot/grub/x86_64-efi/test.mod
/sdc2/boot/grub/x86_64-efi/xnu_uuid.mod
/sdc2/boot/grub/x86_64-efi/video_colors.mod
/sdc2/boot/grub/x86_64-efi/elf.mod
/sdc2/boot/grub/x86_64-efi/part_msdos.mod
/sdc2/boot/grub/x86_64-efi/moddep.lst
/sdc2/boot/grub/x86_64-efi/tftp.mod
/sdc2/boot/grub/x86_64-efi/keylayouts.mod
/sdc2/boot/grub/x86_64-efi/gcry_rsa.mod
/sdc2/boot/grub/x86_64-efi/at_keyboard.mod
/sdc2/boot/grub/x86_64-efi/cacheinfo.mod
/sdc2/boot/grub/x86_64-efi/crypto.lst
/sdc2/boot/grub/x86_64-efi/part_dvh.mod
/sdc2/boot/grub/x86_64-efi/all_video.mod
/sdc2/boot/grub/x86_64-efi/gcry_tiger.mod
/sdc2/boot/grub/x86_64-efi/ls.mod
/sdc2/boot/grub/x86_64-efi/date.mod
/sdc2/boot/grub/x86_64-efi/part_bsd.mod
/sdc2/boot/grub/x86_64-efi/lssal.mod
/sdc2/boot/grub/x86_64-efi/offsetio.mod
/sdc2/boot/grub/x86_64-efi/gzio.mod
/sdc2/boot/grub/x86_64-efi/lsefi.mod
/sdc2/boot/grub/x86_64-efi/morse.mod
/sdc2/boot/grub/x86_64-efi/progress.mod
/sdc2/boot/grub/x86_64-efi/boottime.mod
/sdc2/boot/grub/x86_64-efi/setjmp_test.mod
/sdc2/boot/grub/x86_64-efi/efi_gop.mod
/sdc2/boot/grub/x86_64-efi/strtoull_test.mod
/sdc2/boot/grub/x86_64-efi/luks.mod
/sdc2/boot/grub/x86_64-efi/extcmd.mod
/sdc2/boot/grub/x86_64-efi/png.mod
/sdc2/boot/grub/x86_64-efi/gfxmenu.mod
/sdc2/boot/grub/x86_64-efi/shift_test.mod
/sdc2/boot/grub/x86_64-efi/gcry_whirlpool.mod
/sdc2/boot/grub/x86_64-efi/fshelp.mod
/sdc2/boot/grub/x86_64-efi/gcry_crc.mod
/sdc2/boot/grub/x86_64-efi/lzopio.mod
/sdc2/boot/grub/x86_64-efi/tr.mod
/sdc2/boot/grub/x86_64-efi/smbios.mod
/sdc2/boot/grub/x86_64-efi/testload.mod
/sdc2/boot/grub/x86_64-efi/search_label.mod
/sdc2/boot/grub/x86_64-efi/relocator.mod
/sdc2/boot/grub/x86_64-efi/fat.mod
/sdc2/boot/grub/x86_64-efi/functional_test.mod
/sdc2/boot/grub/x86_64-efi/crc64.mod
/sdc2/boot/grub/x86_64-efi/newc.mod
/sdc2/boot/grub/x86_64-efi/efi_uga.mod
/sdc2/boot/grub/x86_64-efi/videotest_checksum.mod
/sdc2/boot/grub/x86_64-efi/ntfs.mod
/sdc2/boot/grub/x86_64-efi/adler32.mod
/sdc2/boot/grub/x86_64-efi/keystatus.mod
/sdc2/boot/grub/x86_64-efi/help.mod
/sdc2/boot/grub/x86_64-efi/testspeed.mod
/sdc2/boot/grub/x86_64-efi/gcry_twofish.mod
/sdc2/boot/grub/x86_64-efi/bufio.mod
/sdc2/boot/grub/x86_64-efi/syslinuxcfg.mod
/sdc2/boot/grub/x86_64-efi/pcidump.mod
/sdc2/boot/grub/x86_64-efi/password.mod
/sdc2/boot/grub/x86_64-efi/bitmap_scale.mod
/sdc2/boot/grub/x86_64-efi/minix_be.mod
/sdc2/boot/grub/x86_64-efi/command.lst
/sdc2/boot/grub/x86_64-efi/random.mod
/sdc2/boot/grub/x86_64-efi/priority_queue.mod
/sdc2/boot/grub/x86_64-efi/div.mod
/sdc2/boot/grub/x86_64-efi/chain.mod
/sdc2/boot/grub/x86_64-efi/linux16.mod
/sdc2/boot/grub/x86_64-efi/fs.lst
/sdc2/boot/grub/x86_64-efi/xzio.mod
/sdc2/boot/grub/x86_64-efi/aout.mod
/sdc2/boot/grub/x86_64-efi/pbkdf2_test.mod
/sdc2/boot/grub/x86_64-efi/gcry_sha256.mod
/sdc2/boot/grub/x86_64-efi/loopback.mod
/sdc2/boot/grub/x86_64-efi/udf.mod
/sdc2/boot/grub/x86_64-efi/jfs.mod
/sdc2/boot/grub/x86_64-efi/video_cirrus.mod
/sdc2/boot/grub/x86_64-efi/loadbios.mod
/sdc2/boot/grub/x86_64-efi/ata.mod
/sdc2/boot/grub/x86_64-efi/lsacpi.mod
/sdc2/boot/grub/x86_64-efi/spkmodem.mod
/sdc2/boot/grub/x86_64-efi/mdraid1x.mod
/sdc2/boot/grub/x86_64-efi/diskfilter.mod
/sdc2/boot/grub/x86_64-efi/pata.mod
/sdc2/boot/grub/x86_64-efi/hello.mod
/sdc2/boot/grub/x86_64-efi/signature_test.mod
/sdc2/boot/grub/x86_64-efi/zfs.mod
/sdc2/boot/grub/x86_64-efi/gcry_rfc2268.mod
/sdc2/boot/grub/x86_64-efi/cbls.mod
/sdc2/boot/grub/x86_64-efi/normal.mod
/sdc2/boot/grub/x86_64-efi/part_acorn.mod
/sdc2/boot/grub/x86_64-efi/net.mod
/sdc2/boot/grub/x86_64-efi/video.mod
/sdc2/boot/grub/x86_64-efi/affs.mod
/sdc2/boot/grub/x86_64-efi/play.mod
/sdc2/boot/grub/x86_64-efi/efinet.mod
/sdc2/boot/grub/x86_64-efi/gcry_md4.mod
/sdc2/boot/grub/x86_64-efi/efifwsetup.mod
/sdc2/boot/grub/x86_64-efi/procfs.mod
/sdc2/boot/grub/x86_64-efi/usbserial_pl2303.mod
/sdc2/boot/grub/x86_64-efi/ahci.mod
/sdc2/boot/grub/x86_64-efi/regexp.mod
/sdc2/boot/grub/x86_64-efi/ufs2.mod
/sdc2/boot/grub/x86_64-efi/part_amiga.mod
/sdc2/boot/grub/x86_64-efi/datetime.mod
/sdc2/boot/grub/x86_64-efi/parttool.lst
/sdc2/boot/grub/x86_64-efi/xnu_uuid_test.mod
/sdc2/boot/grub/x86_64-efi/blocklist.mod
/sdc2/boot/grub/x86_64-efi/cpuid.mod
/sdc2/boot/grub/x86_64-efi/exfctest.mod
/sdc2/boot/grub/x86_64-efi/cbtable.mod
/sdc2/boot/grub/x86_64-efi/memrw.mod
/sdc2/boot/grub/x86_64-efi/terminfo.mod
/sdc2/boot/grub/x86_64-efi/ext2.mod
/sdc2/boot/grub/x86_64-efi/pbkdf2.mod
/sdc2/boot/grub/x86_64-efi/pgp.mod
/sdc2/boot/grub/x86_64-efi/exfat.mod
/sdc2/boot/grub/x86_64-efi/mdraid09.mod
/sdc2/boot/grub/x86_64-efi/jpeg.mod
/sdc2/boot/grub/x86_64-efi/ctz_test.mod
/sdc2/boot/grub/x86_64-efi/bitmap.mod
/sdc2/boot/grub/x86_64-efi/tpm.mod
/sdc2/boot/grub/x86_64-efi/part_dfly.mod
/sdc2/boot/grub/x86_64-efi/search_fs_file.mod
/sdc2/boot/grub/x86_64-efi/hashsum.mod
/sdc2/boot/grub/x86_64-efi/afsplitter.mod
/sdc2/boot/grub/x86_64-efi/file.mod
/sdc2/boot/grub/x86_64-efi/lsefisystab.mod
/sdc2/boot/grub/x86_64-efi/div_test.mod
/sdc2/boot/grub/x86_64-efi/reiserfs.mod
/sdc2/boot/grub/x86_64-efi/gcry_des.mod
/sdc2/boot/grub/x86_64-efi/fixvideo.mod
/sdc2/boot/grub/x86_64-efi/mmap.mod
/sdc2/boot/grub/x86_64-efi/mul_test.mod
/sdc2/boot/grub/x86_64-efi/dm_nv.mod
/sdc2/boot/grub/x86_64-efi/tga.mod
/sdc2/boot/grub/x86_64-efi/bswap_test.mod
/sdc2/boot/grub/x86_64-efi/appleldr.mod
/sdc2/boot/grub/x86_64-efi/eval.mod
/sdc2/boot/grub/x86_64-efi/cs5536.mod
/sdc2/boot/grub/x86_64-efi/sleep.mod
/sdc2/boot/grub/x86_64-efi/hfs.mod
/sdc2/boot/grub/x86_64-efi/echo.mod
/sdc2/boot/grub/x86_64-efi/boot.mod
/sdc2/boot/grub/x86_64-efi/zfscrypt.mod
/sdc2/boot/grub/x86_64-efi/legacycfg.mod
/sdc2/boot/grub/x86_64-efi/f2fs.mod
/sdc2/boot/grub/x86_64-efi/parttool.mod
/sdc2/boot/grub/x86_64-efi/minix.mod
/sdc2/boot/grub/x86_64-efi/usb_keyboard.mod
/sdc2/boot/grub/x86_64-efi/configfile.mod
/sdc2/boot/grub/x86_64-efi/ntfscomp.mod
/sdc2/boot/grub/x86_64-efi/gfxterm_background.mod
/sdc2/boot/grub/x86_64-efi/part_plan.mod
/sdc2/boot/grub/x86_64-efi/usbms.mod
/sdc2/boot/grub/x86_64-efi/macbless.mod
/sdc2/boot/grub/x86_64-efi/mpi.mod
/sdc2/boot/grub/x86_64-efi/core.efi
/sdc2/boot/grub/x86_64-efi/ufs1.mod
/sdc2/boot/grub/x86_64-efi/videotest.mod
/sdc2/boot/grub/x86_64-efi/cpio.mod
/sdc2/boot/grub/x86_64-efi/gcry_dsa.mod
/sdc2/boot/grub/x86_64-efi/load.cfg
/sdc2/boot/grub/x86_64-efi/crypto.mod
/sdc2/boot/grub/x86_64-efi/minix3.mod
/sdc2/boot/grub/x86_64-efi/hfspluscomp.mod
/sdc2/boot/grub/x86_64-efi/zfsinfo.mod
/sdc2/boot/grub/x86_64-efi/terminal.lst
/sdc2/boot/grub/x86_64-efi/legacy_password_test.mod
/sdc2/boot/grub/x86_64-efi/linux.mod
/sdc2/boot/grub/x86_64-efi/gcry_md5.mod
/sdc2/boot/grub/x86_64-efi/part_sunpc.mod
/sdc2/boot/grub/x86_64-efi/scsi.mod
/sdc2/boot/grub/x86_64-efi/gcry_seed.mod
/sdc2/boot/grub/x86_64-efi/usb.mod
/sdc2/boot/grub/x86_64-efi/lsefimmap.mod
/sdc2/boot/grub/x86_64-efi/hdparm.mod
/sdc2/boot/grub/x86_64-efi/cmp.mod
/sdc2/boot/grub/x86_64-efi/setpci.mod
/sdc2/boot/grub/x86_64-efi/reboot.mod
/sdc2/boot/grub/x86_64-efi/hfsplus.mod
/sdc2/boot/grub/x86_64-efi/sfs.mod
/sdc2/boot/grub/x86_64-efi/gptsync.mod
/sdc2/boot/grub/x86_64-efi/usbserial_ftdi.mod
/sdc2/boot/grub/x86_64-efi/read.mod
/sdc2/boot/grub/x86_64-efi/gcry_idea.mod
/sdc2/boot/grub/x86_64-efi/modinfo.sh
/sdc2/boot/grub/x86_64-efi/halt.mod
/sdc2/boot/grub/x86_64-efi/part_apple.mod
/sdc2/boot/grub/x86_64-efi/gcry_sha1.mod
/sdc2/boot/grub/x86_64-efi/lvm.mod
/sdc2/boot/grub/x86_64-efi/test_blockarg.mod
/sdc2/boot/grub/x86_64-efi/nilfs2.mod
/sdc2/boot/grub/x86_64-efi/datehook.mod
/sdc2/boot/grub/x86_64-efi/afs.mod
/sdc2/boot/grub/x86_64-efi/disk.mod
/sdc2/boot/grub/x86_64-efi/gcry_arcfour.mod
/sdc2/boot/grub/x86_64-efi/time.mod
/sdc2/boot/grub/x86_64-efi/ufs1_be.mod
/sdc2/boot/grub/x86_64-efi/gcry_cast5.mod
/sdc2/boot/grub/x86_64-efi/setjmp.mod
/sdc2/boot/grub/x86_64-efi/loadenv.mod
/sdc2/boot/grub/x86_64-efi/gfxterm_menu.mod
/sdc2/boot/grub/x86_64-efi/luks2.mod
/sdc2/boot/grub/x86_64-efi/bsd.mod
/sdc2/boot/grub/x86_64-efi/lsmmap.mod
/sdc2/boot/grub/x86_64-efi/zstd.mod
/sdc2/boot/grub/x86_64-efi/search.mod
/sdc2/boot/grub/x86_64-efi/iorw.mod
/sdc2/boot/grub/x86_64-efi/acpi.mod
/sdc2/boot/grub/locale
/sdc2/boot/grub/locale/sv.mo
/sdc2/boot/grub/locale/en@quot.mo
/sdc2/boot/grub/locale/pt.mo
/sdc2/boot/grub/locale/pl.mo
/sdc2/boot/grub/locale/fi.mo
/sdc2/boot/grub/locale/id.mo
/sdc2/boot/grub/locale/ro.mo
/sdc2/boot/grub/locale/vi.mo
/sdc2/boot/grub/locale/hu.mo
/sdc2/boot/grub/locale/da.mo
/sdc2/boot/grub/locale/en@cyrillic.mo
/sdc2/boot/grub/locale/en@piglatin.mo
/sdc2/boot/grub/locale/it.mo
/sdc2/boot/grub/locale/en@hebrew.mo
/sdc2/boot/grub/locale/lg.mo
/sdc2/boot/grub/locale/de_CH.mo
/sdc2/boot/grub/locale/zh_TW.mo
/sdc2/boot/grub/locale/ca.mo
/sdc2/boot/grub/locale/hr.mo
/sdc2/boot/grub/locale/nb.mo
/sdc2/boot/grub/locale/en@greek.mo
/sdc2/boot/grub/locale/ka.mo
/sdc2/boot/grub/locale/ast.mo
/sdc2/boot/grub/locale/sr.mo
/sdc2/boot/grub/locale/pt_BR.mo
/sdc2/boot/grub/locale/lt.mo
/sdc2/boot/grub/locale/sl.mo
/sdc2/boot/grub/locale/tr.mo
/sdc2/boot/grub/locale/ru.mo
/sdc2/boot/grub/locale/uk.mo
/sdc2/boot/grub/locale/de@hebrew.mo
/sdc2/boot/grub/locale/fr.mo
/sdc2/boot/grub/locale/pa.mo
/sdc2/boot/grub/locale/es.mo
/sdc2/boot/grub/locale/eo.mo
/sdc2/boot/grub/locale/nl.mo
/sdc2/boot/grub/locale/ja.mo
/sdc2/boot/grub/locale/en@arabic.mo
/sdc2/boot/grub/locale/zh_CN.mo
/sdc2/boot/grub/locale/ko.mo
/sdc2/boot/grub/locale/de.mo
/sdc2/boot/grub/locale/gl.mo
/sdc2/boot/initramfs-5.18-x86_64.img
/sdc2/boot/initramfs-5.19-x86_64-fallback.img
/sdc2/boot/initramfs-5.15-x86_64-fallback.img
/sdc2/boot/vmlinuz-5.18-x86_64
/sdc2/boot/linux515-x86_64.kver
/sdc2/boot/vmlinuz-5.10-x86_64
/sdc2/boot/efi
/sdc2/boot/vmlinuz-5.15-x86_64
/sdc2/boot/initramfs-5.10-x86_64.img
/sdc2/boot/vmlinuz-5.19-x86_64
Any help?
That just indicates that you were on unstable and now on stable⌠so:
sudo pacman-mirrors -c all && sudo pacman-mirrors -f5
pamac upgrade --enable-downgrade --force-refresh --no-aur
Then reinstall again:
Also keep sure syslinux is not installed anymore:
Ok after chroot again did this:
# rm -rv /boot/syslinux/
removed '/boot/syslinux/syslinux.cfg'
removed directory '/boot/syslinux/'
I wonder if those files where generated by any of the recent commands posted in this thread? I checked before deletion:
# cd /boot
# ls -lta syslinux/
drwxr-xr-x 2 root root 4096 Dec 1 2020 .
-rw-r--r-- 1 root root 2350 Nov 21 2019 syslinux.cfg
Letâs see now what happens.
After trying to boot from the device this is what happens:
I press F11 to enter boot device selection, then Please select boot device: appears. There appear 2 items for THE SAME Manjaro drive (kind of duplicated):
If I choose manjaro it boots fine to sddm, however if I choose UEFI OS goes to Entering rescue mode... grub rescue> and fails.
So no idea why there are 2 items for the same drive now, but at least it works perfect one of them and can use the OS.
More news. After a some reboots, the boot option âmanjaro (KINGSTON XXXX)â disappeared when pressing F11, and now thereâs only the âUEFI OS (KINGSTON XXXX)â one, which doesnât boot. What can be the cause and how to I fix it? It seems like something wasnât installed properly.
Iâve got a dd backup of that drive from some months ago, which restoring it to another identical drive shows on boot device selection:
UEFI: KINGSTON xxxxxx, Partition 1
It boots perfectly fine, so the system was in a state months before all the updated and grub reinstall happened. Here is more information:
$ uname
Linux manjaro 5.16.9-1-MANJARO #1 SMP PREEMPT 2022 x86_64 GNU/Linux
$ mount
/dev/mapper/luks-xxxxxxxxxxxxxxxxxxxxxxxx on / type ext4 (rw,noatime)
/dev/sdc1 on /boot/efi type vfat (rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro)
$ find /boot/
/boot/
/boot/syslinux
/boot/memtest86+
/boot/vmlinuz-5.16-x86_64
/boot/initramfs-5.16-x86_64.img
/boot/initramfs-5.16-x86_64-fallback.img
/boot/grub
/boot/grub/fonts
/boot/grub/themes
/boot/grub/grub.cfg
/boot/grub/grubenv
/boot/grub/x86_64-efi/shim_lock.mod
/boot/grub/x86_64-efi/verifiers.mod
/boot/linux516-x86_64.kver
/boot/efi
/boot/efi/EFI
/boot/efi/EFI/Manjaro
/boot/efi/EFI/Manjaro/grubx64.efi
/boot/efi/EFI/boot
/boot/efi/EFI/boot/bootx64.efi
/boot/efi/System Volume Information
/boot/efi/System Volume Information/IndexerVolumeGuid
/boot/efi/System Volume Information/WPSettings.dat
Is possible that I just could delete everything inside /boot/* and /boot/efi/* (without deleting this folder itself) in the not working system, and copy to it files inside /boot/ and /boot/efi/ from this backup device to the current device?
That way it should be displayed properly at boot selection wouldnât it?
