I noticed that the wallpaper i set on cinnamon is nearly always reset to default, when i use the mint-y theme. I’m on a clean install, several months old. Stable branch, everything updated. The wallpapers are on a removable drive, which is correctly mounted at boot.
Thanks you in advance for the attention.
I used to have a similar problem, if i recall correctly the system was looking upon booting for the wallpaper before mounting my removable drive, hence couldn’t find drive and went default.
The thing that i can’t explain is that with Adapta theme it doesn’t happen, or at least almost never…
That confirms what @Alchemix said: The Adapta theme is probably more complex and takes longer to load so you don’t have the problem there.
Try this: copy your one single perfect wallpaper to /usr/share/pixmaps and set it from there.
If the problem is gone, put all your wallpapers there as that’s here any system-wide pixmaps go according to the FSH…
From /usr/share/pixmaps it works; lately it works most of the time from the external drive too, maybe something changed after the last update. Btw, the issue started to happen after an update, so i think that there is something behind the scenes…
Well, as you keep your curtains closed, we can’t look behind the scene, so if /usr/share/pixmaps works, that’s your solution then…
Kernel: 5.4.114-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=2cdd9729-d081-4f66-a6a6-d810429d0474 rw udev.log_priority=3
sysrq_always_enabled
Desktop: Cinnamon 4.8.6 tk: GTK 3.24.29 vt: 7 dm: LightDM 1.30.0
Type: Desktop Mobo: Micro-Star model: B450M PRO-M2 (MS-7B84) v: 1.0
serial: <filter> UEFI: American Megatrends v: 2.40 date: 12/17/2018
RAM: total: 7.79 GiB used: 1.73 GiB (22.1%)
Info: 8-Core model: AMD Ryzen 7 2700 bits: 64 type: MT MCP arch: Zen+
family: 17 (23) model-id: 8 stepping: 2 microcode: 800820D cache: L2: 4 MiB
bogomips: 102427
Speed: 2566 MHz min/max: 1550/3200 MHz boost: enabled Core speeds (MHz):
1: 2566 2: 2956 3: 1376 4: 1373 5: 1378 6: 1375 7: 1375 8: 1375 9: 1332
10: 1330 11: 1334 12: 1330 13: 1338 14: 1341 15: 1376 16: 1375
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm mca
mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc nopl
npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb
perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36
rdrand rdseed rdtscp rep_good sep sev sha_ni skinit smap smca sme smep ssbd
sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock syscall tce topoext
tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt xgetbv1 xsave
xsavec xsaveerptr xsaveopt xsaves
disabled, RSB filling
Device-1: AMD Mars LE [Radeon HD 8530M / R5 M240] vendor: Sapphire Limited
driver: radeon v: kernel alternate: amdgpu bus-ID: 1f:00.0
chip-ID: 1002:6607 class-ID: 0300
Display: x11 server: X.Org 1.20.11 driver: loaded: ati,radeon
unloaded: modesetting alternate: fbdev,vesa display-ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
OpenGL: renderer: AMD OLAND (DRM 2.50.0 5.4.114-1-MANJARO LLVM 11.1.0)
v: 4.5 Mesa 21.0.3 direct render: Yes
Device-1: AMD Oland/Hainan/Cape Verde/Pitcairn HDMI Audio [Radeon HD 7000
Series]
vendor: Sapphire Limited driver: snd_hda_intel v: kernel bus-ID: 1f:00.1
chip-ID: 1002:aab0 class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 21:00.3 chip-ID: 1022:1457
class-ID: 0403
Sound Server-1: ALSA v: k5.4.114-1-MANJARO running: yes
Sound Server-2: JACK v: 1.9.18 running: no
Sound Server-4: PipeWire v: 0.3.26 running: no
vendor: Micro-Star MSI driver: r8169 v: kernel port: f000 bus-ID: 1b:00.0
IF: enp27s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 1.13 TiB used: 109.02 GiB (9.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WDS240G2G0A-00JH30 size: 223.58 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s rotation: SSD serial: <filter> rev: 0000
scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: Toshiba model: MQ04UBF100
size: 931.51 GiB block-size: physical: 512 B logical: 512 B
rotation: 5400 rpm serial: <filter> scheme: MBR
Optical-1: /dev/sr0 vendor: ATAPI model: iHAS124 F rev: CLDM
dev-links: cdrom
rw: cd-r,cd-rw,dvd-r state: running
ID-1: / raw-size: 22.98 GiB size: 22.49 GiB (97.89%) used: 10.56 GiB (46.9%)
fs: ext4 dev: /dev/sda5 maj-min: 8:5 label: N/A
uuid: 2cdd9729-d081-4f66-a6a6-d810429d0474
ID-2: /boot/efi raw-size: 99 MiB size: 95 MiB (95.96%)
used: 27.7 MiB (29.1%) fs: vfat dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: F27D-3EB2
ID-3: /run/media/stocazz/TOSHIBA EXT raw-size: 931.51 GiB
size: 931.51 GiB (100.00%) used: 98.44 GiB (10.6%) fs: ntfs dev: /dev/sdb1
maj-min: 8:17 label: TOSHIBA EXT uuid: 7C7468E37468A21E
ID-1: /dev/sda1 maj-min: 8:1 size: 499 MiB fs: ntfs label: N/A
uuid: 2070DD5970DD366E
ID-2: /dev/sda3 maj-min: 8:3 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/sda4 maj-min: 8:4 size: 200 GiB fs: ntfs label: N/A
uuid: 0CEE8225EE8206E4
Device-1: 1-6:2 info: Logitech Keyboard K120 type: Keyboard,HID
power: 90mA chip-ID: 046d:c31c class-ID: 0300
Device-2: 1-7:3 info: Logitech Unifying Receiver type: Keyboard,Mouse
driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 98mA chip-ID: 046d:c534 class-ID: 0301
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 speed: 5 Gb/s
Device-1: 4-1:2 info: Toshiba America External USB 3.0 type: Mass Storage
driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s power: 896mA
chip-ID: 0480:0901 class-ID: 0806 serial: <filter>
System Temperatures: cpu: 39.5 C mobo: 0 C gpu: radeon temp: 29.0 C
Processes: 308 Uptime: 42m wakeups: 0 Init: systemd v: 247 tool: systemctl
Compilers: gcc: 10.2.0 Packages: pacman: 1152 lib: 374 flatpak: 0
Shell: Bash v: 5.1.0 running-in: konsole inxi: 3.3.04
It’s not that i keep the curtains closed, here is the basic information, if some other info are needed, just ask…
Ok, added to /etc/fstab… then at reboot cinnamon restarted in fallback mode, but after another reboot everything seems back to normal.
# <file system> <mount point> <type> <options> <dump> <pass>
UUID=F27D-3EB2 /boot/efi vfat umask=0077 0 2
UUID=2cdd9729-d081-4f66-a6a6-d810429d0474 / ext4 defaults,noatime 0 1
tmpfs /tmp tmpfs defaults,noatime,mode=1777 0 0
UUID=7C7468E37468A21E /media/toshiba ntfs auto 0 0
It’s good this way?
What is the difference between /media and /run ? I used to mount on the former on ubuntu, but manjaro always mount on the latter…
Does that mean:
- It works!
- It doesn’t work…
Please be more specific!
The desktop environment works, and the wallpaper i set remains, for now the issue appears to be fixed, i hope for good! Thanks!
I don’t know for media (too lazy to check in Linux filesystem guides) but run is a temporary filesystem for your ongoing session, that will reset at next boot.
It’s good for a once usage, not for a permanent one.
Thanks for the answer. I’ve noticed that the run folder is reset after boot, too. But i thought that it was okay, since cinnamon automatically mounted the drive at every boot and it always worked.
