Hello! I’m wanting to switch from KDE to GNOME and I heard that a fresh install is recommended, which I intend to do. However, I am having issues as I am not only unable to move files to my SanDisk Flash Drive but when I tried to fix that with (I think) chmod or chown, I now need that same drive whenever I try to boot into my Manjaro partition as I am dual-booting with Windows 10.
So, what I need help with is being able to move my files onto that flash drive, formatting it again is not an issue, so that I can reinstall Manjaro while keeping my files. I absolutely could backup all my files but I just prefer not, henceforth me requesting the forum’s help.
NAME SIZE OWNER GROUP MODE
/dev/loop0 55.3M root disk brw-rw----
/dev/loop1 55.4M root disk brw-rw----
/dev/loop2 14.5M root disk brw-rw----
/dev/loop3 30.9M root disk brw-rw----
/dev/loop4 30.9M root disk brw-rw----
/dev/sda 931.5G root disk brw-rw----
|-/dev/sda1 100M root disk brw-rw----
|-/dev/sda2 488.8G root disk brw-rw----
|-/dev/sda3 1K root disk brw-rw----
|-/dev/sda4 802M root disk brw-rw----
|-/dev/sda5 31.7G root disk brw-rw----
`-/dev/sda6 410.2G root disk brw-rw----
/dev/sdb 14.9G root disk brw-rw----
`-/dev/sdb1 14.9G root disk brw-rw----
/dev/sr0 1024M root optical brw-rw----
/dev/sdb is my flash drive.
Below is what will happen after a long back screen when I boot into Manjaro from GRUB without the flash drive.
[ TIME] Time out waiting for device /dev/sdb1.
[DEPEND] Dependency failed for /run/media/brandonef/BRANDON'S.
[DEPEND] Dependency failed for Local File Systems.
You're in emergency mode.
Then it gives me commands to use after asking me to put in my password.
So that means the basic scenario is still that ‘root’ owns that usb/partition.
(as shown in the linked threads)
But the broader question is … why does your system depend on it?
I wouldn’t know; I just use Linux since I find it snappier compared to my Windows 10.
Going back to konsole, I found that I can use my up key to find all the inputs I’ve used when I first tried to remedy the issue. Is there any way I can export them so you can take a look?
The second command assumes you ran the first. cat outputs a files contents.
the | and everything after it is sending it to 0x0.st, a pastebin-like service.
The first one simply outputs the command history (which will show you your command history) to a local file of ‘myhistory.txt’.
So, assuming you made the file, then the second command is ‘read this - sending the content to 0x0’.
You could also skip all that and mix the two - history | curl -F 'file=@-' https://0x0.st.
(‘piping’ history directly the the 0x0 share)
I hope that makes it more clear.
(please see the link I left in the previous post)
As no path was provided, it should be right in ‘current directory’ (pwd for print working directory).
By default, if you just opened a terminal, that would usually be your HOME.
The links before weren’t helping and every time I did a google search about “manjaro can’t access flash drive (or usb)” it would be about installing not about permissions and flash drive storage management.
# <file system> <mount point> <type> <options> <dump> <pass>
UUID=9f99869b-17dc-4da5-aaff-a26a1ad672c4 / ext4 noatime 0 1
/dev/sdb1 /run/media/brandonef/BRANDON'S vfat defaults 0 0
Just so I don’t make this mistake, if possible on GNOME, what did I do wrong and how to fix it if you don’t mind telling me? Thanks so much and in advance.
Its nothing super wrong.
You just set the device in fstab … which means the system expects the device to be there.
(also see my warning about not using relative titles like ‘/dev/sda’ as identifiers - they are not reliable)
If I understand correctly, you want to use the drive as both install media and backup. Install lutrisventoy to the drive, copy your ISO and create a directory for your files.
