I have/had a similar issue, but the issue has adapted/changed after trying new kernels so I thought maybe I should make a new post? If that was not the right option, I apologize.
This issue persists despite trying different kernels. My old issue was my wallpaper always being black at start – now the issue relates to the wallpaper always resetting to the default image.
Basically, plasmashell refuses to save my wallpaper settings, whatever I make them be (slideshow, a different manjaro image in the same folder as the default image, etc.). Restarting plasmashell just resets the wallpaper to the default, so does logging out and back in, or restarting my computer. Any other changes seem to be saved fine, it is simply the wallpaper settings that never are.
I have tried replacing plasmashell, quitting and restarting, renaming the plasma-orgwhatever file in .config to force a replacement that way, tried different kernels etc. . But the problem persists.
inxi --full --admin --verbosity=7 --filter --no-host
Kernel: 5.4.60-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=87bc3162-9841-4275-9453-3640070c8bb5 rw quiet apparmor=1
Desktop: KDE Plasma 5.19.4 tk: Qt 5.15.0 info: latte-dock wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Laptop System: Dell product: XPS 13 9300 v: N/A serial: <filter> Chassis:
type: 10 serial: <filter>
Mobo: Dell model: 077Y9N v: A00 serial: <filter> UEFI: Dell v: 1.1.0
date: 07/07/2020
ID-1: BAT0 charge: 18.5 Wh condition: 51.6/51.0 Wh (101%) volts: 7.5/7.6
model: SMP DELL WN0N005 type: Li-poly serial: <filter> status: Discharging
RAM: total: 15.23 GiB used: 2.02 GiB (13.3%)
Topology: Quad Core model: Intel Core i7-1065G7 bits: 64 type: MT MCP
arch: Ice Lake family: 6 model-id: 7E (126) stepping: 5 microcode: 78
L2 cache: 8192 KiB bogomips: 23968
Speed: 1280 MHz min/max: 400/3900 MHz Core speeds (MHz): 1: 1163 2: 1129 3: 1158
4: 1163 5: 1161 6: 1088 7: 1196 8: 1117
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities
arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2 avx512_vnni avx512_vpopcntdq
avx512bw avx512cd avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts
clflush clflushopt cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64
dtherm dts epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase
fxsr gfni ht hwp hwp_act_window hwp_epp hwp_pkg_req ibpb ibrs ibrs_enhanced ida
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe msr
mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge
pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdtscp rep_good sdbg sep
sha_ni smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
tpr_shadow tsc tsc_adjust tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi
vpclmulqdq vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Device-1: Intel Iris Plus Graphics G7 vendor: Dell driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:8a52
Device-2: Realtek Integrated_Webcam_HD type: USB driver: uvcvideo bus ID: 3-9:3
chip ID: 0bda:5511 serial: <filter>
Display: x11 server: X.Org 1.20.8 compositor: kwin_x11 driver: intel
unloaded: modesetting alternate: fbdev,vesa display ID: :0 screens: 1
Screen-1: 0 s-res: 1680x1050 s-dpi: 96 s-size: 443x277mm (17.4x10.9")
s-diag: 522mm (20.6")
Monitor-1: eDP1 res: 1680x1050 hz: 60 dpi: 147 size: 290x180mm (11.4x7.1")
diag: 341mm (13.4")
OpenGL: renderer: Mesa Intel Iris Plus Graphics (ICL GT2) v: 4.6 Mesa 20.1.6
direct render: Yes
Device-1: Intel Smart Sound Audio vendor: Dell driver: snd_hda_intel v: kernel
alternate: snd_sof_pci bus ID: 00:1f.3 chip ID: 8086:34c8
Sound Server: ALSA v: k5.4.60-2-MANJARO
Device-1: Intel Killer Wi-Fi 6 AX1650i 160MHz Wireless Network Adapter
vendor: Bigfoot Networks driver: iwlwifi v: kernel port: 4000 bus ID: 00:14.3
chip ID: 8086:34f0
IP v4: <filter> type: dynamic noprefixroute scope: global broadcast: <filter>
Local Storage: total: 953.87 GiB used: 49.09 GiB (5.1%)
ID-1: /dev/nvme0n1 model: SSDPEMKF010T8 NVMe INTEL 1024GB size: 953.87 GiB
block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
serial: <filter> rev: 7003 scheme: GPT
ID-1: / raw size: 390.62 GiB size: 383.49 GiB (98.17%) used: 49.01 GiB (12.8%)
fs: ext4 dev: /dev/nvme0n1p7 label: N/A uuid: 87bc3162-9841-4275-9453-3640070c8bb5
ID-2: /boot/efi raw size: 190.0 MiB size: 186.0 MiB (97.89%)
used: 76.4 MiB (41.1%) fs: vfat dev: /dev/nvme0n1p1 label: ESP uuid: 30DF-6832
ID-1: /dev/nvme0n1p2 size: 128.0 MiB fs: <superuser/root required> label: N/A
uuid: N/A
ID-2: /dev/nvme0n1p3 size: 547.55 GiB fs: bitlocker label: N/A uuid: N/A
ID-3: /dev/nvme0n1p4 size: 990.0 MiB fs: ntfs label: WINRETOOLS
uuid: 3830AA4330AA07C8
ID-4: /dev/nvme0n1p5 size: 13.11 GiB fs: ntfs label: Image uuid: F812AA9A12AA5D7E
ID-5: /dev/nvme0n1p6 size: 1.30 GiB fs: ntfs label: DELLSUPPORT
uuid: BE181DA1181D59AB
Hub: 1-0:1 info: Full speed (or root) Hub ports: 1 rev: 2.0 speed: 480 Mb/s
chip ID: 1d6b:0002
Hub: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
chip ID: 1d6b:0003
Hub: 3-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0 speed: 480 Mb/s
chip ID: 1d6b:0002
Device-1: 3-5:2 info: Shenzhen Goodix FingerPrint type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s chip ID: 27c6:533c
Device-2: 3-9:3 info: Realtek Integrated_Webcam_HD type: Video driver: uvcvideo
interfaces: 5 rev: 2.0 speed: 480 Mb/s chip ID: 0bda:5511 serial: <filter>
Device-3: 3-10:4 info: Intel type: Bluetooth driver: btusb interfaces: 2 rev: 2.0
speed: 12 Mb/s chip ID: 8087:0026
Hub: 4-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.1 speed: 10 Gb/s
chip ID: 1d6b:0003
System Temperatures: cpu: 41.0 C mobo: N/A
Processes: 237 Uptime: 1h 21m Init: systemd v: 246 Compilers: gcc: 10.2.0
Packages: 1477 pacman: 1461 lib: 398 flatpak: 6 snap: 10 Shell: Bash v: 5.0.18
running in: konsole inxi: 3.1.05
Thank you, and I am happy to delete this if it is deemed better to just stick to my older and still open post on the similar topic before.
